hlist: drop the node parameter from iterators
Author: Sasha Levin <sasha.levin@oracle.com>
I'm not sure why, but the hlist for each entry iterators were conceived
        list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
        hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
 - Fix up the actual hlist iterators in linux/list.h
 - Fix up the declaration of other iterators based on the hlist ones.
 - A very small amount of places were using the 'node' parameter, this
 was modified to use 'obj->member' instead.
 - Coccinelle didn't handle the hlist_for_each_entry_safe iterator
 properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
    <+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin
Acked-by: Paul E. McKenney
Signed-off-by: Sasha Levin
Cc: Wu Fengguang
Cc: Marcelo Tosatti
Cc: Gleb Natapov
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 arch/arm/kernel/kprobes.c                          |  6 +-
 arch/ia64/kernel/kprobes.c                         |  8 +--
 arch/mips/kernel/kprobes.c                         |  6 +-
 arch/powerpc/kernel/kprobes.c                      |  6 +-
 arch/powerpc/kvm/book3s_mmu_hpte.c                 | 18 ++---
 arch/s390/kernel/kprobes.c                         |  8 +--
 arch/s390/pci/pci_msi.c                            |  3 +-
 arch/sh/kernel/kprobes.c                           |  6 +-
 arch/sparc/kernel/kprobes.c                        |  6 +-
 arch/sparc/kernel/ldc.c                            |  3 +-
 arch/x86/kernel/kprobes/core.c                     |  8 +--
 arch/x86/kvm/mmu.c                                 | 26 +++----
 block/blk-cgroup.c                                 |  6 +-
 block/blk-ioc.c                                    |  3 +-
 block/bsg.c                                        |  3 +-
 block/cfq-iosched.c                                |  3 +-
 block/elevator.c                                   |  4 +-
 crypto/algapi.c                                    |  6 +-
 drivers/atm/atmtcp.c                               |  6 +-
 drivers/atm/eni.c                                  |  3 +-
 drivers/atm/he.c                                   |  3 +-
 drivers/atm/solos-pci.c                            |  3 +-
 drivers/clk/clk.c                                  | 59 ++++++----------
 drivers/gpu/drm/drm_hashtab.c                      | 19 +++--
 drivers/infiniband/core/cma.c                      |  3 +-
 drivers/infiniband/core/fmr_pool.c                 |  3 +-
 drivers/isdn/mISDN/socket.c                        |  3 +-
 drivers/isdn/mISDN/stack.c                         |  3 +-
 drivers/md/dm-bio-prison.c                         |  3 +-
 drivers/md/dm-bufio.c                              |  3 +-
 drivers/md/dm-snap.c                               |  3 +-
 .../md/persistent-data/dm-transaction-manager.c    |  7 +-
 drivers/md/raid5.c                                 |  3 +-
 drivers/misc/sgi-gru/grutlbpurge.c                 |  3 +-
 drivers/misc/vmw_vmci/vmci_doorbell.c              |  7 +-
 drivers/misc/vmw_vmci/vmci_resource.c              |  6 +-
 drivers/net/ethernet/intel/ixgbe/ixgbe_ethtool.c   | 18 ++---
 drivers/net/ethernet/intel/ixgbe/ixgbe_main.c      |  8 +--
 drivers/net/ethernet/mellanox/mlx4/en_netdev.c     | 17 +++--
 drivers/net/ethernet/mellanox/mlx4/en_rx.c         |  4 +-
 drivers/net/ethernet/qlogic/qlcnic/qlcnic_hw.c     | 10 +--
 drivers/net/ethernet/qlogic/qlcnic/qlcnic_io.c     | 10 +--
 drivers/net/ethernet/sun/sunvnet.c                 |  3 +-
 drivers/net/macvlan.c                              |  6 +-
 drivers/net/tun.c                                  | 15 ++--
 drivers/net/vxlan.c                                | 12 ++--
 drivers/net/wireless/zd1201.c                      |  7 +-
 drivers/pci/pci.c                                  | 12 ++--
 drivers/staging/android/binder.c                   | 19 ++---
 drivers/target/tcm_fc/tfc_sess.c                   | 12 ++--
 fs/affs/amigaffs.c                                 |  3 +-
 fs/aio.c                                           |  3 +-
 fs/cifs/inode.c                                    |  3 +-
 fs/dcache.c                                        |  9 +--
 fs/dlm/lowcomms.c                                  | 11 ++-
 fs/ecryptfs/messaging.c                            |  6 +-
 fs/exportfs/expfs.c                                |  3 +-
 fs/fat/inode.c                                     |  3 +-
 fs/fat/nfs.c                                       |  3 +-
 fs/fscache/cookie.c                                | 11 ++-
 fs/inode.c                                         | 19 ++---
 fs/lockd/host.c                                    | 29 ++++----
 fs/lockd/svcsubs.c                                 |  7 +-
 fs/nfs/pnfs_dev.c                                  |  9 +--
 fs/nfsd/nfscache.c                                 |  3 +-
 fs/notify/fsnotify.c                               |  3 +-
 fs/notify/inode_mark.c                             | 19 +++--
 fs/notify/vfsmount_mark.c                          | 19 +++--
 fs/ocfs2/dcache.c                                  |  3 +-
 fs/ocfs2/dlm/dlmrecovery.c                         |  6 +-
 fs/super.c                                         |  6 +-
 fs/sysfs/bin.c                                     |  3 +-
 fs/xfs/xfs_log_recover.c                           |  3 +-
 include/linux/hashtable.h                          | 40 +++++------
 include/linux/if_team.h                            |  6 +-
 include/linux/list.h                               | 49 ++++++-------
 include/linux/pid.h                                |  3 +-
 include/linux/rculist.h                            | 56 +++++++--------
 include/net/ax25.h                                 |  8 +--
 include/net/inet_hashtables.h                      |  4 +-
 include/net/inet_timewait_sock.h                   |  8 +--
 include/net/netrom.h                               | 16 ++---
 include/net/sch_generic.h                          |  3 +-
 include/net/sctp/sctp.h                            |  4 +-
 include/net/sock.h                                 | 21 +++---
 kernel/cgroup.c                                    | 12 ++--
 kernel/events/core.c                               |  6 +-
 kernel/kprobes.c                                   | 35 ++++-----
 kernel/pid.c                                       |  3 +-
 kernel/sched/core.c                                |  6 +-
 kernel/smpboot.c                                   |  2 +-
 kernel/trace/ftrace.c                              | 24 +++----
 kernel/trace/trace_output.c                        |  3 +-
 kernel/tracepoint.c                                |  6 +-
 kernel/user-return-notifier.c                      |  4 +-
 kernel/user.c                                      |  3 +-
 kernel/workqueue.c                                 | 13 ++--
 lib/debugobjects.c                                 | 21 +++---
 lib/lru_cache.c                                    |  3 +-
 mm/huge_memory.c                                   |  3 +-
 mm/kmemleak.c                                      |  9 ++-
 mm/ksm.c                                           | 15 ++--
 mm/mmu_notifier.c                                  | 18 ++---
 net/9p/error.c                                     |  4 +-
 net/9p/trans_virtio.c                              |  2 +-
 net/appletalk/ddp.c                                |  9 +--
 net/atm/common.c                                   |  7 +-
 net/atm/lec.c                                      | 66 ++++++++---------
 net/atm/signaling.c                                |  3 +-
 net/ax25/af_ax25.c                                 | 15 ++--
 net/ax25/ax25_ds_subr.c                            |  6 +-
 net/ax25/ax25_ds_timer.c                           |  3 +-
 net/ax25/ax25_iface.c                              |  3 +-
 net/ax25/ax25_uid.c                                | 11 ++-
 net/batman-adv/bat_iv_ogm.c                        | 12 ++--
 net/batman-adv/bridge_loop_avoidance.c             | 39 ++++------
 net/batman-adv/distributed-arp-table.c             | 15 ++--
 net/batman-adv/gateway_client.c                    | 13 ++--
 net/batman-adv/main.c                              |  6 +-
 net/batman-adv/originator.c                        | 31 ++++----
 net/batman-adv/originator.h                        |  3 +-
 net/batman-adv/routing.c                           |  6 +-
 net/batman-adv/send.c                              |  6 +-
 net/batman-adv/translation-table.c                 | 82 +++++++++-------------
 net/batman-adv/vis.c                               | 38 ++++------
 net/bluetooth/hci_sock.c                           | 15 ++--
 net/bluetooth/rfcomm/sock.c                        | 13 ++--
 net/bluetooth/sco.c                                | 14 ++--
 net/bridge/br_fdb.c                                | 23 +++---
 net/bridge/br_mdb.c                                |  6 +-
 net/bridge/br_multicast.c                          | 25 +++----
 net/can/af_can.c                                   | 18 +++--
 net/can/gw.c                                       | 15 ++--
 net/can/proc.c                                     |  3 +-
 net/core/dev.c                                     | 12 ++--
 net/core/flow.c                                    | 11 ++-
 net/core/net-procfs.c                              |  3 +-
 net/core/rtnetlink.c                               |  3 +-
 net/decnet/af_decnet.c                             |  9 +--
 net/decnet/dn_table.c                              | 13 ++--
 net/ieee802154/dgram.c                             |  3 +-
 net/ieee802154/raw.c                               |  3 +-
 net/ipv4/devinet.c                                 | 10 +--
 net/ipv4/fib_frontend.c                            | 15 ++--
 net/ipv4/fib_semantics.c                           | 23 +++---
 net/ipv4/fib_trie.c                                | 33 ++++-----
 net/ipv4/inet_connection_sock.c                    | 10 ++-
 net/ipv4/inet_fragment.c                           | 10 ++-
 net/ipv4/inet_hashtables.c                         |  8 +--
 net/ipv4/inet_timewait_sock.c                      |  7 +-
 net/ipv4/raw.c                                     |  8 +--
 net/ipv4/tcp_ipv4.c                                |  7 +-
 net/ipv6/addrconf.c                                | 32 +++------
 net/ipv6/addrlabel.c                               | 18 +++--
 net/ipv6/inet6_connection_sock.c                   |  5 +-
 net/ipv6/ip6_fib.c                                 | 12 ++--
 net/ipv6/raw.c                                     |  3 +-
 net/ipv6/xfrm6_tunnel.c                            | 10 ++-
 net/ipx/af_ipx.c                                   | 16 ++---
 net/ipx/ipx_proc.c                                 |  5 +-
 net/iucv/af_iucv.c                                 | 21 ++----
 net/key/af_key.c                                   |  3 +-
 net/l2tp/l2tp_core.c                               | 12 ++--
 net/l2tp/l2tp_ip.c                                 |  3 +-
 net/l2tp/l2tp_ip6.c                                |  3 +-
 net/llc/llc_sap.c                                  |  3 +-
 net/mac80211/mesh_pathtbl.c                        | 45 +++++-------
 net/netfilter/ipvs/ip_vs_conn.c                    | 26 +++----
 net/netfilter/nf_conntrack_expect.c                | 17 ++---
 net/netfilter/nf_conntrack_helper.c                | 13 ++--
 net/netfilter/nf_conntrack_netlink.c               |  9 ++-
 net/netfilter/nf_conntrack_sip.c                   |  8 +--
 net/netfilter/nf_nat_core.c                        |  3 +-
 net/netfilter/nfnetlink_cthelper.c                 | 17 ++---
 net/netfilter/nfnetlink_log.c                      |  7 +-
 net/netfilter/nfnetlink_queue_core.c               | 10 ++-
 net/netfilter/xt_RATEEST.c                         |  3 +-
 net/netfilter/xt_connlimit.c                       |  8 +--
 net/netfilter/xt_hashlimit.c                       | 16 ++---
 net/netlink/af_netlink.c                           | 30 +++-----
 net/netrom/af_netrom.c                             | 12 ++--
 net/netrom/nr_route.c                              | 30 ++++----
 net/nfc/llcp/llcp.c                                | 16 ++---
 net/openvswitch/datapath.c                         | 10 ++-
 net/openvswitch/flow.c                             | 13 ++--
 net/openvswitch/vport.c                            |  3 +-
 net/packet/af_packet.c                             |  3 +-
 net/packet/diag.c                                  |  3 +-
 net/phonet/pep.c                                   |  3 +-
 net/phonet/socket.c                                |  9 +--
 net/rds/bind.c                                     |  3 +-
 net/rds/connection.c                               |  9 +--
 net/rose/af_rose.c                                 | 14 ++--
 net/sched/sch_api.c                                |  4 +-
 net/sched/sch_cbq.c                                | 18 ++---
 net/sched/sch_drr.c                                | 10 ++-
 net/sched/sch_hfsc.c                               | 15 ++--
 net/sched/sch_htb.c                                | 12 ++--
 net/sched/sch_qfq.c                                | 16 ++---
 net/sctp/endpointola.c                             |  3 +-
 net/sctp/input.c                                   |  6 +-
 net/sctp/proc.c                                    |  9 +--
 net/sctp/socket.c                                  |  9 ++-
 net/sunrpc/auth.c                                  |  5 +-
 net/sunrpc/cache.c                                 |  4 +-
 net/sunrpc/svcauth.c                               |  3 +-
 net/tipc/name_table.c                              |  8 +--
 net/tipc/node.c                                    |  3 +-
 net/unix/af_unix.c                                 |  6 +-
 net/unix/diag.c                                    |  7 +-
 net/x25/af_x25.c                                   | 12 ++--
 net/xfrm/xfrm_policy.c                             | 47 ++++++-------
 net/xfrm/xfrm_state.c                              | 42 +++++------
 security/integrity/ima/ima_queue.c                 |  3 +-
 security/selinux/avc.c                             | 19 ++---
 tools/perf/util/evlist.c                           |  3 +-
 virt/kvm/eventfd.c                                 |  3 +-
 virt/kvm/irq_comm.c                                | 18 ++---
 218 files changed, 987 insertions(+), 1494 deletions(-)
diff --git a/arch/arm/kernel/kprobes.c b/arch/arm/kernel/kprobes.c
index 4dd41fc..170e9f3 100644
--- a/arch/arm/kernel/kprobes.c
+++ b/arch/arm/kernel/kprobes.c
@@ -395,7 +395,7 @@ static __used __kprobes void *trampoline_handler(struct pt_regs *regs)
 	struct kretprobe_instance *ri = NULL;
 	struct hlist_head *head, empty_rp;
-	struct hlist_node *node, *tmp;
+	struct hlist_node *tmp;
 	unsigned long flags, orig_ret_address = 0;
 	unsigned long trampoline_address = (unsigned long)&kretprobe_trampoline;
@@ -415,7 +415,7 @@ static __used __kprobes void *trampoline_handler(struct pt_regs *regs)
 	 *       real return address, and all the rest will point to
 	 *       kretprobe_trampoline
-	hlist_for_each_entry_safe(ri, node, tmp, head, hlist) {
+	hlist_for_each_entry_safe(ri, tmp, head, hlist) {
 		if (ri->task != current)
 			/* another task is sharing our hash bucket */
 			continue;
@@ -442,7 +442,7 @@ static __used __kprobes void *trampoline_handler(struct pt_regs *regs)
 	kretprobe_assert(ri, orig_ret_address, trampoline_address);
 	kretprobe_hash_unlock(current, &flags);
-	hlist_for_each_entry_safe(ri, node, tmp, &empty_rp, hlist) {
+	hlist_for_each_entry_safe(ri, tmp, &empty_rp, hlist) {
 		hlist_del(&ri->hlist);
 		kfree(ri);
diff --git a/arch/ia64/kernel/kprobes.c b/arch/ia64/kernel/kprobes.c
index 7026b29..f8280a7 100644
--- a/arch/ia64/kernel/kprobes.c
+++ b/arch/ia64/kernel/kprobes.c
@@ -423,7 +423,7 @@ int __kprobes trampoline_probe_handler(struct kprobe *p, struct pt_regs *regs)
 		((struct fnptr *)kretprobe_trampoline)->ip;
@@ -444,7 +444,7 @@ int __kprobes trampoline_probe_handler(struct kprobe *p, struct pt_regs *regs)
 			continue;
@@ -461,7 +461,7 @@ int __kprobes trampoline_probe_handler(struct kprobe *p, struct pt_regs *regs)
 	regs->cr_iip = orig_ret_address;
 			continue;
@@ -487,7 +487,7 @@ int __kprobes trampoline_probe_handler(struct kprobe *p, struct pt_regs *regs)
 	preempt_enable_no_resched();
 		kfree(ri);
diff --git a/arch/mips/kernel/kprobes.c b/arch/mips/kernel/kprobes.c
index 158467d..ce3f080 100644
--- a/arch/mips/kernel/kprobes.c
+++ b/arch/mips/kernel/kprobes.c
@@ -598,7 +598,7 @@ static int __kprobes trampoline_probe_handler(struct kprobe *p,
 	unsigned long trampoline_address = (unsigned long)kretprobe_trampoline;
@@ -618,7 +618,7 @@ static int __kprobes trampoline_probe_handler(struct kprobe *p,
 			continue;
@@ -645,7 +645,7 @@ static int __kprobes trampoline_probe_handler(struct kprobe *p,
 		kfree(ri);
diff --git a/arch/powerpc/kernel/kprobes.c b/arch/powerpc/kernel/kprobes.c
index e88c643..11f5b03 100644
--- a/arch/powerpc/kernel/kprobes.c
+++ b/arch/powerpc/kernel/kprobes.c
@@ -310,7 +310,7 @@ static int __kprobes trampoline_probe_handler(struct kprobe *p,
 	unsigned long trampoline_address =(unsigned long)&kretprobe_trampoline;
@@ -330,7 +330,7 @@ static int __kprobes trampoline_probe_handler(struct kprobe *p,
 			continue;
@@ -357,7 +357,7 @@ static int __kprobes trampoline_probe_handler(struct kprobe *p,
 		kfree(ri);
diff --git a/arch/powerpc/kvm/book3s_mmu_hpte.c b/arch/powerpc/kvm/book3s_mmu_hpte.c
index 2c86b0d..da8b13c 100644
--- a/arch/powerpc/kvm/book3s_mmu_hpte.c
+++ b/arch/powerpc/kvm/book3s_mmu_hpte.c
@@ -124,7 +124,6 @@ static void kvmppc_mmu_pte_flush_all(struct kvm_vcpu *vcpu)
 	struct kvmppc_vcpu_book3s *vcpu3s = to_book3s(vcpu);
 	struct hpte_cache *pte;
-	struct hlist_node *node;
 	int i;
 	rcu_read_lock();
@@ -132,7 +131,7 @@ static void kvmppc_mmu_pte_flush_all(struct kvm_vcpu *vcpu)
 	for (i = 0; i < HPTEG_HASH_NUM_VPTE_LONG; i++) {
 		struct hlist_head *list = &vcpu3s->hpte_hash_vpte_long[i];
-		hlist_for_each_entry_rcu(pte, node, list, list_vpte_long)
+		hlist_for_each_entry_rcu(pte, list, list_vpte_long)
 			invalidate_pte(vcpu, pte);
@@ -143,7 +142,6 @@ static void kvmppc_mmu_pte_flush_page(struct kvm_vcpu *vcpu, ulong guest_ea)
 	struct hlist_head *list;
 	/* Find the list of entries in the map */
@@ -152,7 +150,7 @@ static void kvmppc_mmu_pte_flush_page(struct kvm_vcpu *vcpu, ulong guest_ea)
 	rcu_read_lock();
 	/* Check the list for matching entries and invalidate */
-	hlist_for_each_entry_rcu(pte, node, list, list_pte)
+	hlist_for_each_entry_rcu(pte, list, list_pte)
 		if ((pte->pte.eaddr & ~0xfffUL) == guest_ea)
@@ -163,7 +161,6 @@ static void kvmppc_mmu_pte_flush_long(struct kvm_vcpu *vcpu, ulong guest_ea)
@@ -173,7 +170,7 @@ static void kvmppc_mmu_pte_flush_long(struct kvm_vcpu *vcpu, ulong guest_ea)
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(pte, node, list, list_pte_long)
+	hlist_for_each_entry_rcu(pte, list, list_pte_long)
 		if ((pte->pte.eaddr & 0x0ffff000UL) == guest_ea)
@@ -207,7 +204,6 @@ static void kvmppc_mmu_pte_vflush_short(struct kvm_vcpu *vcpu, u64 guest_vp)
 	u64 vp_mask = 0xfffffffffULL;
@@ -216,7 +212,7 @@ static void kvmppc_mmu_pte_vflush_short(struct kvm_vcpu *vcpu, u64 guest_vp)
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(pte, node, list, list_vpte)
+	hlist_for_each_entry_rcu(pte, list, list_vpte)
 		if ((pte->pte.vpage & vp_mask) == guest_vp)
@@ -228,7 +224,6 @@ static void kvmppc_mmu_pte_vflush_long(struct kvm_vcpu *vcpu, u64 guest_vp)
 	u64 vp_mask = 0xffffff000ULL;
@@ -238,7 +233,7 @@ static void kvmppc_mmu_pte_vflush_long(struct kvm_vcpu *vcpu, u64 guest_vp)
 	rcu_read_lock();
@@ -266,7 +261,6 @@ void kvmppc_mmu_pte_vflush(struct kvm_vcpu *vcpu, u64 guest_vp, u64 vp_mask)
 void kvmppc_mmu_pte_pflush(struct kvm_vcpu *vcpu, ulong pa_start, ulong pa_end)
 	int i;
@@ -277,7 +271,7 @@ void kvmppc_mmu_pte_pflush(struct kvm_vcpu *vcpu, ulong pa_start, ulong pa_end)
 			if ((pte->pte.raddr >= pa_start) &&
 			    (pte->pte.raddr < pa_end))
diff --git a/arch/s390/kernel/kprobes.c b/arch/s390/kernel/kprobes.c
index d1c7214..3388b2b 100644
--- a/arch/s390/kernel/kprobes.c
+++ b/arch/s390/kernel/kprobes.c
@@ -354,7 +354,7 @@ static int __kprobes trampoline_probe_handler(struct kprobe *p,
 	struct kretprobe_instance *ri;
 	unsigned long flags, orig_ret_address;
 	unsigned long trampoline_address;
 	kprobe_opcode_t *correct_ret_addr;
@@ -379,7 +379,7 @@ static int __kprobes trampoline_probe_handler(struct kprobe *p,
 	correct_ret_addr = NULL;
 	trampoline_address = (unsigned long) &kretprobe_trampoline;
 			continue;
@@ -398,7 +398,7 @@ static int __kprobes trampoline_probe_handler(struct kprobe *p,
 	correct_ret_addr = ri->ret_addr;
 			continue;
@@ -427,7 +427,7 @@ static int __kprobes trampoline_probe_handler(struct kprobe *p,
 		kfree(ri);
diff --git a/arch/s390/pci/pci_msi.c b/arch/s390/pci/pci_msi.c
index 90fd348..0297931 100644
--- a/arch/s390/pci/pci_msi.c
+++ b/arch/s390/pci/pci_msi.c
@@ -25,10 +25,9 @@ static DEFINE_SPINLOCK(msi_map_lock);
 struct msi_desc *__irq_get_msi_desc(unsigned int irq)
-	struct hlist_node *entry;
 	struct msi_map *map;
-	hlist_for_each_entry_rcu(map, entry,
+	hlist_for_each_entry_rcu(map,
 			&msi_hash[msi_hashfn(irq)], msi_chain)
 		if (map->irq == irq)
 			return map->msi;
diff --git a/arch/sh/kernel/kprobes.c b/arch/sh/kernel/kprobes.c
index 1208b09..42b46e6 100644
--- a/arch/sh/kernel/kprobes.c
+++ b/arch/sh/kernel/kprobes.c
@@ -310,7 +310,7 @@ int __kprobes trampoline_probe_handler(struct kprobe *p, struct pt_regs *regs)
@@ -330,7 +330,7 @@ int __kprobes trampoline_probe_handler(struct kprobe *p, struct pt_regs *regs)
 			continue;
@@ -360,7 +360,7 @@ int __kprobes trampoline_probe_handler(struct kprobe *p, struct pt_regs *regs)
 		kfree(ri);
diff --git a/arch/sparc/kernel/kprobes.c b/arch/sparc/kernel/kprobes.c
index a39d1ba..e722121 100644
--- a/arch/sparc/kernel/kprobes.c
+++ b/arch/sparc/kernel/kprobes.c
@@ -511,7 +511,7 @@ int __kprobes trampoline_probe_handler(struct kprobe *p, struct pt_regs *regs)
@@ -531,7 +531,7 @@ int __kprobes trampoline_probe_handler(struct kprobe *p, struct pt_regs *regs)
 			continue;
@@ -559,7 +559,7 @@ int __kprobes trampoline_probe_handler(struct kprobe *p, struct pt_regs *regs)
 		kfree(ri);
diff --git a/arch/sparc/kernel/ldc.c b/arch/sparc/kernel/ldc.c
index 9fcc6b4..54df554 100644
--- a/arch/sparc/kernel/ldc.c
+++ b/arch/sparc/kernel/ldc.c
@@ -953,9 +953,8 @@ static HLIST_HEAD(ldc_channel_list);
 static int __ldc_channel_exists(unsigned long id)
 	struct ldc_channel *lp;
-	struct hlist_node *n;
-	hlist_for_each_entry(lp, n, &ldc_channel_list, list) {
+	hlist_for_each_entry(lp, &ldc_channel_list, list) {
 		if (lp->id == id)
 			return 1;
diff --git a/arch/x86/kernel/kprobes/core.c b/arch/x86/kernel/kprobes/core.c
index e124554..3f06e61 100644
--- a/arch/x86/kernel/kprobes/core.c
+++ b/arch/x86/kernel/kprobes/core.c
@@ -652,7 +652,7 @@ static __used __kprobes void *trampoline_handler(struct pt_regs *regs)
 	kprobe_opcode_t *correct_ret_addr = NULL;
@@ -682,7 +682,7 @@ static __used __kprobes void *trampoline_handler(struct pt_regs *regs)
 	 *	 will be the real return address, and all the rest will
 	 *	 point to kretprobe_trampoline.
 			continue;
@@ -701,7 +701,7 @@ static __used __kprobes void *trampoline_handler(struct pt_regs *regs)
 			continue;
@@ -728,7 +728,7 @@ static __used __kprobes void *trampoline_handler(struct pt_regs *regs)
 		kfree(ri);
diff --git a/arch/x86/kvm/mmu.c b/arch/x86/kvm/mmu.c
index 4ed3edb..956ca35 100644
--- a/arch/x86/kvm/mmu.c
+++ b/arch/x86/kvm/mmu.c
@@ -1644,13 +1644,13 @@ static int kvm_mmu_prepare_zap_page(struct kvm *kvm, struct kvm_mmu_page *sp,
 static void kvm_mmu_commit_zap_page(struct kvm *kvm,
 				    struct list_head *invalid_list);
-#define for_each_gfn_sp(kvm, sp, gfn, pos)				\
-  hlist_for_each_entry(sp, pos,						\
+#define for_each_gfn_sp(kvm, sp, gfn)					\
+  hlist_for_each_entry(sp,						\
    &(kvm)->arch.mmu_page_hash[kvm_page_table_hashfn(gfn)], hash_link)	\
 	if ((sp)->gfn != (gfn)) {} else
-#define for_each_gfn_indirect_valid_sp(kvm, sp, gfn, pos)		\
+#define for_each_gfn_indirect_valid_sp(kvm, sp, gfn)			\
 		if ((sp)->gfn != (gfn) || (sp)->role.direct ||		\
 			(sp)->role.invalid) {} else
@@ -1706,11 +1706,10 @@ static int kvm_sync_page(struct kvm_vcpu *vcpu, struct kvm_mmu_page *sp,
 static void kvm_sync_pages(struct kvm_vcpu *vcpu,  gfn_t gfn)
 	struct kvm_mmu_page *s;
 	LIST_HEAD(invalid_list);
 	bool flush = false;
-	for_each_gfn_indirect_valid_sp(vcpu->kvm, s, gfn, node) {
+	for_each_gfn_indirect_valid_sp(vcpu->kvm, s, gfn) {
 		if (!s->unsync)
 			continue;
@@ -1848,7 +1847,6 @@ static struct kvm_mmu_page *kvm_mmu_get_page(struct kvm_vcpu *vcpu,
 	union kvm_mmu_page_role role;
 	unsigned quadrant;
 	struct kvm_mmu_page *sp;
 	bool need_sync = false;
 	role = vcpu->arch.mmu.base_role;
@@ -1863,7 +1861,7 @@ static struct kvm_mmu_page *kvm_mmu_get_page(struct kvm_vcpu *vcpu,
 		quadrant &= (1 << ((PT32_PT_BITS - PT64_PT_BITS) * level)) - 1;
 		role.quadrant = quadrant;
-	for_each_gfn_sp(vcpu->kvm, sp, gfn, node) {
+	for_each_gfn_sp(vcpu->kvm, sp, gfn) {
 		if (!need_sync && sp->unsync)
 			need_sync = true;
@@ -2151,14 +2149,13 @@ void kvm_mmu_change_mmu_pages(struct kvm *kvm, unsigned int goal_nr_mmu_pages)
 int kvm_mmu_unprotect_page(struct kvm *kvm, gfn_t gfn)
 	int r;
 	pgprintk("%s: looking for gfn %llx\n", __func__, gfn);
 	r = 0;
 	spin_lock(&kvm->mmu_lock);
-	for_each_gfn_indirect_valid_sp(kvm, sp, gfn, node) {
+	for_each_gfn_indirect_valid_sp(kvm, sp, gfn) {
 		pgprintk("%s: gfn %llx role %x\n", __func__, gfn,
 			 sp->role.word);
 		r = 1;
@@ -2288,9 +2285,8 @@ static void __kvm_unsync_page(struct kvm_vcpu *vcpu, struct kvm_mmu_page *sp)
 static void kvm_unsync_pages(struct kvm_vcpu *vcpu,  gfn_t gfn)
 		if (s->unsync)
 			continue;
 		WARN_ON(s->role.level != PT_PAGE_TABLE_LEVEL);
@@ -2302,10 +2298,9 @@ static int mmu_need_write_protect(struct kvm_vcpu *vcpu, gfn_t gfn,
 				  bool can_unsync)
 	bool need_unsync = false;
 		if (!can_unsync)
 			return 1;
@@ -3933,7 +3928,6 @@ void kvm_mmu_pte_write(struct kvm_vcpu *vcpu, gpa_t gpa,
 	gfn_t gfn = gpa >> PAGE_SHIFT;
 	union kvm_mmu_page_role mask = { .word = 0 };
 	u64 entry, gentry, *spte;
 	int npte;
@@ -3964,7 +3958,7 @@ void kvm_mmu_pte_write(struct kvm_vcpu *vcpu, gpa_t gpa,
 	kvm_mmu_audit(vcpu, AUDIT_PRE_PTE_WRITE);
 	mask.cr0_wp = mask.cr4_pae = mask.nxe = 1;
-	for_each_gfn_indirect_valid_sp(vcpu->kvm, sp, gfn, node) {
+	for_each_gfn_indirect_valid_sp(vcpu->kvm, sp, gfn) {
 		if (detect_write_misaligned(sp, gpa, bytes) ||
 		      detect_write_flooding(sp)) {
 			zap_page |= !!kvm_mmu_prepare_zap_page(vcpu->kvm, sp,
diff --git a/block/blk-cgroup.c b/block/blk-cgroup.c
index b8858fb..8bdebb6 100644
--- a/block/blk-cgroup.c
+++ b/block/blk-cgroup.c
@@ -357,7 +357,6 @@ static int blkcg_reset_stats(struct cgroup *cgroup, struct cftype *cftype,
 	struct blkcg *blkcg = cgroup_to_blkcg(cgroup);
 	struct blkcg_gq *blkg;
 	int i;
 	mutex_lock(&blkcg_pol_mutex);
@@ -368,7 +367,7 @@ static int blkcg_reset_stats(struct cgroup *cgroup, struct cftype *cftype,
 	 * stat updates.  This is a debug feature which shouldn't exist
 	 * anyway.  If you get hit by a race, retry.
-	hlist_for_each_entry(blkg, n, &blkcg->blkg_list, blkcg_node) {
+	hlist_for_each_entry(blkg, &blkcg->blkg_list, blkcg_node) {
 		for (i = 0; i < BLKCG_MAX_POLS; i++) {
 			struct blkcg_policy *pol = blkcg_policy[i];
@@ -415,11 +414,10 @@ void blkcg_print_blkgs(struct seq_file *sf, struct blkcg *blkcg,
 		       bool show_total)
 	u64 total = 0;
 	spin_lock_irq(&blkcg->lock);
 		if (blkcg_policy_enabled(blkg->q, pol))
 			total += prfill(sf, blkg->pd[pol->plid], data);
 	spin_unlock_irq(&blkcg->lock);
diff --git a/block/blk-ioc.c b/block/blk-ioc.c
index fab4cdd..9c4bb82 100644
--- a/block/blk-ioc.c
+++ b/block/blk-ioc.c
@@ -164,7 +164,6 @@ EXPORT_SYMBOL(put_io_context);
 void put_io_context_active(struct io_context *ioc)
 	unsigned long flags;
 	struct io_cq *icq;
@@ -180,7 +179,7 @@ void put_io_context_active(struct io_context *ioc)
 retry:
 	spin_lock_irqsave_nested(&ioc->lock, flags, 1);
-	hlist_for_each_entry(icq, n, &ioc->icq_list, ioc_node) {
+	hlist_for_each_entry(icq, &ioc->icq_list, ioc_node) {
 		if (icq->flags & ICQ_EXITED)
 			continue;
 		if (spin_trylock(icq->q->queue_lock)) {
diff --git a/block/bsg.c b/block/bsg.c
index 3ca92eb..420a5a9 100644
--- a/block/bsg.c
+++ b/block/bsg.c
@@ -800,11 +800,10 @@ static struct bsg_device *bsg_add_device(struct inode *inode,
 static struct bsg_device *__bsg_get_device(int minor, struct request_queue *q)
 	struct bsg_device *bd;
 	mutex_lock(&bsg_mutex);
-	hlist_for_each_entry(bd, entry, bsg_dev_idx_hash(minor), dev_list) {
+	hlist_for_each_entry(bd, bsg_dev_idx_hash(minor), dev_list) {
 		if (bd->queue == q) {
 			atomic_inc(&bd->ref_count);
 			goto found;
diff --git a/block/cfq-iosched.c b/block/cfq-iosched.c
index e62e920..ec52807 100644
--- a/block/cfq-iosched.c
+++ b/block/cfq-iosched.c
@@ -1435,7 +1435,6 @@ static int cfq_set_weight(struct cgroup *cgrp, struct cftype *cft, u64 val)
 	struct blkcg *blkcg = cgroup_to_blkcg(cgrp);
 	if (val < CFQ_WEIGHT_MIN || val > CFQ_WEIGHT_MAX)
 		return -EINVAL;
@@ -1443,7 +1442,7 @@ static int cfq_set_weight(struct cgroup *cgrp, struct cftype *cft, u64 val)
 	blkcg->cfq_weight = (unsigned int)val;
 		struct cfq_group *cfqg = blkg_to_cfqg(blkg);
 		if (cfqg && !cfqg->dev_weight)
diff --git a/block/elevator.c b/block/elevator.c
index 603b2c1..d0acb31 100644
--- a/block/elevator.c
+++ b/block/elevator.c
@@ -288,10 +288,10 @@ static struct request *elv_rqhash_find(struct request_queue *q, sector_t offset)
 	struct elevator_queue *e = q->elevator;
 	struct hlist_head *hash_list = &e->hash[ELV_HASH_FN(offset)];
-	struct hlist_node *entry, *next;
+	struct hlist_node *next;
 	struct request *rq;
-	hlist_for_each_entry_safe(rq, entry, next, hash_list, hash) {
+	hlist_for_each_entry_safe(rq, next, hash_list, hash) {
 		BUG_ON(!ELV_ON_HASH(rq));
 		if (unlikely(!rq_mergeable(rq))) {
diff --git a/crypto/algapi.c b/crypto/algapi.c
index 08c57c8..6149a6e 100644
--- a/crypto/algapi.c
+++ b/crypto/algapi.c
@@ -447,7 +447,7 @@ EXPORT_SYMBOL_GPL(crypto_register_template);
 void crypto_unregister_template(struct crypto_template *tmpl)
 	struct crypto_instance *inst;
-	struct hlist_node *p, *n;
+	struct hlist_node *n;
 	LIST_HEAD(users);
@@ -457,7 +457,7 @@ void crypto_unregister_template(struct crypto_template *tmpl)
 	list_del_init(&tmpl->list);
 	list = &tmpl->instances;
-	hlist_for_each_entry(inst, p, list, list) {
+	hlist_for_each_entry(inst, list, list) {
 		int err = crypto_remove_alg(&inst->alg, &users);
 		BUG_ON(err);
@@ -466,7 +466,7 @@ void crypto_unregister_template(struct crypto_template *tmpl)
 	up_write(&crypto_alg_sem);
-	hlist_for_each_entry_safe(inst, p, n, list, list) {
+	hlist_for_each_entry_safe(inst, n, list, list) {
 		BUG_ON(atomic_read(&inst->alg.cra_refcnt) != 1);
 		tmpl->free(inst);
diff --git a/drivers/atm/atmtcp.c b/drivers/atm/atmtcp.c
index b22d71c..0e3f8f9 100644
--- a/drivers/atm/atmtcp.c
+++ b/drivers/atm/atmtcp.c
@@ -157,7 +157,6 @@ static int atmtcp_v_ioctl(struct atm_dev *dev,unsigned int cmd,void __user *arg)
 	struct atm_cirange ci;
 	struct atm_vcc *vcc;
 	struct sock *s;
 	int i;
@@ -171,7 +170,7 @@ static int atmtcp_v_ioctl(struct atm_dev *dev,unsigned int cmd,void __user *arg)
 	for(i = 0; i < VCC_HTABLE_SIZE; ++i) {
 		struct hlist_head *head = &vcc_hash[i];
-		sk_for_each(s, node, head) {
+		sk_for_each(s, head) {
 			vcc = atm_sk(s);
 			if (vcc->dev != dev)
 				continue;
@@ -264,12 +263,11 @@ static struct atm_vcc *find_vcc(struct atm_dev *dev, short vpi, int vci)
         struct hlist_head *head;
         struct sock *s;
         head = &vcc_hash[vci & (VCC_HTABLE_SIZE -1)];
                 vcc = atm_sk(s);
                 if (vcc->dev == dev &&
                     vcc->vci == vci && vcc->vpi == vpi &&
diff --git a/drivers/atm/eni.c b/drivers/atm/eni.c
index c1eb6fa..b1955ba 100644
--- a/drivers/atm/eni.c
+++ b/drivers/atm/eni.c
@@ -2093,7 +2093,6 @@ static unsigned char eni_phy_get(struct atm_dev *dev,unsigned long addr)
 static int eni_proc_read(struct atm_dev *dev,loff_t *pos,char *page)
 	struct sock *s;
 	static const char *signal[] = { "LOST","unknown","okay" };
 	struct eni_dev *eni_dev = ENI_DEV(dev);
@@ -2171,7 +2170,7 @@ static int eni_proc_read(struct atm_dev *dev,loff_t *pos,char *page)
 			struct eni_vcc *eni_vcc;
 			int length;
diff --git a/drivers/atm/he.c b/drivers/atm/he.c
index 72b6960..d689126 100644
--- a/drivers/atm/he.c
+++ b/drivers/atm/he.c
@@ -329,7 +329,6 @@ __find_vcc(struct he_dev *he_dev, unsigned cid)
 	struct sock *s;
 	short vpi;
 	int vci;
@@ -338,7 +337,7 @@ __find_vcc(struct he_dev *he_dev, unsigned cid)
 	vci = cid & ((1 << he_dev->vcibits) - 1);
 		vcc = atm_sk(s);
 		if (vcc->dev == he_dev->atm_dev &&
diff --git a/drivers/atm/solos-pci.c b/drivers/atm/solos-pci.c
index 0474a89..32784d1 100644
--- a/drivers/atm/solos-pci.c
+++ b/drivers/atm/solos-pci.c
@@ -896,12 +896,11 @@ static struct atm_vcc *find_vcc(struct atm_dev *dev, short vpi, int vci)
 	struct atm_vcc *vcc = NULL;
 	struct sock *s;
 	read_lock(&vcc_sklist_lock);
 		vcc = atm_sk(s);
 		if (vcc->dev == dev && vcc->vci == vci &&
 		    vcc->vpi == vpi && vcc->qos.rxtp.traffic_class != ATM_NONE &&
diff --git a/drivers/clk/clk.c b/drivers/clk/clk.c
index fabbfe1..ed87b24 100644
--- a/drivers/clk/clk.c
+++ b/drivers/clk/clk.c
@@ -52,31 +52,29 @@ static void clk_summary_show_subtree(struct seq_file *s, struct clk *c,
 				     int level)
 	struct clk *child;
-	struct hlist_node *tmp;
 	if (!c)
 		return;
 	clk_summary_show_one(s, c, level);
-	hlist_for_each_entry(child, tmp, &c->children, child_node)
+	hlist_for_each_entry(child, &c->children, child_node)
 		clk_summary_show_subtree(s, child, level + 1);
 static int clk_summary_show(struct seq_file *s, void *data)
 	struct clk *c;
 	seq_printf(s, "   clock                        enable_cnt  prepare_cnt  rate\n");
 	seq_printf(s, "---------------------------------------------------------------------\n");
 	mutex_lock(&prepare_lock);
-	hlist_for_each_entry(c, tmp, &clk_root_list, child_node)
+	hlist_for_each_entry(c, &clk_root_list, child_node)
 		clk_summary_show_subtree(s, c, 0);
-	hlist_for_each_entry(c, tmp, &clk_orphan_list, child_node)
+	hlist_for_each_entry(c, &clk_orphan_list, child_node)
 	mutex_unlock(&prepare_lock);
@@ -111,14 +109,13 @@ static void clk_dump_one(struct seq_file *s, struct clk *c, int level)
 static void clk_dump_subtree(struct seq_file *s, struct clk *c, int level)
 	struct clk *child;
 	if (!c)
 		return;
 	clk_dump_one(s, c, level);
-	hlist_for_each_entry(child, tmp, &c->children, child_node) {
+	hlist_for_each_entry(child, &c->children, child_node) {
 		seq_printf(s, ",");
 		clk_dump_subtree(s, child, level + 1);
@@ -129,21 +126,20 @@ static void clk_dump_subtree(struct seq_file *s, struct clk *c, int level)
 static int clk_dump(struct seq_file *s, void *data)
 	struct clk *c;
 	bool first_node = true;
 	seq_printf(s, "{");
-	hlist_for_each_entry(c, tmp, &clk_root_list, child_node) {
+	hlist_for_each_entry(c, &clk_root_list, child_node) {
 		if (!first_node)
 			seq_printf(s, ",");
 		first_node = false;
 		clk_dump_subtree(s, c, 0);
-	hlist_for_each_entry(c, tmp, &clk_orphan_list, child_node) {
+	hlist_for_each_entry(c, &clk_orphan_list, child_node) {
 		seq_printf(s, ",");
@@ -222,7 +218,6 @@ out:
 static int clk_debug_create_subtree(struct clk *clk, struct dentry *pdentry)
 	struct clk *child;
 	int ret = -EINVAL;;
 	if (!clk || !pdentry)
@@ -233,7 +228,7 @@ static int clk_debug_create_subtree(struct clk *clk, struct dentry *pdentry)
 	if (ret)
 		goto out;
-	hlist_for_each_entry(child, tmp, &clk->children, child_node)
+	hlist_for_each_entry(child, &clk->children, child_node)
 		clk_debug_create_subtree(child, clk->dentry);
 	ret = 0;
@@ -299,7 +294,6 @@ out:
 static int __init clk_debug_init(void)
 	struct clk *clk;
 	struct dentry *d;
 	rootdir = debugfs_create_dir("clk", NULL);
@@ -324,10 +318,10 @@ static int __init clk_debug_init(void)
-	hlist_for_each_entry(clk, tmp, &clk_root_list, child_node)
+	hlist_for_each_entry(clk, &clk_root_list, child_node)
 		clk_debug_create_subtree(clk, rootdir);
-	hlist_for_each_entry(clk, tmp, &clk_orphan_list, child_node)
+	hlist_for_each_entry(clk, &clk_orphan_list, child_node)
 		clk_debug_create_subtree(clk, orphandir);
 	inited = 1;
@@ -345,13 +339,12 @@ static inline int clk_debug_register(struct clk *clk) { return 0; }
 static void clk_disable_unused_subtree(struct clk *clk)
 	struct clk *child;
 	if (!clk)
 		goto out;
 		clk_disable_unused_subtree(child);
 	spin_lock_irqsave(&enable_lock, flags);
@@ -384,14 +377,13 @@ out:
 static int clk_disable_unused(void)
 	struct clk *clk;
 		clk_disable_unused_subtree(clk);
@@ -484,12 +476,11 @@ static struct clk *__clk_lookup_subtree(const char *name, struct clk *clk)
 	struct clk *child;
 	struct clk *ret;
 	if (!strcmp(clk->name, name))
 		return clk;
-	hlist_for_each_entry(child, tmp, &clk->children, child_node) {
+	hlist_for_each_entry(child, &clk->children, child_node) {
 		ret = __clk_lookup_subtree(name, child);
 		if (ret)
 			return ret;
@@ -502,20 +493,19 @@ struct clk *__clk_lookup(const char *name)
 	struct clk *root_clk;
 	struct clk *ret;
 	if (!name)
 		return NULL;
 	/* search the 'proper' clk tree first */
-	hlist_for_each_entry(root_clk, tmp, &clk_root_list, child_node) {
+	hlist_for_each_entry(root_clk, &clk_root_list, child_node) {
 		ret = __clk_lookup_subtree(name, root_clk);
 		if (ret)
 			return ret;
 	/* if not found, then search the orphan tree */
-	hlist_for_each_entry(root_clk, tmp, &clk_orphan_list, child_node) {
+	hlist_for_each_entry(root_clk, &clk_orphan_list, child_node) {
 		if (ret)
 			return ret;
@@ -812,7 +802,6 @@ static void __clk_recalc_rates(struct clk *clk, unsigned long msg)
 	unsigned long old_rate;
 	unsigned long parent_rate = 0;
 	struct clk *child;
 	old_rate = clk->rate;
@@ -832,7 +821,7 @@ static void __clk_recalc_rates(struct clk *clk, unsigned long msg)
 	if (clk->notifier_count && msg)
 		__clk_notify(clk, msg, old_rate, clk->rate);
 		__clk_recalc_rates(child, msg);
@@ -878,7 +867,6 @@ EXPORT_SYMBOL_GPL(clk_get_rate);
 static int __clk_speculate_rates(struct clk *clk, unsigned long parent_rate)
 	struct clk *child;
 	unsigned long new_rate;
 	int ret = NOTIFY_DONE;
@@ -895,7 +883,7 @@ static int __clk_speculate_rates(struct clk *clk, unsigned long parent_rate)
 	if (ret == NOTIFY_BAD)
 		goto out;
 		ret = __clk_speculate_rates(child, new_rate);
 			break;
@@ -908,11 +896,10 @@ out:
 static void clk_calc_subtree(struct clk *clk, unsigned long new_rate)
 	struct clk *child;
 	clk->new_rate = new_rate;
 		if (child->ops->recalc_rate)
 			child->new_rate = child->ops->recalc_rate(child->hw, new_rate);
 		else
@@ -983,7 +970,6 @@ out:
 static struct clk *clk_propagate_rate_change(struct clk *clk, unsigned long event)
 	struct clk *child, *fail_clk = NULL;
@@ -996,7 +982,7 @@ static struct clk *clk_propagate_rate_change(struct clk *clk, unsigned long even
 			fail_clk = clk;
 		clk = clk_propagate_rate_change(child, event);
 		if (clk)
 			fail_clk = clk;
@@ -1014,7 +1000,6 @@ static void clk_change_rate(struct clk *clk)
 	struct clk *child;
 	unsigned long best_parent_rate = 0;
@@ -1032,7 +1017,7 @@ static void clk_change_rate(struct clk *clk)
 	if (clk->notifier_count && old_rate != clk->rate)
 		__clk_notify(clk, POST_RATE_CHANGE, old_rate, clk->rate);
 		clk_change_rate(child);
@@ -1348,7 +1333,7 @@ int __clk_init(struct device *dev, struct clk *clk)
 	int i, ret = 0;
 	struct clk *orphan;
-	struct hlist_node *tmp, *tmp2;
+	struct hlist_node *tmp2;
 	if (!clk)
 		return -EINVAL;
@@ -1448,7 +1433,7 @@ int __clk_init(struct device *dev, struct clk *clk)
 	 * walk the list of orphan clocks and reparent any that are children of
 	 * this clock
-	hlist_for_each_entry_safe(orphan, tmp, tmp2, &clk_orphan_list, child_node) {
+	hlist_for_each_entry_safe(orphan, tmp2, &clk_orphan_list, child_node) {
 		if (orphan->ops->get_parent) {
 			i = orphan->ops->get_parent(orphan->hw);
 			if (!strcmp(clk->name, orphan->parent_names[i]))
diff --git a/drivers/gpu/drm/drm_hashtab.c b/drivers/gpu/drm/drm_hashtab.c
index 8025454..7e4bae7 100644
--- a/drivers/gpu/drm/drm_hashtab.c
+++ b/drivers/gpu/drm/drm_hashtab.c
@@ -60,14 +60,13 @@ void drm_ht_verbose_list(struct drm_open_hash *ht, unsigned long key)
 	struct drm_hash_item *entry;
 	struct hlist_head *h_list;
-	struct hlist_node *list;
 	unsigned int hashed_key;
 	int count = 0;
 	hashed_key = hash_long(key, ht->order);
 	DRM_DEBUG("Key is 0x%08lx, Hashed key is 0x%08x\n", key, hashed_key);
 	h_list = &ht->table[hashed_key];
-	hlist_for_each_entry(entry, list, h_list, head)
+	hlist_for_each_entry(entry, h_list, head)
 		DRM_DEBUG("count %d, key: 0x%08lx\n", count++, entry->key);
@@ -76,14 +75,13 @@ static struct hlist_node *drm_ht_find_key(struct drm_open_hash *ht,
-	hlist_for_each_entry(entry, list, h_list, head) {
+	hlist_for_each_entry(entry, h_list, head) {
 		if (entry->key == key)
-			return list;
+			return &entry->head;
 		if (entry->key > key)
 			break;
@@ -95,14 +93,13 @@ static struct hlist_node *drm_ht_find_key_rcu(struct drm_open_hash *ht,
-	hlist_for_each_entry_rcu(entry, list, h_list, head) {
+	hlist_for_each_entry_rcu(entry, h_list, head) {
-			return list;
 			break;
@@ -113,19 +110,19 @@ int drm_ht_insert_item(struct drm_open_hash *ht, struct drm_hash_item *item)
-	struct hlist_node *list, *parent;
+	struct hlist_node *parent;
 	unsigned long key = item->key;
 	parent = NULL;
 			return -EINVAL;
 			break;
-		parent = list;
+		parent = &entry->head;
 	if (parent) {
 		hlist_add_after_rcu(parent, &item->head);
diff --git a/drivers/infiniband/core/cma.c b/drivers/infiniband/core/cma.c
index c32eeaa..71c2c71 100644
--- a/drivers/infiniband/core/cma.c
+++ b/drivers/infiniband/core/cma.c
@@ -2204,10 +2204,9 @@ static int cma_check_port(struct rdma_bind_list *bind_list,
 	struct rdma_id_private *cur_id;
 	struct sockaddr *addr, *cur_addr;
 	addr = (struct sockaddr *) &id_priv->id.route.addr.src_addr;
-	hlist_for_each_entry(cur_id, node, &bind_list->owners, node) {
+	hlist_for_each_entry(cur_id, &bind_list->owners, node) {
 		if (id_priv == cur_id)
 			continue;
diff --git a/drivers/infiniband/core/fmr_pool.c b/drivers/infiniband/core/fmr_pool.c
index 176c8f9..9f5ad7c 100644
--- a/drivers/infiniband/core/fmr_pool.c
+++ b/drivers/infiniband/core/fmr_pool.c
@@ -118,14 +118,13 @@ static inline struct ib_pool_fmr *ib_fmr_cache_lookup(struct ib_fmr_pool *pool,
 	struct hlist_head *bucket;
 	struct ib_pool_fmr *fmr;
-	struct hlist_node *pos;
 	if (!pool->cache_bucket)
 		return NULL;
 	bucket = pool->cache_bucket + ib_fmr_hash(*page_list);
-	hlist_for_each_entry(fmr, pos, bucket, cache_node)
+	hlist_for_each_entry(fmr, bucket, cache_node)
 		if (io_virtual_address == fmr->io_virtual_address &&
 		    page_list_len      == fmr->page_list_len      &&
 		    !memcmp(page_list, fmr->page_list,
diff --git a/drivers/isdn/mISDN/socket.c b/drivers/isdn/mISDN/socket.c
index abe2d69..8b07f83 100644
--- a/drivers/isdn/mISDN/socket.c
+++ b/drivers/isdn/mISDN/socket.c
@@ -483,7 +483,6 @@ data_sock_bind(struct socket *sock, struct sockaddr *addr, int addr_len)
 	struct sockaddr_mISDN *maddr = (struct sockaddr_mISDN *) addr;
 	struct sock *sk = sock->sk;
 	struct sock *csk;
 	int err = 0;
@@ -508,7 +507,7 @@ data_sock_bind(struct socket *sock, struct sockaddr *addr, int addr_len)
 	if (sk->sk_protocol < ISDN_P_B_START) {
 		read_lock_bh(&data_sockets.lock);
-		sk_for_each(csk, node, &data_sockets.head) {
+		sk_for_each(csk, &data_sockets.head) {
 			if (sk == csk)
 				continue;
 			if (_pms(csk)->dev != _pms(sk)->dev)
diff --git a/drivers/isdn/mISDN/stack.c b/drivers/isdn/mISDN/stack.c
index deda591..9cb4b62 100644
--- a/drivers/isdn/mISDN/stack.c
+++ b/drivers/isdn/mISDN/stack.c
@@ -64,12 +64,11 @@ unlock:
 static void
 send_socklist(struct mISDN_sock_list *sl, struct sk_buff *skb)
 	struct sock		*sk;
 	struct sk_buff		*cskb = NULL;
 	read_lock(&sl->lock);
-	sk_for_each(sk, node, &sl->head) {
+	sk_for_each(sk, &sl->head) {
 		if (sk->sk_state != MISDN_BOUND)
 			continue;
 		if (!cskb)
diff --git a/drivers/md/dm-bio-prison.c b/drivers/md/dm-bio-prison.c
index aefb78e..d9d3f1c 100644
--- a/drivers/md/dm-bio-prison.c
+++ b/drivers/md/dm-bio-prison.c
@@ -106,9 +106,8 @@ static struct dm_bio_prison_cell *__search_bucket(struct hlist_head *bucket,
 						  struct dm_cell_key *key)
 	struct dm_bio_prison_cell *cell;
-	hlist_for_each_entry(cell, tmp, bucket, list)
+	hlist_for_each_entry(cell, bucket, list)
 		if (keys_equal(&cell->key, key))
 			return cell;
diff --git a/drivers/md/dm-bufio.c b/drivers/md/dm-bufio.c
index 651ca79..93205e3 100644
--- a/drivers/md/dm-bufio.c
+++ b/drivers/md/dm-bufio.c
@@ -859,9 +859,8 @@ static void __check_watermark(struct dm_bufio_client *c)
 static struct dm_buffer *__find(struct dm_bufio_client *c, sector_t block)
 	struct dm_buffer *b;
-	struct hlist_node *hn;
-	hlist_for_each_entry(b, hn, &c->cache_hash[DM_BUFIO_HASH(block)],
+	hlist_for_each_entry(b, &c->cache_hash[DM_BUFIO_HASH(block)],
 			     hash_list) {
 		dm_bufio_cond_resched();
 		if (b->block == block)
diff --git a/drivers/md/dm-snap.c b/drivers/md/dm-snap.c
index 59fc18a..10079e0 100644
--- a/drivers/md/dm-snap.c
+++ b/drivers/md/dm-snap.c
@@ -227,12 +227,11 @@ static void stop_tracking_chunk(struct dm_snapshot *s, struct bio *bio)
 static int __chunk_is_tracked(struct dm_snapshot *s, chunk_t chunk)
 	struct dm_snap_tracked_chunk *c;
 	int found = 0;
 	spin_lock_irq(&s->tracked_chunk_lock);
-	hlist_for_each_entry(c, hn,
 	    &s->tracked_chunk_hash[DM_TRACKED_CHUNK_HASH(chunk)], node) {
 		if (c->chunk == chunk) {
 			found = 1;
diff --git a/drivers/md/persistent-data/dm-transaction-manager.c b/drivers/md/persistent-data/dm-transaction-manager.c
index 7b17a1f..81da1a2 100644
--- a/drivers/md/persistent-data/dm-transaction-manager.c
+++ b/drivers/md/persistent-data/dm-transaction-manager.c
@@ -46,10 +46,9 @@ static int is_shadow(struct dm_transaction_manager *tm, dm_block_t b)
 	int r = 0;
 	unsigned bucket = dm_hash_block(b, DM_HASH_MASK);
 	struct shadow_info *si;
 	spin_lock(&tm->lock);
-	hlist_for_each_entry(si, n, tm->buckets + bucket, hlist)
+	hlist_for_each_entry(si, tm->buckets + bucket, hlist)
 		if (si->where == b) {
 			r = 1;
 			break;
@@ -81,14 +80,14 @@ static void insert_shadow(struct dm_transaction_manager *tm, dm_block_t b)
 static void wipe_shadow_table(struct dm_transaction_manager *tm)
-	struct hlist_node *n, *tmp;
 	int i;
 	for (i = 0; i < DM_HASH_SIZE; i++) {
 		bucket = tm->buckets + i;
-		hlist_for_each_entry_safe(si, n, tmp, bucket, hlist)
+		hlist_for_each_entry_safe(si, tmp, bucket, hlist)
 			kfree(si);
 		INIT_HLIST_HEAD(bucket);
diff --git a/drivers/md/raid5.c b/drivers/md/raid5.c
index 19d77a0..697f026 100644
--- a/drivers/md/raid5.c
+++ b/drivers/md/raid5.c
@@ -365,10 +365,9 @@ static struct stripe_head *__find_stripe(struct r5conf *conf, sector_t sector,
 					 short generation)
 	struct stripe_head *sh;
 	pr_debug("__find_stripe, sector %llu\n", (unsigned long long)sector);
-	hlist_for_each_entry(sh, hn, stripe_hash(conf, sector), hash)
+	hlist_for_each_entry(sh, stripe_hash(conf, sector), hash)
 		if (sh->sector == sector && sh->generation == generation)
 			return sh;
 	pr_debug("__stripe %llu not in cache\n", (unsigned long long)sector);
diff --git a/drivers/misc/sgi-gru/grutlbpurge.c b/drivers/misc/sgi-gru/grutlbpurge.c
index 240a6d3..2129274 100644
--- a/drivers/misc/sgi-gru/grutlbpurge.c
+++ b/drivers/misc/sgi-gru/grutlbpurge.c
@@ -280,11 +280,10 @@ static struct mmu_notifier *mmu_find_ops(struct mm_struct *mm,
 			const struct mmu_notifier_ops *ops)
 	struct mmu_notifier *mn, *gru_mn = NULL;
 	if (mm->mmu_notifier_mm) {
 		rcu_read_lock();
-		hlist_for_each_entry_rcu(mn, n, &mm->mmu_notifier_mm->list,
+		hlist_for_each_entry_rcu(mn, &mm->mmu_notifier_mm->list,
 					 hlist)
 		    if (mn->ops == ops) {
 			gru_mn = mn;
diff --git a/drivers/misc/vmw_vmci/vmci_doorbell.c b/drivers/misc/vmw_vmci/vmci_doorbell.c
index c3e8397..a8cee33 100644
--- a/drivers/misc/vmw_vmci/vmci_doorbell.c
+++ b/drivers/misc/vmw_vmci/vmci_doorbell.c
@@ -127,9 +127,8 @@ static struct dbell_entry *dbell_index_table_find(u32 idx)
 	u32 bucket = VMCI_DOORBELL_HASH(idx);
 	struct dbell_entry *dbell;
-	hlist_for_each_entry(dbell, node, &vmci_doorbell_it.entries[bucket],
+	hlist_for_each_entry(dbell, &vmci_doorbell_it.entries[bucket],
 			     node) {
 		if (idx == dbell->idx)
 			return dbell;
@@ -359,12 +358,10 @@ static void dbell_fire_entries(u32 notify_idx)
 	u32 bucket = VMCI_DOORBELL_HASH(notify_idx);
 	spin_lock_bh(&vmci_doorbell_it.lock);
-			     &vmci_doorbell_it.entries[bucket], node) {
+	hlist_for_each_entry(dbell, &vmci_doorbell_it.entries[bucket], node) {
 		if (dbell->idx == notify_idx &&
 		    atomic_read(&dbell->active) == 1) {
 			if (dbell->run_delayed) {
diff --git a/drivers/misc/vmw_vmci/vmci_resource.c b/drivers/misc/vmw_vmci/vmci_resource.c
index a196f84..9a53a30 100644
--- a/drivers/misc/vmw_vmci/vmci_resource.c
+++ b/drivers/misc/vmw_vmci/vmci_resource.c
@@ -46,11 +46,10 @@ static struct vmci_resource *vmci_resource_lookup(struct vmci_handle handle,
 						  enum vmci_resource_type type)
 	struct vmci_resource *r, *resource = NULL;
 	unsigned int idx = vmci_resource_hash(handle);
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(r, node,
+	hlist_for_each_entry_rcu(r,
 				 &vmci_resource_table.entries[idx], node) {
 		u32 cid = r->handle.context;
 		u32 rid = r->handle.resource;
@@ -146,12 +145,11 @@ void vmci_resource_remove(struct vmci_resource *resource)
 	struct vmci_handle handle = resource->handle;
 	struct vmci_resource *r;
 	/* Remove resource from hash table. */
 	spin_lock(&vmci_resource_table.lock);
-	hlist_for_each_entry(r, node, &vmci_resource_table.entries[idx], node) {
+	hlist_for_each_entry(r, &vmci_resource_table.entries[idx], node) {
 		if (vmci_handle_is_equal(r->handle, resource->handle)) {
 			hlist_del_init_rcu(&r->node);
 			break;
diff --git a/drivers/net/ethernet/intel/ixgbe/ixgbe_ethtool.c b/drivers/net/ethernet/intel/ixgbe/ixgbe_ethtool.c
index f4d2e9e..c3f1afd 100644
--- a/drivers/net/ethernet/intel/ixgbe/ixgbe_ethtool.c
+++ b/drivers/net/ethernet/intel/ixgbe/ixgbe_ethtool.c
@@ -2197,13 +2197,13 @@ static int ixgbe_get_ethtool_fdir_entry(struct ixgbe_adapter *adapter,
 	union ixgbe_atr_input *mask = &adapter->fdir_mask;
 	struct ethtool_rx_flow_spec *fsp =
 		(struct ethtool_rx_flow_spec *)&cmd->fs;
-	struct hlist_node *node, *node2;
+	struct hlist_node *node2;
 	struct ixgbe_fdir_filter *rule = NULL;
 	/* report total rule count */
 	cmd->data = (1024 << adapter->fdir_pballoc) - 2;
-	hlist_for_each_entry_safe(rule, node, node2,
+	hlist_for_each_entry_safe(rule, node2,
 				  &adapter->fdir_filter_list, fdir_node) {
 		if (fsp->location <= rule->sw_idx)
 			break;
@@ -2264,14 +2264,14 @@ static int ixgbe_get_ethtool_fdir_all(struct ixgbe_adapter *adapter,
 				      struct ethtool_rxnfc *cmd,
 				      u32 *rule_locs)
 	struct ixgbe_fdir_filter *rule;
 	int cnt = 0;
 		if (cnt == cmd->rule_cnt)
 			return -EMSGSIZE;
@@ -2358,19 +2358,19 @@ static int ixgbe_update_ethtool_fdir_entry(struct ixgbe_adapter *adapter,
 					   u16 sw_idx)
 	struct ixgbe_hw *hw = &adapter->hw;
-	struct hlist_node *node, *node2, *parent;
-	struct ixgbe_fdir_filter *rule;
+	struct ixgbe_fdir_filter *rule, *parent;
 	int err = -EINVAL;
 	parent = NULL;
 	rule = NULL;
 		/* hash found, or no matching entry */
 		if (rule->sw_idx >= sw_idx)
 			break;
-		parent = node;
+		parent = rule;
 	/* if there is an old rule occupying our place remove it */
@@ -2399,7 +2399,7 @@ static int ixgbe_update_ethtool_fdir_entry(struct ixgbe_adapter *adapter,
 	/* add filter to the list */
 	if (parent)
-		hlist_add_after(parent, &input->fdir_node);
+		hlist_add_after(&parent->fdir_node, &input->fdir_node);
 	else
 		hlist_add_head(&input->fdir_node,
 			       &adapter->fdir_filter_list);
diff --git a/drivers/net/ethernet/intel/ixgbe/ixgbe_main.c b/drivers/net/ethernet/intel/ixgbe/ixgbe_main.c
index 68478d6..db5611a 100644
--- a/drivers/net/ethernet/intel/ixgbe/ixgbe_main.c
+++ b/drivers/net/ethernet/intel/ixgbe/ixgbe_main.c
@@ -3891,7 +3891,7 @@ static void ixgbe_configure_pb(struct ixgbe_adapter *adapter)
 static void ixgbe_fdir_filter_restore(struct ixgbe_adapter *adapter)
 	struct ixgbe_fdir_filter *filter;
 	spin_lock(&adapter->fdir_perfect_lock);
@@ -3899,7 +3899,7 @@ static void ixgbe_fdir_filter_restore(struct ixgbe_adapter *adapter)
 	if (!hlist_empty(&adapter->fdir_filter_list))
 		ixgbe_fdir_set_input_mask_82599(hw, &adapter->fdir_mask);
-	hlist_for_each_entry_safe(filter, node, node2,
+	hlist_for_each_entry_safe(filter, node2,
 		ixgbe_fdir_write_perfect_filter_82599(hw,
 				&filter->filter,
@@ -4356,12 +4356,12 @@ static void ixgbe_clean_all_tx_rings(struct ixgbe_adapter *adapter)
 static void ixgbe_fdir_filter_exit(struct ixgbe_adapter *adapter)
 		hlist_del(&filter->fdir_node);
 		kfree(filter);
diff --git a/drivers/net/ethernet/mellanox/mlx4/en_netdev.c b/drivers/net/ethernet/mellanox/mlx4/en_netdev.c
index 5385474..bb4d8d9 100644
--- a/drivers/net/ethernet/mellanox/mlx4/en_netdev.c
+++ b/drivers/net/ethernet/mellanox/mlx4/en_netdev.c
@@ -225,11 +225,10 @@ static inline struct mlx4_en_filter *
 mlx4_en_filter_find(struct mlx4_en_priv *priv, __be32 src_ip, __be32 dst_ip,
 		    __be16 src_port, __be16 dst_port)
-	struct hlist_node *elem;
 	struct mlx4_en_filter *filter;
 	struct mlx4_en_filter *ret = NULL;
-	hlist_for_each_entry(filter, elem,
+	hlist_for_each_entry(filter,
 			     filter_hash_bucket(priv, src_ip, dst_ip,
 						src_port, dst_port),
 			     filter_chain) {
@@ -574,13 +573,13 @@ static void mlx4_en_put_qp(struct mlx4_en_priv *priv)
 	if (dev->caps.steering_mode != MLX4_STEERING_MODE_A0) {
 		struct mlx4_mac_entry *entry;
 		unsigned int mac_hash;
 		mac_hash = priv->dev->dev_addr[MLX4_EN_MAC_HASH_IDX];
 		bucket = &priv->mac_hash[mac_hash];
-		hlist_for_each_entry_safe(entry, n, tmp, bucket, hlist) {
+		hlist_for_each_entry_safe(entry, tmp, bucket, hlist) {
 			if (ether_addr_equal_64bits(entry->mac,
 						    priv->dev->dev_addr)) {
 				en_dbg(DRV, priv, "Releasing qp: port %d, MAC %pM, qpn %d\n",
@@ -609,11 +608,11 @@ static int mlx4_en_replace_mac(struct mlx4_en_priv *priv, int qpn,
 		u64 prev_mac_u64 = mlx4_en_mac_to_u64(prev_mac);
 		bucket = &priv->mac_hash[prev_mac[MLX4_EN_MAC_HASH_IDX]];
 			if (ether_addr_equal_64bits(entry->mac, prev_mac)) {
 				mlx4_en_uc_steer_release(priv, entry->mac,
 							 qpn, entry->reg_id);
@@ -1019,7 +1018,7 @@ static void mlx4_en_do_uc_filter(struct mlx4_en_priv *priv,
 	struct netdev_hw_addr *ha;
 	bool found;
 	u64 mac;
 	int err = 0;
@@ -1035,7 +1034,7 @@ static void mlx4_en_do_uc_filter(struct mlx4_en_priv *priv,
 	/* find what to remove */
 	for (i = 0; i < MLX4_EN_MAC_HASH_SIZE; ++i) {
 		bucket = &priv->mac_hash[i];
 			found = false;
 			netdev_for_each_uc_addr(ha, dev) {
@@ -1078,7 +1077,7 @@ static void mlx4_en_do_uc_filter(struct mlx4_en_priv *priv,
 		found = false;
 		bucket = &priv->mac_hash[ha->addr[MLX4_EN_MAC_HASH_IDX]];
-		hlist_for_each_entry(entry, n, bucket, hlist) {
+		hlist_for_each_entry(entry, bucket, hlist) {
 			if (ether_addr_equal_64bits(entry->mac, ha->addr)) {
 				found = true;
 				break;
diff --git a/drivers/net/ethernet/mellanox/mlx4/en_rx.c b/drivers/net/ethernet/mellanox/mlx4/en_rx.c
index ce38654..c7f8563 100644
--- a/drivers/net/ethernet/mellanox/mlx4/en_rx.c
+++ b/drivers/net/ethernet/mellanox/mlx4/en_rx.c
@@ -35,6 +35,7 @@
 #include <linux/slab.h>
 #include <linux/mlx4/qp.h>
 #include <linux/skbuff.h>
+#include <linux/rculist.h>
 #include <linux/if_ether.h>
 #include <linux/if_vlan.h>
 #include <linux/vmalloc.h>
@@ -617,7 +618,6 @@ int mlx4_en_process_rx_cq(struct net_device *dev, struct mlx4_en_cq *cq, int bud
 			if (is_multicast_ether_addr(ethh->h_dest)) {
@@ -625,7 +625,7 @@ int mlx4_en_process_rx_cq(struct net_device *dev, struct mlx4_en_cq *cq, int bud
 				mac_hash = ethh->h_source[MLX4_EN_MAC_HASH_IDX];
 				rcu_read_lock();
-				hlist_for_each_entry_rcu(entry, n, bucket, hlist) {
+				hlist_for_each_entry_rcu(entry, bucket, hlist) {
 								    ethh->h_source)) {
 						rcu_read_unlock();
diff --git a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_hw.c b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_hw.c
index 325e11e..f89cc7a 100644
--- a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_hw.c
+++ b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_hw.c
@@ -576,7 +576,7 @@ void qlcnic_free_mac_list(struct qlcnic_adapter *adapter)
 void qlcnic_prune_lb_filters(struct qlcnic_adapter *adapter)
 	struct qlcnic_filter *tmp_fil;
-	struct hlist_node *tmp_hnode, *n;
 	int i;
 	unsigned long time;
@@ -584,7 +584,7 @@ void qlcnic_prune_lb_filters(struct qlcnic_adapter *adapter)
 	for (i = 0; i < adapter->fhash.fbucket_size; i++) {
 		head = &(adapter->fhash.fhead[i]);
-		hlist_for_each_entry_safe(tmp_fil, tmp_hnode, n, head, fnode) {
+		hlist_for_each_entry_safe(tmp_fil, n, head, fnode) {
 			cmd =  tmp_fil->vlan_id ? QLCNIC_MAC_VLAN_DEL :
 						  QLCNIC_MAC_DEL;
 			time = tmp_fil->ftime;
@@ -604,7 +604,7 @@ void qlcnic_prune_lb_filters(struct qlcnic_adapter *adapter)
 	for (i = 0; i < adapter->rx_fhash.fbucket_size; i++) {
 		head = &(adapter->rx_fhash.fhead[i]);
 			if (jiffies > (QLCNIC_FILTER_AGE * HZ + time)) {
@@ -621,14 +621,14 @@ void qlcnic_prune_lb_filters(struct qlcnic_adapter *adapter)
 void qlcnic_delete_lb_filters(struct qlcnic_adapter *adapter)
 	int i;
 	u8 cmd;
 						  QLCNIC_MAC_DEL;
 			qlcnic_sre_macaddr_change(adapter,
diff --git a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_io.c b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_io.c
index 6387e0c..0e63006 100644
--- a/drivers/net/ethernet/qlogic/qlcnic/qlcnic_io.c
+++ b/drivers/net/ethernet/qlogic/qlcnic/qlcnic_io.c
@@ -162,7 +162,7 @@ void qlcnic_add_lb_filter(struct qlcnic_adapter *adapter, struct sk_buff *skb,
 	struct ethhdr *phdr = (struct ethhdr *)(skb->data);
 	struct qlcnic_filter *fil, *tmp_fil;
 	unsigned long time;
 	u64 src_addr = 0;
@@ -179,7 +179,7 @@ void qlcnic_add_lb_filter(struct qlcnic_adapter *adapter, struct sk_buff *skb,
 			 (adapter->fhash.fbucket_size - 1);
 		head = &(adapter->rx_fhash.fhead[hindex]);
 			if (!memcmp(tmp_fil->faddr, &src_addr, ETH_ALEN) &&
 			    tmp_fil->vlan_id == vlan_id) {
@@ -205,7 +205,7 @@ void qlcnic_add_lb_filter(struct qlcnic_adapter *adapter, struct sk_buff *skb,
 		spin_lock(&adapter->rx_mac_learn_lock);
 				found = 1;
@@ -272,7 +272,7 @@ static void qlcnic_send_filter(struct qlcnic_adapter *adapter,
 	struct net_device *netdev = adapter->netdev;
@@ -294,7 +294,7 @@ static void qlcnic_send_filter(struct qlcnic_adapter *adapter,
 	hindex = qlcnic_mac_hash(src_addr) & (adapter->fhash.fbucket_size - 1);
 	head = &(adapter->fhash.fhead[hindex]);
 			if (jiffies > (QLCNIC_READD_AGE * HZ + tmp_fil->ftime))
diff --git a/drivers/net/ethernet/sun/sunvnet.c b/drivers/net/ethernet/sun/sunvnet.c
index 289b4ee..1df0ff3 100644
--- a/drivers/net/ethernet/sun/sunvnet.c
+++ b/drivers/net/ethernet/sun/sunvnet.c
@@ -614,10 +614,9 @@ struct vnet_port *__tx_port_find(struct vnet *vp, struct sk_buff *skb)
 	unsigned int hash = vnet_hashfn(skb->data);
 	struct hlist_head *hp = &vp->port_hash[hash];
 	struct vnet_port *port;
-	hlist_for_each_entry(port, n, hp, hash) {
+	hlist_for_each_entry(port, hp, hash) {
 		if (ether_addr_equal(port->raddr, skb->data))
 			return port;
diff --git a/drivers/net/macvlan.c b/drivers/net/macvlan.c
index defcd8a8..417b2af 100644
--- a/drivers/net/macvlan.c
+++ b/drivers/net/macvlan.c
@@ -55,9 +55,8 @@ static struct macvlan_dev *macvlan_hash_lookup(const struct macvlan_port *port,
 					       const unsigned char *addr)
 	struct macvlan_dev *vlan;
-	hlist_for_each_entry_rcu(vlan, n, &port->vlan_hash[addr[5]], hlist) {
+	hlist_for_each_entry_rcu(vlan, &port->vlan_hash[addr[5]], hlist) {
 		if (ether_addr_equal_64bits(vlan->dev->dev_addr, addr))
 			return vlan;
@@ -149,7 +148,6 @@ static void macvlan_broadcast(struct sk_buff *skb,
 	const struct ethhdr *eth = eth_hdr(skb);
 	const struct macvlan_dev *vlan;
 	struct sk_buff *nskb;
 	unsigned int i;
 	int err;
@@ -159,7 +157,7 @@ static void macvlan_broadcast(struct sk_buff *skb,
 		return;
 	for (i = 0; i < MACVLAN_HASH_SIZE; i++) {
-		hlist_for_each_entry_rcu(vlan, n, &port->vlan_hash[i], hlist) {
+		hlist_for_each_entry_rcu(vlan, &port->vlan_hash[i], hlist) {
 			if (vlan->dev == src || !(vlan->mode & mode))
 				continue;
diff --git a/drivers/net/tun.c b/drivers/net/tun.c
index b6f45c5..2c6a22e 100644
--- a/drivers/net/tun.c
+++ b/drivers/net/tun.c
@@ -197,9 +197,8 @@ static inline u32 tun_hashfn(u32 rxhash)
 static struct tun_flow_entry *tun_flow_find(struct hlist_head *head, u32 rxhash)
 	struct tun_flow_entry *e;
-	hlist_for_each_entry_rcu(e, n, head, hash_link) {
+	hlist_for_each_entry_rcu(e, head, hash_link) {
 		if (e->rxhash == rxhash)
 			return e;
@@ -241,9 +240,9 @@ static void tun_flow_flush(struct tun_struct *tun)
 	spin_lock_bh(&tun->lock);
 	for (i = 0; i < TUN_NUM_FLOW_ENTRIES; i++) {
-		struct hlist_node *h, *n;
-		hlist_for_each_entry_safe(e, h, n, &tun->flows[i], hash_link)
+		hlist_for_each_entry_safe(e, n, &tun->flows[i], hash_link)
 			tun_flow_delete(tun, e);
 	spin_unlock_bh(&tun->lock);
@@ -256,9 +255,9 @@ static void tun_flow_delete_by_queue(struct tun_struct *tun, u16 queue_index)
-		hlist_for_each_entry_safe(e, h, n, &tun->flows[i], hash_link) {
+		hlist_for_each_entry_safe(e, n, &tun->flows[i], hash_link) {
 			if (e->queue_index == queue_index)
@@ -279,9 +278,9 @@ static void tun_flow_cleanup(unsigned long data)
 			unsigned long this_timer;
 			count++;
 			this_timer = e->updated + delay;
diff --git a/drivers/net/vxlan.c b/drivers/net/vxlan.c
index f736823..f10e58a 100644
--- a/drivers/net/vxlan.c
+++ b/drivers/net/vxlan.c
@@ -145,9 +145,8 @@ static inline struct hlist_head *vni_head(struct net *net, u32 id)
 static struct vxlan_dev *vxlan_find_vni(struct net *net, u32 id)
 	struct vxlan_dev *vxlan;
-	hlist_for_each_entry_rcu(vxlan, node, vni_head(net, id), hlist) {
+	hlist_for_each_entry_rcu(vxlan, vni_head(net, id), hlist) {
 		if (vxlan->vni == id)
 			return vxlan;
@@ -292,9 +291,8 @@ static struct vxlan_fdb *vxlan_find_mac(struct vxlan_dev *vxlan,
 	struct hlist_head *head = vxlan_fdb_head(vxlan, mac);
 	struct vxlan_fdb *f;
-	hlist_for_each_entry_rcu(f, node, head, hlist) {
+	hlist_for_each_entry_rcu(f, head, hlist) {
 		if (compare_ether_addr(mac, f->eth_addr) == 0)
 			return f;
@@ -422,10 +420,9 @@ static int vxlan_fdb_dump(struct sk_buff *skb, struct netlink_callback *cb,
 	for (h = 0; h < FDB_HASH_SIZE; ++h) {
 		int err;
-		hlist_for_each_entry_rcu(f, n, &vxlan->fdb_head[h], hlist) {
+		hlist_for_each_entry_rcu(f, &vxlan->fdb_head[h], hlist) {
 			if (idx < cb->args[0])
 				goto skip;
@@ -483,11 +480,10 @@ static bool vxlan_group_used(struct vxlan_net *vn,
 			     const struct vxlan_dev *this)
 	const struct vxlan_dev *vxlan;
 	unsigned h;
 	for (h = 0; h < VNI_HASH_SIZE; ++h)
-		hlist_for_each_entry(vxlan, node, &vn->vni_list[h], hlist) {
+		hlist_for_each_entry(vxlan, &vn->vni_list[h], hlist) {
 			if (vxlan == this)
 				continue;
diff --git a/drivers/net/wireless/zd1201.c b/drivers/net/wireless/zd1201.c
index 48273dd..4941f20 100644
--- a/drivers/net/wireless/zd1201.c
+++ b/drivers/net/wireless/zd1201.c
@@ -309,7 +309,6 @@ static void zd1201_usbrx(struct urb *urb)
 	if (data[urb->actual_length-1] == ZD1201_PACKET_RXDATA) {
 		int datalen = urb->actual_length-1;
 		unsigned short len, fc, seq;
 		len = ntohs(*(__be16 *)&data[datalen-2]);
 		if (len>datalen)
@@ -362,7 +361,7 @@ static void zd1201_usbrx(struct urb *urb)
 				hlist_add_head(&frag->fnode, &zd->fraglist);
 				goto resubmit;
-			hlist_for_each_entry(frag, node, &zd->fraglist, fnode)
+			hlist_for_each_entry(frag, &zd->fraglist, fnode)
 				if (frag->seq == (seq&IEEE80211_SCTL_SEQ))
 					break;
 			if (!frag)
@@ -1831,14 +1830,14 @@ err_zd:
 static void zd1201_disconnect(struct usb_interface *interface)
 	struct zd1201 *zd = usb_get_intfdata(interface);
 	struct zd1201_frag *frag;
 	if (!zd)
 		return;
 	usb_set_intfdata(interface, NULL);
-	hlist_for_each_entry_safe(frag, node, node2, &zd->fraglist, fnode) {
+	hlist_for_each_entry_safe(frag, node2, &zd->fraglist, fnode) {
 		hlist_del_init(&frag->fnode);
 		kfree_skb(frag->skb);
 		kfree(frag);
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c
index 924e466..b099e00 100644
--- a/drivers/pci/pci.c
+++ b/drivers/pci/pci.c
@@ -842,9 +842,8 @@ static struct pci_cap_saved_state *pci_find_saved_cap(
 	struct pci_dev *pci_dev, char cap)
 	struct pci_cap_saved_state *tmp;
-	hlist_for_each_entry(tmp, pos, &pci_dev->saved_cap_space, next) {
+	hlist_for_each_entry(tmp, &pci_dev->saved_cap_space, next) {
 		if (tmp->cap.cap_nr == cap)
 			return tmp;
@@ -1041,7 +1040,6 @@ struct pci_saved_state *pci_store_saved_state(struct pci_dev *dev)
 	struct pci_saved_state *state;
 	struct pci_cap_saved_data *cap;
 	size_t size;
 	if (!dev->state_saved)
@@ -1049,7 +1047,7 @@ struct pci_saved_state *pci_store_saved_state(struct pci_dev *dev)
 	size = sizeof(*state) + sizeof(struct pci_cap_saved_data);
-	hlist_for_each_entry(tmp, pos, &dev->saved_cap_space, next)
+	hlist_for_each_entry(tmp, &dev->saved_cap_space, next)
 		size += sizeof(struct pci_cap_saved_data) + tmp->cap.size;
 	state = kzalloc(size, GFP_KERNEL);
@@ -1060,7 +1058,7 @@ struct pci_saved_state *pci_store_saved_state(struct pci_dev *dev)
 	       sizeof(state->config_space));
 	cap = state->cap;
-	hlist_for_each_entry(tmp, pos, &dev->saved_cap_space, next) {
+	hlist_for_each_entry(tmp, &dev->saved_cap_space, next) {
 		size_t len = sizeof(struct pci_cap_saved_data) + tmp->cap.size;
 		memcpy(cap, &tmp->cap, len);
 		cap = (struct pci_cap_saved_data *)((u8 *)cap + len);
@@ -2038,9 +2036,9 @@ void pci_allocate_cap_save_buffers(struct pci_dev *dev)
 void pci_free_cap_save_buffers(struct pci_dev *dev)
-	struct hlist_node *pos, *n;
-	hlist_for_each_entry_safe(tmp, pos, n, &dev->saved_cap_space, next)
+	hlist_for_each_entry_safe(tmp, n, &dev->saved_cap_space, next)
 		kfree(tmp);
diff --git a/drivers/staging/android/binder.c b/drivers/staging/android/binder.c
index 538ebe2..24456a0 100644
--- a/drivers/staging/android/binder.c
+++ b/drivers/staging/android/binder.c
@@ -2880,7 +2880,6 @@ static int binder_release(struct inode *nodp, struct file *filp)
 static void binder_deferred_release(struct binder_proc *proc)
 	struct binder_transaction *t;
 	struct rb_node *n;
 	int threads, nodes, incoming_refs, outgoing_refs, buffers, active_transactions, page_count;
@@ -2924,7 +2923,7 @@ static void binder_deferred_release(struct binder_proc *proc)
 			node->local_weak_refs = 0;
 			hlist_add_head(&node->dead_node, &binder_dead_nodes);
-			hlist_for_each_entry(ref, pos, &node->refs, node_entry) {
+			hlist_for_each_entry(ref, &node->refs, node_entry) {
 				incoming_refs++;
 				if (ref->death) {
 					death++;
@@ -3156,12 +3155,11 @@ static void print_binder_thread(struct seq_file *m,
 static void print_binder_node(struct seq_file *m, struct binder_node *node)
 	struct binder_ref *ref;
 	struct binder_work *w;
 	int count;
 	count = 0;
 		count++;
 	seq_printf(m, "  node %d: u%p c%p hs %d hw %d ls %d lw %d is %d iw %d",
@@ -3171,7 +3169,7 @@ static void print_binder_node(struct seq_file *m, struct binder_node *node)
 		   node->internal_strong_refs, count);
 	if (count) {
 		seq_puts(m, " proc");
 			seq_printf(m, " %d", ref->proc->pid);
 	seq_puts(m, "\n");
@@ -3369,7 +3367,6 @@ static void print_binder_proc_stats(struct seq_file *m,
 static int binder_state_show(struct seq_file *m, void *unused)
 	struct binder_proc *proc;
 	struct binder_node *node;
 	int do_lock = !binder_debug_no_lock;
@@ -3380,10 +3377,10 @@ static int binder_state_show(struct seq_file *m, void *unused)
 	if (!hlist_empty(&binder_dead_nodes))
 		seq_puts(m, "dead nodes:\n");
-	hlist_for_each_entry(node, pos, &binder_dead_nodes, dead_node)
+	hlist_for_each_entry(node, &binder_dead_nodes, dead_node)
 		print_binder_node(m, node);
-	hlist_for_each_entry(proc, pos, &binder_procs, proc_node)
+	hlist_for_each_entry(proc, &binder_procs, proc_node)
 		print_binder_proc(m, proc, 1);
 	if (do_lock)
 		binder_unlock(__func__);
@@ -3393,7 +3390,6 @@ static int binder_state_show(struct seq_file *m, void *unused)
 static int binder_stats_show(struct seq_file *m, void *unused)
 	if (do_lock)
@@ -3403,7 +3399,7 @@ static int binder_stats_show(struct seq_file *m, void *unused)
 	print_binder_stats(m, "", &binder_stats);
 		print_binder_proc_stats(m, proc);
 	if (do_lock)
@@ -3413,14 +3409,13 @@ static int binder_stats_show(struct seq_file *m, void *unused)
 static int binder_transactions_show(struct seq_file *m, void *unused)
 	if (do_lock)
 		binder_lock(__func__);
 	seq_puts(m, "binder transactions:\n");
 		print_binder_proc(m, proc, 0);
 	if (do_lock)
diff --git a/drivers/target/tcm_fc/tfc_sess.c b/drivers/target/tcm_fc/tfc_sess.c
index 6659dd3..113f335 100644
--- a/drivers/target/tcm_fc/tfc_sess.c
+++ b/drivers/target/tcm_fc/tfc_sess.c
@@ -169,7 +169,6 @@ static struct ft_sess *ft_sess_get(struct fc_lport *lport, u32 port_id)
 	struct ft_tport *tport;
 	struct ft_sess *sess;
 	rcu_read_lock();
@@ -178,7 +177,7 @@ static struct ft_sess *ft_sess_get(struct fc_lport *lport, u32 port_id)
 		goto out;
 	head = &tport->hash[ft_sess_hash(port_id)];
-	hlist_for_each_entry_rcu(sess, pos, head, hash) {
+	hlist_for_each_entry_rcu(sess, head, hash) {
 		if (sess->port_id == port_id) {
 			kref_get(&sess->kref);
 			rcu_read_unlock();
@@ -201,10 +200,9 @@ static struct ft_sess *ft_sess_create(struct ft_tport *tport, u32 port_id,
 			return sess;
@@ -253,11 +251,10 @@ static void ft_sess_unhash(struct ft_sess *sess)
 static struct ft_sess *ft_sess_delete(struct ft_tport *tport, u32 port_id)
 			ft_sess_unhash(sess);
 			return sess;
@@ -273,12 +270,11 @@ static struct ft_sess *ft_sess_delete(struct ft_tport *tport, u32 port_id)
 static void ft_sess_delete_all(struct ft_tport *tport)
 	for (head = tport->hash;
 	     head < &tport->hash[FT_SESS_HASH_SIZE]; head++) {
 			transport_deregister_session_configfs(sess->se_sess);
 			ft_sess_put(sess);	/* release from table */
diff --git a/fs/affs/amigaffs.c b/fs/affs/amigaffs.c
index eb82ee5..d9a4367 100644
--- a/fs/affs/amigaffs.c
+++ b/fs/affs/amigaffs.c
@@ -125,9 +125,8 @@ static void
 affs_fix_dcache(struct inode *inode, u32 entry_ino)
 	struct dentry *dentry;
-	struct hlist_node *p;
 	spin_lock(&inode->i_lock);
-	hlist_for_each_entry(dentry, p, &inode->i_dentry, d_alias) {
+	hlist_for_each_entry(dentry, &inode->i_dentry, d_alias) {
 		if (entry_ino == (u32)(long)dentry->d_fsdata) {
 			dentry->d_fsdata = (void *)inode->i_ino;
 			break;
diff --git a/fs/aio.c b/fs/aio.c
index 064bfbe..3f941f2 100644
--- a/fs/aio.c
+++ b/fs/aio.c
@@ -591,11 +591,10 @@ static struct kioctx *lookup_ioctx(unsigned long ctx_id)
 	struct mm_struct *mm = current->mm;
 	struct kioctx *ctx, *ret = NULL;
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(ctx, n, &mm->ioctx_list, list) {
+	hlist_for_each_entry_rcu(ctx, &mm->ioctx_list, list) {
 		 * RCU protects us against accessing freed memory but
 		 * we have to be careful not to get a reference when the
diff --git a/fs/cifs/inode.c b/fs/cifs/inode.c
index d2a8339..83f2606 100644
--- a/fs/cifs/inode.c
+++ b/fs/cifs/inode.c
@@ -816,10 +816,9 @@ static bool
 inode_has_hashed_dentries(struct inode *inode)
 		if (!d_unhashed(dentry) || IS_ROOT(dentry)) {
 			spin_unlock(&inode->i_lock);
 			return true;
diff --git a/fs/dcache.c b/fs/dcache.c
index 68220dd..fbfae008 100644
--- a/fs/dcache.c
+++ b/fs/dcache.c
@@ -675,11 +675,10 @@ EXPORT_SYMBOL(dget_parent);
 static struct dentry *__d_find_alias(struct inode *inode, int want_discon)
 	struct dentry *alias, *discon_alias;
 again:
 	discon_alias = NULL;
-	hlist_for_each_entry(alias, p, &inode->i_dentry, d_alias) {
+	hlist_for_each_entry(alias, &inode->i_dentry, d_alias) {
 		spin_lock(&alias->d_lock);
  		if (S_ISDIR(inode->i_mode) || !d_unhashed(alias)) {
 			if (IS_ROOT(alias) &&
@@ -730,10 +729,9 @@ EXPORT_SYMBOL(d_find_alias);
 void d_prune_aliases(struct inode *inode)
 restart:
 		spin_lock(&dentry->d_lock);
 		if (!dentry->d_count) {
 			__dget_dlock(dentry);
@@ -1443,14 +1441,13 @@ static struct dentry *__d_instantiate_unique(struct dentry *entry,
 	int len = entry->d_name.len;
 	const char *name = entry->d_name.name;
 	unsigned int hash = entry->d_name.hash;
 	if (!inode) {
 		__d_instantiate(entry, NULL);
 		return NULL;
 		 * Don't need alias->d_lock here, because aliases with
 		 * d_parent == entry->d_parent are not subject to name or
diff --git a/fs/dlm/lowcomms.c b/fs/dlm/lowcomms.c
index dd87a31..4f5ad24 100644
--- a/fs/dlm/lowcomms.c
+++ b/fs/dlm/lowcomms.c
@@ -177,12 +177,11 @@ static inline int nodeid_hash(int nodeid)
 static struct connection *__find_con(int nodeid)
 	int r;
-	struct hlist_node *h;
 	struct connection *con;
 	r = nodeid_hash(nodeid);
-	hlist_for_each_entry(con, h, &connection_hash[r], list) {
+	hlist_for_each_entry(con, &connection_hash[r], list) {
 		if (con->nodeid == nodeid)
 			return con;
@@ -232,13 +231,12 @@ static struct connection *__nodeid2con(int nodeid, gfp_t alloc)
 static void foreach_conn(void (*conn_func)(struct connection *c))
 	int i;
 	for (i = 0; i < CONN_HASH_SIZE; i++) {
-		hlist_for_each_entry_safe(con, h, n, &connection_hash[i], list){
+		hlist_for_each_entry_safe(con, n, &connection_hash[i], list)
 			conn_func(con);
@@ -257,13 +255,12 @@ static struct connection *nodeid2con(int nodeid, gfp_t allocation)
 static struct connection *assoc2con(int assoc_id)
 	int i;
 	mutex_lock(&connections_lock);
 	for (i = 0 ; i < CONN_HASH_SIZE; i++) {
-		hlist_for_each_entry(con, h, &connection_hash[i], list) {
+		hlist_for_each_entry(con, &connection_hash[i], list) {
 			if (con->sctp_assoc == assoc_id) {
 				mutex_unlock(&connections_lock);
 				return con;
diff --git a/fs/ecryptfs/messaging.c b/fs/ecryptfs/messaging.c
index 5fa2471..8d7a577 100644
--- a/fs/ecryptfs/messaging.c
+++ b/fs/ecryptfs/messaging.c
@@ -115,10 +115,9 @@ void ecryptfs_msg_ctx_alloc_to_free(struct ecryptfs_msg_ctx *msg_ctx)
 int ecryptfs_find_daemon_by_euid(struct ecryptfs_daemon **daemon)
 	int rc;
-	hlist_for_each_entry(*daemon, elem,
+	hlist_for_each_entry(*daemon,
 			    &ecryptfs_daemon_hash[ecryptfs_current_euid_hash()],
 			    euid_chain) {
 		if (uid_eq((*daemon)->file->f_cred->euid, current_euid())) {
@@ -445,7 +444,6 @@ void ecryptfs_release_messaging(void)
 		mutex_unlock(&ecryptfs_msg_ctx_lists_mux);
 	if (ecryptfs_daemon_hash) {
 		struct ecryptfs_daemon *daemon;
 		int i;
@@ -453,7 +451,7 @@ void ecryptfs_release_messaging(void)
 		for (i = 0; i < (1 << ecryptfs_hash_bits); i++) {
 			int rc;
-			hlist_for_each_entry(daemon, elem,
+			hlist_for_each_entry(daemon,
 					     &ecryptfs_daemon_hash[i],
 					     euid_chain) {
 				rc = ecryptfs_exorcise_daemon(daemon);
diff --git a/fs/exportfs/expfs.c b/fs/exportfs/expfs.c
index 5df4bb4..262fc99 100644
--- a/fs/exportfs/expfs.c
+++ b/fs/exportfs/expfs.c
@@ -44,14 +44,13 @@ find_acceptable_alias(struct dentry *result,
 	struct dentry *dentry, *toput = NULL;
 	struct inode *inode;
 	if (acceptable(context, result))
 		return result;
 	inode = result->d_inode;
 		dget(dentry);
 		if (toput)
diff --git a/fs/fat/inode.c b/fs/fat/inode.c
index 780e208..acf6e47 100644
--- a/fs/fat/inode.c
+++ b/fs/fat/inode.c
@@ -341,12 +341,11 @@ struct inode *fat_iget(struct super_block *sb, loff_t i_pos)
 	struct msdos_sb_info *sbi = MSDOS_SB(sb);
 	struct hlist_head *head = sbi->inode_hashtable + fat_hash(i_pos);
-	struct hlist_node *_p;
 	struct msdos_inode_info *i;
 	struct inode *inode = NULL;
 	spin_lock(&sbi->inode_hash_lock);
-	hlist_for_each_entry(i, _p, head, i_fat_hash) {
+	hlist_for_each_entry(i, head, i_fat_hash) {
 		BUG_ON(i->vfs_inode.i_sb != sb);
 		if (i->i_pos != i_pos)
 			continue;
diff --git a/fs/fat/nfs.c b/fs/fat/nfs.c
index ef4b5fa..499c104 100644
--- a/fs/fat/nfs.c
+++ b/fs/fat/nfs.c
@@ -21,13 +21,12 @@ static struct inode *fat_dget(struct super_block *sb, int i_logstart)
 	head = sbi->dir_hashtable + fat_dir_hash(i_logstart);
 	spin_lock(&sbi->dir_hash_lock);
-	hlist_for_each_entry(i, _p, head, i_dir_hash) {
+	hlist_for_each_entry(i, head, i_dir_hash) {
 		if (i->i_logstart != i_logstart)
 			continue;
diff --git a/fs/fscache/cookie.c b/fs/fscache/cookie.c
index 8dcb114..e2cba1f 100644
--- a/fs/fscache/cookie.c
+++ b/fs/fscache/cookie.c
@@ -237,13 +237,12 @@ static int fscache_alloc_object(struct fscache_cache *cache,
 				struct fscache_cookie *cookie)
 	struct fscache_object *object;
-	struct hlist_node *_n;
 	int ret;
 	_enter("%p,%p{%s}", cache, cookie, cookie->def->name);
 	spin_lock(&cookie->lock);
-	hlist_for_each_entry(object, _n, &cookie->backing_objects,
+	hlist_for_each_entry(object, &cookie->backing_objects,
 			     cookie_link) {
 		if (object->cache == cache)
 			goto object_already_extant;
@@ -311,7 +310,6 @@ static int fscache_attach_object(struct fscache_cookie *cookie,
 	struct fscache_object *p;
 	struct fscache_cache *cache = object->cache;
 	int ret;
 	_enter("{%s},{OBJ%x}", cookie->def->name, object->debug_id);
@@ -321,7 +319,7 @@ static int fscache_attach_object(struct fscache_cookie *cookie,
 	/* there may be multiple initial creations of this object, but we only
 	 * want one */
 	ret = -EEXIST;
-	hlist_for_each_entry(p, _n, &cookie->backing_objects, cookie_link) {
+	hlist_for_each_entry(p, &cookie->backing_objects, cookie_link) {
 		if (p->cache == object->cache) {
 			if (p->state >= FSCACHE_OBJECT_DYING)
 				ret = -ENOBUFS;
@@ -331,7 +329,7 @@ static int fscache_attach_object(struct fscache_cookie *cookie,
 	/* pin the parent object */
 	spin_lock_nested(&cookie->parent->lock, 1);
-	hlist_for_each_entry(p, _n, &cookie->parent->backing_objects,
+	hlist_for_each_entry(p, &cookie->parent->backing_objects,
 			     cookie_link) {
 			if (p->state >= FSCACHE_OBJECT_DYING) {
@@ -435,7 +433,6 @@ EXPORT_SYMBOL(__fscache_wait_on_invalidate);
 void __fscache_update_cookie(struct fscache_cookie *cookie)
 	fscache_stat(&fscache_n_updates);
@@ -452,7 +449,7 @@ void __fscache_update_cookie(struct fscache_cookie *cookie)
 	/* update the index entry on disk in each cache backing this cookie */
-	hlist_for_each_entry(object, _p,
 		fscache_raise_event(object, FSCACHE_OBJECT_EV_UPDATE);
diff --git a/fs/inode.c b/fs/inode.c
index 67880e6..f5f7c06 100644
--- a/fs/inode.c
+++ b/fs/inode.c
@@ -798,11 +798,10 @@ static struct inode *find_inode(struct super_block *sb,
 				int (*test)(struct inode *, void *),
 				void *data)
 repeat:
-	hlist_for_each_entry(inode, node, head, i_hash) {
+	hlist_for_each_entry(inode, head, i_hash) {
 		if (inode->i_sb != sb) {
@@ -830,11 +829,10 @@ repeat:
 static struct inode *find_inode_fast(struct super_block *sb,
 				struct hlist_head *head, unsigned long ino)
 repeat:
 		if (inode->i_ino != ino) {
@@ -1132,11 +1130,10 @@ EXPORT_SYMBOL(iget_locked);
 static int test_inode_iunique(struct super_block *sb, unsigned long ino)
 	struct hlist_head *b = inode_hashtable + hash(sb, ino);
 	spin_lock(&inode_hash_lock);
-	hlist_for_each_entry(inode, node, b, i_hash) {
+	hlist_for_each_entry(inode, b, i_hash) {
 		if (inode->i_ino == ino && inode->i_sb == sb) {
 			spin_unlock(&inode_hash_lock);
 			return 0;
@@ -1291,10 +1288,9 @@ int insert_inode_locked(struct inode *inode)
 	struct hlist_head *head = inode_hashtable + hash(sb, ino);
 	while (1) {
 		struct inode *old = NULL;
-		hlist_for_each_entry(old, node, head, i_hash) {
+		hlist_for_each_entry(old, head, i_hash) {
 			if (old->i_ino != ino)
 				continue;
 			if (old->i_sb != sb)
@@ -1306,7 +1302,7 @@ int insert_inode_locked(struct inode *inode)
 			break;
-		if (likely(!node)) {
+		if (likely(!old)) {
 			inode->i_state |= I_NEW;
 			hlist_add_head(&inode->i_hash, head);
@@ -1334,11 +1330,10 @@ int insert_inode_locked4(struct inode *inode, unsigned long hashval,
 	struct hlist_head *head = inode_hashtable + hash(sb, hashval);
 	while (1) {
-		struct hlist_node *node;
 				continue;
 			if (!test(old, data))
@@ -1350,7 +1345,7 @@ int insert_inode_locked4(struct inode *inode, unsigned long hashval,
 			break;
diff --git a/fs/lockd/host.c b/fs/lockd/host.c
index 0e17090..abdd75d 100644
--- a/fs/lockd/host.c
+++ b/fs/lockd/host.c
@@ -32,15 +32,15 @@
 static struct hlist_head	nlm_server_hosts[NLM_HOST_NRHASH];
 static struct hlist_head	nlm_client_hosts[NLM_HOST_NRHASH];
-#define for_each_host(host, pos, chain, table) \
+#define for_each_host(host, chain, table) \
 	for ((chain) = (table); \
 	     (chain) < (table) + NLM_HOST_NRHASH; ++(chain)) \
-		hlist_for_each_entry((host), (pos), (chain), h_hash)
+		hlist_for_each_entry((host), (chain), h_hash)
-#define for_each_host_safe(host, pos, next, chain, table) \
+#define for_each_host_safe(host, next, chain, table) \
-		hlist_for_each_entry_safe((host), (pos), (next), \
+		hlist_for_each_entry_safe((host), (next), \
 						(chain), h_hash)
 static unsigned long		nrhosts;
@@ -225,7 +225,6 @@ struct nlm_host *nlmclnt_lookup_host(const struct sockaddr *sap,
 		.net		= net,
 	struct hlist_head *chain;
 	struct nlm_host	*host;
 	struct nsm_handle *nsm = NULL;
 	struct lockd_net *ln = net_generic(net, lockd_net_id);
@@ -237,7 +236,7 @@ struct nlm_host *nlmclnt_lookup_host(const struct sockaddr *sap,
 	mutex_lock(&nlm_host_mutex);
 	chain = &nlm_client_hosts[nlm_hash_address(sap)];
-	hlist_for_each_entry(host, pos, chain, h_hash) {
+	hlist_for_each_entry(host, chain, h_hash) {
 		if (host->net != net)
 			continue;
 		if (!rpc_cmp_addr(nlm_addr(host), sap))
@@ -322,7 +321,6 @@ struct nlm_host *nlmsvc_lookup_host(const struct svc_rqst *rqstp,
 				    const size_t hostname_len)
 	struct nlm_host	*host = NULL;
 	struct sockaddr *src_sap = svc_daddr(rqstp);
@@ -350,7 +348,7 @@ struct nlm_host *nlmsvc_lookup_host(const struct svc_rqst *rqstp,
 		nlm_gc_hosts(net);
 	chain = &nlm_server_hosts[nlm_hash_address(ni.sap)];
 			continue;
 		if (!rpc_cmp_addr(nlm_addr(host), ni.sap))
@@ -515,10 +513,9 @@ static struct nlm_host *next_host_state(struct hlist_head *cache,
-	for_each_host(host, pos, chain, cache) {
+	for_each_host(host, chain, cache) {
 		if (host->h_nsmhandle == nsm
 		    && host->h_nsmstate != info->state) {
 			host->h_nsmstate = info->state;
@@ -570,7 +567,6 @@ void nlm_host_rebooted(const struct nlm_reboot *info)
 static void nlm_complain_hosts(struct net *net)
 	if (net) {
@@ -587,7 +583,7 @@ static void nlm_complain_hosts(struct net *net)
 		dprintk("lockd: %lu hosts left:\n", nrhosts);
-	for_each_host(host, pos, chain, nlm_server_hosts) {
+	for_each_host(host, chain, nlm_server_hosts) {
 		if (net && host->net != net)
 			continue;
 		dprintk("       %s (cnt %d use %d exp %ld net %p)\n",
@@ -600,14 +596,13 @@ void
 nlm_shutdown_hosts_net(struct net *net)
 	/* First, make all hosts eligible for gc */
 	dprintk("lockd: nuking all hosts in net %p...\n", net);
 			continue;
 		host->h_expires = jiffies - 1;
@@ -644,11 +639,11 @@ static void
 nlm_gc_hosts(struct net *net)
-	struct hlist_node *pos, *next;
 	dprintk("lockd: host garbage collection for net %p\n", net);
 			continue;
 		host->h_inuse = 0;
@@ -657,7 +652,7 @@ nlm_gc_hosts(struct net *net)
 	/* Mark all hosts that hold locks, blocks or shares */
 	nlmsvc_mark_resources(net);
-	for_each_host_safe(host, pos, next, chain, nlm_server_hosts) {
+	for_each_host_safe(host, next, chain, nlm_server_hosts) {
 			continue;
 		if (atomic_read(&host->h_count) || host->h_inuse
diff --git a/fs/lockd/svcsubs.c b/fs/lockd/svcsubs.c
index b3a24b0..d17bb62 100644
--- a/fs/lockd/svcsubs.c
+++ b/fs/lockd/svcsubs.c
@@ -84,7 +84,6 @@ __be32
 nlm_lookup_file(struct svc_rqst *rqstp, struct nlm_file **result,
 					struct nfs_fh *f)
 	struct nlm_file	*file;
 	unsigned int	hash;
 	__be32		nfserr;
@@ -96,7 +95,7 @@ nlm_lookup_file(struct svc_rqst *rqstp, struct nlm_file **result,
 	/* Lock file table */
 	mutex_lock(&nlm_file_mutex);
-	hlist_for_each_entry(file, pos, &nlm_files[hash], f_list)
+	hlist_for_each_entry(file, &nlm_files[hash], f_list)
 		if (!nfs_compare_fh(&file->f_handle, f))
 			goto found;
@@ -248,13 +247,13 @@ static int
 nlm_traverse_files(void *data, nlm_host_match_fn_t match,
 		int (*is_failover_file)(void *data, struct nlm_file *file))
 	int i, ret = 0;
 	for (i = 0; i < FILE_NRHASH; i++) {
-		hlist_for_each_entry_safe(file, pos, next, &nlm_files[i], f_list) {
+		hlist_for_each_entry_safe(file, next, &nlm_files[i], f_list) {
 			if (is_failover_file && !is_failover_file(data, file))
 				continue;
 			file->f_count++;
diff --git a/fs/nfs/pnfs_dev.c b/fs/nfs/pnfs_dev.c
index d35b62e..6da209b 100644
--- a/fs/nfs/pnfs_dev.c
+++ b/fs/nfs/pnfs_dev.c
@@ -77,9 +77,8 @@ _lookup_deviceid(const struct pnfs_layoutdriver_type *ld,
 		 long hash)
 	struct nfs4_deviceid_node *d;
-	hlist_for_each_entry_rcu(d, n, &nfs4_deviceid_cache[hash], node)
+	hlist_for_each_entry_rcu(d, &nfs4_deviceid_cache[hash], node)
 		if (d->ld == ld && d->nfs_client == clp &&
 		    !memcmp(&d->deviceid, id, sizeof(*id))) {
 			if (atomic_read(&d->ref))
@@ -248,12 +247,11 @@ static void
 _deviceid_purge_client(const struct nfs_client *clp, long hash)
-	struct hlist_node *n;
 	HLIST_HEAD(tmp);
 	spin_lock(&nfs4_deviceid_lock);
 	rcu_read_lock();
 		if (d->nfs_client == clp && atomic_read(&d->ref)) {
 			hlist_del_init_rcu(&d->node);
 			hlist_add_head(&d->tmpnode, &tmp);
@@ -291,12 +289,11 @@ void
 nfs4_deviceid_mark_client_invalid(struct nfs_client *clp)
 	int i;
 	rcu_read_lock();
 	for (i = 0; i < NFS4_DEVICE_ID_HASH_SIZE; i ++){
-		hlist_for_each_entry_rcu(d, n, &nfs4_deviceid_cache[i], node)
+		hlist_for_each_entry_rcu(d, &nfs4_deviceid_cache[i], node)
 			if (d->nfs_client == clp)
 				set_bit(NFS_DEVICEID_INVALID, &d->flags);
diff --git a/fs/nfsd/nfscache.c b/fs/nfsd/nfscache.c
index 2cbac34..da3dbd0 100644
--- a/fs/nfsd/nfscache.c
+++ b/fs/nfsd/nfscache.c
@@ -120,7 +120,6 @@ hash_refile(struct svc_cacherep *rp)
 int
 nfsd_cache_lookup(struct svc_rqst *rqstp)
 	struct hlist_head 	*rh;
 	struct svc_cacherep	*rp;
 	__be32			xid = rqstp->rq_xid;
@@ -141,7 +140,7 @@ nfsd_cache_lookup(struct svc_rqst *rqstp)
 	rtn = RC_DOIT;
 	rh = &cache_hash[request_hash(xid)];
-	hlist_for_each_entry(rp, hn, rh, c_hash) {
+	hlist_for_each_entry(rp, rh, c_hash) {
 		if (rp->c_state != RC_UNUSED &&
 		    xid == rp->c_xid && proc == rp->c_proc &&
 		    proto == rp->c_prot && vers == rp->c_vers &&
diff --git a/fs/notify/fsnotify.c b/fs/notify/fsnotify.c
index 6baadb5..4bb21d6 100644
--- a/fs/notify/fsnotify.c
+++ b/fs/notify/fsnotify.c
@@ -52,7 +52,6 @@ void __fsnotify_vfsmount_delete(struct vfsmount *mnt)
 void __fsnotify_update_child_dentry_flags(struct inode *inode)
 	struct dentry *alias;
 	int watched;
 	if (!S_ISDIR(inode->i_mode))
@@ -64,7 +63,7 @@ void __fsnotify_update_child_dentry_flags(struct inode *inode)
 	/* run all of the dentries associated with this inode.  Since this is a
 	 * directory, there damn well better only be one item on this list */
 		struct dentry *child;
 		/* run all of the children of the original inode and fix their
diff --git a/fs/notify/inode_mark.c b/fs/notify/inode_mark.c
index f31e90f..74825be 100644
--- a/fs/notify/inode_mark.c
+++ b/fs/notify/inode_mark.c
@@ -36,12 +36,11 @@
 static void fsnotify_recalc_inode_mask_locked(struct inode *inode)
 	struct fsnotify_mark *mark;
 	__u32 new_mask = 0;
 	assert_spin_locked(&inode->i_lock);
-	hlist_for_each_entry(mark, pos, &inode->i_fsnotify_marks, i.i_list)
+	hlist_for_each_entry(mark, &inode->i_fsnotify_marks, i.i_list)
 		new_mask |= mark->mask;
 	inode->i_fsnotify_mask = new_mask;
@@ -87,11 +86,11 @@ void fsnotify_destroy_inode_mark(struct fsnotify_mark *mark)
 void fsnotify_clear_marks_by_inode(struct inode *inode)
 	struct fsnotify_mark *mark, *lmark;
 	LIST_HEAD(free_list);
-	hlist_for_each_entry_safe(mark, pos, n, &inode->i_fsnotify_marks, i.i_list) {
+	hlist_for_each_entry_safe(mark, n, &inode->i_fsnotify_marks, i.i_list) {
 		list_add(&mark->i.free_i_list, &free_list);
 		hlist_del_init_rcu(&mark->i.i_list);
 		fsnotify_get_mark(mark);
@@ -129,11 +128,10 @@ static struct fsnotify_mark *fsnotify_find_inode_mark_locked(
-	hlist_for_each_entry(mark, pos, &inode->i_fsnotify_marks, i.i_list) {
+	hlist_for_each_entry(mark, &inode->i_fsnotify_marks, i.i_list) {
 		if (mark->group == group) {
 			return mark;
@@ -194,8 +192,7 @@ int fsnotify_add_inode_mark(struct fsnotify_mark *mark,
 			    struct fsnotify_group *group, struct inode *inode,
 			    int allow_dups)
-	struct fsnotify_mark *lmark;
-	struct hlist_node *node, *last = NULL;
+	struct fsnotify_mark *lmark, *last = NULL;
 	int ret = 0;
 	mark->flags |= FSNOTIFY_MARK_FLAG_INODE;
@@ -214,8 +211,8 @@ int fsnotify_add_inode_mark(struct fsnotify_mark *mark,
 	/* should mark be in the middle of the current list? */
-	hlist_for_each_entry(lmark, node, &inode->i_fsnotify_marks, i.i_list) {
-		last = node;
+	hlist_for_each_entry(lmark, &inode->i_fsnotify_marks, i.i_list) {
+		last = lmark;
 		if ((lmark->group == group) && !allow_dups) {
 			ret = -EEXIST;
@@ -235,7 +232,7 @@ int fsnotify_add_inode_mark(struct fsnotify_mark *mark,
 	BUG_ON(last == NULL);
 	/* mark should be the last entry.  last is the current last entry */
-	hlist_add_after_rcu(last, &mark->i.i_list);
+	hlist_add_after_rcu(&last->i.i_list, &mark->i.i_list);
 out:
 	fsnotify_recalc_inode_mask_locked(inode);
diff --git a/fs/notify/vfsmount_mark.c b/fs/notify/vfsmount_mark.c
index 4df58b8..68ca5a8 100644
--- a/fs/notify/vfsmount_mark.c
+++ b/fs/notify/vfsmount_mark.c
@@ -33,12 +33,12 @@
 void fsnotify_clear_marks_by_mount(struct vfsmount *mnt)
 	struct mount *m = real_mount(mnt);
 	spin_lock(&mnt->mnt_root->d_lock);
-	hlist_for_each_entry_safe(mark, pos, n, &m->mnt_fsnotify_marks, m.m_list) {
+	hlist_for_each_entry_safe(mark, n, &m->mnt_fsnotify_marks, m.m_list) {
 		list_add(&mark->m.free_m_list, &free_list);
 		hlist_del_init_rcu(&mark->m.m_list);
@@ -71,12 +71,11 @@ static void fsnotify_recalc_vfsmount_mask_locked(struct vfsmount *mnt)
 	__u32 new_mask = 0;
 	assert_spin_locked(&mnt->mnt_root->d_lock);
-	hlist_for_each_entry(mark, pos, &m->mnt_fsnotify_marks, m.m_list)
+	hlist_for_each_entry(mark, &m->mnt_fsnotify_marks, m.m_list)
 	m->mnt_fsnotify_mask = new_mask;
@@ -114,11 +113,10 @@ static struct fsnotify_mark *fsnotify_find_vfsmount_mark_locked(struct fsnotify_
-	hlist_for_each_entry(mark, pos, &m->mnt_fsnotify_marks, m.m_list) {
+	hlist_for_each_entry(mark, &m->mnt_fsnotify_marks, m.m_list) {
 			return mark;
@@ -153,8 +151,7 @@ int fsnotify_add_vfsmount_mark(struct fsnotify_mark *mark,
 			       int allow_dups)
 	int ret = 0;
 	mark->flags |= FSNOTIFY_MARK_FLAG_VFSMOUNT;
@@ -173,8 +170,8 @@ int fsnotify_add_vfsmount_mark(struct fsnotify_mark *mark,
-	hlist_for_each_entry(lmark, node, &m->mnt_fsnotify_marks, m.m_list) {
-		last = node;
+	hlist_for_each_entry(lmark, &m->mnt_fsnotify_marks, m.m_list) {
+		last = lmark;
 			ret = -EEXIST;
@@ -194,7 +191,7 @@ int fsnotify_add_vfsmount_mark(struct fsnotify_mark *mark,
-	hlist_add_after_rcu(last, &mark->m.m_list);
+	hlist_add_after_rcu(&last->m.m_list, &mark->m.m_list);
 out:
 	fsnotify_recalc_vfsmount_mask_locked(mnt);
 	spin_unlock(&mnt->mnt_root->d_lock);
diff --git a/fs/ocfs2/dcache.c b/fs/ocfs2/dcache.c
index 8db4b58..ef99972 100644
--- a/fs/ocfs2/dcache.c
+++ b/fs/ocfs2/dcache.c
@@ -169,11 +169,10 @@ struct dentry *ocfs2_find_local_alias(struct inode *inode,
 				      u64 parent_blkno,
 				      int skip_unhashed)
 		if (ocfs2_match_dentry(dentry, parent_blkno, skip_unhashed)) {
 			trace_ocfs2_find_local_alias(dentry->d_name.len,
diff --git a/fs/ocfs2/dlm/dlmrecovery.c b/fs/ocfs2/dlm/dlmrecovery.c
index 01ebfd0..eeac97b 100644
--- a/fs/ocfs2/dlm/dlmrecovery.c
+++ b/fs/ocfs2/dlm/dlmrecovery.c
@@ -2083,7 +2083,6 @@ static void dlm_finish_local_lockres_recovery(struct dlm_ctxt *dlm,
 					      u8 dead_node, u8 new_master)
 	int i;
-	struct hlist_node *hash_iter;
 	struct dlm_lock_resource *res, *next;
@@ -2114,7 +2113,7 @@ static void dlm_finish_local_lockres_recovery(struct dlm_ctxt *dlm,
 	 * if necessary */
 	for (i = 0; i < DLM_HASH_BUCKETS; i++) {
 		bucket = dlm_lockres_hash(dlm, i);
-		hlist_for_each_entry(res, hash_iter, bucket, hash_node) {
+		hlist_for_each_entry(res, bucket, hash_node) {
 			if (!(res->state & DLM_LOCK_RES_RECOVERING))
 				continue;
@@ -2273,7 +2272,6 @@ static void dlm_free_dead_locks(struct dlm_ctxt *dlm,
 static void dlm_do_local_recovery_cleanup(struct dlm_ctxt *dlm, u8 dead_node)
-	struct hlist_node *iter;
 	struct dlm_lock_resource *res;
 	int i;
@@ -2299,7 +2297,7 @@ static void dlm_do_local_recovery_cleanup(struct dlm_ctxt *dlm, u8 dead_node)
-		hlist_for_each_entry(res, iter, bucket, hash_node) {
  			/* always prune any $RECOVERY entries for dead nodes,
  			 * otherwise hangs can occur during later recovery */
 			if (dlm_is_recovery_lock(res->lockname.name,
diff --git a/fs/super.c b/fs/super.c
index df6c2f4..7465d43 100644
--- a/fs/super.c
+++ b/fs/super.c
@@ -447,14 +447,13 @@ struct super_block *sget(struct file_system_type *type,
 			void *data)
 	struct super_block *s = NULL;
 	struct super_block *old;
 	int err;
 retry:
 	spin_lock(&sb_lock);
 	if (test) {
-		hlist_for_each_entry(old, node, &type->fs_supers, s_instances) {
+		hlist_for_each_entry(old, &type->fs_supers, s_instances) {
 				continue;
 			if (!grab_super(old))
@@ -554,10 +553,9 @@ void iterate_supers_type(struct file_system_type *type,
 	void (*f)(struct super_block *, void *), void *arg)
 	struct super_block *sb, *p = NULL;
-	hlist_for_each_entry(sb, node, &type->fs_supers, s_instances) {
+	hlist_for_each_entry(sb, &type->fs_supers, s_instances) {
 		sb->s_count++;
 		spin_unlock(&sb_lock);
diff --git a/fs/sysfs/bin.c b/fs/sysfs/bin.c
index 2ce9a5d..15c68f9 100644
--- a/fs/sysfs/bin.c
+++ b/fs/sysfs/bin.c
@@ -461,14 +461,13 @@ const struct file_operations bin_fops = {
 void unmap_bin_file(struct sysfs_dirent *attr_sd)
 	struct bin_buffer *bb;
 	if (sysfs_type(attr_sd) != SYSFS_KOBJ_BIN_ATTR)
 		return;
 	mutex_lock(&sysfs_bin_lock);
-	hlist_for_each_entry(bb, tmp, &attr_sd->s_bin_attr.buffers, list) {
+	hlist_for_each_entry(bb, &attr_sd->s_bin_attr.buffers, list) {
 		struct inode *inode = file_inode(bb->file);
 		unmap_mapping_range(inode->i_mapping, 0, 0, 1);
diff --git a/fs/xfs/xfs_log_recover.c b/fs/xfs/xfs_log_recover.c
index 96fcbb8..d1dba7c 100644
--- a/fs/xfs/xfs_log_recover.c
+++ b/fs/xfs/xfs_log_recover.c
@@ -1442,9 +1442,8 @@ xlog_recover_find_tid(
 	xlog_tid_t		tid)
 	xlog_recover_t		*trans;
-	hlist_for_each_entry(trans, n, head, r_list) {
+	hlist_for_each_entry(trans, head, r_list) {
 		if (trans->r_log_tid == tid)
 			return trans;
diff --git a/include/linux/hashtable.h b/include/linux/hashtable.h
index 227c624..a9df51f 100644
--- a/include/linux/hashtable.h
+++ b/include/linux/hashtable.h
@@ -115,51 +115,50 @@ static inline void hash_del_rcu(struct hlist_node *node)
  * hash_for_each - iterate over a hashtable
  * @name: hashtable to iterate
  * @bkt: integer to use as bucket loop cursor
- * @node: the &struct list_head to use as a loop cursor for each entry
  * @obj: the type * to use as a loop cursor for each entry
  * @member: the name of the hlist_node within the struct
-#define hash_for_each(name, bkt, node, obj, member)				\
-	for ((bkt) = 0, node = NULL; node == NULL && (bkt) < HASH_SIZE(name); (bkt)++)\
-		hlist_for_each_entry(obj, node, &name[bkt], member)
+#define hash_for_each(name, bkt, obj, member)				\
+	for ((bkt) = 0, obj = NULL; obj == NULL && (bkt) < HASH_SIZE(name);\
+			(bkt)++)\
+		hlist_for_each_entry(obj, &name[bkt], member)
  * hash_for_each_rcu - iterate over a rcu enabled hashtable
-#define hash_for_each_rcu(name, bkt, node, obj, member)				\
-		hlist_for_each_entry_rcu(obj, node, &name[bkt], member)
+#define hash_for_each_rcu(name, bkt, obj, member)			\
+			(bkt)++)\
+		hlist_for_each_entry_rcu(obj, &name[bkt], member)
  * hash_for_each_safe - iterate over a hashtable safe against removal of
  * hash entry
  * @tmp: a &struct used for temporary storage
-#define hash_for_each_safe(name, bkt, node, tmp, obj, member)			\
-		hlist_for_each_entry_safe(obj, node, tmp, &name[bkt], member)
+#define hash_for_each_safe(name, bkt, tmp, obj, member)			\
+			(bkt)++)\
+		hlist_for_each_entry_safe(obj, tmp, &name[bkt], member)
  * hash_for_each_possible - iterate over all possible objects hashing to the
  * same bucket
  * @key: the key of the objects to iterate over
-#define hash_for_each_possible(name, obj, node, member, key)			\
-	hlist_for_each_entry(obj, node,	&name[hash_min(key, HASH_BITS(name))], member)
+#define hash_for_each_possible(name, obj, member, key)			\
+	hlist_for_each_entry(obj, &name[hash_min(key, HASH_BITS(name))], member)
  * hash_for_each_possible_rcu - iterate over all possible objects hashing to the
@@ -167,25 +166,24 @@ static inline void hash_del_rcu(struct hlist_node *node)
  * in a rcu enabled hashtable
-#define hash_for_each_possible_rcu(name, obj, node, member, key)		\
-	hlist_for_each_entry_rcu(obj, node, &name[hash_min(key, HASH_BITS(name))], member)
+#define hash_for_each_possible_rcu(name, obj, member, key)		\
+	hlist_for_each_entry_rcu(obj, &name[hash_min(key, HASH_BITS(name))],\
+		member)
  * hash_for_each_possible_safe - iterate over all possible objects hashing to the
  * same bucket safe against removals
-#define hash_for_each_possible_safe(name, obj, node, tmp, member, key)		\
-	hlist_for_each_entry_safe(obj, node, tmp,				\
+#define hash_for_each_possible_safe(name, obj, tmp, member, key)	\
+	hlist_for_each_entry_safe(obj, tmp,\
diff --git a/include/linux/if_team.h b/include/linux/if_team.h
index 4648d80..cfd21e3 100644
--- a/include/linux/if_team.h
+++ b/include/linux/if_team.h
@@ -216,11 +216,10 @@ static inline struct hlist_head *team_port_index_hash(struct team *team,
 static inline struct team_port *team_get_port_by_index(struct team *team,
 						       int port_index)
 	struct team_port *port;
 	struct hlist_head *head = team_port_index_hash(team, port_index);
-	hlist_for_each_entry(port, p, head, hlist)
+	hlist_for_each_entry(port, head, hlist)
 		if (port->index == port_index)
 			return port;
 	return NULL;
@@ -228,11 +227,10 @@ static inline struct team_port *team_get_port_by_index(struct team *team,
 static inline struct team_port *team_get_port_by_index_rcu(struct team *team,
 							   int port_index)
-	hlist_for_each_entry_rcu(port, p, head, hlist)
+	hlist_for_each_entry_rcu(port, head, hlist)
 			return port;
 	return NULL;
diff --git a/include/linux/list.h b/include/linux/list.h
index cc6d2aa..d991cc1 100644
--- a/include/linux/list.h
+++ b/include/linux/list.h
@@ -666,54 +666,49 @@ static inline void hlist_move_list(struct hlist_head *old,
 	for (pos = (head)->first; pos && ({ n = pos->next; 1; }); \
 	     pos = n)
+#define hlist_entry_safe(ptr, type, member) \
+	(ptr) ? hlist_entry(ptr, type, member) : NULL
  * hlist_for_each_entry	- iterate over list of given type
- * @tpos:	the type * to use as a loop cursor.
- * @pos:	the &struct hlist_node to use as a loop cursor.
+ * @pos:	the type * to use as a loop cursor.
  * @head:	the head for your list.
  * @member:	the name of the hlist_node within the struct.
-#define hlist_for_each_entry(tpos, pos, head, member)			 \
-	for (pos = (head)->first;					 \
-	     pos &&							 \
-		({ tpos = hlist_entry(pos, typeof(*tpos), member); 1;}); \
-	     pos = pos->next)
+#define hlist_for_each_entry(pos, head, member)				\
+	for (pos = hlist_entry_safe((head)->first, typeof(*(pos)), member);\
+	     pos;							\
+	     pos = hlist_entry_safe((pos)->member.next, typeof(*(pos)), member))
  * hlist_for_each_entry_continue - iterate over a hlist continuing after current point
-#define hlist_for_each_entry_continue(tpos, pos, member)		 \
-	for (pos = (pos)->next;						 \
-	     pos &&							 \
-	     pos = pos->next)
+#define hlist_for_each_entry_continue(pos, member)			\
+	for (pos = hlist_entry_safe((pos)->member.next, typeof(*(pos)), member);\
+	     pos;							\
  * hlist_for_each_entry_from - iterate over a hlist continuing from current point
-#define hlist_for_each_entry_from(tpos, pos, member)			 \
-	for (; pos &&							 \
-	     pos = pos->next)
+#define hlist_for_each_entry_from(pos, member)				\
+	for (; pos;							\
  * hlist_for_each_entry_safe - iterate over list of given type safe against removal of list entry
  * @n:		another &struct hlist_node to use as temporary storage
-#define hlist_for_each_entry_safe(tpos, pos, n, head, member) 		 \
-	     pos && ({ n = pos->next; 1; }) && 				 \
-	     pos = n)
+#define hlist_for_each_entry_safe(pos, n, head, member) 		\
+	for (pos = hlist_entry_safe((head)->first, typeof(*pos), member);\
+	     pos && ({ n = pos->member.next; 1; });			\
+	     pos = hlist_entry_safe(n, typeof(*pos), member))
 #endif
diff --git a/include/linux/pid.h b/include/linux/pid.h
index 2381c97..a089a3c 100644
--- a/include/linux/pid.h
+++ b/include/linux/pid.h
@@ -176,9 +176,8 @@ pid_t pid_vnr(struct pid *pid);
 #define do_each_pid_task(pid, type, task)				\
 	do {								\
-		struct hlist_node *pos___;				\
 		if ((pid) != NULL)					\
-			hlist_for_each_entry_rcu((task), pos___,	\
+			hlist_for_each_entry_rcu((task),		\
 				&(pid)->tasks[type], pids[type].node) {
diff --git a/include/linux/rculist.h b/include/linux/rculist.h
index c92dd28..8089e35 100644
--- a/include/linux/rculist.h
+++ b/include/linux/rculist.h
@@ -445,8 +445,7 @@ static inline void hlist_add_after_rcu(struct hlist_node *prev,
  * hlist_for_each_entry_rcu - iterate over rcu list of given type
@@ -454,16 +453,16 @@ static inline void hlist_add_after_rcu(struct hlist_node *prev,
  * the _rcu list-mutation primitives such as hlist_add_head_rcu()
  * as long as the traversal is guarded by rcu_read_lock().
-#define hlist_for_each_entry_rcu(tpos, pos, head, member)		\
-	for (pos = rcu_dereference_raw(hlist_first_rcu(head));		\
-		pos &&							 \
-		({ tpos = hlist_entry(pos, typeof(*tpos), member); 1; }); \
-		pos = rcu_dereference_raw(hlist_next_rcu(pos)))
+#define hlist_for_each_entry_rcu(pos, head, member)			\
+	for (pos = hlist_entry_safe (rcu_dereference_raw(hlist_first_rcu(head)),\
+			typeof(*(pos)), member);			\
+		pos;							\
+		pos = hlist_entry_safe(rcu_dereference_raw(hlist_next_rcu(\
+			&(pos)->member)), typeof(*(pos)), member))
  * hlist_for_each_entry_rcu_bh - iterate over rcu list of given type
@@ -471,35 +470,36 @@ static inline void hlist_add_after_rcu(struct hlist_node *prev,
-#define hlist_for_each_entry_rcu_bh(tpos, pos, head, member)		 \
-	for (pos = rcu_dereference_bh((head)->first);			 \
-		pos &&							 \
-		pos = rcu_dereference_bh(pos->next))
+#define hlist_for_each_entry_rcu_bh(pos, head, member)			\
+	for (pos = hlist_entry_safe(rcu_dereference_bh(hlist_first_rcu(head)),\
+		pos;							\
+		pos = hlist_entry_safe(rcu_dereference_bh(hlist_next_rcu(\
  * hlist_for_each_entry_continue_rcu - iterate over a hlist continuing after current point
-#define hlist_for_each_entry_continue_rcu(tpos, pos, member)		\
-	for (pos = rcu_dereference((pos)->next);			\
-	     pos &&							\
-	     pos = rcu_dereference(pos->next))
+#define hlist_for_each_entry_continue_rcu(pos, member)			\
+	for (pos = hlist_entry_safe(rcu_dereference((pos)->member.next),\
+	     pos;							\
+	     pos = hlist_entry_safe(rcu_dereference((pos)->member.next),\
+			typeof(*(pos)), member))
  * hlist_for_each_entry_continue_rcu_bh - iterate over a hlist continuing after current point
-#define hlist_for_each_entry_continue_rcu_bh(tpos, pos, member)		\
-	for (pos = rcu_dereference_bh((pos)->next);			\
-	     pos &&							\
+#define hlist_for_each_entry_continue_rcu_bh(pos, member)		\
+	for (pos = hlist_entry_safe(rcu_dereference_bh((pos)->member.next),\
+	     pos;							\
+	     pos = hlist_entry_safe(rcu_dereference_bh((pos)->member.next),\
 #endif	/* __KERNEL__ */
diff --git a/include/net/ax25.h b/include/net/ax25.h
index 53539ac..89ed9ac 100644
--- a/include/net/ax25.h
+++ b/include/net/ax25.h
@@ -161,8 +161,8 @@ typedef struct ax25_uid_assoc {
 	ax25_address		call;
 } ax25_uid_assoc;
-#define ax25_uid_for_each(__ax25, node, list) \
-	hlist_for_each_entry(__ax25, node, list, uid_node)
+#define ax25_uid_for_each(__ax25, list) \
+	hlist_for_each_entry(__ax25, list, uid_node)
 #define ax25_uid_hold(ax25) \
 	atomic_inc(&((ax25)->refcount))
@@ -247,8 +247,8 @@ typedef struct ax25_cb {
 #define ax25_sk(__sk) ((ax25_cb *)(__sk)->sk_protinfo)
-#define ax25_for_each(__ax25, node, list) \
-	hlist_for_each_entry(__ax25, node, list, ax25_node)
+#define ax25_for_each(__ax25, list) \
+	hlist_for_each_entry(__ax25, list, ax25_node)
 #define ax25_cb_hold(__ax25) \
 	atomic_inc(&((__ax25)->refcount))
diff --git a/include/net/inet_hashtables.h b/include/net/inet_hashtables.h
index 7b2ae9d..ef83d9e 100644
--- a/include/net/inet_hashtables.h
+++ b/include/net/inet_hashtables.h
@@ -94,8 +94,8 @@ static inline struct net *ib_net(struct inet_bind_bucket *ib)
 	return read_pnet(&ib->ib_net);
-#define inet_bind_bucket_for_each(tb, pos, head) \
-	hlist_for_each_entry(tb, pos, head, node)
+#define inet_bind_bucket_for_each(tb, head) \
+	hlist_for_each_entry(tb, head, node)
 struct inet_bind_hashbucket {
 	spinlock_t		lock;
diff --git a/include/net/inet_timewait_sock.h b/include/net/inet_timewait_sock.h
index 7d658d5..f908dfc 100644
--- a/include/net/inet_timewait_sock.h
+++ b/include/net/inet_timewait_sock.h
@@ -178,11 +178,11 @@ static inline int inet_twsk_del_dead_node(struct inet_timewait_sock *tw)
 #define inet_twsk_for_each(tw, node, head) \
 	hlist_nulls_for_each_entry(tw, node, head, tw_node)
-#define inet_twsk_for_each_inmate(tw, node, jail) \
-	hlist_for_each_entry(tw, node, jail, tw_death_node)
+#define inet_twsk_for_each_inmate(tw, jail) \
+	hlist_for_each_entry(tw, jail, tw_death_node)
-#define inet_twsk_for_each_inmate_safe(tw, node, safe, jail) \
-	hlist_for_each_entry_safe(tw, node, safe, jail, tw_death_node)
+#define inet_twsk_for_each_inmate_safe(tw, safe, jail) \
+	hlist_for_each_entry_safe(tw, safe, jail, tw_death_node)
 static inline struct inet_timewait_sock *inet_twsk(const struct sock *sk)
diff --git a/include/net/netrom.h b/include/net/netrom.h
index f0793c1..121dcf8 100644
--- a/include/net/netrom.h
+++ b/include/net/netrom.h
@@ -154,17 +154,17 @@ static __inline__ void nr_node_unlock(struct nr_node *nr_node)
 	nr_node_put(nr_node);
-#define nr_neigh_for_each(__nr_neigh, node, list) \
-	hlist_for_each_entry(__nr_neigh, node, list, neigh_node)
+#define nr_neigh_for_each(__nr_neigh, list) \
+	hlist_for_each_entry(__nr_neigh, list, neigh_node)
-#define nr_neigh_for_each_safe(__nr_neigh, node, node2, list) \
-	hlist_for_each_entry_safe(__nr_neigh, node, node2, list, neigh_node)
+#define nr_neigh_for_each_safe(__nr_neigh, node2, list) \
+	hlist_for_each_entry_safe(__nr_neigh, node2, list, neigh_node)
-#define nr_node_for_each(__nr_node, node, list) \
-	hlist_for_each_entry(__nr_node, node, list, node_node)
+#define nr_node_for_each(__nr_node, list) \
+	hlist_for_each_entry(__nr_node, list, node_node)
-#define nr_node_for_each_safe(__nr_node, node, node2, list) \
-	hlist_for_each_entry_safe(__nr_node, node, node2, list, node_node)
+#define nr_node_for_each_safe(__nr_node, node2, list) \
+	hlist_for_each_entry_safe(__nr_node, node2, list, node_node)
diff --git a/include/net/sch_generic.h b/include/net/sch_generic.h
index 2761c90..f10818f 100644
--- a/include/net/sch_generic.h
+++ b/include/net/sch_generic.h
@@ -339,11 +339,10 @@ static inline struct Qdisc_class_common *
 qdisc_class_find(const struct Qdisc_class_hash *hash, u32 id)
 	struct Qdisc_class_common *cl;
 	unsigned int h;
 	h = qdisc_class_hash(id, hash->hashmask);
-	hlist_for_each_entry(cl, n, &hash->hash[h], hnode) {
+	hlist_for_each_entry(cl, &hash->hash[h], hnode) {
 		if (cl->classid == id)
 			return cl;
diff --git a/include/net/sctp/sctp.h b/include/net/sctp/sctp.h
index 7fdf298..df85a0c 100644
--- a/include/net/sctp/sctp.h
+++ b/include/net/sctp/sctp.h
@@ -675,8 +675,8 @@ static inline int sctp_vtag_hashfn(__u16 lport, __u16 rport, __u32 vtag)
 	return h & (sctp_assoc_hashsize - 1);
-#define sctp_for_each_hentry(epb, node, head) \
-	hlist_for_each_entry(epb, node, head, node)
+#define sctp_for_each_hentry(epb, head) \
+	hlist_for_each_entry(epb, head, node)
 /* Is a socket of this style? */
 #define sctp_style(sk, style) __sctp_style((sk), (SCTP_SOCKET_##style))
diff --git a/include/net/sock.h b/include/net/sock.h
index a66caa2..14f6e9d 100644
--- a/include/net/sock.h
+++ b/include/net/sock.h
@@ -606,24 +606,23 @@ static inline void sk_add_bind_node(struct sock *sk,
 	hlist_add_head(&sk->sk_bind_node, list);
-#define sk_for_each(__sk, node, list) \
-	hlist_for_each_entry(__sk, node, list, sk_node)
-#define sk_for_each_rcu(__sk, node, list) \
-	hlist_for_each_entry_rcu(__sk, node, list, sk_node)
+#define sk_for_each(__sk, list) \
+	hlist_for_each_entry(__sk, list, sk_node)
+#define sk_for_each_rcu(__sk, list) \
+	hlist_for_each_entry_rcu(__sk, list, sk_node)
 #define sk_nulls_for_each(__sk, node, list) \
 	hlist_nulls_for_each_entry(__sk, node, list, sk_nulls_node)
 #define sk_nulls_for_each_rcu(__sk, node, list) \
 	hlist_nulls_for_each_entry_rcu(__sk, node, list, sk_nulls_node)
-#define sk_for_each_from(__sk, node) \
-	if (__sk && ({ node = &(__sk)->sk_node; 1; })) \
-		hlist_for_each_entry_from(__sk, node, sk_node)
+#define sk_for_each_from(__sk) \
+	hlist_for_each_entry_from(__sk, sk_node)
 #define sk_nulls_for_each_from(__sk, node) \
 	if (__sk && ({ node = &(__sk)->sk_nulls_node; 1; })) \
 		hlist_nulls_for_each_entry_from(__sk, node, sk_nulls_node)
-#define sk_for_each_safe(__sk, node, tmp, list) \
-	hlist_for_each_entry_safe(__sk, node, tmp, list, sk_node)
-#define sk_for_each_bound(__sk, node, list) \
-	hlist_for_each_entry(__sk, node, list, sk_bind_node)
+#define sk_for_each_safe(__sk, tmp, list) \
+	hlist_for_each_entry_safe(__sk, tmp, list, sk_node)
+#define sk_for_each_bound(__sk, list) \
+	hlist_for_each_entry(__sk, list, sk_bind_node)
 static inline struct user_namespace *sk_user_ns(struct sock *sk)
diff --git a/kernel/cgroup.c b/kernel/cgroup.c
index 40e0df6..a32f943 100644
--- a/kernel/cgroup.c
+++ b/kernel/cgroup.c
@@ -554,7 +554,6 @@ static struct css_set *find_existing_css_set(
 	int i;
 	struct cgroupfs_root *root = cgrp->root;
 	struct css_set *cg;
 	unsigned long key;
@@ -577,7 +576,7 @@ static struct css_set *find_existing_css_set(
 	key = css_set_hash(template);
-	hash_for_each_possible(css_set_table, cg, node, hlist, key) {
+	hash_for_each_possible(css_set_table, cg, hlist, key) {
 		if (!compare_css_sets(cg, oldcg, cgrp, template))
 			continue;
@@ -1611,7 +1610,6 @@ static struct dentry *cgroup_mount(struct file_system_type *fs_type,
 		struct cgroupfs_root *existing_root;
 		const struct cred *cred;
 		int i;
 		struct css_set *cg;
 		BUG_ON(sb->s_root != NULL);
@@ -1666,7 +1664,7 @@ static struct dentry *cgroup_mount(struct file_system_type *fs_type,
 		/* Link the top cgroup in this hierarchy into all
 		 * the css_set objects */
 		write_lock(&css_set_lock);
-		hash_for_each(css_set_table, i, node, cg, hlist)
+		hash_for_each(css_set_table, i, cg, hlist)
 			link_css_set(&tmp_cg_links, cg, root_cgrp);
 		write_unlock(&css_set_lock);
@@ -4493,7 +4491,7 @@ int __init_or_module cgroup_load_subsys(struct cgroup_subsys *ss)
 	struct cgroup_subsys_state *css;
 	int i, ret;
-	struct hlist_node *node, *tmp;
+	struct hlist_node *tmp;
 	struct css_set *cg;
 	unsigned long key;
@@ -4561,7 +4559,7 @@ int __init_or_module cgroup_load_subsys(struct cgroup_subsys *ss)
 	 * this is all done under the css_set_lock.
-	hash_for_each_safe(css_set_table, i, node, tmp, cg, hlist) {
+	hash_for_each_safe(css_set_table, i, tmp, cg, hlist) {
 		/* skip entries that we already rehashed */
 		if (cg->subsys[ss->subsys_id])
 			continue;
@@ -4571,7 +4569,7 @@ int __init_or_module cgroup_load_subsys(struct cgroup_subsys *ss)
 		cg->subsys[ss->subsys_id] = css;
 		/* recompute hash and restore entry */
 		key = css_set_hash(cg->subsys);
-		hash_add(css_set_table, node, key);
+		hash_add(css_set_table, &cg->hlist, key);
diff --git a/kernel/events/core.c b/kernel/events/core.c
index 5a92cf6..b0cd865 100644
--- a/kernel/events/core.c
+++ b/kernel/events/core.c
@@ -5126,7 +5126,6 @@ static void do_perf_sw_event(enum perf_type_id type, u32 event_id,
 	struct swevent_htable *swhash = &__get_cpu_var(swevent_htable);
 	struct perf_event *event;
 	struct hlist_head *head;
 	rcu_read_lock();
@@ -5134,7 +5133,7 @@ static void do_perf_sw_event(enum perf_type_id type, u32 event_id,
 	if (!head)
 		goto end;
-	hlist_for_each_entry_rcu(event, node, head, hlist_entry) {
+	hlist_for_each_entry_rcu(event, head, hlist_entry) {
 		if (perf_swevent_match(event, type, event_id, data, regs))
 			perf_swevent_event(event, nr, data, regs);
@@ -5419,7 +5418,6 @@ void perf_tp_event(u64 addr, u64 count, void *record, int entry_size,
 	struct perf_sample_data data;
 	struct perf_raw_record raw = {
 		.size = entry_size,
@@ -5429,7 +5427,7 @@ void perf_tp_event(u64 addr, u64 count, void *record, int entry_size,
 	perf_sample_data_init(&data, addr, 0);
 	data.raw = &raw;
 		if (perf_tp_event_match(event, &data, regs))
 			perf_swevent_event(event, count, &data, regs);
diff --git a/kernel/kprobes.c b/kernel/kprobes.c
index 550294d..e35be53 100644
--- a/kernel/kprobes.c
+++ b/kernel/kprobes.c
@@ -334,11 +334,10 @@ static inline void reset_kprobe_instance(void)
 struct kprobe __kprobes *get_kprobe(void *addr)
 	struct kprobe *p;
 	head = &kprobe_table[hash_ptr(addr, KPROBE_HASH_BITS)];
-	hlist_for_each_entry_rcu(p, node, head, hlist) {
+	hlist_for_each_entry_rcu(p, head, hlist) {
 		if (p->addr == addr)
 			return p;
@@ -799,7 +798,6 @@ out:
 static void __kprobes optimize_all_kprobes(void)
 	struct kprobe *p;
 	unsigned int i;
@@ -810,7 +808,7 @@ static void __kprobes optimize_all_kprobes(void)
 	kprobes_allow_optimization = true;
 	for (i = 0; i < KPROBE_TABLE_SIZE; i++) {
 		head = &kprobe_table[i];
 			if (!kprobe_disabled(p))
 				optimize_kprobe(p);
@@ -821,7 +819,6 @@ static void __kprobes optimize_all_kprobes(void)
 static void __kprobes unoptimize_all_kprobes(void)
 	struct kprobe *p;
 	unsigned int i;
@@ -832,7 +829,7 @@ static void __kprobes unoptimize_all_kprobes(void)
 	kprobes_allow_optimization = false;
 				unoptimize_kprobe(p, false);
@@ -1148,7 +1145,7 @@ void __kprobes kprobe_flush_task(struct task_struct *tk)
 	struct kretprobe_instance *ri;
 	struct hlist_head *head, empty_rp;
 	unsigned long hash, flags = 0;
 	if (unlikely(!kprobes_initialized))
@@ -1159,12 +1156,12 @@ void __kprobes kprobe_flush_task(struct task_struct *tk)
 	hash = hash_ptr(tk, KPROBE_HASH_BITS);
 	head = &kretprobe_inst_table[hash];
 	kretprobe_table_lock(hash, &flags);
-	hlist_for_each_entry_safe(ri, node, tmp, head, hlist) {
+	hlist_for_each_entry_safe(ri, tmp, head, hlist) {
 		if (ri->task == tk)
 			recycle_rp_inst(ri, &empty_rp);
 	kretprobe_table_unlock(hash, &flags);
-	hlist_for_each_entry_safe(ri, node, tmp, &empty_rp, hlist) {
+	hlist_for_each_entry_safe(ri, tmp, &empty_rp, hlist) {
 		hlist_del(&ri->hlist);
 		kfree(ri);
@@ -1173,9 +1170,9 @@ void __kprobes kprobe_flush_task(struct task_struct *tk)
 static inline void free_rp_inst(struct kretprobe *rp)
+	struct hlist_node *next;
-	hlist_for_each_entry_safe(ri, pos, next, &rp->free_instances, hlist) {
+	hlist_for_each_entry_safe(ri, next, &rp->free_instances, hlist) {
 		kfree(ri);
@@ -1185,14 +1182,14 @@ static void __kprobes cleanup_rp_inst(struct kretprobe *rp)
 	unsigned long flags, hash;
 	/* No race here */
 	for (hash = 0; hash < KPROBE_TABLE_SIZE; hash++) {
-		hlist_for_each_entry_safe(ri, pos, next, head, hlist) {
+		hlist_for_each_entry_safe(ri, next, head, hlist) {
 			if (ri->rp == rp)
 				ri->rp = NULL;
@@ -2028,7 +2025,6 @@ static int __kprobes kprobes_module_callback(struct notifier_block *nb,
 	struct module *mod = data;
 	struct kprobe *p;
 	unsigned int i;
 	int checkcore = (val == MODULE_STATE_GOING);
@@ -2045,7 +2041,7 @@ static int __kprobes kprobes_module_callback(struct notifier_block *nb,
 	mutex_lock(&kprobe_mutex);
 			if (within_module_init((unsigned long)p->addr, mod) ||
 			    (checkcore &&
 			     within_module_core((unsigned long)p->addr, mod))) {
@@ -2192,7 +2188,6 @@ static void __kprobes kprobe_seq_stop(struct seq_file *f, void *v)
 static int __kprobes show_kprobe_addr(struct seq_file *pi, void *v)
 	struct kprobe *p, *kp;
 	const char *sym = NULL;
 	unsigned int i = *(loff_t *) v;
@@ -2201,7 +2196,7 @@ static int __kprobes show_kprobe_addr(struct seq_file *pi, void *v)
 	preempt_disable();
 		sym = kallsyms_lookup((unsigned long)p->addr, NULL,
 					&offset, &modname, namebuf);
 		if (kprobe_aggrprobe(p)) {
@@ -2236,7 +2231,6 @@ static const struct file_operations debugfs_kprobes_operations = {
 static void __kprobes arm_all_kprobes(void)
 	struct kprobe *p;
 	unsigned int i;
@@ -2249,7 +2243,7 @@ static void __kprobes arm_all_kprobes(void)
 	/* Arming kprobes doesn't optimize kprobe itself */
 				arm_kprobe(p);
@@ -2265,7 +2259,6 @@ already_enabled:
 static void __kprobes disarm_all_kprobes(void)
 	struct kprobe *p;
 	unsigned int i;
@@ -2282,7 +2275,7 @@ static void __kprobes disarm_all_kprobes(void)
 			if (!arch_trampoline_kprobe(p) && !kprobe_disabled(p))
 				disarm_kprobe(p, false);
diff --git a/kernel/pid.c b/kernel/pid.c
index f2c6a68..047dc62 100644
--- a/kernel/pid.c
+++ b/kernel/pid.c
@@ -350,10 +350,9 @@ void disable_pid_allocation(struct pid_namespace *ns)
 struct pid *find_pid_ns(int nr, struct pid_namespace *ns)
-	struct hlist_node *elem;
 	struct upid *pnr;
-	hlist_for_each_entry_rcu(pnr, elem,
+	hlist_for_each_entry_rcu(pnr,
 			&pid_hash[pid_hashfn(nr, ns)], pid_chain)
 		if (pnr->nr == nr && pnr->ns == ns)
 			return container_of(pnr, struct pid,
diff --git a/kernel/sched/core.c b/kernel/sched/core.c
index 2b52431..12af427 100644
--- a/kernel/sched/core.c
+++ b/kernel/sched/core.c
@@ -1752,9 +1752,8 @@ EXPORT_SYMBOL_GPL(preempt_notifier_unregister);
 static void fire_sched_in_preempt_notifiers(struct task_struct *curr)
 	struct preempt_notifier *notifier;
-	hlist_for_each_entry(notifier, node, &curr->preempt_notifiers, link)
+	hlist_for_each_entry(notifier, &curr->preempt_notifiers, link)
 		notifier->ops->sched_in(notifier, raw_smp_processor_id());
@@ -1763,9 +1762,8 @@ fire_sched_out_preempt_notifiers(struct task_struct *curr,
 				 struct task_struct *next)
 		notifier->ops->sched_out(notifier, next);
diff --git a/kernel/smpboot.c b/kernel/smpboot.c
index d4abac2..b9bde57 100644
--- a/kernel/smpboot.c
+++ b/kernel/smpboot.c
@@ -131,7 +131,7 @@ static int smpboot_thread_fn(void *data)
 			continue;
-		BUG_ON(td->cpu != smp_processor_id());
+		//BUG_ON(td->cpu != smp_processor_id());
 		/* Check for state change setup */
 		switch (td->status) {
diff --git a/kernel/trace/ftrace.c b/kernel/trace/ftrace.c
index 98ca94a..ab25b88 100644
--- a/kernel/trace/ftrace.c
+++ b/kernel/trace/ftrace.c
@@ -762,7 +762,6 @@ ftrace_find_profiled_func(struct ftrace_profile_stat *stat, unsigned long ip)
 	struct ftrace_profile *rec;
 	struct hlist_head *hhd;
 	unsigned long key;
 	key = hash_long(ip, ftrace_profile_bits);
@@ -771,7 +770,7 @@ ftrace_find_profiled_func(struct ftrace_profile_stat *stat, unsigned long ip)
 	if (hlist_empty(hhd))
 		return NULL;
-	hlist_for_each_entry_rcu(rec, n, hhd, node) {
+	hlist_for_each_entry_rcu(rec, hhd, node) {
 		if (rec->ip == ip)
 			return rec;
@@ -1133,7 +1132,6 @@ ftrace_lookup_ip(struct ftrace_hash *hash, unsigned long ip)
 	unsigned long key;
 	struct ftrace_func_entry *entry;
 	if (ftrace_hash_empty(hash))
 		return NULL;
@@ -1145,7 +1143,7 @@ ftrace_lookup_ip(struct ftrace_hash *hash, unsigned long ip)
 	hhd = &hash->buckets[key];
-	hlist_for_each_entry_rcu(entry, n, hhd, hlist) {
+	hlist_for_each_entry_rcu(entry, hhd, hlist) {
 		if (entry->ip == ip)
 			return entry;
@@ -1202,7 +1200,7 @@ remove_hash_entry(struct ftrace_hash *hash,
 static void ftrace_hash_clear(struct ftrace_hash *hash)
-	struct hlist_node *tp, *tn;
+	struct hlist_node *tn;
 	int size = 1 << hash->size_bits;
 	int i;
@@ -1212,7 +1210,7 @@ static void ftrace_hash_clear(struct ftrace_hash *hash)
 	for (i = 0; i < size; i++) {
 		hhd = &hash->buckets[i];
-		hlist_for_each_entry_safe(entry, tp, tn, hhd, hlist)
+		hlist_for_each_entry_safe(entry, tn, hhd, hlist)
 			free_hash_entry(hash, entry);
 	FTRACE_WARN_ON(hash->count);
@@ -1275,7 +1273,6 @@ alloc_and_copy_ftrace_hash(int size_bits, struct ftrace_hash *hash)
 	struct ftrace_hash *new_hash;
-	struct hlist_node *tp;
 	int size;
 	int ret;
 	int i;
@@ -1290,7 +1287,7 @@ alloc_and_copy_ftrace_hash(int size_bits, struct ftrace_hash *hash)
-		hlist_for_each_entry(entry, tp, &hash->buckets[i], hlist) {
+		hlist_for_each_entry(entry, &hash->buckets[i], hlist) {
 			ret = add_hash_entry(new_hash, entry->ip);
 			if (ret < 0)
 				goto free_hash;
@@ -1316,7 +1313,7 @@ ftrace_hash_move(struct ftrace_ops *ops, int enable,
 		 struct ftrace_hash **dst, struct ftrace_hash *src)
 	struct ftrace_hash *old_hash;
@@ -1362,7 +1359,7 @@ ftrace_hash_move(struct ftrace_ops *ops, int enable,
 	size = 1 << src->size_bits;
 		hhd = &src->buckets[i];
-		hlist_for_each_entry_safe(entry, tp, tn, hhd, hlist) {
+		hlist_for_each_entry_safe(entry, tn, hhd, hlist) {
 			if (bits > 0)
 				key = hash_long(entry->ip, bits);
 			else
@@ -2901,7 +2898,6 @@ static void function_trace_probe_call(unsigned long ip, unsigned long parent_ip,
 	struct ftrace_func_probe *entry;
 	unsigned long key;
 	key = hash_long(ip, FTRACE_HASH_BITS);
@@ -2917,7 +2913,7 @@ static void function_trace_probe_call(unsigned long ip, unsigned long parent_ip,
 	 * on the hash. rcu_read_lock is too dangerous here.
 	preempt_disable_notrace();
-	hlist_for_each_entry_rcu(entry, n, hhd, node) {
+	hlist_for_each_entry_rcu(entry, hhd, node) {
 			entry->ops->func(ip, parent_ip, &entry->data);
@@ -3068,7 +3064,7 @@ __unregister_ftrace_function_probe(char *glob, struct ftrace_probe_ops *ops,
 				  void *data, int flags)
-	struct hlist_node *n, *tmp;
 	char str[KSYM_SYMBOL_LEN];
 	int type = MATCH_FULL;
 	int i, len = 0;
@@ -3091,7 +3087,7 @@ __unregister_ftrace_function_probe(char *glob, struct ftrace_probe_ops *ops,
 	for (i = 0; i < FTRACE_FUNC_HASHSIZE; i++) {
 		struct hlist_head *hhd = &ftrace_func_hash[i];
-		hlist_for_each_entry_safe(entry, n, tmp, hhd, node) {
+		hlist_for_each_entry_safe(entry, tmp, hhd, node) {
 			/* break up if statements for readability */
 			if ((flags & PROBE_TEST_FUNC) && entry->ops != ops)
diff --git a/kernel/trace/trace_output.c b/kernel/trace/trace_output.c
index 194d796..697e88d 100644
--- a/kernel/trace/trace_output.c
+++ b/kernel/trace/trace_output.c
@@ -739,12 +739,11 @@ static int task_state_char(unsigned long state)
 struct trace_event *ftrace_find_event(int type)
 	struct trace_event *event;
 	unsigned key;
 	key = type & (EVENT_HASHSIZE - 1);
-	hlist_for_each_entry(event, n, &event_hash[key], node) {
+	hlist_for_each_entry(event, &event_hash[key], node) {
 		if (event->type == type)
 			return event;
diff --git a/kernel/tracepoint.c b/kernel/tracepoint.c
index d96ba22..0c05a45 100644
--- a/kernel/tracepoint.c
+++ b/kernel/tracepoint.c
@@ -192,12 +192,11 @@ tracepoint_entry_remove_probe(struct tracepoint_entry *entry,
 static struct tracepoint_entry *get_tracepoint(const char *name)
 	struct tracepoint_entry *e;
 	u32 hash = jhash(name, strlen(name), 0);
 	head = &tracepoint_table[hash & (TRACEPOINT_TABLE_SIZE - 1)];
-	hlist_for_each_entry(e, node, head, hlist) {
+	hlist_for_each_entry(e, head, hlist) {
 		if (!strcmp(name, e->name))
 			return e;
@@ -211,13 +210,12 @@ static struct tracepoint_entry *get_tracepoint(const char *name)
 static struct tracepoint_entry *add_tracepoint(const char *name)
 	size_t name_len = strlen(name) + 1;
 	u32 hash = jhash(name, name_len-1, 0);
 		if (!strcmp(name, e->name)) {
 			printk(KERN_NOTICE
 				"tracepoint %s busy\n", name);
diff --git a/kernel/user-return-notifier.c b/kernel/user-return-notifier.c
index 1744bb8..394f70b 100644
--- a/kernel/user-return-notifier.c
+++ b/kernel/user-return-notifier.c
@@ -34,11 +34,11 @@ EXPORT_SYMBOL_GPL(user_return_notifier_unregister);
 void fire_user_return_notifiers(void)
 	struct user_return_notifier *urn;
-	struct hlist_node *tmp1, *tmp2;
+	struct hlist_node *tmp2;
 	head = &get_cpu_var(return_notifier_list);
-	hlist_for_each_entry_safe(urn, tmp1, tmp2, head, link)
+	hlist_for_each_entry_safe(urn, tmp2, head, link)
 		urn->on_user_return(urn);
 	put_cpu_var(return_notifier_list);
diff --git a/kernel/user.c b/kernel/user.c
index 57ebfd4..e81978e 100644
--- a/kernel/user.c
+++ b/kernel/user.c
@@ -105,9 +105,8 @@ static void uid_hash_remove(struct user_struct *up)
 static struct user_struct *uid_hash_find(kuid_t uid, struct hlist_head *hashent)
 	struct user_struct *user;
-	hlist_for_each_entry(user, h, hashent, uidhash_node) {
+	hlist_for_each_entry(user, hashent, uidhash_node) {
 		if (uid_eq(user->uid, uid)) {
 			atomic_inc(&user->__count);
 			return user;
diff --git a/kernel/workqueue.c b/kernel/workqueue.c
index f4feaca..81f2457 100644
--- a/kernel/workqueue.c
+++ b/kernel/workqueue.c
@@ -251,8 +251,8 @@ EXPORT_SYMBOL_GPL(system_freezable_wq);
 	for ((pool) = &std_worker_pools(cpu)[0];			\
 	     (pool) < &std_worker_pools(cpu)[NR_STD_WORKER_POOLS]; (pool)++)
-#define for_each_busy_worker(worker, i, pos, pool)			\
-	hash_for_each(pool->busy_hash, i, pos, worker, hentry)
+#define for_each_busy_worker(worker, i, pool)				\
+	hash_for_each(pool->busy_hash, i, worker, hentry)
 static inline int __next_wq_cpu(int cpu, const struct cpumask *mask,
 				unsigned int sw)
@@ -909,9 +909,8 @@ static struct worker *find_worker_executing_work(struct worker_pool *pool,
 						 struct work_struct *work)
 	struct worker *worker;
-	struct hlist_node *tmp;
-	hash_for_each_possible(pool->busy_hash, worker, tmp, hentry,
+	hash_for_each_possible(pool->busy_hash, worker, hentry,
 			       (unsigned long)work)
 		if (worker->current_work == work &&
 		    worker->current_func == work->func)
@@ -1626,7 +1625,6 @@ static void busy_worker_rebind_fn(struct work_struct *work)
 static void rebind_workers(struct worker_pool *pool)
 	struct worker *worker, *n;
-	struct hlist_node *pos;
 	int i;
 	lockdep_assert_held(&pool->assoc_mutex);
@@ -1648,7 +1646,7 @@ static void rebind_workers(struct worker_pool *pool)
 	/* rebind busy workers */
-	for_each_busy_worker(worker, i, pos, pool) {
+	for_each_busy_worker(worker, i, pool) {
 		struct work_struct *rebind_work = &worker->rebind_work;
 		struct workqueue_struct *wq;
@@ -3423,7 +3421,6 @@ static void wq_unbind_fn(struct work_struct *work)
 	int cpu = smp_processor_id();
 	struct worker_pool *pool;
 	int i;
 	for_each_std_worker_pool(pool, cpu) {
@@ -3442,7 +3439,7 @@ static void wq_unbind_fn(struct work_struct *work)
 		list_for_each_entry(worker, &pool->idle_list, entry)
 			worker->flags |= WORKER_UNBOUND;
 		pool->flags |= POOL_DISASSOCIATED;
diff --git a/lib/debugobjects.c b/lib/debugobjects.c
index d11808c..37061ed 100644
--- a/lib/debugobjects.c
+++ b/lib/debugobjects.c
@@ -109,11 +109,10 @@ static void fill_pool(void)
 static struct debug_obj *lookup_object(void *addr, struct debug_bucket *b)
 	struct debug_obj *obj;
 	int cnt = 0;
-	hlist_for_each_entry(obj, node, &b->list, node) {
+	hlist_for_each_entry(obj, &b->list, node) {
 		cnt++;
 		if (obj->object == addr)
 			return obj;
@@ -213,7 +212,7 @@ static void free_object(struct debug_obj *obj)
 static void debug_objects_oom(void)
 	struct debug_bucket *db = obj_hash;
 	HLIST_HEAD(freelist);
 	unsigned long flags;
@@ -227,7 +226,7 @@ static void debug_objects_oom(void)
 		raw_spin_unlock_irqrestore(&db->lock, flags);
 		/* Now free them */
-		hlist_for_each_entry_safe(obj, node, tmp, &freelist, node) {
+		hlist_for_each_entry_safe(obj, tmp, &freelist, node) {
 			hlist_del(&obj->node);
 			free_object(obj);
@@ -658,7 +657,7 @@ debug_object_active_state(void *addr, struct debug_obj_descr *descr,
 static void __debug_check_no_obj_freed(const void *address, unsigned long size)
 	unsigned long flags, oaddr, saddr, eaddr, paddr, chunks;
 	struct debug_obj_descr *descr;
 	enum debug_obj_state state;
@@ -678,7 +677,7 @@ static void __debug_check_no_obj_freed(const void *address, unsigned long size)
 repeat:
 		cnt = 0;
 		raw_spin_lock_irqsave(&db->lock, flags);
-		hlist_for_each_entry_safe(obj, node, tmp, &db->list, node) {
+		hlist_for_each_entry_safe(obj, tmp, &db->list, node) {
 			cnt++;
 			oaddr = (unsigned long) obj->object;
 			if (oaddr < saddr || oaddr >= eaddr)
@@ -702,7 +701,7 @@ repeat:
 		/* Now free them */
 			free_object(obj);
@@ -1013,7 +1012,7 @@ void __init debug_objects_early_init(void)
 static int __init debug_objects_replace_static_objects(void)
 	struct debug_obj *obj, *new;
 	HLIST_HEAD(objects);
 	int i, cnt = 0;
@@ -1033,7 +1032,7 @@ static int __init debug_objects_replace_static_objects(void)
 	local_irq_disable();
 	/* Remove the statically allocated objects from the pool */
-	hlist_for_each_entry_safe(obj, node, tmp, &obj_pool, node)
+	hlist_for_each_entry_safe(obj, tmp, &obj_pool, node)
 	/* Move the allocated objects to the pool */
 	hlist_move_list(&objects, &obj_pool);
@@ -1042,7 +1041,7 @@ static int __init debug_objects_replace_static_objects(void)
 	for (i = 0; i < ODEBUG_HASH_SIZE; i++, db++) {
 		hlist_move_list(&db->list, &objects);
-		hlist_for_each_entry(obj, node, &objects, node) {
+		hlist_for_each_entry(obj, &objects, node) {
 			new = hlist_entry(obj_pool.first, typeof(*obj), node);
 			hlist_del(&new->node);
 			/* copy object data */
@@ -1057,7 +1056,7 @@ static int __init debug_objects_replace_static_objects(void)
 	       obj_pool_used);
 	return 0;
 free:
-	hlist_for_each_entry_safe(obj, node, tmp, &objects, node) {
+	hlist_for_each_entry_safe(obj, tmp, &objects, node) {
 		kmem_cache_free(obj_cache, obj);
diff --git a/lib/lru_cache.c b/lib/lru_cache.c
index d71d894..8335d39 100644
--- a/lib/lru_cache.c
+++ b/lib/lru_cache.c
@@ -262,12 +262,11 @@ static struct hlist_head *lc_hash_slot(struct lru_cache *lc, unsigned int enr)
 static struct lc_element *__lc_find(struct lru_cache *lc, unsigned int enr,
 		bool include_changing)
 	struct lc_element *e;
 	BUG_ON(!lc);
 	BUG_ON(!lc->nr_elements);
-	hlist_for_each_entry(e, n, lc_hash_slot(lc, enr), colision) {
+	hlist_for_each_entry(e, lc_hash_slot(lc, enr), colision) {
 		/* "about to be changed" elements, pending transaction commit,
 		 * are hashed by their "new number". "Normal" elements have
 		 * lc_number == lc_new_number. */
diff --git a/mm/huge_memory.c b/mm/huge_memory.c
index bfa142e..e2f7f5aa 100644
--- a/mm/huge_memory.c
+++ b/mm/huge_memory.c
@@ -1906,9 +1906,8 @@ static inline void free_mm_slot(struct mm_slot *mm_slot)
 static struct mm_slot *get_mm_slot(struct mm_struct *mm)
 	struct mm_slot *mm_slot;
-	hash_for_each_possible(mm_slots_hash, mm_slot, node, hash, (unsigned long)mm)
+	hash_for_each_possible(mm_slots_hash, mm_slot, hash, (unsigned long)mm)
 		if (mm == mm_slot->mm)
 			return mm_slot;
diff --git a/mm/kmemleak.c b/mm/kmemleak.c
index 83dd5fb..c8d7f31 100644
--- a/mm/kmemleak.c
+++ b/mm/kmemleak.c
@@ -436,7 +436,7 @@ static int get_object(struct kmemleak_object *object)
 static void free_object_rcu(struct rcu_head *rcu)
-	struct hlist_node *elem, *tmp;
 	struct kmemleak_scan_area *area;
 	struct kmemleak_object *object =
 		container_of(rcu, struct kmemleak_object, rcu);
@@ -445,8 +445,8 @@ static void free_object_rcu(struct rcu_head *rcu)
 	 * Once use_count is 0 (guaranteed by put_object), there is no other
 	 * code accessing this object, hence no need for locking.
-	hlist_for_each_entry_safe(area, elem, tmp, &object->area_list, node) {
-		hlist_del(elem);
+	hlist_for_each_entry_safe(area, tmp, &object->area_list, node) {
+		hlist_del(&area->node);
 		kmem_cache_free(scan_area_cache, area);
 	kmem_cache_free(object_cache, object);
@@ -1177,7 +1177,6 @@ static void scan_block(void *_start, void *_end,
 static void scan_object(struct kmemleak_object *object)
@@ -1205,7 +1204,7 @@ static void scan_object(struct kmemleak_object *object)
 			spin_lock_irqsave(&object->lock, flags);
 	} else
-		hlist_for_each_entry(area, elem, &object->area_list, node)
+		hlist_for_each_entry(area, &object->area_list, node)
 			scan_block((void *)area->start,
 				   (void *)(area->start + area->size),
 				   object, 0);
diff --git a/mm/ksm.c b/mm/ksm.c
index ab2ba9a..85bfd4c 100644
--- a/mm/ksm.c
+++ b/mm/ksm.c
@@ -320,10 +320,9 @@ static inline void free_mm_slot(struct mm_slot *mm_slot)
 	struct mm_slot *slot;
-	hash_for_each_possible(mm_slots_hash, slot, node, link, (unsigned long)mm)
+	hash_for_each_possible(mm_slots_hash, slot, link, (unsigned long)mm)
 		if (slot->mm == mm)
 			return slot;
@@ -496,9 +495,8 @@ static inline int get_kpfn_nid(unsigned long kpfn)
 static void remove_node_from_stable_tree(struct stable_node *stable_node)
 	struct rmap_item *rmap_item;
-	struct hlist_node *hlist;
-	hlist_for_each_entry(rmap_item, hlist, &stable_node->hlist, hlist) {
+	hlist_for_each_entry(rmap_item, &stable_node->hlist, hlist) {
 		if (rmap_item->hlist.next)
 			ksm_pages_sharing--;
 		else
@@ -1898,7 +1896,6 @@ int page_referenced_ksm(struct page *page, struct mem_cgroup *memcg,
 	struct stable_node *stable_node;
 	unsigned int mapcount = page_mapcount(page);
 	int referenced = 0;
 	int search_new_forks = 0;
@@ -1910,7 +1907,7 @@ int page_referenced_ksm(struct page *page, struct mem_cgroup *memcg,
 	if (!stable_node)
 		return 0;
 again:
 		struct anon_vma *anon_vma = rmap_item->anon_vma;
 		struct anon_vma_chain *vmac;
 		struct vm_area_struct *vma;
@@ -1952,7 +1949,6 @@ out:
 int try_to_unmap_ksm(struct page *page, enum ttu_flags flags)
 	int ret = SWAP_AGAIN;
@@ -1964,7 +1960,7 @@ int try_to_unmap_ksm(struct page *page, enum ttu_flags flags)
 	if (!stable_node)
 		return SWAP_FAIL;
 again:
@@ -2005,7 +2001,6 @@ int rmap_walk_ksm(struct page *page, int (*rmap_one)(struct page *,
 		  struct vm_area_struct *, unsigned long, void *), void *arg)
@@ -2017,7 +2012,7 @@ int rmap_walk_ksm(struct page *page, int (*rmap_one)(struct page *,
 	if (!stable_node)
 		return ret;
 again:
diff --git a/mm/mmu_notifier.c b/mm/mmu_notifier.c
index 2175fb0..be04122 100644
--- a/mm/mmu_notifier.c
+++ b/mm/mmu_notifier.c
@@ -95,11 +95,10 @@ int __mmu_notifier_clear_flush_young(struct mm_struct *mm,
 					unsigned long address)
 	struct mmu_notifier *mn;
 	int young = 0, id;
 	id = srcu_read_lock(&srcu);
-	hlist_for_each_entry_rcu(mn, n, &mm->mmu_notifier_mm->list, hlist) {
+	hlist_for_each_entry_rcu(mn, &mm->mmu_notifier_mm->list, hlist) {
 		if (mn->ops->clear_flush_young)
 			young |= mn->ops->clear_flush_young(mn, mm, address);
@@ -112,11 +111,10 @@ int __mmu_notifier_test_young(struct mm_struct *mm,
 	int young = 0, id;
 		if (mn->ops->test_young) {
 			young = mn->ops->test_young(mn, mm, address);
 			if (young)
@@ -132,11 +130,10 @@ void __mmu_notifier_change_pte(struct mm_struct *mm, unsigned long address,
 			       pte_t pte)
 	int id;
 		if (mn->ops->change_pte)
 			mn->ops->change_pte(mn, mm, address, pte);
@@ -147,11 +144,10 @@ void __mmu_notifier_invalidate_page(struct mm_struct *mm,
 	int id;
 		if (mn->ops->invalidate_page)
 			mn->ops->invalidate_page(mn, mm, address);
@@ -162,11 +158,10 @@ void __mmu_notifier_invalidate_range_start(struct mm_struct *mm,
 				  unsigned long start, unsigned long end)
 	int id;
 		if (mn->ops->invalidate_range_start)
 			mn->ops->invalidate_range_start(mn, mm, start, end);
@@ -178,11 +173,10 @@ void __mmu_notifier_invalidate_range_end(struct mm_struct *mm,
 	int id;
 		if (mn->ops->invalidate_range_end)
 			mn->ops->invalidate_range_end(mn, mm, start, end);
diff --git a/net/9p/error.c b/net/9p/error.c
index 2ab2de7..126fd0d 100644
--- a/net/9p/error.c
+++ b/net/9p/error.c
@@ -221,15 +221,13 @@ EXPORT_SYMBOL(p9_error_init);
 int p9_errstr2errno(char *errstr, int len)
 	int errno;
-	struct hlist_node *p;
 	struct errormap *c;
 	int bucket;
 	errno = 0;
-	p = NULL;
 	c = NULL;
 	bucket = jhash(errstr, len, 0) % ERRHASHSZ;
-	hlist_for_each_entry(c, p, &hash_errmap[bucket], list) {
+	hlist_for_each_entry(c, &hash_errmap[bucket], list) {
 		if (c->namelen == len && !memcmp(c->name, errstr, len)) {
 			errno = c->val;
 			break;
diff --git a/net/9p/trans_virtio.c b/net/9p/trans_virtio.c
index de2e950..74dea37 100644
--- a/net/9p/trans_virtio.c
+++ b/net/9p/trans_virtio.c
@@ -655,7 +655,7 @@ static struct p9_trans_module p9_virtio_trans = {
 	.create = p9_virtio_create,
 	.close = p9_virtio_close,
 	.request = p9_virtio_request,
-	.zc_request = p9_virtio_zc_request,
+	//.zc_request = p9_virtio_zc_request,
 	.cancel = p9_virtio_cancel,
 	 * We leave one entry for input and one entry for response
diff --git a/net/appletalk/ddp.c b/net/appletalk/ddp.c
index 3347529..4a141e3 100644
--- a/net/appletalk/ddp.c
+++ b/net/appletalk/ddp.c
@@ -93,10 +93,9 @@ static struct sock *atalk_search_socket(struct sockaddr_at *to,
 					struct atalk_iface *atif)
 	struct sock *s;
 	read_lock_bh(&atalk_sockets_lock);
-	sk_for_each(s, node, &atalk_sockets) {
+	sk_for_each(s, &atalk_sockets) {
 		struct atalk_sock *at = at_sk(s);
 		if (to->sat_port != at->src_port)
@@ -141,11 +140,10 @@ static struct sock *atalk_find_or_insert_socket(struct sock *sk,
 						struct sockaddr_at *sat)
 	struct sock *s;
 	struct atalk_sock *at;
 	write_lock_bh(&atalk_sockets_lock);
 		at = at_sk(s);
 		if (at->src_net == sat->sat_addr.s_net &&
@@ -1084,9 +1082,8 @@ static int atalk_pick_and_bind_port(struct sock *sk, struct sockaddr_at *sat)
 	     sat->sat_port < ATPORT_LAST;
 	     sat->sat_port++) {
 		struct sock *s;
diff --git a/net/atm/common.c b/net/atm/common.c
index 806fc0a..7b49100 100644
--- a/net/atm/common.c
+++ b/net/atm/common.c
@@ -270,11 +270,11 @@ void atm_dev_release_vccs(struct atm_dev *dev)
 	write_lock_irq(&vcc_sklist_lock);
 	for (i = 0; i < VCC_HTABLE_SIZE; i++) {
 		struct hlist_head *head = &vcc_hash[i];
 		struct sock *s;
 		struct atm_vcc *vcc;
-		sk_for_each_safe(s, node, tmp, head) {
+		sk_for_each_safe(s, tmp, head) {
 			vcc = atm_sk(s);
 			if (vcc->dev == dev) {
 				vcc_release_async(vcc, -EPIPE);
@@ -317,11 +317,10 @@ static int adjust_tp(struct atm_trafprm *tp, unsigned char aal)
 static int check_ci(const struct atm_vcc *vcc, short vpi, int vci)
 	struct hlist_head *head = &vcc_hash[vci & (VCC_HTABLE_SIZE - 1)];
 	struct sock *s;
 	struct atm_vcc *walk;
-	sk_for_each(s, node, head) {
+	sk_for_each(s, head) {
 		walk = atm_sk(s);
 		if (walk->dev != vcc->dev)
 			continue;
diff --git a/net/atm/lec.c b/net/atm/lec.c
index 2e3d942..f23916b 100644
--- a/net/atm/lec.c
+++ b/net/atm/lec.c
@@ -842,7 +842,9 @@ static void *lec_tbl_walk(struct lec_state *state, struct hlist_head *tbl,
 		--*l;
-	hlist_for_each_entry_from(tmp, e, next) {
+	tmp = container_of(e, struct lec_arp_table, next);
+	hlist_for_each_entry_from(tmp, next) {
 		if (--*l < 0)
 			break;
@@ -1307,7 +1309,6 @@ lec_arp_add(struct lec_priv *priv, struct lec_arp_table *entry)
 static int
 lec_arp_remove(struct lec_priv *priv, struct lec_arp_table *to_remove)
 	struct lec_arp_table *entry;
 	int i, remove_vcc = 1;
@@ -1326,7 +1327,7 @@ lec_arp_remove(struct lec_priv *priv, struct lec_arp_table *to_remove)
 		 * ESI_FLUSH_PENDING, ESI_FORWARD_DIRECT
 		for (i = 0; i < LEC_ARP_TABLE_SIZE; i++) {
-			hlist_for_each_entry(entry, node,
 					     &priv->lec_arp_tables[i], next) {
 				if (memcmp(to_remove->atm_addr,
 					   entry->atm_addr, ATM_ESA_LEN) == 0) {
@@ -1364,14 +1365,13 @@ static const char *get_status_string(unsigned char st)
 static void dump_arp_table(struct lec_priv *priv)
 	struct lec_arp_table *rulla;
 	char buf[256];
 	int i, j, offset;
 	pr_info("Dump %p:\n", priv);
-		hlist_for_each_entry(rulla, node,
+		hlist_for_each_entry(rulla,
 			offset = 0;
 			offset += sprintf(buf, "%d: %p\n", i, rulla);
@@ -1403,7 +1403,7 @@ static void dump_arp_table(struct lec_priv *priv)
 	if (!hlist_empty(&priv->lec_no_forward))
 		pr_info("No forward\n");
-	hlist_for_each_entry(rulla, node, &priv->lec_no_forward, next) {
+	hlist_for_each_entry(rulla, &priv->lec_no_forward, next) {
 		offset = 0;
 		offset += sprintf(buf + offset, "Mac: %pM", rulla->mac_addr);
 		offset += sprintf(buf + offset, " Atm:");
@@ -1428,7 +1428,7 @@ static void dump_arp_table(struct lec_priv *priv)
 	if (!hlist_empty(&priv->lec_arp_empty_ones))
 		pr_info("Empty ones\n");
-	hlist_for_each_entry(rulla, node, &priv->lec_arp_empty_ones, next) {
+	hlist_for_each_entry(rulla, &priv->lec_arp_empty_ones, next) {
 		offset = 0;
@@ -1453,7 +1453,7 @@ static void dump_arp_table(struct lec_priv *priv)
 	if (!hlist_empty(&priv->mcast_fwds))
 		pr_info("Multicast Forward VCCs\n");
-	hlist_for_each_entry(rulla, node, &priv->mcast_fwds, next) {
+	hlist_for_each_entry(rulla, &priv->mcast_fwds, next) {
 		offset = 0;
@@ -1487,7 +1487,7 @@ static void dump_arp_table(struct lec_priv *priv)
 static void lec_arp_destroy(struct lec_priv *priv)
-	struct hlist_node *node, *next;
 	int i;
@@ -1499,7 +1499,7 @@ static void lec_arp_destroy(struct lec_priv *priv)
 	spin_lock_irqsave(&priv->lec_arp_lock, flags);
-		hlist_for_each_entry_safe(entry, node, next,
+		hlist_for_each_entry_safe(entry, next,
 			lec_arp_remove(priv, entry);
 			lec_arp_put(entry);
@@ -1507,7 +1507,7 @@ static void lec_arp_destroy(struct lec_priv *priv)
 		INIT_HLIST_HEAD(&priv->lec_arp_tables[i]);
 		del_timer_sync(&entry->timer);
 		lec_arp_clear_vccs(entry);
@@ -1516,7 +1516,7 @@ static void lec_arp_destroy(struct lec_priv *priv)
 	INIT_HLIST_HEAD(&priv->lec_arp_empty_ones);
@@ -1525,7 +1525,7 @@ static void lec_arp_destroy(struct lec_priv *priv)
 	INIT_HLIST_HEAD(&priv->lec_no_forward);
-	hlist_for_each_entry_safe(entry, node, next, &priv->mcast_fwds, next) {
+	hlist_for_each_entry_safe(entry, next, &priv->mcast_fwds, next) {
 		/* No timer, LANEv2 7.1.20 and 2.3.5.3 */
 		hlist_del(&entry->next);
@@ -1542,14 +1542,13 @@ static void lec_arp_destroy(struct lec_priv *priv)
 static struct lec_arp_table *lec_arp_find(struct lec_priv *priv,
 					  const unsigned char *mac_addr)
 	pr_debug("%pM\n", mac_addr);
 	head = &priv->lec_arp_tables[HASH(mac_addr[ETH_ALEN - 1])];
-	hlist_for_each_entry(entry, node, head, next) {
+	hlist_for_each_entry(entry, head, next) {
 		if (ether_addr_equal(mac_addr, entry->mac_addr))
 			return entry;
@@ -1686,7 +1685,7 @@ static void lec_arp_check_expire(struct work_struct *work)
 	struct lec_priv *priv =
 		container_of(work, struct lec_priv, lec_arp_work.work);
 	unsigned long now;
 	int i;
@@ -1696,7 +1695,7 @@ static void lec_arp_check_expire(struct work_struct *work)
 restart:
 			if (__lec_arp_check_expire(entry, now, priv)) {
 				struct sk_buff *skb;
@@ -1823,14 +1822,14 @@ lec_addr_delete(struct lec_priv *priv, const unsigned char *atm_addr,
 		unsigned long permanent)
 	int i;
 	pr_debug("\n");
 			if (!memcmp(atm_addr, entry->atm_addr, ATM_ESA_LEN) &&
 			    (permanent ||
@@ -1855,7 +1854,7 @@ lec_arp_update(struct lec_priv *priv, const unsigned char *mac_addr,
 	       unsigned int targetless_le_arp)
 	struct lec_arp_table *entry, *tmp;
 	int i;
@@ -1870,7 +1869,7 @@ lec_arp_update(struct lec_priv *priv, const unsigned char *mac_addr,
 				 * we have no entry in the cache. 7.1.30
 	if (!hlist_empty(&priv->lec_arp_empty_ones)) {
 			if (memcmp(entry->atm_addr, atm_addr, ATM_ESA_LEN) == 0) {
@@ -1915,7 +1914,7 @@ lec_arp_update(struct lec_priv *priv, const unsigned char *mac_addr,
 	memcpy(entry->atm_addr, atm_addr, ATM_ESA_LEN);
 	del_timer(&entry->timer);
-		hlist_for_each_entry(tmp, node,
+		hlist_for_each_entry(tmp,
 			if (entry != tmp &&
 			    !memcmp(tmp->atm_addr, atm_addr, ATM_ESA_LEN)) {
@@ -1956,7 +1955,6 @@ lec_vcc_added(struct lec_priv *priv, const struct atmlec_ioc *ioc_data,
 	      void (*old_push) (struct atm_vcc *vcc, struct sk_buff *skb))
-	struct hlist_node *node;
 	int i, found_entry = 0;
@@ -2026,7 +2024,7 @@ lec_vcc_added(struct lec_priv *priv, const struct atmlec_ioc *ioc_data,
 		 ioc_data->atm_addr[16], ioc_data->atm_addr[17],
 		 ioc_data->atm_addr[18], ioc_data->atm_addr[19]);
 			if (memcmp
 			    (ioc_data->atm_addr, entry->atm_addr,
@@ -2103,7 +2101,6 @@ out:
 static void lec_flush_complete(struct lec_priv *priv, unsigned long tran_id)
 	int i;
@@ -2111,7 +2108,7 @@ static void lec_flush_complete(struct lec_priv *priv, unsigned long tran_id)
 restart:
 			if (entry->flush_tran_id == tran_id &&
 			    entry->status == ESI_FLUSH_PENDING) {
@@ -2140,13 +2137,12 @@ lec_set_flush_tran_id(struct lec_priv *priv,
 		      const unsigned char *atm_addr, unsigned long tran_id)
 	int i;
 			if (!memcmp(atm_addr, entry->atm_addr, ATM_ESA_LEN)) {
 				entry->flush_tran_id = tran_id;
@@ -2198,7 +2194,7 @@ out:
 static void lec_vcc_close(struct lec_priv *priv, struct atm_vcc *vcc)
 	int i;
@@ -2208,7 +2204,7 @@ static void lec_vcc_close(struct lec_priv *priv, struct atm_vcc *vcc)
 			if (vcc == entry->vcc) {
@@ -2219,7 +2215,7 @@ static void lec_vcc_close(struct lec_priv *priv, struct atm_vcc *vcc)
 		if (entry->vcc == vcc) {
@@ -2229,7 +2225,7 @@ static void lec_vcc_close(struct lec_priv *priv, struct atm_vcc *vcc)
 		if (entry->recv_vcc == vcc) {
@@ -2239,7 +2235,7 @@ static void lec_vcc_close(struct lec_priv *priv, struct atm_vcc *vcc)
@@ -2257,13 +2253,13 @@ lec_arp_check_empties(struct lec_priv *priv,
 	struct lecdatahdr_8023 *hdr = (struct lecdatahdr_8023 *)skb->data;
 	unsigned char *src = hdr->h_source;
diff --git a/net/atm/signaling.c b/net/atm/signaling.c
index 86767ca..4176887 100644
--- a/net/atm/signaling.c
+++ b/net/atm/signaling.c
@@ -217,7 +217,6 @@ static void purge_vcc(struct atm_vcc *vcc)
 static void sigd_close(struct atm_vcc *vcc)
 	struct sock *s;
 	int i;
@@ -231,7 +230,7 @@ static void sigd_close(struct atm_vcc *vcc)
 	for (i = 0; i < VCC_HTABLE_SIZE; ++i) {
 			vcc = atm_sk(s);
 			purge_vcc(vcc);
diff --git a/net/ax25/af_ax25.c b/net/ax25/af_ax25.c
index 69a06c4..7b11f8b 100644
--- a/net/ax25/af_ax25.c
+++ b/net/ax25/af_ax25.c
@@ -81,14 +81,13 @@ static void ax25_kill_by_device(struct net_device *dev)
 	ax25_dev *ax25_dev;
 	ax25_cb *s;
 	if ((ax25_dev = ax25_dev_ax25dev(dev)) == NULL)
 		return;
 	spin_lock_bh(&ax25_list_lock);
 again:
-	ax25_for_each(s, node, &ax25_list) {
+	ax25_for_each(s, &ax25_list) {
 		if (s->ax25_dev == ax25_dev) {
 			s->ax25_dev = NULL;
 			spin_unlock_bh(&ax25_list_lock);
@@ -158,10 +157,9 @@ struct sock *ax25_find_listener(ax25_address *addr, int digi,
 	struct net_device *dev, int type)
 	ax25_cb *s;
 	spin_lock(&ax25_list_lock);
 		if ((s->iamdigi && !digi) || (!s->iamdigi && digi))
 			continue;
 		if (s->sk && !ax25cmp(&s->source_addr, addr) &&
@@ -187,10 +185,9 @@ struct sock *ax25_get_socket(ax25_address *my_addr, ax25_address *dest_addr,
 	struct sock *sk = NULL;
 	ax25_cb *s;
 		if (s->sk && !ax25cmp(&s->source_addr, my_addr) &&
 		    !ax25cmp(&s->dest_addr, dest_addr) &&
 		    s->sk->sk_type == type) {
@@ -213,10 +210,9 @@ ax25_cb *ax25_find_cb(ax25_address *src_addr, ax25_address *dest_addr,
 	ax25_digi *digi, struct net_device *dev)
 	ax25_cb *s;
 		if (s->sk && s->sk->sk_type != SOCK_SEQPACKET)
 			continue;
 		if (s->ax25_dev == NULL)
@@ -248,10 +244,9 @@ void ax25_send_to_raw(ax25_address *addr, struct sk_buff *skb, int proto)
 	ax25_cb *s;
 	struct sk_buff *copy;
 		if (s->sk != NULL && ax25cmp(&s->source_addr, addr) == 0 &&
 		    s->sk->sk_type == SOCK_RAW &&
 		    s->sk->sk_protocol == proto &&
diff --git a/net/ax25/ax25_ds_subr.c b/net/ax25/ax25_ds_subr.c
index 5ea7fd3..e05bd57 100644
--- a/net/ax25/ax25_ds_subr.c
+++ b/net/ax25/ax25_ds_subr.c
@@ -39,7 +39,6 @@ void ax25_ds_nr_error_recovery(ax25_cb *ax25)
 void ax25_ds_enquiry_response(ax25_cb *ax25)
 	ax25_cb *ax25o;
 	/* Please note that neither DK4EG's nor DG2FEF's
 	 * DAMA spec mention the following behaviour as seen
@@ -80,7 +79,7 @@ void ax25_ds_enquiry_response(ax25_cb *ax25)
 	ax25_ds_set_timer(ax25->ax25_dev);
-	ax25_for_each(ax25o, node, &ax25_list) {
+	ax25_for_each(ax25o, &ax25_list) {
 		if (ax25o == ax25)
 			continue;
@@ -159,10 +158,9 @@ static int ax25_check_dama_slave(ax25_dev *ax25_dev)
 	ax25_cb *ax25;
 	int res = 0;
-	ax25_for_each(ax25, node, &ax25_list)
+	ax25_for_each(ax25, &ax25_list)
 		if (ax25->ax25_dev == ax25_dev && (ax25->condition & AX25_COND_DAMA_MODE) && ax25->state > AX25_STATE_1) {
 			res = 1;
 			break;
diff --git a/net/ax25/ax25_ds_timer.c b/net/ax25/ax25_ds_timer.c
index 993c439..951cd57 100644
--- a/net/ax25/ax25_ds_timer.c
+++ b/net/ax25/ax25_ds_timer.c
@@ -70,7 +70,6 @@ static void ax25_ds_timeout(unsigned long arg)
 	ax25_dev *ax25_dev = (struct ax25_dev *) arg;
 	ax25_cb *ax25;
 	if (ax25_dev == NULL || !ax25_dev->dama.slave)
 		return;			/* Yikes! */
@@ -81,7 +80,7 @@ static void ax25_ds_timeout(unsigned long arg)
-	ax25_for_each(ax25, node, &ax25_list) {
+	ax25_for_each(ax25, &ax25_list) {
 		if (ax25->ax25_dev != ax25_dev || !(ax25->condition & AX25_COND_DAMA_MODE))
 			continue;
diff --git a/net/ax25/ax25_iface.c b/net/ax25/ax25_iface.c
index 7d5f24b..7f16e8a 100644
--- a/net/ax25/ax25_iface.c
+++ b/net/ax25/ax25_iface.c
@@ -193,10 +193,9 @@ int ax25_listen_mine(ax25_address *callsign, struct net_device *dev)
 void ax25_link_failed(ax25_cb *ax25, int reason)
 	struct ax25_linkfail *lf;
 	spin_lock_bh(&linkfail_lock);
-	hlist_for_each_entry(lf, node, &ax25_linkfail_list, lf_node)
+	hlist_for_each_entry(lf, &ax25_linkfail_list, lf_node)
 		lf->func(ax25, reason);
 	spin_unlock_bh(&linkfail_lock);
diff --git a/net/ax25/ax25_uid.c b/net/ax25/ax25_uid.c
index 957999e..71c4bad 100644
--- a/net/ax25/ax25_uid.c
+++ b/net/ax25/ax25_uid.c
@@ -54,10 +54,9 @@ EXPORT_SYMBOL(ax25_uid_policy);
 ax25_uid_assoc *ax25_findbyuid(kuid_t uid)
 	ax25_uid_assoc *ax25_uid, *res = NULL;
 	read_lock(&ax25_uid_lock);
-	ax25_uid_for_each(ax25_uid, node, &ax25_uid_list) {
+	ax25_uid_for_each(ax25_uid, &ax25_uid_list) {
 		if (uid_eq(ax25_uid->uid, uid)) {
 			ax25_uid_hold(ax25_uid);
 			res = ax25_uid;
@@ -74,7 +73,6 @@ EXPORT_SYMBOL(ax25_findbyuid);
 int ax25_uid_ioctl(int cmd, struct sockaddr_ax25 *sax)
 	ax25_uid_assoc *ax25_uid;
 	ax25_uid_assoc *user;
 	unsigned long res;
@@ -82,7 +80,7 @@ int ax25_uid_ioctl(int cmd, struct sockaddr_ax25 *sax)
 	case SIOCAX25GETUID:
 		res = -ENOENT;
 			if (ax25cmp(&sax->sax25_call, &ax25_uid->call) == 0) {
 				res = from_kuid_munged(current_user_ns(), ax25_uid->uid);
 				break;
@@ -126,7 +124,7 @@ int ax25_uid_ioctl(int cmd, struct sockaddr_ax25 *sax)
 		ax25_uid = NULL;
 		write_lock(&ax25_uid_lock);
 				break;
@@ -212,11 +210,10 @@ const struct file_operations ax25_uid_fops = {
 void __exit ax25_uid_free(void)
 again:
 		hlist_del_init(&ax25_uid->uid_node);
 		ax25_uid_put(ax25_uid);
 		goto again;
diff --git a/net/batman-adv/bat_iv_ogm.c b/net/batman-adv/bat_iv_ogm.c
index 72fe1bb..a0b253e 100644
--- a/net/batman-adv/bat_iv_ogm.c
+++ b/net/batman-adv/bat_iv_ogm.c
@@ -487,7 +487,6 @@ static void batadv_iv_ogm_queue_add(struct batadv_priv *bat_priv,
 	struct batadv_forw_packet *forw_packet_aggr = NULL;
 	struct batadv_forw_packet *forw_packet_pos = NULL;
-	struct hlist_node *tmp_node;
 	struct batadv_ogm_packet *batadv_ogm_packet;
 	bool direct_link;
 	unsigned long max_aggregation_jiffies;
@@ -500,7 +499,7 @@ static void batadv_iv_ogm_queue_add(struct batadv_priv *bat_priv,
 	spin_lock_bh(&bat_priv->forw_bat_list_lock);
 	/* own packets are not to be aggregated */
 	if ((atomic_read(&bat_priv->aggregated_ogms)) && (!own_packet)) {
-		hlist_for_each_entry(forw_packet_pos, tmp_node,
+		hlist_for_each_entry(forw_packet_pos,
 				     &bat_priv->forw_bat_list, list) {
 			if (batadv_iv_ogm_can_aggregate(batadv_ogm_packet,
 							bat_priv, packet_len,
@@ -655,7 +654,6 @@ batadv_iv_ogm_orig_update(struct batadv_priv *bat_priv,
 	struct batadv_neigh_node *neigh_node = NULL, *tmp_neigh_node = NULL;
 	struct batadv_neigh_node *router = NULL;
 	struct batadv_orig_node *orig_node_tmp;
 	int if_num;
 	uint8_t sum_orig, sum_neigh;
 	uint8_t *neigh_addr;
@@ -665,7 +663,7 @@ batadv_iv_ogm_orig_update(struct batadv_priv *bat_priv,
 		   "update_originator(): Searching and updating originator entry of received packet\n");
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(tmp_neigh_node, node,
+	hlist_for_each_entry_rcu(tmp_neigh_node,
 				 &orig_node->neigh_list, list) {
 		neigh_addr = tmp_neigh_node->addr;
 		if (batadv_compare_eth(neigh_addr, ethhdr->h_source) &&
@@ -801,7 +799,6 @@ static int batadv_iv_ogm_calc_tq(struct batadv_orig_node *orig_node,
 	struct batadv_priv *bat_priv = netdev_priv(if_incoming->soft_iface);
 	struct batadv_neigh_node *neigh_node = NULL, *tmp_neigh_node;
 	uint8_t total_count;
 	uint8_t orig_eq_count, neigh_rq_count, neigh_rq_inv, tq_own;
 	unsigned int neigh_rq_inv_cube, neigh_rq_max_cube;
@@ -810,7 +807,7 @@ static int batadv_iv_ogm_calc_tq(struct batadv_orig_node *orig_node,
 	/* find corresponding one hop neighbor */
 	rcu_read_lock();
 				 &orig_neigh_node->neigh_list, list) {
 		if (!batadv_compare_eth(tmp_neigh_node->addr,
 					orig_neigh_node->orig))
@@ -920,7 +917,6 @@ batadv_iv_ogm_update_seqnos(const struct ethhdr *ethhdr,
 	struct batadv_orig_node *orig_node;
 	struct batadv_neigh_node *tmp_neigh_node;
 	int is_duplicate = 0;
 	int32_t seq_diff;
 	int need_update = 0;
@@ -943,7 +939,7 @@ batadv_iv_ogm_update_seqnos(const struct ethhdr *ethhdr,
 		goto out;
 	rcu_read_lock();
 		is_duplicate |= batadv_test_bit(tmp_neigh_node->real_bits,
 						orig_node->last_real_seqno,
diff --git a/net/batman-adv/bridge_loop_avoidance.c b/net/batman-adv/bridge_loop_avoidance.c
index 30f4652..6a4f728 100644
--- a/net/batman-adv/bridge_loop_avoidance.c
+++ b/net/batman-adv/bridge_loop_avoidance.c
@@ -144,7 +144,6 @@ static struct batadv_bla_claim
 	struct batadv_hashtable *hash = bat_priv->bla.claim_hash;
 	struct batadv_bla_claim *claim;
 	struct batadv_bla_claim *claim_tmp = NULL;
 	int index;
@@ -156,7 +155,7 @@ static struct batadv_bla_claim
 	head = &hash->table[index];
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(claim, node, head, hash_entry) {
+	hlist_for_each_entry_rcu(claim, head, hash_entry) {
 		if (!batadv_compare_claim(&claim->hash_entry, data))
 			continue;
@@ -185,7 +184,6 @@ batadv_backbone_hash_find(struct batadv_priv *bat_priv,
 	struct batadv_hashtable *hash = bat_priv->bla.backbone_hash;
 	struct batadv_bla_backbone_gw search_entry, *backbone_gw;
 	struct batadv_bla_backbone_gw *backbone_gw_tmp = NULL;
 	int index;
@@ -200,7 +198,7 @@ batadv_backbone_hash_find(struct batadv_priv *bat_priv,
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(backbone_gw, node, head, hash_entry) {
+	hlist_for_each_entry_rcu(backbone_gw, head, hash_entry) {
 		if (!batadv_compare_backbone_gw(&backbone_gw->hash_entry,
 						&search_entry))
 			continue;
@@ -221,7 +219,7 @@ static void
 batadv_bla_del_backbone_claims(struct batadv_bla_backbone_gw *backbone_gw)
 	struct batadv_hashtable *hash;
-	struct hlist_node *node, *node_tmp;
+	struct hlist_node *node_tmp;
 	int i;
@@ -236,13 +234,13 @@ batadv_bla_del_backbone_claims(struct batadv_bla_backbone_gw *backbone_gw)
 		list_lock = &hash->list_locks[i];
 		spin_lock_bh(list_lock);
-		hlist_for_each_entry_safe(claim, node, node_tmp,
+		hlist_for_each_entry_safe(claim, node_tmp,
 					  head, hash_entry) {
 			if (claim->backbone_gw != backbone_gw)
 				continue;
 			batadv_claim_free_ref(claim);
-			hlist_del_rcu(node);
+			hlist_del_rcu(&claim->hash_entry);
 		spin_unlock_bh(list_lock);
@@ -460,7 +458,6 @@ static void batadv_bla_answer_request(struct batadv_priv *bat_priv,
 				      struct batadv_hard_iface *primary_if,
 				      short vid)
@@ -481,7 +478,7 @@ static void batadv_bla_answer_request(struct batadv_priv *bat_priv,
 		head = &hash->table[i];
 		rcu_read_lock();
 			/* only own claims are interesting */
 				continue;
@@ -958,7 +955,7 @@ static int batadv_bla_process_claim(struct batadv_priv *bat_priv,
 static void batadv_bla_purge_backbone_gw(struct batadv_priv *bat_priv, int now)
 	struct batadv_bla_backbone_gw *backbone_gw;
 	spinlock_t *list_lock;	/* protects write access to the hash lists */
@@ -973,7 +970,7 @@ static void batadv_bla_purge_backbone_gw(struct batadv_priv *bat_priv, int now)
-		hlist_for_each_entry_safe(backbone_gw, node, node_tmp,
+		hlist_for_each_entry_safe(backbone_gw, node_tmp,
 					  head, hash_entry) {
 			if (now)
 				goto purge_now;
@@ -992,7 +989,7 @@ purge_now:
 			batadv_bla_del_backbone_claims(backbone_gw);
+			hlist_del_rcu(&backbone_gw->hash_entry);
 			batadv_backbone_gw_free_ref(backbone_gw);
@@ -1013,7 +1010,6 @@ static void batadv_bla_purge_claims(struct batadv_priv *bat_priv,
 				    int now)
 	int i;
@@ -1026,7 +1022,7 @@ static void batadv_bla_purge_claims(struct batadv_priv *bat_priv,
 		rcu_read_lock();
 			if (now)
 				goto purge_now;
 			if (!batadv_compare_eth(claim->backbone_gw->orig,
@@ -1062,7 +1058,6 @@ void batadv_bla_update_orig_address(struct batadv_priv *bat_priv,
 				    struct batadv_hard_iface *oldif)
 	__be16 group;
@@ -1086,7 +1081,7 @@ void batadv_bla_update_orig_address(struct batadv_priv *bat_priv,
 		rcu_read_lock();
 			/* own orig still holds the old value. */
 			if (!batadv_compare_eth(backbone_gw->orig,
 						oldif->net_dev->dev_addr))
@@ -1112,7 +1107,6 @@ static void batadv_bla_periodic_work(struct work_struct *work)
 	struct delayed_work *delayed_work;
 	struct batadv_priv *bat_priv;
 	struct batadv_priv_bla *priv_bla;
@@ -1140,7 +1134,7 @@ static void batadv_bla_periodic_work(struct work_struct *work)
 		rcu_read_lock();
 						primary_if->net_dev->dev_addr))
 				continue;
@@ -1322,7 +1316,6 @@ int batadv_bla_is_backbone_gw_orig(struct batadv_priv *bat_priv, uint8_t *orig)
 	int i;
@@ -1336,7 +1329,7 @@ int batadv_bla_is_backbone_gw_orig(struct batadv_priv *bat_priv, uint8_t *orig)
 		rcu_read_lock();
 			if (batadv_compare_eth(backbone_gw->orig, orig)) {
 				rcu_read_unlock();
 				return 1;
@@ -1607,7 +1600,6 @@ int batadv_bla_claim_table_seq_print_text(struct seq_file *seq, void *offset)
 	struct batadv_hard_iface *primary_if;
 	uint32_t i;
 	bool is_own;
@@ -1628,7 +1620,7 @@ int batadv_bla_claim_table_seq_print_text(struct seq_file *seq, void *offset)
 		rcu_read_lock();
 			is_own = batadv_compare_eth(claim->backbone_gw->orig,
 						    primary_addr);
 			seq_printf(seq,	" * %pM on % 5d by %pM [%c] (%#.4x)\n",
@@ -1652,7 +1644,6 @@ int batadv_bla_backbone_table_seq_print_text(struct seq_file *seq, void *offset)
 	int secs, msecs;
 	uint32_t i;
@@ -1674,7 +1665,7 @@ int batadv_bla_backbone_table_seq_print_text(struct seq_file *seq, void *offset)
 		rcu_read_lock();
 			msecs = jiffies_to_msecs(jiffies -
 						 backbone_gw->lasttime);
 			secs = msecs / 1000;
diff --git a/net/batman-adv/distributed-arp-table.c b/net/batman-adv/distributed-arp-table.c
index 761a590..d54188a 100644
--- a/net/batman-adv/distributed-arp-table.c
+++ b/net/batman-adv/distributed-arp-table.c
@@ -83,7 +83,7 @@ static void __batadv_dat_purge(struct batadv_priv *bat_priv,
 	struct batadv_dat_entry *dat_entry;
 	uint32_t i;
@@ -95,7 +95,7 @@ static void __batadv_dat_purge(struct batadv_priv *bat_priv,
 		list_lock = &bat_priv->dat.hash->list_locks[i];
-		hlist_for_each_entry_safe(dat_entry, node, node_tmp, head,
+		hlist_for_each_entry_safe(dat_entry, node_tmp, head,
 					  hash_entry) {
 			/* if an helper function has been passed as parameter,
 			 * ask it if the entry has to be purged or not
@@ -103,7 +103,7 @@ static void __batadv_dat_purge(struct batadv_priv *bat_priv,
 			if (to_purge && !to_purge(dat_entry))
 				continue;
+			hlist_del_rcu(&dat_entry->hash_entry);
 			batadv_dat_entry_free_ref(dat_entry);
@@ -235,7 +235,6 @@ static struct batadv_dat_entry *
 batadv_dat_entry_hash_find(struct batadv_priv *bat_priv, __be32 ip)
 	struct batadv_dat_entry *dat_entry, *dat_entry_tmp = NULL;
 	struct batadv_hashtable *hash = bat_priv->dat.hash;
 	uint32_t index;
@@ -247,7 +246,7 @@ batadv_dat_entry_hash_find(struct batadv_priv *bat_priv, __be32 ip)
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(dat_entry, node, head, hash_entry) {
+	hlist_for_each_entry_rcu(dat_entry, head, hash_entry) {
 		if (dat_entry->ip != ip)
 			continue;
@@ -465,7 +464,6 @@ static void batadv_choose_next_candidate(struct batadv_priv *bat_priv,
 	batadv_dat_addr_t max = 0, tmp_max = 0;
 	struct batadv_orig_node *orig_node, *max_orig_node = NULL;
 	struct batadv_hashtable *hash = bat_priv->orig_hash;
 	int i;
@@ -481,7 +479,7 @@ static void batadv_choose_next_candidate(struct batadv_priv *bat_priv,
 		rcu_read_lock();
-		hlist_for_each_entry_rcu(orig_node, node, head, hash_entry) {
+		hlist_for_each_entry_rcu(orig_node, head, hash_entry) {
 			/* the dht space is a ring and addresses are unsigned */
 			tmp_max = BATADV_DAT_ADDR_MAX - orig_node->dat_addr +
 				  ip_key;
@@ -686,7 +684,6 @@ int batadv_dat_cache_seq_print_text(struct seq_file *seq, void *offset)
 	unsigned long last_seen_jiffies;
 	int last_seen_msecs, last_seen_secs, last_seen_mins;
@@ -704,7 +701,7 @@ int batadv_dat_cache_seq_print_text(struct seq_file *seq, void *offset)
 		rcu_read_lock();
 			last_seen_jiffies = jiffies - dat_entry->last_update;
 			last_seen_msecs = jiffies_to_msecs(last_seen_jiffies);
 			last_seen_mins = last_seen_msecs / 60000;
diff --git a/net/batman-adv/gateway_client.c b/net/batman-adv/gateway_client.c
index 074107f..34f99a4 100644
--- a/net/batman-adv/gateway_client.c
+++ b/net/batman-adv/gateway_client.c
@@ -114,7 +114,6 @@ static struct batadv_gw_node *
 batadv_gw_get_best_gw_node(struct batadv_priv *bat_priv)
 	struct batadv_neigh_node *router;
 	struct batadv_gw_node *gw_node, *curr_gw = NULL;
 	uint32_t max_gw_factor = 0, tmp_gw_factor = 0;
 	uint32_t gw_divisor;
@@ -127,7 +126,7 @@ batadv_gw_get_best_gw_node(struct batadv_priv *bat_priv)
 	gw_divisor *= 64;
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(gw_node, node, &bat_priv->gw.list, list) {
+	hlist_for_each_entry_rcu(gw_node, &bat_priv->gw.list, list) {
 		if (gw_node->deleted)
 			continue;
@@ -344,7 +343,6 @@ void batadv_gw_node_update(struct batadv_priv *bat_priv,
 			   uint8_t new_gwflags)
 	struct batadv_gw_node *gw_node, *curr_gw;
 	/* Note: We don't need a NULL check here, since curr_gw never gets
@@ -355,7 +353,7 @@ void batadv_gw_node_update(struct batadv_priv *bat_priv,
 	curr_gw = batadv_gw_get_selected_gw_node(bat_priv);
 	rcu_read_lock();
 		if (gw_node->orig_node != orig_node)
 			continue;
@@ -403,7 +401,7 @@ void batadv_gw_node_delete(struct batadv_priv *bat_priv,
 void batadv_gw_node_purge(struct batadv_priv *bat_priv)
 	unsigned long timeout = msecs_to_jiffies(2 * BATADV_PURGE_TIMEOUT);
 	int do_deselect = 0;
@@ -411,7 +409,7 @@ void batadv_gw_node_purge(struct batadv_priv *bat_priv)
 	spin_lock_bh(&bat_priv->gw.list_lock);
-	hlist_for_each_entry_safe(gw_node, node, node_tmp,
+	hlist_for_each_entry_safe(gw_node, node_tmp,
 		if (((!gw_node->deleted) ||
 		     (time_before(jiffies, gw_node->deleted + timeout))) &&
@@ -476,7 +474,6 @@ int batadv_gw_client_seq_print_text(struct seq_file *seq, void *offset)
 	struct batadv_priv *bat_priv = netdev_priv(net_dev);
 	struct batadv_gw_node *gw_node;
 	int gw_count = 0;
 	primary_if = batadv_seq_print_text_primary_if_get(seq);
@@ -490,7 +487,7 @@ int batadv_gw_client_seq_print_text(struct seq_file *seq, void *offset)
 		   primary_if->net_dev->dev_addr, net_dev->name);
 	rcu_read_lock();
 			continue;
diff --git a/net/batman-adv/main.c b/net/batman-adv/main.c
index 21fe698..0488d70 100644
--- a/net/batman-adv/main.c
+++ b/net/batman-adv/main.c
@@ -345,9 +345,8 @@ void batadv_recv_handler_unregister(uint8_t packet_type)
 static struct batadv_algo_ops *batadv_algo_get(char *name)
 	struct batadv_algo_ops *bat_algo_ops = NULL, *bat_algo_ops_tmp;
-	hlist_for_each_entry(bat_algo_ops_tmp, node, &batadv_algo_list, list) {
+	hlist_for_each_entry(bat_algo_ops_tmp, &batadv_algo_list, list) {
 		if (strcmp(bat_algo_ops_tmp->name, name) != 0)
 			continue;
@@ -411,11 +410,10 @@ out:
 int batadv_algo_seq_print_text(struct seq_file *seq, void *offset)
 	struct batadv_algo_ops *bat_algo_ops;
 	seq_printf(seq, "Available routing algorithms:\n");
-	hlist_for_each_entry(bat_algo_ops, node, &batadv_algo_list, list) {
+	hlist_for_each_entry(bat_algo_ops, &batadv_algo_list, list) {
 		seq_printf(seq, "%s\n", bat_algo_ops->name);
diff --git a/net/batman-adv/originator.c b/net/batman-adv/originator.c
index 457ea44..96fb80b 100644
--- a/net/batman-adv/originator.c
+++ b/net/batman-adv/originator.c
@@ -118,7 +118,7 @@ out:
 static void batadv_orig_node_free_rcu(struct rcu_head *rcu)
 	struct batadv_neigh_node *neigh_node, *tmp_neigh_node;
@@ -134,7 +134,7 @@ static void batadv_orig_node_free_rcu(struct rcu_head *rcu)
 	/* for all neighbors towards this originator ... */
-	hlist_for_each_entry_safe(neigh_node, node, node_tmp,
+	hlist_for_each_entry_safe(neigh_node, node_tmp,
 		hlist_del_rcu(&neigh_node->list);
 		batadv_neigh_node_free_ref(neigh_node);
@@ -161,7 +161,7 @@ void batadv_orig_node_free_ref(struct batadv_orig_node *orig_node)
 void batadv_originator_free(struct batadv_priv *bat_priv)
 	spinlock_t *list_lock; /* spinlock to protect write access */
@@ -179,9 +179,9 @@ void batadv_originator_free(struct batadv_priv *bat_priv)
-		hlist_for_each_entry_safe(orig_node, node, node_tmp,
+		hlist_for_each_entry_safe(orig_node, node_tmp,
 					  head, hash_entry) {
+			hlist_del_rcu(&orig_node->hash_entry);
 			batadv_orig_node_free_ref(orig_node);
@@ -274,7 +274,7 @@ batadv_purge_orig_neighbors(struct batadv_priv *bat_priv,
 			    struct batadv_neigh_node **best_neigh_node)
 	struct batadv_neigh_node *neigh_node;
 	bool neigh_purged = false;
 	unsigned long last_seen;
@@ -285,7 +285,7 @@ batadv_purge_orig_neighbors(struct batadv_priv *bat_priv,
 	spin_lock_bh(&orig_node->neigh_list_lock);
 		last_seen = neigh_node->last_seen;
 		if_incoming = neigh_node->if_incoming;
@@ -348,7 +348,7 @@ static bool batadv_purge_orig_node(struct batadv_priv *bat_priv,
 static void _batadv_purge_orig(struct batadv_priv *bat_priv)
@@ -363,13 +363,13 @@ static void _batadv_purge_orig(struct batadv_priv *bat_priv)
 					  head, hash_entry) {
 			if (batadv_purge_orig_node(bat_priv, orig_node)) {
 				if (orig_node->gw_flags)
 					batadv_gw_node_delete(bat_priv,
 							      orig_node);
 				continue;
@@ -408,7 +408,6 @@ int batadv_orig_seq_print_text(struct seq_file *seq, void *offset)
 	struct net_device *net_dev = (struct net_device *)seq->private;
@@ -434,7 +433,7 @@ int batadv_orig_seq_print_text(struct seq_file *seq, void *offset)
 		rcu_read_lock();
 			neigh_node = batadv_orig_node_get_router(orig_node);
 			if (!neigh_node)
 				continue;
@@ -453,7 +452,7 @@ int batadv_orig_seq_print_text(struct seq_file *seq, void *offset)
 				   neigh_node->addr,
 				   neigh_node->if_incoming->net_dev->name);
-			hlist_for_each_entry_rcu(neigh_node_tmp, node_tmp,
+			hlist_for_each_entry_rcu(neigh_node_tmp,
 				seq_printf(seq, " %pM (%3i)",
 					   neigh_node_tmp->addr,
@@ -511,7 +510,6 @@ int batadv_orig_hash_add_if(struct batadv_hard_iface *hard_iface,
 	struct batadv_priv *bat_priv = netdev_priv(hard_iface->soft_iface);
 	uint32_t i;
@@ -524,7 +522,7 @@ int batadv_orig_hash_add_if(struct batadv_hard_iface *hard_iface,
 		rcu_read_lock();
 			spin_lock_bh(&orig_node->ogm_cnt_lock);
 			ret = batadv_orig_node_add_if(orig_node, max_if_num);
 			spin_unlock_bh(&orig_node->ogm_cnt_lock);
@@ -595,7 +593,6 @@ int batadv_orig_hash_del_if(struct batadv_hard_iface *hard_iface,
 	struct batadv_hard_iface *hard_iface_tmp;
@@ -609,7 +606,7 @@ int batadv_orig_hash_del_if(struct batadv_hard_iface *hard_iface,
 		rcu_read_lock();
 			ret = batadv_orig_node_del_if(orig_node, max_if_num,
 						      hard_iface->if_num);
diff --git a/net/batman-adv/originator.h b/net/batman-adv/originator.h
index 286bf74..7df48fa 100644
--- a/net/batman-adv/originator.h
+++ b/net/batman-adv/originator.h
@@ -68,7 +68,6 @@ batadv_orig_hash_find(struct batadv_priv *bat_priv, const void *data)
 	struct batadv_orig_node *orig_node, *orig_node_tmp = NULL;
 	int index;
@@ -79,7 +78,7 @@ batadv_orig_hash_find(struct batadv_priv *bat_priv, const void *data)
 	rcu_read_lock();
 		if (!batadv_compare_eth(orig_node, data))
 			continue;
diff --git a/net/batman-adv/routing.c b/net/batman-adv/routing.c
index 60ba03f..5ee21ce 100644
--- a/net/batman-adv/routing.c
+++ b/net/batman-adv/routing.c
@@ -37,7 +37,6 @@ void batadv_slide_own_bcast_window(struct batadv_hard_iface *hard_iface)
 	unsigned long *word;
@@ -49,7 +48,7 @@ void batadv_slide_own_bcast_window(struct batadv_hard_iface *hard_iface)
 		rcu_read_lock();
 			word_index = hard_iface->if_num * BATADV_NUM_WORDS;
 			word = &(orig_node->bcast_own[word_index]);
@@ -146,7 +145,6 @@ out:
 void batadv_bonding_candidate_add(struct batadv_orig_node *orig_node,
 				  struct batadv_neigh_node *neigh_node)
 	struct batadv_neigh_node *tmp_neigh_node, *router = NULL;
 	uint8_t interference_candidate = 0;
@@ -169,7 +167,7 @@ void batadv_bonding_candidate_add(struct batadv_orig_node *orig_node,
 	 * interface. If we do, we won't select this candidate because of
 	 * possible interference.
 		if (tmp_neigh_node == neigh_node)
 			continue;
diff --git a/net/batman-adv/send.c b/net/batman-adv/send.c
index 80ca65f..a67cffd 100644
--- a/net/batman-adv/send.c
+++ b/net/batman-adv/send.c
@@ -316,7 +316,7 @@ batadv_purge_outstanding_packets(struct batadv_priv *bat_priv,
 				 const struct batadv_hard_iface *hard_iface)
 	struct batadv_forw_packet *forw_packet;
-	struct hlist_node *tmp_node, *safe_tmp_node;
+	struct hlist_node *safe_tmp_node;
 	bool pending;
 	if (hard_iface)
@@ -329,7 +329,7 @@ batadv_purge_outstanding_packets(struct batadv_priv *bat_priv,
 	/* free bcast list */
 	spin_lock_bh(&bat_priv->forw_bcast_list_lock);
-	hlist_for_each_entry_safe(forw_packet, tmp_node, safe_tmp_node,
+	hlist_for_each_entry_safe(forw_packet, safe_tmp_node,
 				  &bat_priv->forw_bcast_list, list) {
 		/* if purge_outstanding_packets() was called with an argument
 		 * we delete only packets belonging to the given interface
@@ -355,7 +355,7 @@ batadv_purge_outstanding_packets(struct batadv_priv *bat_priv,
 	/* free batman packet list */
diff --git a/net/batman-adv/translation-table.c b/net/batman-adv/translation-table.c
index d44672f..98a66a0 100644
--- a/net/batman-adv/translation-table.c
+++ b/net/batman-adv/translation-table.c
@@ -56,7 +56,6 @@ static struct batadv_tt_common_entry *
 batadv_tt_hash_find(struct batadv_hashtable *hash, const void *data)
 	struct batadv_tt_common_entry *tt_common_entry;
 	struct batadv_tt_common_entry *tt_common_entry_tmp = NULL;
 	uint32_t index;
@@ -68,7 +67,7 @@ batadv_tt_hash_find(struct batadv_hashtable *hash, const void *data)
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(tt_common_entry, node, head, hash_entry) {
+	hlist_for_each_entry_rcu(tt_common_entry, head, hash_entry) {
 		if (!batadv_compare_eth(tt_common_entry, data))
 			continue;
@@ -257,7 +256,6 @@ void batadv_tt_local_add(struct net_device *soft_iface, const uint8_t *addr,
 	struct batadv_tt_local_entry *tt_local;
 	struct batadv_tt_global_entry *tt_global;
 	struct batadv_tt_orig_list_entry *orig_entry;
 	int hash_added;
 	bool roamed_back = false;
@@ -339,7 +337,7 @@ check_roaming:
 		/* These node are probably going to update their tt table */
 		head = &tt_global->orig_list;
 		rcu_read_lock();
-		hlist_for_each_entry_rcu(orig_entry, node, head, list) {
+		hlist_for_each_entry_rcu(orig_entry, head, list) {
 			batadv_send_roam_adv(bat_priv, tt_global->common.addr,
 					     orig_entry->orig_node);
@@ -470,7 +468,6 @@ int batadv_tt_local_seq_print_text(struct seq_file *seq, void *offset)
 	uint32_t i;
 	int last_seen_secs;
@@ -494,7 +491,7 @@ int batadv_tt_local_seq_print_text(struct seq_file *seq, void *offset)
 		rcu_read_lock();
 					 head, hash_entry) {
 			tt_local = container_of(tt_common_entry,
 						struct batadv_tt_local_entry,
@@ -605,9 +602,9 @@ static void batadv_tt_local_purge_list(struct batadv_priv *bat_priv,
 	struct batadv_tt_local_entry *tt_local_entry;
-	hlist_for_each_entry_safe(tt_common_entry, node, node_tmp, head,
+	hlist_for_each_entry_safe(tt_common_entry, node_tmp, head,
 				  hash_entry) {
 		tt_local_entry = container_of(tt_common_entry,
@@ -651,7 +648,7 @@ static void batadv_tt_local_table_free(struct batadv_priv *bat_priv)
 	uint32_t i;
@@ -665,9 +662,9 @@ static void batadv_tt_local_table_free(struct batadv_priv *bat_priv)
 					  head, hash_entry) {
+			hlist_del_rcu(&tt_common_entry->hash_entry);
 						common);
@@ -724,11 +721,10 @@ batadv_tt_global_orig_entry_find(const struct batadv_tt_global_entry *entry,
 	struct batadv_tt_orig_list_entry *tmp_orig_entry, *orig_entry = NULL;
 	const struct hlist_head *head;
 	rcu_read_lock();
 	head = &entry->orig_list;
-	hlist_for_each_entry_rcu(tmp_orig_entry, node, head, list) {
+	hlist_for_each_entry_rcu(tmp_orig_entry, head, list) {
 		if (tmp_orig_entry->orig_node != orig_node)
 			continue;
 		if (!atomic_inc_not_zero(&tmp_orig_entry->refcount))
@@ -940,12 +936,11 @@ batadv_transtable_best_orig(struct batadv_tt_global_entry *tt_global_entry)
 	struct batadv_tt_orig_list_entry *orig_entry, *best_entry = NULL;
 	int best_tq = 0;
 	head = &tt_global_entry->orig_list;
 		router = batadv_orig_node_get_router(orig_entry->orig_node);
 		if (!router)
 			continue;
@@ -973,7 +968,6 @@ batadv_tt_global_print_entry(struct batadv_tt_global_entry *tt_global_entry,
 			     struct seq_file *seq)
 	struct batadv_tt_orig_list_entry *orig_entry, *best_entry;
 	uint16_t flags;
@@ -997,7 +991,7 @@ batadv_tt_global_print_entry(struct batadv_tt_global_entry *tt_global_entry,
 		if (best_entry == orig_entry)
 			continue;
@@ -1020,7 +1014,6 @@ int batadv_tt_global_seq_print_text(struct seq_file *seq, void *offset)
 	uint32_t i;
@@ -1039,7 +1032,7 @@ int batadv_tt_global_seq_print_text(struct seq_file *seq, void *offset)
 		rcu_read_lock();
 					 head, hash_entry) {
 			tt_global = container_of(tt_common_entry,
 						 struct batadv_tt_global_entry,
@@ -1059,13 +1052,13 @@ static void
 batadv_tt_global_del_orig_list(struct batadv_tt_global_entry *tt_global_entry)
-	struct hlist_node *node, *safe;
+	struct hlist_node *safe;
 	spin_lock_bh(&tt_global_entry->list_lock);
-	hlist_for_each_entry_safe(orig_entry, node, safe, head, list) {
+	hlist_for_each_entry_safe(orig_entry, safe, head, list) {
+		hlist_del_rcu(&orig_entry->list);
 		batadv_tt_orig_list_entry_free_ref(orig_entry);
 	spin_unlock_bh(&tt_global_entry->list_lock);
@@ -1078,18 +1071,18 @@ batadv_tt_global_del_orig_entry(struct batadv_priv *bat_priv,
 				const char *message)
 		if (orig_entry->orig_node == orig_node) {
 			batadv_dbg(BATADV_DBG_TT, bat_priv,
 				   "Deleting %pM from global tt entry %pM: %s\n",
 				   orig_node->orig,
 				   tt_global_entry->common.addr, message);
@@ -1108,7 +1101,6 @@ batadv_tt_global_del_roaming(struct batadv_priv *bat_priv,
 	bool last_entry = true;
 	/* no local entry exists, case 1:
@@ -1117,7 +1109,7 @@ batadv_tt_global_del_roaming(struct batadv_priv *bat_priv,
 	rcu_read_lock();
 		if (orig_entry->orig_node != orig_node) {
 			last_entry = false;
 			break;
@@ -1202,7 +1194,7 @@ void batadv_tt_global_del_orig(struct batadv_priv *bat_priv,
 	uint32_t i;
 	struct batadv_hashtable *hash = bat_priv->tt.global_hash;
@@ -1214,7 +1206,7 @@ void batadv_tt_global_del_orig(struct batadv_priv *bat_priv,
-		hlist_for_each_entry_safe(tt_common_entry, node, safe,
+		hlist_for_each_entry_safe(tt_common_entry, safe,
 					  head, hash_entry) {
@@ -1227,7 +1219,7 @@ void batadv_tt_global_del_orig(struct batadv_priv *bat_priv,
 					   "Deleting global tt entry %pM: %s\n",
 					   tt_global->common.addr, message);
 				batadv_tt_global_entry_free_ref(tt_global);
@@ -1262,7 +1254,7 @@ static void batadv_tt_global_purge(struct batadv_priv *bat_priv)
 	uint32_t i;
 	char *msg = NULL;
@@ -1274,7 +1266,7 @@ static void batadv_tt_global_purge(struct batadv_priv *bat_priv)
-		hlist_for_each_entry_safe(tt_common, node, node_tmp, head,
+		hlist_for_each_entry_safe(tt_common, node_tmp, head,
 					  hash_entry) {
 			tt_global = container_of(tt_common,
@@ -1287,7 +1279,7 @@ static void batadv_tt_global_purge(struct batadv_priv *bat_priv)
 				   "Deleting global tt entry (%pM): %s\n",
 				   tt_global->common.addr, msg);
+			hlist_del_rcu(&tt_common->hash_entry);
@@ -1301,7 +1293,7 @@ static void batadv_tt_global_table_free(struct batadv_priv *bat_priv)
 	uint32_t i;
@@ -1315,9 +1307,9 @@ static void batadv_tt_global_table_free(struct batadv_priv *bat_priv)
 					  head, hash_entry) {
 						 common);
@@ -1397,7 +1389,6 @@ static uint16_t batadv_tt_global_crc(struct batadv_priv *bat_priv,
 	struct batadv_tt_common_entry *tt_common;
 	uint32_t i;
 	int j;
@@ -1406,7 +1397,7 @@ static uint16_t batadv_tt_global_crc(struct batadv_priv *bat_priv,
 		rcu_read_lock();
-		hlist_for_each_entry_rcu(tt_common, node, head, hash_entry) {
+		hlist_for_each_entry_rcu(tt_common, head, hash_entry) {
 						 common);
@@ -1449,7 +1440,6 @@ static uint16_t batadv_tt_local_crc(struct batadv_priv *bat_priv)
 	uint16_t total = 0, total_one;
 	struct batadv_hashtable *hash = bat_priv->tt.local_hash;
 	uint32_t i;
 	int j;
@@ -1458,7 +1448,7 @@ static uint16_t batadv_tt_local_crc(struct batadv_priv *bat_priv)
 		rcu_read_lock();
 			/* not yet committed clients have not to be taken into
 			 * account while computing the CRC
@@ -1597,7 +1587,6 @@ batadv_tt_response_fill_table(uint16_t tt_len, uint8_t ttvn,
 	struct batadv_tt_query_packet *tt_response;
 	struct batadv_tt_change *tt_change;
 	struct sk_buff *skb = NULL;
 	uint16_t tt_tot, tt_count;
@@ -1627,7 +1616,7 @@ batadv_tt_response_fill_table(uint16_t tt_len, uint8_t ttvn,
 	for (i = 0; i < hash->size; i++) {
 					 head, hash_entry) {
 			if (tt_count == tt_tot)
 				break;
@@ -2307,7 +2296,6 @@ static uint16_t batadv_tt_set_flags(struct batadv_hashtable *hash,
 	uint32_t i;
 	uint16_t changed_num = 0;
 	if (!hash)
@@ -2317,7 +2305,7 @@ static uint16_t batadv_tt_set_flags(struct batadv_hashtable *hash,
 		rcu_read_lock();
 					 head, hash_entry) {
 			if (enable) {
 				if ((tt_common_entry->flags & flags) == flags)
@@ -2342,7 +2330,7 @@ static void batadv_tt_local_purge_pending_clients(struct batadv_priv *bat_priv)
 	uint32_t i;
@@ -2355,7 +2343,7 @@ static void batadv_tt_local_purge_pending_clients(struct batadv_priv *bat_priv)
 					  hash_entry) {
 			if (!(tt_common->flags & BATADV_TT_CLIENT_PENDING))
 				continue;
@@ -2365,7 +2353,7 @@ static void batadv_tt_local_purge_pending_clients(struct batadv_priv *bat_priv)
 				   tt_common->addr);
 			atomic_dec(&bat_priv->tt.local_entry_num);
 			tt_local = container_of(tt_common,
 						common);
diff --git a/net/batman-adv/vis.c b/net/batman-adv/vis.c
index 22d2785..c053244 100644
--- a/net/batman-adv/vis.c
+++ b/net/batman-adv/vis.c
@@ -97,7 +97,6 @@ batadv_vis_hash_find(struct batadv_priv *bat_priv, const void *data)
 	struct batadv_hashtable *hash = bat_priv->vis.hash;
 	struct batadv_vis_info *vis_info, *vis_info_tmp = NULL;
 	uint32_t index;
@@ -108,8 +107,8 @@ batadv_vis_hash_find(struct batadv_priv *bat_priv, const void *data)
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(vis_info, node, head, hash_entry) {
-		if (!batadv_vis_info_cmp(node, data))
+	hlist_for_each_entry_rcu(vis_info, head, hash_entry) {
+		if (!batadv_vis_info_cmp(&vis_info->hash_entry, data))
 			continue;
 		vis_info_tmp = vis_info;
@@ -128,9 +127,8 @@ static void batadv_vis_data_insert_interface(const uint8_t *interface,
 					     bool primary)
 	struct batadv_vis_if_list_entry *entry;
-	hlist_for_each_entry(entry, pos, if_list, list) {
+	hlist_for_each_entry(entry, if_list, list) {
 		if (batadv_compare_eth(entry->addr, interface))
 			return;
@@ -148,9 +146,8 @@ static void batadv_vis_data_read_prim_sec(struct seq_file *seq,
 					  const struct hlist_head *if_list)
 		if (entry->primary)
 			seq_printf(seq, "PRIMARY, ");
 		else
@@ -198,9 +195,8 @@ static void batadv_vis_data_read_entries(struct seq_file *seq,
 	int i;
-	hlist_for_each_entry(entry, pos, list, list) {
+	hlist_for_each_entry(entry, list, list) {
 		seq_printf(seq, "%pM,", entry->addr);
 		for (i = 0; i < packet->entries; i++)
@@ -218,17 +214,16 @@ static void batadv_vis_data_read_entries(struct seq_file *seq,
 static void batadv_vis_seq_print_text_bucket(struct seq_file *seq,
 					     const struct hlist_head *head)
 	struct batadv_vis_info *info;
 	struct batadv_vis_packet *packet;
 	uint8_t *entries_pos;
 	struct batadv_vis_info_entry *entries;
-	struct hlist_node *pos, *n;
+	struct hlist_node *n;
 	HLIST_HEAD(vis_if_list);
-	hlist_for_each_entry_rcu(info, node, head, hash_entry) {
+	hlist_for_each_entry_rcu(info, head, hash_entry) {
 		packet = (struct batadv_vis_packet *)info->skb_packet->data;
 		entries_pos = (uint8_t *)packet + sizeof(*packet);
 		entries = (struct batadv_vis_info_entry *)entries_pos;
@@ -240,7 +235,7 @@ static void batadv_vis_seq_print_text_bucket(struct seq_file *seq,
 		batadv_vis_data_read_entries(seq, &vis_if_list, packet,
 					     entries);
-		hlist_for_each_entry_safe(entry, pos, n, &vis_if_list, list) {
+		hlist_for_each_entry_safe(entry, n, &vis_if_list, list) {
 			hlist_del(&entry->list);
 			kfree(entry);
@@ -519,7 +514,6 @@ static int batadv_find_best_vis_server(struct batadv_priv *bat_priv,
@@ -532,7 +526,7 @@ static int batadv_find_best_vis_server(struct batadv_priv *bat_priv,
 		rcu_read_lock();
 			router = batadv_orig_node_get_router(orig_node);
 			if (!router)
 				continue;
@@ -571,7 +565,6 @@ static bool batadv_vis_packet_full(const struct batadv_vis_info *info)
 static int batadv_generate_vis_packet(struct batadv_priv *bat_priv)
@@ -605,7 +598,7 @@ static int batadv_generate_vis_packet(struct batadv_priv *bat_priv)
 		rcu_read_lock();
 			if (!router)
 				continue;
@@ -644,7 +637,7 @@ next:
 		rcu_read_lock();
 					 hash_entry) {
 			packet_pos = skb_put(info->skb_packet, sizeof(*entry));
 			entry = (struct batadv_vis_info_entry *)packet_pos;
@@ -673,14 +666,14 @@ static void batadv_purge_vis_packets(struct batadv_priv *bat_priv)
 	uint32_t i;
-		hlist_for_each_entry_safe(info, node, node_tmp,
+		hlist_for_each_entry_safe(info, node_tmp,
 					  head, hash_entry) {
 			/* never purge own data. */
 			if (info == bat_priv->vis.my_info)
@@ -688,7 +681,7 @@ static void batadv_purge_vis_packets(struct batadv_priv *bat_priv)
 			if (batadv_has_timed_out(info->first_seen,
 						 BATADV_VIS_TIMEOUT)) {
-				hlist_del(node);
+				hlist_del(&info->hash_entry);
 				batadv_send_list_del(info);
 				kref_put(&info->refcount, batadv_free_info);
@@ -700,7 +693,6 @@ static void batadv_broadcast_vis_packet(struct batadv_priv *bat_priv,
@@ -715,7 +707,7 @@ static void batadv_broadcast_vis_packet(struct batadv_priv *bat_priv,
 		rcu_read_lock();
 			/* if it's a vis server and reachable, send it. */
 			if (!(orig_node->flags & BATADV_VIS_SERVER))
 				continue;
diff --git a/net/bluetooth/hci_sock.c b/net/bluetooth/hci_sock.c
index 07f0739..6a93614 100644
--- a/net/bluetooth/hci_sock.c
+++ b/net/bluetooth/hci_sock.c
@@ -70,14 +70,13 @@ static struct bt_sock_list hci_sk_list = {
 void hci_send_to_sock(struct hci_dev *hdev, struct sk_buff *skb)
 	struct sock *sk;
 	struct sk_buff *skb_copy = NULL;
 	BT_DBG("hdev %p len %d", hdev, skb->len);
 	read_lock(&hci_sk_list.lock);
-	sk_for_each(sk, node, &hci_sk_list.head) {
+	sk_for_each(sk, &hci_sk_list.head) {
 		struct hci_filter *flt;
 		struct sk_buff *nskb;
@@ -142,13 +141,12 @@ void hci_send_to_sock(struct hci_dev *hdev, struct sk_buff *skb)
 void hci_send_to_control(struct sk_buff *skb, struct sock *skip_sk)
 	struct sock *sk;
 	BT_DBG("len %d", skb->len);
 		/* Skip the original socket */
@@ -176,7 +174,6 @@ void hci_send_to_control(struct sk_buff *skb, struct sock *skip_sk)
 void hci_send_to_monitor(struct hci_dev *hdev, struct sk_buff *skb)
 	struct sock *sk;
 	__le16 opcode;
@@ -210,7 +207,7 @@ void hci_send_to_monitor(struct hci_dev *hdev, struct sk_buff *skb)
 		if (sk->sk_state != BT_BOUND)
@@ -251,13 +248,12 @@ void hci_send_to_monitor(struct hci_dev *hdev, struct sk_buff *skb)
 static void send_monitor_event(struct sk_buff *skb)
 	struct sock *sk;
@@ -393,11 +389,10 @@ void hci_sock_dev_event(struct hci_dev *hdev, int event)
 	if (event == HCI_DEV_UNREG) {
 		struct sock *sk;
 		/* Detach sockets from device */
 			bh_lock_sock_nested(sk);
 			if (hci_pi(sk)->hdev == hdev) {
 				hci_pi(sk)->hdev = NULL;
diff --git a/net/bluetooth/rfcomm/sock.c b/net/bluetooth/rfcomm/sock.c
index ce3f665..c23bae8 100644
--- a/net/bluetooth/rfcomm/sock.c
+++ b/net/bluetooth/rfcomm/sock.c
@@ -107,15 +107,14 @@ static void rfcomm_sk_state_change(struct rfcomm_dlc *d, int err)
 static struct sock *__rfcomm_get_sock_by_addr(u8 channel, bdaddr_t *src)
-	sk_for_each(sk, node, &rfcomm_sk_list.head) {
+	sk_for_each(sk, &rfcomm_sk_list.head) {
 		if (rfcomm_pi(sk)->channel == channel &&
 				!bacmp(&bt_sk(sk)->src, src))
 			break;
-	return node ? sk : NULL;
+	return sk ? sk : NULL;
 /* Find socket with channel and source bdaddr.
@@ -124,11 +123,10 @@ static struct sock *__rfcomm_get_sock_by_addr(u8 channel, bdaddr_t *src)
 static struct sock *rfcomm_get_sock_by_channel(int state, u8 channel, bdaddr_t *src)
 	struct sock *sk = NULL, *sk1 = NULL;
 	read_lock(&rfcomm_sk_list.lock);
 		if (state && sk->sk_state != state)
 			continue;
@@ -145,7 +143,7 @@ static struct sock *rfcomm_get_sock_by_channel(int state, u8 channel, bdaddr_t *
 	read_unlock(&rfcomm_sk_list.lock);
-	return node ? sk : sk1;
+	return sk ? sk : sk1;
 static void rfcomm_sock_destruct(struct sock *sk)
@@ -970,11 +968,10 @@ done:
 static int rfcomm_sock_debugfs_show(struct seq_file *f, void *p)
 	struct sock *sk;
 		seq_printf(f, "%pMR %pMR %d %d\n",
 			   &bt_sk(sk)->src, &bt_sk(sk)->dst,
 			   sk->sk_state, rfcomm_pi(sk)->channel);
diff --git a/net/bluetooth/sco.c b/net/bluetooth/sco.c
index b5178d6..79d87d8 100644
--- a/net/bluetooth/sco.c
+++ b/net/bluetooth/sco.c
@@ -259,10 +259,9 @@ drop:
 /* -------- Socket interface ---------- */
 static struct sock *__sco_get_sock_listen_by_addr(bdaddr_t *ba)
 	struct sock *sk;
-	sk_for_each(sk, node, &sco_sk_list.head) {
+	sk_for_each(sk, &sco_sk_list.head) {
 		if (sk->sk_state != BT_LISTEN)
 			continue;
@@ -279,11 +278,10 @@ static struct sock *__sco_get_sock_listen_by_addr(bdaddr_t *ba)
 static struct sock *sco_get_sock_listen(bdaddr_t *src)
 	read_lock(&sco_sk_list.lock);
 			continue;
@@ -298,7 +296,7 @@ static struct sock *sco_get_sock_listen(bdaddr_t *src)
 	read_unlock(&sco_sk_list.lock);
 static void sco_sock_destruct(struct sock *sk)
@@ -951,14 +949,13 @@ static void sco_conn_ready(struct sco_conn *conn)
 int sco_connect_ind(struct hci_dev *hdev, bdaddr_t *bdaddr, __u8 *flags)
 	struct sock *sk;
 	int lm = 0;
 	BT_DBG("hdev %s, bdaddr %pMR", hdev->name, bdaddr);
 	/* Find listening sockets */
 			continue;
@@ -1018,11 +1015,10 @@ drop:
 static int sco_debugfs_show(struct seq_file *f, void *p)
 	struct sock *sk;
 		seq_printf(f, "%pMR %pMR %d\n", &bt_sk(sk)->src,
 			   &bt_sk(sk)->dst, sk->sk_state);
diff --git a/net/bridge/br_fdb.c b/net/bridge/br_fdb.c
index 8117900..b0812c9 100644
--- a/net/bridge/br_fdb.c
+++ b/net/bridge/br_fdb.c
@@ -181,9 +181,9 @@ void br_fdb_cleanup(unsigned long _data)
 	spin_lock(&br->hash_lock);
 	for (i = 0; i < BR_HASH_SIZE; i++) {
 		struct net_bridge_fdb_entry *f;
-		struct hlist_node *h, *n;
-		hlist_for_each_entry_safe(f, h, n, &br->hash[i], hlist) {
+		hlist_for_each_entry_safe(f, n, &br->hash[i], hlist) {
 			unsigned long this_timer;
 			if (f->is_static)
 				continue;
@@ -207,8 +207,8 @@ void br_fdb_flush(struct net_bridge *br)
 	spin_lock_bh(&br->hash_lock);
 			if (!f->is_static)
 				fdb_delete(br, f);
@@ -266,10 +266,9 @@ struct net_bridge_fdb_entry *__br_fdb_get(struct net_bridge *br,
 					  const unsigned char *addr,
 					  __u16 vid)
-	struct hlist_node *h;
 	struct net_bridge_fdb_entry *fdb;
-	hlist_for_each_entry_rcu(fdb, h,
+	hlist_for_each_entry_rcu(fdb,
 				&br->hash[br_mac_hash(addr, vid)], hlist) {
 		if (ether_addr_equal(fdb->addr.addr, addr) &&
 		    fdb->vlan_id == vid) {
@@ -315,14 +314,13 @@ int br_fdb_fillbuf(struct net_bridge *br, void *buf,
 	struct __fdb_entry *fe = buf;
 	int i, num = 0;
 	memset(buf, 0, maxnum*sizeof(struct __fdb_entry));
 	rcu_read_lock();
-		hlist_for_each_entry_rcu(f, h, &br->hash[i], hlist) {
+		hlist_for_each_entry_rcu(f, &br->hash[i], hlist) {
 			if (num >= maxnum)
 				goto out;
@@ -363,10 +361,9 @@ static struct net_bridge_fdb_entry *fdb_find(struct hlist_head *head,
 					     __u16 vid)
-	hlist_for_each_entry(fdb, h, head, hlist) {
+	hlist_for_each_entry(fdb, head, hlist) {
 			return fdb;
@@ -378,10 +375,9 @@ static struct net_bridge_fdb_entry *fdb_find_rcu(struct hlist_head *head,
 						 __u16 vid)
-	hlist_for_each_entry_rcu(fdb, h, head, hlist) {
+	hlist_for_each_entry_rcu(fdb, head, hlist) {
 			return fdb;
@@ -593,10 +589,9 @@ int br_fdb_dump(struct sk_buff *skb,
 		goto out;
 			if (idx < cb->args[0])
 				goto skip;
diff --git a/net/bridge/br_mdb.c b/net/bridge/br_mdb.c
index 38991e0..9f97b85 100644
--- a/net/bridge/br_mdb.c
+++ b/net/bridge/br_mdb.c
@@ -18,7 +18,6 @@ static int br_rports_fill_info(struct sk_buff *skb, struct netlink_callback *cb,
 	struct net_bridge *br = netdev_priv(dev);
 	struct net_bridge_port *p;
-	struct hlist_node *n;
 	struct nlattr *nest;
 	if (!br->multicast_router || hlist_empty(&br->router_list))
@@ -28,7 +27,7 @@ static int br_rports_fill_info(struct sk_buff *skb, struct netlink_callback *cb,
 	if (nest == NULL)
 		return -EMSGSIZE;
-	hlist_for_each_entry_rcu(p, n, &br->router_list, rlist) {
+	hlist_for_each_entry_rcu(p, &br->router_list, rlist) {
 		if (p && nla_put_u32(skb, MDBA_ROUTER_PORT, p->dev->ifindex))
 			goto fail;
@@ -61,12 +60,11 @@ static int br_mdb_fill_info(struct sk_buff *skb, struct netlink_callback *cb,
 		return -EMSGSIZE;
 	for (i = 0; i < mdb->max; i++) {
 		struct net_bridge_mdb_entry *mp;
 		struct net_bridge_port_group *p, **pp;
 		struct net_bridge_port *port;
-		hlist_for_each_entry_rcu(mp, h, &mdb->mhash[i], hlist[mdb->ver]) {
+		hlist_for_each_entry_rcu(mp, &mdb->mhash[i], hlist[mdb->ver]) {
 			if (idx < s_idx)
 				goto skip;
diff --git a/net/bridge/br_multicast.c b/net/bridge/br_multicast.c
index 7d886b0..10e6fce 100644
--- a/net/bridge/br_multicast.c
+++ b/net/bridge/br_multicast.c
@@ -86,9 +86,8 @@ static struct net_bridge_mdb_entry *__br_mdb_ip_get(
 	struct net_bridge_mdb_htable *mdb, struct br_ip *dst, int hash)
-	hlist_for_each_entry_rcu(mp, p, &mdb->mhash[hash], hlist[mdb->ver]) {
+	hlist_for_each_entry_rcu(mp, &mdb->mhash[hash], hlist[mdb->ver]) {
 		if (br_ip_equal(&mp->addr, dst))
 			return mp;
@@ -178,13 +177,12 @@ static int br_mdb_copy(struct net_bridge_mdb_htable *new,
 		       int elasticity)
 	int maxlen;
 	int len;
 	int i;
 	for (i = 0; i < old->max; i++)
-		hlist_for_each_entry(mp, p, &old->mhash[i], hlist[old->ver])
+		hlist_for_each_entry(mp, &old->mhash[i], hlist[old->ver])
 			hlist_add_head(&mp->hlist[new->ver],
 				       &new->mhash[br_ip_hash(new, &mp->addr)]);
@@ -194,7 +192,7 @@ static int br_mdb_copy(struct net_bridge_mdb_htable *new,
 	maxlen = 0;
 	for (i = 0; i < new->max; i++) {
 		len = 0;
-		hlist_for_each_entry(mp, p, &new->mhash[i], hlist[new->ver])
+		hlist_for_each_entry(mp, &new->mhash[i], hlist[new->ver])
 			len++;
 		if (len > maxlen)
 			maxlen = len;
@@ -510,14 +508,13 @@ static struct net_bridge_mdb_entry *br_multicast_get_group(
 	struct net_bridge_mdb_htable *mdb;
 	unsigned int count = 0;
 	unsigned int max;
 	int elasticity;
 	int err;
 	mdb = rcu_dereference_protected(br->mdb, 1);
-	hlist_for_each_entry(mp, p, &mdb->mhash[hash], hlist[mdb->ver]) {
+	hlist_for_each_entry(mp, &mdb->mhash[hash], hlist[mdb->ver]) {
 		count++;
 		if (unlikely(br_ip_equal(group, &mp->addr)))
 			return mp;
@@ -882,10 +879,10 @@ void br_multicast_disable_port(struct net_bridge_port *port)
 	struct net_bridge *br = port->br;
 	struct net_bridge_port_group *pg;
-	struct hlist_node *p, *n;
 	spin_lock(&br->multicast_lock);
-	hlist_for_each_entry_safe(pg, p, n, &port->mglist, mglist)
+	hlist_for_each_entry_safe(pg, n, &port->mglist, mglist)
 		br_multicast_del_pg(br, pg);
 	if (!hlist_unhashed(&port->rlist))
@@ -1025,12 +1022,12 @@ static void br_multicast_add_router(struct net_bridge *br,
-	struct hlist_node *n, *slot = NULL;
+	struct hlist_node *slot = NULL;
-	hlist_for_each_entry(p, n, &br->router_list, rlist) {
+	hlist_for_each_entry(p, &br->router_list, rlist) {
 		if ((unsigned long) port >= (unsigned long) p)
 			break;
-		slot = n;
+		slot = &p->rlist;
 	if (slot)
@@ -1653,7 +1650,7 @@ void br_multicast_stop(struct net_bridge *br)
 	u32 ver;
 	int i;
@@ -1670,7 +1667,7 @@ void br_multicast_stop(struct net_bridge *br)
 	ver = mdb->ver;
-		hlist_for_each_entry_safe(mp, p, n, &mdb->mhash[i],
+		hlist_for_each_entry_safe(mp, n, &mdb->mhash[i],
 					  hlist[ver]) {
 			del_timer(&mp->timer);
 			call_rcu_bh(&mp->rcu, br_multicast_free_group);
diff --git a/net/can/af_can.c b/net/can/af_can.c
index ddac1ee..c48e522 100644
--- a/net/can/af_can.c
+++ b/net/can/af_can.c
@@ -516,7 +516,6 @@ void can_rx_unregister(struct net_device *dev, canid_t can_id, canid_t mask,
 	struct receiver *r = NULL;
 	struct hlist_head *rl;
-	struct hlist_node *next;
 	struct dev_rcv_lists *d;
 	if (dev && dev->type != ARPHRD_CAN)
@@ -540,7 +539,7 @@ void can_rx_unregister(struct net_device *dev, canid_t can_id, canid_t mask,
 	 * been registered before.
-	hlist_for_each_entry_rcu(r, next, rl, list) {
+	hlist_for_each_entry_rcu(r, rl, list) {
 		if (r->can_id == can_id && r->mask == mask &&
 		    r->func == func && r->data == data)
 			break;
@@ -552,7 +551,7 @@ void can_rx_unregister(struct net_device *dev, canid_t can_id, canid_t mask,
 	 * will be NULL, while r will point to the last item of the list.
-	if (!next) {
+	if (!r) {
 		printk(KERN_ERR "BUG: receive list entry not found for "
 		       "dev %s, id %03X, mask %03X\n",
 		       DNAME(dev), can_id, mask);
@@ -590,7 +589,6 @@ static inline void deliver(struct sk_buff *skb, struct receiver *r)
 static int can_rcv_filter(struct dev_rcv_lists *d, struct sk_buff *skb)
 	struct receiver *r;
 	int matches = 0;
 	struct can_frame *cf = (struct can_frame *)skb->data;
 	canid_t can_id = cf->can_id;
@@ -600,7 +598,7 @@ static int can_rcv_filter(struct dev_rcv_lists *d, struct sk_buff *skb)
 	if (can_id & CAN_ERR_FLAG) {
 		/* check for error message frame entries only */
-		hlist_for_each_entry_rcu(r, n, &d->rx[RX_ERR], list) {
+		hlist_for_each_entry_rcu(r, &d->rx[RX_ERR], list) {
 			if (can_id & r->mask) {
 				deliver(skb, r);
 				matches++;
@@ -610,13 +608,13 @@ static int can_rcv_filter(struct dev_rcv_lists *d, struct sk_buff *skb)
 	/* check for unfiltered entries */
-	hlist_for_each_entry_rcu(r, n, &d->rx[RX_ALL], list) {
+	hlist_for_each_entry_rcu(r, &d->rx[RX_ALL], list) {
 		deliver(skb, r);
 		matches++;
 	/* check for can_id/mask entries */
-	hlist_for_each_entry_rcu(r, n, &d->rx[RX_FIL], list) {
+	hlist_for_each_entry_rcu(r, &d->rx[RX_FIL], list) {
 		if ((can_id & r->mask) == r->can_id) {
 			deliver(skb, r);
 			matches++;
@@ -624,7 +622,7 @@ static int can_rcv_filter(struct dev_rcv_lists *d, struct sk_buff *skb)
 	/* check for inverted can_id/mask entries */
-	hlist_for_each_entry_rcu(r, n, &d->rx[RX_INV], list) {
+	hlist_for_each_entry_rcu(r, &d->rx[RX_INV], list) {
 		if ((can_id & r->mask) != r->can_id) {
 			deliver(skb, r);
 			matches++;
@@ -636,7 +634,7 @@ static int can_rcv_filter(struct dev_rcv_lists *d, struct sk_buff *skb)
 		return matches;
 	if (can_id & CAN_EFF_FLAG) {
-		hlist_for_each_entry_rcu(r, n, &d->rx[RX_EFF], list) {
+		hlist_for_each_entry_rcu(r, &d->rx[RX_EFF], list) {
 			if (r->can_id == can_id) {
 				deliver(skb, r);
 				matches++;
@@ -644,7 +642,7 @@ static int can_rcv_filter(struct dev_rcv_lists *d, struct sk_buff *skb)
 	} else {
 		can_id &= CAN_SFF_MASK;
-		hlist_for_each_entry_rcu(r, n, &d->rx_sff[can_id], list) {
+		hlist_for_each_entry_rcu(r, &d->rx_sff[can_id], list) {
 			deliver(skb, r);
 			matches++;
diff --git a/net/can/gw.c b/net/can/gw.c
index c185fcd..2d117dc 100644
--- a/net/can/gw.c
+++ b/net/can/gw.c
@@ -457,11 +457,11 @@ static int cgw_notifier(struct notifier_block *nb,
 	if (msg == NETDEV_UNREGISTER) {
 		struct cgw_job *gwj = NULL;
-		struct hlist_node *n, *nx;
+		struct hlist_node *nx;
 		ASSERT_RTNL();
-		hlist_for_each_entry_safe(gwj, n, nx, &cgw_list, list) {
+		hlist_for_each_entry_safe(gwj, nx, &cgw_list, list) {
 			if (gwj->src.dev == dev || gwj->dst.dev == dev) {
 				hlist_del(&gwj->list);
@@ -575,12 +575,11 @@ cancel:
 static int cgw_dump_jobs(struct sk_buff *skb, struct netlink_callback *cb)
 	int idx = 0;
 	int s_idx = cb->args[0];
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(gwj, n, &cgw_list, list) {
+	hlist_for_each_entry_rcu(gwj, &cgw_list, list) {
 		if (idx < s_idx)
 			goto cont;
@@ -858,11 +857,11 @@ out:
 static void cgw_remove_all_jobs(void)
 	ASSERT_RTNL();
 		cgw_unregister_filter(gwj);
 		kfree(gwj);
@@ -872,7 +871,7 @@ static void cgw_remove_all_jobs(void)
 static int cgw_remove_job(struct sk_buff *skb,  struct nlmsghdr *nlh, void *arg)
 	struct rtcanmsg *r;
 	struct cf_mod mod;
 	struct can_can_gw ccgw;
@@ -907,7 +906,7 @@ static int cgw_remove_job(struct sk_buff *skb,  struct nlmsghdr *nlh, void *arg)
 	ASSERT_RTNL();
 	/* remove only the first matching entry */
 		if (gwj->flags != r->flags)
 			continue;
diff --git a/net/can/proc.c b/net/can/proc.c
index 4973358..1ab8c88 100644
--- a/net/can/proc.c
+++ b/net/can/proc.c
@@ -195,9 +195,8 @@ static void can_print_rcvlist(struct seq_file *m, struct hlist_head *rx_list,
 	struct receiver *r;
-	hlist_for_each_entry_rcu(r, n, rx_list, list) {
+	hlist_for_each_entry_rcu(r, rx_list, list) {
 		char *fmt = (r->can_id & CAN_EFF_FLAG)?
 			"   %-5s  %08x  %08x  %pK  %pK  %8ld  %s\n" :
 			"   %-5s     %03x    %08x  %pK  %pK  %8ld  %s\n";
diff --git a/net/core/dev.c b/net/core/dev.c
index 18d8b5a..a06a7a5 100644
--- a/net/core/dev.c
+++ b/net/core/dev.c
@@ -658,11 +658,10 @@ __setup("netdev=", netdev_boot_setup);
 struct net_device *__dev_get_by_name(struct net *net, const char *name)
 	struct net_device *dev;
 	struct hlist_head *head = dev_name_hash(net, name);
-	hlist_for_each_entry(dev, p, head, name_hlist)
+	hlist_for_each_entry(dev, head, name_hlist)
 		if (!strncmp(dev->name, name, IFNAMSIZ))
 			return dev;
@@ -684,11 +683,10 @@ EXPORT_SYMBOL(__dev_get_by_name);
 struct net_device *dev_get_by_name_rcu(struct net *net, const char *name)
-	hlist_for_each_entry_rcu(dev, p, head, name_hlist)
+	hlist_for_each_entry_rcu(dev, head, name_hlist)
 			return dev;
@@ -735,11 +733,10 @@ EXPORT_SYMBOL(dev_get_by_name);
 struct net_device *__dev_get_by_index(struct net *net, int ifindex)
-	struct hlist_node *p;
 	struct hlist_head *head = dev_index_hash(net, ifindex);
-	hlist_for_each_entry(dev, p, head, index_hlist)
+	hlist_for_each_entry(dev, head, index_hlist)
 		if (dev->ifindex == ifindex)
 			return dev;
@@ -760,11 +757,10 @@ EXPORT_SYMBOL(__dev_get_by_index);
 struct net_device *dev_get_by_index_rcu(struct net *net, int ifindex)
-	hlist_for_each_entry_rcu(dev, p, head, index_hlist)
+	hlist_for_each_entry_rcu(dev, head, index_hlist)
 			return dev;
diff --git a/net/core/flow.c b/net/core/flow.c
index 43f7495..c56ea6f 100644
--- a/net/core/flow.c
+++ b/net/core/flow.c
@@ -132,14 +132,14 @@ static void __flow_cache_shrink(struct flow_cache *fc,
 				int shrink_to)
 	struct flow_cache_entry *fle;
-	struct hlist_node *entry, *tmp;
+	struct hlist_node *tmp;
 	LIST_HEAD(gc_list);
 	int i, deleted = 0;
 	for (i = 0; i < flow_cache_hash_size(fc); i++) {
 		int saved = 0;
-		hlist_for_each_entry_safe(fle, entry, tmp,
+		hlist_for_each_entry_safe(fle, tmp,
 					  &fcp->hash_table[i], u.hlist) {
 			if (saved < shrink_to &&
 			    flow_entry_valid(fle)) {
@@ -211,7 +211,6 @@ flow_cache_lookup(struct net *net, const struct flowi *key, u16 family, u8 dir,
 	struct flow_cache *fc = &flow_cache_global;
 	struct flow_cache_percpu *fcp;
 	struct flow_cache_entry *fle, *tfle;
-	struct hlist_node *entry;
 	struct flow_cache_object *flo;
 	size_t keysize;
 	unsigned int hash;
@@ -235,7 +234,7 @@ flow_cache_lookup(struct net *net, const struct flowi *key, u16 family, u8 dir,
 		flow_new_hash_rnd(fc, fcp);
 	hash = flow_hash_code(fc, fcp, key, keysize);
-	hlist_for_each_entry(tfle, entry, &fcp->hash_table[hash], u.hlist) {
+	hlist_for_each_entry(tfle, &fcp->hash_table[hash], u.hlist) {
 		if (tfle->net == net &&
 		    tfle->family == family &&
 		    tfle->dir == dir &&
@@ -301,13 +300,13 @@ static void flow_cache_flush_tasklet(unsigned long data)
 	struct flow_cache *fc = info->cache;
 	LIST_HEAD(gc_list);
 	int i, deleted = 0;
 	fcp = this_cpu_ptr(fc->percpu);
 			if (flow_entry_valid(fle))
 				continue;
diff --git a/net/core/net-procfs.c b/net/core/net-procfs.c
index 0f6bb6f..3174f19 100644
--- a/net/core/net-procfs.c
+++ b/net/core/net-procfs.c
@@ -16,12 +16,11 @@ static inline struct net_device *dev_from_same_bucket(struct seq_file *seq, loff
 	struct net *net = seq_file_net(seq);
 	struct hlist_head *h;
 	unsigned int count = 0, offset = get_offset(*pos);
 	h = &net->dev_name_head[get_bucket(*pos)];
-	hlist_for_each_entry_rcu(dev, p, h, name_hlist) {
+	hlist_for_each_entry_rcu(dev, h, name_hlist) {
 		if (++count == offset)
 			return dev;
diff --git a/net/core/rtnetlink.c b/net/core/rtnetlink.c
index d8aa20f..b376410 100644
--- a/net/core/rtnetlink.c
+++ b/net/core/rtnetlink.c
@@ -1060,7 +1060,6 @@ static int rtnl_dump_ifinfo(struct sk_buff *skb, struct netlink_callback *cb)
 	int idx = 0, s_idx;
 	struct nlattr *tb[IFLA_MAX+1];
 	u32 ext_filter_mask = 0;
@@ -1080,7 +1079,7 @@ static int rtnl_dump_ifinfo(struct sk_buff *skb, struct netlink_callback *cb)
 	for (h = s_h; h < NETDEV_HASHENTRIES; h++, s_idx = 0) {
 		idx = 0;
 		head = &net->dev_index_head[h];
-		hlist_for_each_entry_rcu(dev, node, head, index_hlist) {
+		hlist_for_each_entry_rcu(dev, head, index_hlist) {
 			if (idx < s_idx)
 				goto cont;
 			if (rtnl_fill_ifinfo(skb, dev, RTM_NEWLINK,
diff --git a/net/decnet/af_decnet.c b/net/decnet/af_decnet.c
index c4a2def..c21f200 100644
--- a/net/decnet/af_decnet.c
+++ b/net/decnet/af_decnet.c
@@ -175,12 +175,11 @@ static struct hlist_head *dn_find_list(struct sock *sk)
 static int check_port(__le16 port)
 	struct sock *sk;
 	if (port == 0)
 		return -1;
-	sk_for_each(sk, node, &dn_sk_hash[le16_to_cpu(port) & DN_SK_HASH_MASK]) {
+	sk_for_each(sk, &dn_sk_hash[le16_to_cpu(port) & DN_SK_HASH_MASK]) {
 		struct dn_scp *scp = DN_SK(sk);
 		if (scp->addrloc == port)
 			return -1;
@@ -374,11 +373,10 @@ int dn_username2sockaddr(unsigned char *data, int len, struct sockaddr_dn *sdn,
 struct sock *dn_sklist_find_listener(struct sockaddr_dn *addr)
 	struct hlist_head *list = listen_hash(addr);
 	struct sock *sk;
 	read_lock(&dn_hash_lock);
-	sk_for_each(sk, node, list) {
+	sk_for_each(sk, list) {
 		if (sk->sk_state != TCP_LISTEN)
 			continue;
@@ -414,11 +412,10 @@ struct sock *dn_find_by_skb(struct sk_buff *skb)
 	struct dn_skb_cb *cb = DN_SKB_CB(skb);
 	struct sock *sk;
 	struct dn_scp *scp;
-	sk_for_each(sk, node, &dn_sk_hash[le16_to_cpu(cb->dst_port) & DN_SK_HASH_MASK]) {
+	sk_for_each(sk, &dn_sk_hash[le16_to_cpu(cb->dst_port) & DN_SK_HASH_MASK]) {
 		scp = DN_SK(sk);
 		if (cb->src != dn_saddr2dn(&scp->peer))
 			continue;
diff --git a/net/decnet/dn_table.c b/net/decnet/dn_table.c
index f968c1b..6c2445b 100644
--- a/net/decnet/dn_table.c
+++ b/net/decnet/dn_table.c
@@ -483,7 +483,6 @@ int dn_fib_dump(struct sk_buff *skb, struct netlink_callback *cb)
 	unsigned int h, s_h;
 	unsigned int e = 0, s_e;
 	struct dn_fib_table *tb;
 	int dumped = 0;
 	if (!net_eq(net, &init_net))
@@ -498,7 +497,7 @@ int dn_fib_dump(struct sk_buff *skb, struct netlink_callback *cb)
 	for (h = s_h; h < DN_FIB_TABLE_HASHSZ; h++, s_h = 0) {
 		e = 0;
-		hlist_for_each_entry(tb, node, &dn_fib_table_hash[h], hlist) {
+		hlist_for_each_entry(tb, &dn_fib_table_hash[h], hlist) {
 			if (e < s_e)
 				goto next;
 			if (dumped)
@@ -828,7 +827,6 @@ out:
 struct dn_fib_table *dn_fib_get_table(u32 n, int create)
 	struct dn_fib_table *t;
 	unsigned int h;
 	if (n < RT_TABLE_MIN)
@@ -839,7 +837,7 @@ struct dn_fib_table *dn_fib_get_table(u32 n, int create)
 	h = n & (DN_FIB_TABLE_HASHSZ - 1);
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(t, node, &dn_fib_table_hash[h], hlist) {
+	hlist_for_each_entry_rcu(t, &dn_fib_table_hash[h], hlist) {
 		if (t->n == n) {
 			rcu_read_unlock();
 			return t;
@@ -885,11 +883,10 @@ void dn_fib_flush(void)
 	int flushed = 0;
 	unsigned int h;
 	for (h = 0; h < DN_FIB_TABLE_HASHSZ; h++) {
 			flushed += tb->flush(tb);
@@ -908,12 +905,12 @@ void __init dn_fib_table_init(void)
 void __exit dn_fib_table_cleanup(void)
-	struct hlist_node *node, *next;
+	struct hlist_node *next;
 	unsigned int h;
 	write_lock(&dn_fib_tables_lock);
-		hlist_for_each_entry_safe(t, node, next, &dn_fib_table_hash[h],
+		hlist_for_each_entry_safe(t, next, &dn_fib_table_hash[h],
 					  hlist) {
 			hlist_del(&t->hlist);
 			kfree(t);
diff --git a/net/ieee802154/dgram.c b/net/ieee802154/dgram.c
index 1670561..e0da175 100644
--- a/net/ieee802154/dgram.c
+++ b/net/ieee802154/dgram.c
@@ -350,7 +350,6 @@ static inline int ieee802154_match_sock(u8 *hw_addr, u16 pan_id,
 int ieee802154_dgram_deliver(struct net_device *dev, struct sk_buff *skb)
 	struct sock *sk, *prev = NULL;
 	int ret = NET_RX_SUCCESS;
 	u16 pan_id, short_addr;
@@ -361,7 +360,7 @@ int ieee802154_dgram_deliver(struct net_device *dev, struct sk_buff *skb)
 	short_addr = ieee802154_mlme_ops(dev)->get_short_addr(dev);
 	read_lock(&dgram_lock);
-	sk_for_each(sk, node, &dgram_head) {
+	sk_for_each(sk, &dgram_head) {
 		if (ieee802154_match_sock(dev->dev_addr, pan_id, short_addr,
 					dgram_sk(sk))) {
 			if (prev) {
diff --git a/net/ieee802154/raw.c b/net/ieee802154/raw.c
index 50e8239..41f538b 100644
--- a/net/ieee802154/raw.c
+++ b/net/ieee802154/raw.c
@@ -221,10 +221,9 @@ static int raw_rcv_skb(struct sock *sk, struct sk_buff *skb)
 void ieee802154_raw_deliver(struct net_device *dev, struct sk_buff *skb)
 	struct sock *sk;
 	read_lock(&raw_lock);
-	sk_for_each(sk, node, &raw_head) {
+	sk_for_each(sk, &raw_head) {
 		bh_lock_sock(sk);
 		if (!sk->sk_bound_dev_if ||
 		    sk->sk_bound_dev_if == dev->ifindex) {
diff --git a/net/ipv4/devinet.c b/net/ipv4/devinet.c
index 5281314..f678507 100644
--- a/net/ipv4/devinet.c
+++ b/net/ipv4/devinet.c
@@ -139,10 +139,9 @@ struct net_device *__ip_dev_find(struct net *net, __be32 addr, bool devref)
 	u32 hash = inet_addr_hash(net, addr);
 	struct net_device *result = NULL;
 	struct in_ifaddr *ifa;
-	struct hlist_node *node;
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(ifa, node, &inet_addr_lst[hash], hash) {
+	hlist_for_each_entry_rcu(ifa, &inet_addr_lst[hash], hash) {
 		if (ifa->ifa_local == addr) {
 			struct net_device *dev = ifa->ifa_dev->dev;
@@ -588,7 +587,6 @@ static void check_lifetime(struct work_struct *work)
 	unsigned long now, next, next_sec, next_sched;
 	int i;
 	now = jiffies;
@@ -596,8 +594,7 @@ static void check_lifetime(struct work_struct *work)
 	rcu_read_lock();
 	for (i = 0; i < IN4_ADDR_HSIZE; i++) {
-					 &inet_addr_lst[i], hash) {
+		hlist_for_each_entry_rcu(ifa, &inet_addr_lst[i], hash) {
 			unsigned long age;
 			if (ifa->ifa_flags & IFA_F_PERMANENT)
@@ -1493,7 +1490,6 @@ static int inet_dump_ifaddr(struct sk_buff *skb, struct netlink_callback *cb)
 	struct in_device *in_dev;
 	s_h = cb->args[0];
 	s_idx = idx = cb->args[1];
@@ -1503,7 +1499,7 @@ static int inet_dump_ifaddr(struct sk_buff *skb, struct netlink_callback *cb)
 		idx = 0;
 		rcu_read_lock();
 			if (idx < s_idx)
 				goto cont;
 			if (h > s_h || idx > s_idx)
diff --git a/net/ipv4/fib_frontend.c b/net/ipv4/fib_frontend.c
index 99f00d3..eb4bb12 100644
--- a/net/ipv4/fib_frontend.c
+++ b/net/ipv4/fib_frontend.c
@@ -112,7 +112,6 @@ struct fib_table *fib_new_table(struct net *net, u32 id)
 struct fib_table *fib_get_table(struct net *net, u32 id)
 	struct fib_table *tb;
 	unsigned int h;
@@ -122,7 +121,7 @@ struct fib_table *fib_get_table(struct net *net, u32 id)
 	rcu_read_lock();
 	head = &net->ipv4.fib_table_hash[h];
-	hlist_for_each_entry_rcu(tb, node, head, tb_hlist) {
+	hlist_for_each_entry_rcu(tb, head, tb_hlist) {
 		if (tb->tb_id == id) {
 			rcu_read_unlock();
 			return tb;
@@ -137,13 +136,12 @@ static void fib_flush(struct net *net)
 	int flushed = 0;
 	unsigned int h;
 	for (h = 0; h < FIB_TABLE_HASHSZ; h++) {
-		hlist_for_each_entry(tb, node, head, tb_hlist)
+		hlist_for_each_entry(tb, head, tb_hlist)
 			flushed += fib_table_flush(tb);
@@ -656,7 +654,6 @@ static int inet_dump_fib(struct sk_buff *skb, struct netlink_callback *cb)
 	int dumped = 0;
@@ -670,7 +667,7 @@ static int inet_dump_fib(struct sk_buff *skb, struct netlink_callback *cb)
 	for (h = s_h; h < FIB_TABLE_HASHSZ; h++, s_e = 0) {
 		e = 0;
-		hlist_for_each_entry(tb, node, head, tb_hlist) {
+		hlist_for_each_entry(tb, head, tb_hlist) {
 			if (e < s_e)
 				goto next;
 			if (dumped)
@@ -1117,11 +1114,11 @@ static void ip_fib_net_exit(struct net *net)
 	for (i = 0; i < FIB_TABLE_HASHSZ; i++) {
-		struct hlist_node *node, *tmp;
 		head = &net->ipv4.fib_table_hash[i];
-		hlist_for_each_entry_safe(tb, node, tmp, head, tb_hlist) {
-			hlist_del(node);
+		hlist_for_each_entry_safe(tb, tmp, head, tb_hlist) {
+			hlist_del(&tb->tb_hlist);
 			fib_free_table(tb);
diff --git a/net/ipv4/fib_semantics.c b/net/ipv4/fib_semantics.c
index 4797a80..8f6cb7a 100644
--- a/net/ipv4/fib_semantics.c
+++ b/net/ipv4/fib_semantics.c
@@ -298,14 +298,13 @@ static inline unsigned int fib_info_hashfn(const struct fib_info *fi)
 static struct fib_info *fib_find_info(const struct fib_info *nfi)
 	struct fib_info *fi;
 	unsigned int hash;
 	hash = fib_info_hashfn(nfi);
 	head = &fib_info_hash[hash];
-	hlist_for_each_entry(fi, node, head, fib_hash) {
+	hlist_for_each_entry(fi, head, fib_hash) {
 		if (!net_eq(fi->fib_net, nfi->fib_net))
 			continue;
 		if (fi->fib_nhs != nfi->fib_nhs)
@@ -331,7 +330,6 @@ static struct fib_info *fib_find_info(const struct fib_info *nfi)
 int ip_fib_check_default(__be32 gw, struct net_device *dev)
 	struct fib_nh *nh;
 	unsigned int hash;
@@ -339,7 +337,7 @@ int ip_fib_check_default(__be32 gw, struct net_device *dev)
 	hash = fib_devindex_hashfn(dev->ifindex);
 	head = &fib_info_devhash[hash];
-	hlist_for_each_entry(nh, node, head, nh_hash) {
+	hlist_for_each_entry(nh, head, nh_hash) {
 		if (nh->nh_dev == dev &&
 		    nh->nh_gw == gw &&
 		    !(nh->nh_flags & RTNH_F_DEAD)) {
@@ -721,10 +719,10 @@ static void fib_info_hash_move(struct hlist_head *new_info_hash,
 	for (i = 0; i < old_size; i++) {
 		struct hlist_head *head = &fib_info_hash[i];
-		struct hlist_node *node, *n;
-		hlist_for_each_entry_safe(fi, node, n, head, fib_hash) {
+		hlist_for_each_entry_safe(fi, n, head, fib_hash) {
 			struct hlist_head *dest;
 			unsigned int new_hash;
@@ -739,10 +737,10 @@ static void fib_info_hash_move(struct hlist_head *new_info_hash,
 		struct hlist_head *lhead = &fib_info_laddrhash[i];
-		hlist_for_each_entry_safe(fi, node, n, lhead, fib_lhash) {
+		hlist_for_each_entry_safe(fi, n, lhead, fib_lhash) {
 			struct hlist_head *ldest;
@@ -1096,13 +1094,12 @@ int fib_sync_down_addr(struct net *net, __be32 local)
 	int ret = 0;
 	unsigned int hash = fib_laddr_hashfn(local);
 	struct hlist_head *head = &fib_info_laddrhash[hash];
 	if (fib_info_laddrhash == NULL || local == 0)
 		return 0;
-	hlist_for_each_entry(fi, node, head, fib_lhash) {
+	hlist_for_each_entry(fi, head, fib_lhash) {
 		if (!net_eq(fi->fib_net, net))
 			continue;
 		if (fi->fib_prefsrc == local) {
@@ -1120,13 +1117,12 @@ int fib_sync_down_dev(struct net_device *dev, int force)
 	struct fib_info *prev_fi = NULL;
 	unsigned int hash = fib_devindex_hashfn(dev->ifindex);
 	struct hlist_head *head = &fib_info_devhash[hash];
 	struct fib_nh *nh;
 	if (force)
 		scope = -1;
 		struct fib_info *fi = nh->nh_parent;
 		int dead;
@@ -1232,7 +1228,6 @@ int fib_sync_up(struct net_device *dev)
 	struct fib_info *prev_fi;
 	unsigned int hash;
 	struct fib_nh *nh;
 	int ret;
@@ -1244,7 +1239,7 @@ int fib_sync_up(struct net_device *dev)
 	ret = 0;
 		int alive;
diff --git a/net/ipv4/fib_trie.c b/net/ipv4/fib_trie.c
index 61e03da..ff06b75 100644
--- a/net/ipv4/fib_trie.c
+++ b/net/ipv4/fib_trie.c
@@ -920,10 +920,9 @@ nomem:
 static struct leaf_info *find_leaf_info(struct leaf *l, int plen)
 	struct hlist_head *head = &l->list;
 	struct leaf_info *li;
-	hlist_for_each_entry_rcu(li, node, head, hlist)
+	hlist_for_each_entry_rcu(li, head, hlist)
 		if (li->plen == plen)
 			return li;
@@ -943,12 +942,11 @@ static inline struct list_head *get_fa_head(struct leaf *l, int plen)
 static void insert_leaf_info(struct hlist_head *head, struct leaf_info *new)
 	struct leaf_info *li = NULL, *last = NULL;
 	if (hlist_empty(head)) {
 		hlist_add_head_rcu(&new->hlist, head);
 	} else {
-		hlist_for_each_entry(li, node, head, hlist) {
+		hlist_for_each_entry(li, head, hlist) {
 			if (new->plen > li->plen)
 				break;
@@ -1354,9 +1352,8 @@ static int check_leaf(struct fib_table *tb, struct trie *t, struct leaf *l,
 	struct hlist_head *hhead = &l->list;
-	hlist_for_each_entry_rcu(li, node, hhead, hlist) {
+	hlist_for_each_entry_rcu(li, hhead, hlist) {
 		struct fib_alias *fa;
 		if (l->key != (key & li->mask_plen))
@@ -1740,10 +1737,10 @@ static int trie_flush_leaf(struct leaf *l)
 	int found = 0;
 	struct hlist_head *lih = &l->list;
 	struct leaf_info *li = NULL;
-	hlist_for_each_entry_safe(li, node, tmp, lih, hlist) {
+	hlist_for_each_entry_safe(li, tmp, lih, hlist) {
 		found += trie_flush_list(&li->falh);
 		if (list_empty(&li->falh)) {
@@ -1895,14 +1892,13 @@ static int fn_trie_dump_leaf(struct leaf *l, struct fib_table *tb,
 	int i, s_i;
 	s_i = cb->args[4];
 	i = 0;
 	/* rcu_read_lock is hold by caller */
-	hlist_for_each_entry_rcu(li, node, &l->list, hlist) {
+	hlist_for_each_entry_rcu(li, &l->list, hlist) {
 		if (i < s_i) {
 			i++;
 			continue;
@@ -2092,14 +2088,13 @@ static void trie_collect_stats(struct trie *t, struct trie_stat *s)
 		if (IS_LEAF(n)) {
 			struct leaf *l = (struct leaf *)n;
-			struct hlist_node *tmp;
 			s->leaves++;
 			s->totdepth += iter.depth;
 			if (iter.depth > s->maxdepth)
 				s->maxdepth = iter.depth;
-			hlist_for_each_entry_rcu(li, tmp, &l->list, hlist)
 				++s->prefixes;
 		} else {
 			const struct tnode *tn = (const struct tnode *) n;
@@ -2200,10 +2195,9 @@ static int fib_triestat_seq_show(struct seq_file *seq, void *v)
 		struct hlist_head *head = &net->ipv4.fib_table_hash[h];
 			struct trie *t = (struct trie *) tb->tb_data;
 			struct trie_stat stat;
@@ -2245,10 +2239,9 @@ static struct rt_trie_node *fib_trie_get_idx(struct seq_file *seq, loff_t pos)
 			struct rt_trie_node *n;
 			for (n = fib_trie_get_first(iter,
@@ -2298,7 +2291,7 @@ static void *fib_trie_seq_next(struct seq_file *seq, void *v, loff_t *pos)
 	/* new hash chain */
 	while (++h < FIB_TABLE_HASHSZ) {
-		hlist_for_each_entry_rcu(tb, tb_node, head, tb_hlist) {
 			n = fib_trie_get_first(iter, (struct trie *) tb->tb_data);
 			if (n)
 				goto found;
@@ -2381,13 +2374,12 @@ static int fib_trie_seq_show(struct seq_file *seq, void *v)
 	} else {
 		struct leaf *l = (struct leaf *) n;
 		__be32 val = htonl(l->key);
 		seq_indent(seq, iter->depth);
 		seq_printf(seq, "  |-- %pI4\n", &val);
 			list_for_each_entry_rcu(fa, &li->falh, fa_list) {
@@ -2532,7 +2524,6 @@ static int fib_route_seq_show(struct seq_file *seq, void *v)
 	struct leaf *l = v;
 	if (v == SEQ_START_TOKEN) {
 		seq_printf(seq, "%-127s\n", "Iface\tDestination\tGateway "
@@ -2541,7 +2532,7 @@ static int fib_route_seq_show(struct seq_file *seq, void *v)
 		return 0;
 		__be32 mask, prefix;
diff --git a/net/ipv4/inet_connection_sock.c b/net/ipv4/inet_connection_sock.c
index 11cb497..7d1874b 100644
--- a/net/ipv4/inet_connection_sock.c
+++ b/net/ipv4/inet_connection_sock.c
@@ -57,7 +57,6 @@ int inet_csk_bind_conflict(const struct sock *sk,
 			   const struct inet_bind_bucket *tb, bool relax)
 	struct sock *sk2;
 	int reuse = sk->sk_reuse;
 	int reuseport = sk->sk_reuseport;
 	kuid_t uid = sock_i_uid((struct sock *)sk);
@@ -69,7 +68,7 @@ int inet_csk_bind_conflict(const struct sock *sk,
 	 * one this bucket belongs to.
-	sk_for_each_bound(sk2, node, &tb->owners) {
+	sk_for_each_bound(sk2, &tb->owners) {
 		if (sk != sk2 &&
 		    !inet_v6_ipv6only(sk2) &&
@@ -95,7 +94,7 @@ int inet_csk_bind_conflict(const struct sock *sk,
-	return node != NULL;
+	return sk2 != NULL;
 EXPORT_SYMBOL_GPL(inet_csk_bind_conflict);
@@ -106,7 +105,6 @@ int inet_csk_get_port(struct sock *sk, unsigned short snum)
 	struct inet_hashinfo *hashinfo = sk->sk_prot->h.hashinfo;
 	struct inet_bind_hashbucket *head;
 	struct inet_bind_bucket *tb;
 	int ret, attempts = 5;
 	struct net *net = sock_net(sk);
@@ -129,7 +127,7 @@ again:
 			head = &hashinfo->bhash[inet_bhashfn(net, rover,
 					hashinfo->bhash_size)];
 			spin_lock(&head->lock);
-			inet_bind_bucket_for_each(tb, node, &head->chain)
+			inet_bind_bucket_for_each(tb, &head->chain)
 				if (net_eq(ib_net(tb), net) && tb->port == rover) {
 					if (((tb->fastreuse > 0 &&
 					      sk->sk_reuse &&
@@ -183,7 +181,7 @@ have_snum:
 		head = &hashinfo->bhash[inet_bhashfn(net, snum,
 			if (net_eq(ib_net(tb), net) && tb->port == snum)
 				goto tb_found;
diff --git a/net/ipv4/inet_fragment.c b/net/ipv4/inet_fragment.c
index 2e453bd..245ae078a 100644
--- a/net/ipv4/inet_fragment.c
+++ b/net/ipv4/inet_fragment.c
@@ -33,9 +33,9 @@ static void inet_frag_secret_rebuild(unsigned long dummy)
 	get_random_bytes(&f->rnd, sizeof(u32));
 	for (i = 0; i < INETFRAGS_HASHSZ; i++) {
 		struct inet_frag_queue *q;
-		hlist_for_each_entry_safe(q, p, n, &f->hash[i], list) {
+		hlist_for_each_entry_safe(q, n, &f->hash[i], list) {
 			unsigned int hval = f->hashfn(q);
 			if (hval != i) {
@@ -203,7 +203,6 @@ static struct inet_frag_queue *inet_frag_intern(struct netns_frags *nf,
 	struct inet_frag_queue *qp;
 #ifdef CONFIG_SMP
 #endif
 	unsigned int hash;
@@ -219,7 +218,7 @@ static struct inet_frag_queue *inet_frag_intern(struct netns_frags *nf,
 	 * such entry could be created on other cpu, while we
 	 * promoted read lock to write lock.
-	hlist_for_each_entry(qp, n, &f->hash[hash], list) {
+	hlist_for_each_entry(qp, &f->hash[hash], list) {
 		if (qp->net == nf && f->match(qp, arg)) {
 			atomic_inc(&qp->refcnt);
 			write_unlock(&f->lock);
@@ -278,9 +277,8 @@ struct inet_frag_queue *inet_frag_find(struct netns_frags *nf,
 	__releases(&f->lock)
-	hlist_for_each_entry(q, n, &f->hash[hash], list) {
+	hlist_for_each_entry(q, &f->hash[hash], list) {
 		if (q->net == nf && f->match(q, key)) {
 			atomic_inc(&q->refcnt);
 			read_unlock(&f->lock);
diff --git a/net/ipv4/inet_hashtables.c b/net/ipv4/inet_hashtables.c
index 0ce0595..6af375a 100644
--- a/net/ipv4/inet_hashtables.c
+++ b/net/ipv4/inet_hashtables.c
@@ -120,13 +120,12 @@ int __inet_inherit_port(struct sock *sk, struct sock *child)
 		 * that the listener socket's icsk_bind_hash is the same
 		 * as that of the child socket. We have to look up or
 		 * create a new bind bucket for the child here. */
-		inet_bind_bucket_for_each(tb, node, &head->chain) {
+		inet_bind_bucket_for_each(tb, &head->chain) {
 			if (net_eq(ib_net(tb), sock_net(sk)) &&
 			    tb->port == port)
 				break;
-		if (!node) {
+		if (!tb) {
 			tb = inet_bind_bucket_create(table->bind_bucket_cachep,
 						     sock_net(sk), head, port);
 			if (!tb) {
@@ -493,7 +492,6 @@ int __inet_hash_connect(struct inet_timewait_death_row *death_row,
 		int i, remaining, low, high, port;
 		static u32 hint;
 		u32 offset = hint + port_offset;
 		struct inet_timewait_sock *tw = NULL;
 		inet_get_local_port_range(&low, &high);
@@ -512,7 +510,7 @@ int __inet_hash_connect(struct inet_timewait_death_row *death_row,
 			 * because the established check is already
 			 * unique enough.
 				    tb->port == port) {
 					if (tb->fastreuse >= 0 ||
diff --git a/net/ipv4/inet_timewait_sock.c b/net/ipv4/inet_timewait_sock.c
index 2784db3..1f27c9f 100644
--- a/net/ipv4/inet_timewait_sock.c
+++ b/net/ipv4/inet_timewait_sock.c
@@ -216,7 +216,6 @@ static int inet_twdr_do_twkill_work(struct inet_timewait_death_row *twdr,
 				    const int slot)
 	struct inet_timewait_sock *tw;
 	unsigned int killed;
 	int ret;
@@ -229,7 +228,7 @@ static int inet_twdr_do_twkill_work(struct inet_timewait_death_row *twdr,
 	killed = 0;
 	ret = 0;
 rescan:
-	inet_twsk_for_each_inmate(tw, node, &twdr->cells[slot]) {
+	inet_twsk_for_each_inmate(tw, &twdr->cells[slot]) {
 		__inet_twsk_del_dead_node(tw);
 		spin_unlock(&twdr->death_lock);
 		__inet_twsk_kill(tw, twdr->hashinfo);
@@ -438,10 +437,10 @@ void inet_twdr_twcal_tick(unsigned long data)
 	for (n = 0; n < INET_TWDR_RECYCLE_SLOTS; n++) {
 		if (time_before_eq(j, now)) {
-			inet_twsk_for_each_inmate_safe(tw, node, safe,
+			inet_twsk_for_each_inmate_safe(tw, safe,
 						       &twdr->twcal_row[slot]) {
diff --git a/net/ipv4/raw.c b/net/ipv4/raw.c
index 53ddebc..dd44e0a 100644
--- a/net/ipv4/raw.c
+++ b/net/ipv4/raw.c
@@ -111,9 +111,7 @@ EXPORT_SYMBOL_GPL(raw_unhash_sk);
 static struct sock *__raw_v4_lookup(struct net *net, struct sock *sk,
 		unsigned short num, __be32 raddr, __be32 laddr, int dif)
-	sk_for_each_from(sk, node) {
+	sk_for_each_from(sk) {
 		struct inet_sock *inet = inet_sk(sk);
 		if (net_eq(sock_net(sk), net) && inet->inet_num == num	&&
@@ -914,9 +912,7 @@ static struct sock *raw_get_first(struct seq_file *seq)
 	for (state->bucket = 0; state->bucket < RAW_HTABLE_SIZE;
 			++state->bucket) {
-		sk_for_each(sk, node, &state->h->ht[state->bucket])
+		sk_for_each(sk, &state->h->ht[state->bucket])
 			if (sock_net(sk) == seq_file_net(seq))
 				goto found;
diff --git a/net/ipv4/tcp_ipv4.c b/net/ipv4/tcp_ipv4.c
index 145d3bf..4a8ec45 100644
--- a/net/ipv4/tcp_ipv4.c
+++ b/net/ipv4/tcp_ipv4.c
@@ -954,7 +954,6 @@ struct tcp_md5sig_key *tcp_md5_do_lookup(struct sock *sk,
 	struct tcp_sock *tp = tcp_sk(sk);
 	struct tcp_md5sig_key *key;
-	struct hlist_node *pos;
 	unsigned int size = sizeof(struct in_addr);
 	struct tcp_md5sig_info *md5sig;
@@ -968,7 +967,7 @@ struct tcp_md5sig_key *tcp_md5_do_lookup(struct sock *sk,
 	if (family == AF_INET6)
 		size = sizeof(struct in6_addr);
 #endif
-	hlist_for_each_entry_rcu(key, pos, &md5sig->head, node) {
+	hlist_for_each_entry_rcu(key, &md5sig->head, node) {
 		if (key->family != family)
 			continue;
 		if (!memcmp(&key->addr, addr, size))
@@ -1069,14 +1068,14 @@ static void tcp_clear_md5_list(struct sock *sk)
 	md5sig = rcu_dereference_protected(tp->md5sig_info, 1);
 	if (!hlist_empty(&md5sig->head))
 		tcp_free_md5sig_pool();
-	hlist_for_each_entry_safe(key, pos, n, &md5sig->head, node) {
+	hlist_for_each_entry_safe(key, n, &md5sig->head, node) {
 		hlist_del_rcu(&key->node);
 		atomic_sub(sizeof(*key), &sk->sk_omem_alloc);
 		kfree_rcu(key, rcu);
diff --git a/net/ipv6/addrconf.c b/net/ipv6/addrconf.c
index 4dc0d44..f2c7e61 100644
--- a/net/ipv6/addrconf.c
+++ b/net/ipv6/addrconf.c
@@ -1419,11 +1419,10 @@ int ipv6_chk_addr(struct net *net, const struct in6_addr *addr,
 		  struct net_device *dev, int strict)
 	struct inet6_ifaddr *ifp;
 	unsigned int hash = inet6_addr_hash(addr);
 	rcu_read_lock_bh();
-	hlist_for_each_entry_rcu(ifp, node, &inet6_addr_lst[hash], addr_lst) {
+	hlist_for_each_entry_rcu(ifp, &inet6_addr_lst[hash], addr_lst) {
 		if (!net_eq(dev_net(ifp->idev->dev), net))
 			continue;
 		if (ipv6_addr_equal(&ifp->addr, addr) &&
@@ -1445,9 +1444,8 @@ static bool ipv6_chk_same_addr(struct net *net, const struct in6_addr *addr,
-	hlist_for_each_entry(ifp, node, &inet6_addr_lst[hash], addr_lst) {
+	hlist_for_each_entry(ifp, &inet6_addr_lst[hash], addr_lst) {
 			continue;
 		if (ipv6_addr_equal(&ifp->addr, addr)) {
@@ -1487,10 +1485,9 @@ struct inet6_ifaddr *ipv6_get_ifaddr(struct net *net, const struct in6_addr *add
 	struct inet6_ifaddr *ifp, *result = NULL;
 	rcu_read_lock_bh();
-	hlist_for_each_entry_rcu_bh(ifp, node, &inet6_addr_lst[hash], addr_lst) {
+	hlist_for_each_entry_rcu_bh(ifp, &inet6_addr_lst[hash], addr_lst) {
 			continue;
@@ -2907,11 +2904,10 @@ static int addrconf_ifdown(struct net_device *dev, int how)
 	/* Step 2: clear hash table */
 	for (i = 0; i < IN6_ADDR_HSIZE; i++) {
 		struct hlist_head *h = &inet6_addr_lst[i];
 		spin_lock_bh(&addrconf_hash_lock);
 	restart:
-		hlist_for_each_entry_rcu(ifa, n, h, addr_lst) {
+		hlist_for_each_entry_rcu(ifa, h, addr_lst) {
 			if (ifa->idev == idev) {
 				hlist_del_init_rcu(&ifa->addr_lst);
 				addrconf_del_timer(ifa);
@@ -3218,8 +3214,7 @@ static struct inet6_ifaddr *if6_get_first(struct seq_file *seq, loff_t pos)
 	for (; state->bucket < IN6_ADDR_HSIZE; ++state->bucket) {
-		hlist_for_each_entry_rcu_bh(ifa, n, &inet6_addr_lst[state->bucket],
+		hlist_for_each_entry_rcu_bh(ifa, &inet6_addr_lst[state->bucket],
 					 addr_lst) {
 			if (!net_eq(dev_net(ifa->idev->dev), net))
 				continue;
@@ -3244,9 +3239,8 @@ static struct inet6_ifaddr *if6_get_next(struct seq_file *seq,
 	struct if6_iter_state *state = seq->private;
-	struct hlist_node *n = &ifa->addr_lst;
-	hlist_for_each_entry_continue_rcu_bh(ifa, n, addr_lst) {
+	hlist_for_each_entry_continue_rcu_bh(ifa, addr_lst) {
 			continue;
 		state->offset++;
@@ -3255,7 +3249,7 @@ static struct inet6_ifaddr *if6_get_next(struct seq_file *seq,
 	while (++state->bucket < IN6_ADDR_HSIZE) {
 		state->offset = 0;
 				     &inet6_addr_lst[state->bucket], addr_lst) {
 				continue;
@@ -3357,11 +3351,10 @@ int ipv6_chk_home_addr(struct net *net, const struct in6_addr *addr)
 	int ret = 0;
 	struct inet6_ifaddr *ifp = NULL;
 	rcu_read_lock_bh();
-	hlist_for_each_entry_rcu_bh(ifp, n, &inet6_addr_lst[hash], addr_lst) {
 			continue;
@@ -3383,7 +3376,6 @@ static void addrconf_verify(unsigned long foo)
 	int i;
 	rcu_read_lock_bh();
@@ -3395,7 +3387,7 @@ static void addrconf_verify(unsigned long foo)
 restart:
 					 &inet6_addr_lst[i], addr_lst) {
 			unsigned long age;
@@ -3866,7 +3858,6 @@ static int inet6_dump_addr(struct sk_buff *skb, struct netlink_callback *cb,
 	struct inet6_dev *idev;
 	s_h = cb->args[0];
@@ -3876,7 +3867,7 @@ static int inet6_dump_addr(struct sk_buff *skb, struct netlink_callback *cb,
 		idx = 0;
 			if (idx < s_idx)
 				goto cont;
@@ -4222,7 +4213,6 @@ static int inet6_dump_ifinfo(struct sk_buff *skb, struct netlink_callback *cb)
 	s_h = cb->args[0];
 	s_idx = cb->args[1];
@@ -4231,7 +4221,7 @@ static int inet6_dump_ifinfo(struct sk_buff *skb, struct netlink_callback *cb)
 		idx = 0;
 			if (idx < s_idx)
 				goto cont;
 			idev = __in6_dev_get(dev);
diff --git a/net/ipv6/addrlabel.c b/net/ipv6/addrlabel.c
index ff76eec..aad6435 100644
--- a/net/ipv6/addrlabel.c
+++ b/net/ipv6/addrlabel.c
@@ -173,9 +173,8 @@ static struct ip6addrlbl_entry *__ipv6_addr_label(struct net *net,
 						  int type, int ifindex)
 	struct ip6addrlbl_entry *p;
-	hlist_for_each_entry_rcu(p, pos, &ip6addrlbl_table.head, list) {
+	hlist_for_each_entry_rcu(p, &ip6addrlbl_table.head, list) {
 		if (__ip6addrlbl_match(net, p, addr, type, ifindex))
 			return p;
@@ -261,9 +260,9 @@ static int __ip6addrlbl_add(struct ip6addrlbl_entry *newp, int replace)
 	if (hlist_empty(&ip6addrlbl_table.head)) {
 		hlist_add_head_rcu(&newp->list, &ip6addrlbl_table.head);
 	} else {
 		struct ip6addrlbl_entry *p = NULL;
-		hlist_for_each_entry_safe(p, pos, n,
+		hlist_for_each_entry_safe(p, n,
 			if (p->prefixlen == newp->prefixlen &&
 			    net_eq(ip6addrlbl_net(p), ip6addrlbl_net(newp)) &&
@@ -319,13 +318,13 @@ static int __ip6addrlbl_del(struct net *net,
 			    int ifindex)
 	int ret = -ESRCH;
 	ADDRLABEL(KERN_DEBUG "%s(prefix=%pI6, prefixlen=%d, ifindex=%d)\n",
 		  __func__, prefix, prefixlen, ifindex);
-	hlist_for_each_entry_safe(p, pos, n, &ip6addrlbl_table.head, list) {
+	hlist_for_each_entry_safe(p, n, &ip6addrlbl_table.head, list) {
 		if (p->prefixlen == prefixlen &&
 		    net_eq(ip6addrlbl_net(p), net) &&
 		    p->ifindex == ifindex &&
@@ -380,11 +379,11 @@ static int __net_init ip6addrlbl_net_init(struct net *net)
 static void __net_exit ip6addrlbl_net_exit(struct net *net)
 	/* Remove all labels belonging to the exiting net */
 	spin_lock(&ip6addrlbl_table.lock);
 		if (net_eq(ip6addrlbl_net(p), net)) {
 			hlist_del_rcu(&p->list);
 			ip6addrlbl_put(p);
@@ -505,12 +504,11 @@ static int ip6addrlbl_dump(struct sk_buff *skb, struct netlink_callback *cb)
 	struct net *net = sock_net(skb->sk);
 	int idx = 0, s_idx = cb->args[0];
 	int err;
 	rcu_read_lock();
 		if (idx >= s_idx &&
 			if ((err = ip6addrlbl_fill(skb, p,
diff --git a/net/ipv6/inet6_connection_sock.c b/net/ipv6/inet6_connection_sock.c
index b386a2c..9bfab19 100644
--- a/net/ipv6/inet6_connection_sock.c
+++ b/net/ipv6/inet6_connection_sock.c
@@ -31,7 +31,6 @@ int inet6_csk_bind_conflict(const struct sock *sk,
 	const struct sock *sk2;
-	const struct hlist_node *node;
@@ -41,7 +40,7 @@ int inet6_csk_bind_conflict(const struct sock *sk,
 	 * See comment in inet_csk_bind_conflict about sock lookup
 	 * vs net namespaces issues.
 		if (sk != sk2 &&
 		     !sk2->sk_bound_dev_if ||
@@ -58,7 +57,7 @@ int inet6_csk_bind_conflict(const struct sock *sk,
 EXPORT_SYMBOL_GPL(inet6_csk_bind_conflict);
diff --git a/net/ipv6/ip6_fib.c b/net/ipv6/ip6_fib.c
index 710cafd..192dd1a 100644
--- a/net/ipv6/ip6_fib.c
+++ b/net/ipv6/ip6_fib.c
@@ -224,7 +224,6 @@ struct fib6_table *fib6_get_table(struct net *net, u32 id)
 	struct fib6_table *tb;
 	unsigned int h;
 	if (id == 0)
@@ -232,7 +231,7 @@ struct fib6_table *fib6_get_table(struct net *net, u32 id)
 	h = id & (FIB6_TABLE_HASHSZ - 1);
 	rcu_read_lock();
 	head = &net->ipv6.fib_table_hash[h];
-	hlist_for_each_entry_rcu(tb, node, head, tb6_hlist) {
+	hlist_for_each_entry_rcu(tb, head, tb6_hlist) {
 		if (tb->tb6_id == id) {
 			rcu_read_unlock();
 			return tb;
@@ -363,7 +362,6 @@ static int inet6_dump_fib(struct sk_buff *skb, struct netlink_callback *cb)
 	struct rt6_rtnl_dump_arg arg;
 	struct fib6_walker_t *w;
 	int res = 0;
@@ -398,7 +396,7 @@ static int inet6_dump_fib(struct sk_buff *skb, struct netlink_callback *cb)
 	for (h = s_h; h < FIB6_TABLE_HASHSZ; h++, s_e = 0) {
 		e = 0;
 			if (e < s_e)
 				goto next;
 			res = fib6_dump_table(tb, skb, cb);
@@ -1520,14 +1518,13 @@ void fib6_clean_all_ro(struct net *net, int (*func)(struct rt6_info *, void *arg
 		    int prune, void *arg)
 	struct fib6_table *table;
 	unsigned int h;
 	rcu_read_lock();
 	for (h = 0; h < FIB6_TABLE_HASHSZ; h++) {
-		hlist_for_each_entry_rcu(table, node, head, tb6_hlist) {
+		hlist_for_each_entry_rcu(table, head, tb6_hlist) {
 			read_lock_bh(&table->tb6_lock);
 			fib6_clean_tree(net, &table->tb6_root,
 					func, prune, arg);
@@ -1540,14 +1537,13 @@ void fib6_clean_all(struct net *net, int (*func)(struct rt6_info *, void *arg),
 	unsigned int h;
 	rcu_read_lock();
 			write_lock_bh(&table->tb6_lock);
 					func, prune, arg);
diff --git a/net/ipv6/raw.c b/net/ipv6/raw.c
index c65907d..330b5e7 100644
--- a/net/ipv6/raw.c
+++ b/net/ipv6/raw.c
@@ -71,10 +71,9 @@ static struct sock *__raw_v6_lookup(struct net *net, struct sock *sk,
 		unsigned short num, const struct in6_addr *loc_addr,
 		const struct in6_addr *rmt_addr, int dif)
 	bool is_multicast = ipv6_addr_is_multicast(loc_addr);
 		if (inet_sk(sk)->inet_num == num) {
 			struct ipv6_pinfo *np = inet6_sk(sk);
diff --git a/net/ipv6/xfrm6_tunnel.c b/net/ipv6/xfrm6_tunnel.c
index 6cc4801..de2bcfa 100644
--- a/net/ipv6/xfrm6_tunnel.c
+++ b/net/ipv6/xfrm6_tunnel.c
@@ -89,9 +89,8 @@ static struct xfrm6_tunnel_spi *__xfrm6_tunnel_spi_lookup(struct net *net, const
 	struct xfrm6_tunnel_net *xfrm6_tn = xfrm6_tunnel_pernet(net);
 	struct xfrm6_tunnel_spi *x6spi;
-	hlist_for_each_entry_rcu(x6spi, pos,
+	hlist_for_each_entry_rcu(x6spi,
 			     &xfrm6_tn->spi_byaddr[xfrm6_tunnel_spi_hash_byaddr(saddr)],
 			     list_byaddr) {
 		if (xfrm6_addr_equal(&x6spi->addr, saddr))
@@ -120,9 +119,8 @@ static int __xfrm6_tunnel_spi_check(struct net *net, u32 spi)
 	int index = xfrm6_tunnel_spi_hash_byspi(spi);
-	hlist_for_each_entry(x6spi, pos,
+	hlist_for_each_entry(x6spi,
 			     &xfrm6_tn->spi_byspi[index],
 			     list_byspi) {
 		if (x6spi->spi == spi)
@@ -203,11 +201,11 @@ static void xfrm6_tunnel_free_spi(struct net *net, xfrm_address_t *saddr)
 	spin_lock_bh(&xfrm6_tunnel_spi_lock);
-	hlist_for_each_entry_safe(x6spi, pos, n,
+	hlist_for_each_entry_safe(x6spi, n,
 				  list_byaddr)
diff --git a/net/ipx/af_ipx.c b/net/ipx/af_ipx.c
index dfd6faa..f547a47 100644
--- a/net/ipx/af_ipx.c
+++ b/net/ipx/af_ipx.c
@@ -228,9 +228,8 @@ static struct sock *__ipxitf_find_socket(struct ipx_interface *intrfc,
 					 __be16 port)
 	struct sock *s;
-	sk_for_each(s, node, &intrfc->if_sklist)
+	sk_for_each(s, &intrfc->if_sklist)
 		if (ipx_sk(s)->port == port)
 			goto found;
 	s = NULL;
@@ -259,12 +258,11 @@ static struct sock *ipxitf_find_internal_socket(struct ipx_interface *intrfc,
 						__be16 port)
 	struct sock *s;
 	ipxitf_hold(intrfc);
 	spin_lock_bh(&intrfc->if_sklist_lock);
-	sk_for_each(s, node, &intrfc->if_sklist) {
+	sk_for_each(s, &intrfc->if_sklist) {
 		struct ipx_sock *ipxs = ipx_sk(s);
 		if (ipxs->port == port &&
@@ -282,14 +280,14 @@ found:
 static void __ipxitf_down(struct ipx_interface *intrfc)
 	struct sock *s;
-	struct hlist_node *node, *t;
+	struct hlist_node *t;
 	/* Delete all routes associated with this interface */
 	ipxrtr_del_routes(intrfc);
 	/* error sockets */
-	sk_for_each_safe(s, node, t, &intrfc->if_sklist) {
+	sk_for_each_safe(s, t, &intrfc->if_sklist) {
 		s->sk_err = ENOLINK;
@@ -385,12 +383,11 @@ static int ipxitf_demux_socket(struct ipx_interface *intrfc,
 	int is_broadcast = !memcmp(ipx->ipx_dest.node, ipx_broadcast_node,
 				   IPX_NODE_LEN);
 	struct sock *s;
 	int rc;
 		if (ipxs->port == ipx->ipx_dest.sock &&
@@ -446,12 +443,11 @@ static struct sock *ncp_connection_hack(struct ipx_interface *intrfc,
 		connection = (((int) *(ncphdr + 9)) << 8) | (int) *(ncphdr + 8);
 	if (connection) {
 		/* Now we have to look for a special NCP connection handling
 		 * socket. Only these sockets have ipx_ncp_conn != 0, set by
 		 * SIOCIPXNCPCONN. */
-		sk_for_each(sk, node, &intrfc->if_sklist)
+		sk_for_each(sk, &intrfc->if_sklist)
 			if (ipx_sk(sk)->ipx_ncp_conn == connection) {
 				sock_hold(sk);
 				goto found;
diff --git a/net/ipx/ipx_proc.c b/net/ipx/ipx_proc.c
index 02ff7f2..65e8833 100644
--- a/net/ipx/ipx_proc.c
+++ b/net/ipx/ipx_proc.c
@@ -103,19 +103,18 @@ out:
 static __inline__ struct sock *ipx_get_socket_idx(loff_t pos)
 	struct sock *s = NULL;
 	struct ipx_interface *i;
 	list_for_each_entry(i, &ipx_interfaces, node) {
 		spin_lock_bh(&i->if_sklist_lock);
-		sk_for_each(s, node, &i->if_sklist) {
+		sk_for_each(s, &i->if_sklist) {
 			if (!pos)
 				break;
 			--pos;
 		spin_unlock_bh(&i->if_sklist_lock);
 		if (!pos) {
-			if (node)
+			if (s)
 				goto found;
 			break;
diff --git a/net/iucv/af_iucv.c b/net/iucv/af_iucv.c
index cd6f7a9..a7d11ffe 100644
--- a/net/iucv/af_iucv.c
+++ b/net/iucv/af_iucv.c
@@ -156,14 +156,13 @@ static int afiucv_pm_freeze(struct device *dev)
 	struct iucv_sock *iucv;
 	struct sock *sk;
 	int err = 0;
 #ifdef CONFIG_PM_DEBUG
 	printk(KERN_WARNING "afiucv_pm_freeze\n");
 #endif
 	read_lock(&iucv_sk_list.lock);
-	sk_for_each(sk, node, &iucv_sk_list.head) {
+	sk_for_each(sk, &iucv_sk_list.head) {
 		iucv = iucv_sk(sk);
 		switch (sk->sk_state) {
 		case IUCV_DISCONN:
@@ -194,13 +193,12 @@ static int afiucv_pm_freeze(struct device *dev)
 static int afiucv_pm_restore_thaw(struct device *dev)
 	struct sock *sk;
 	printk(KERN_WARNING "afiucv_pm_restore_thaw\n");
 #endif
 		case IUCV_CONNECTED:
 			sk->sk_err = EPIPE;
@@ -390,9 +388,8 @@ static int afiucv_hs_send(struct iucv_message *imsg, struct sock *sock,
 static struct sock *__iucv_get_sock_by_name(char *nm)
 	struct sock *sk;
 		if (!memcmp(&iucv_sk(sk)->src_name, nm, 8))
 			return sk;
@@ -1678,7 +1675,6 @@ static int iucv_callback_connreq(struct iucv_path *path,
 	unsigned char user_data[16];
 	unsigned char nuser_data[16];
 	unsigned char src_name[8];
 	struct sock *sk, *nsk;
 	struct iucv_sock *iucv, *niucv;
 	int err;
@@ -1689,7 +1685,7 @@ static int iucv_callback_connreq(struct iucv_path *path,
 	iucv = NULL;
 	sk = NULL;
 		if (sk->sk_state == IUCV_LISTEN &&
 		    !memcmp(&iucv_sk(sk)->src_name, src_name, 8)) {
@@ -2115,7 +2111,6 @@ static int afiucv_hs_callback_rx(struct sock *sk, struct sk_buff *skb)
 static int afiucv_hs_rcv(struct sk_buff *skb, struct net_device *dev,
 	struct packet_type *pt, struct net_device *orig_dev)
 	struct sock *sk;
 	struct af_iucv_trans_hdr *trans_hdr;
@@ -2132,7 +2127,7 @@ static int afiucv_hs_rcv(struct sk_buff *skb, struct net_device *dev,
 	iucv = NULL;
 	sk = NULL;
 		if (trans_hdr->flags == AF_IUCV_FLAG_SYN) {
 			if ((!memcmp(&iucv_sk(sk)->src_name,
 				     trans_hdr->destAppName, 8)) &&
@@ -2225,10 +2220,9 @@ static void afiucv_hs_callback_txnotify(struct sk_buff *skb,
 	struct sk_buff *list_skb;
 	unsigned long flags;
 	read_lock_irqsave(&iucv_sk_list.lock, flags);
 		if (sk == isk) {
 			iucv = iucv_sk(sk);
 			break;
@@ -2299,14 +2293,13 @@ static int afiucv_netdev_event(struct notifier_block *this,
 			       unsigned long event, void *ptr)
 	struct net_device *event_dev = (struct net_device *)ptr;
 	struct sock *sk;
 	switch (event) {
 	case NETDEV_REBOOT:
 	case NETDEV_GOING_DOWN:
 			iucv = iucv_sk(sk);
 			if ((iucv->hs_dev == event_dev) &&
 			    (sk->sk_state == IUCV_CONNECTED)) {
diff --git a/net/key/af_key.c b/net/key/af_key.c
index 9ef7985..556fdaf 100644
--- a/net/key/af_key.c
+++ b/net/key/af_key.c
@@ -225,7 +225,6 @@ static int pfkey_broadcast(struct sk_buff *skb, gfp_t allocation,
 	struct netns_pfkey *net_pfkey = net_generic(net, pfkey_net_id);
 	struct sock *sk;
 	struct sk_buff *skb2 = NULL;
 	int err = -ESRCH;
@@ -236,7 +235,7 @@ static int pfkey_broadcast(struct sk_buff *skb, gfp_t allocation,
 		return -ENOMEM;
 	rcu_read_lock();
-	sk_for_each_rcu(sk, node, &net_pfkey->table) {
+	sk_for_each_rcu(sk, &net_pfkey->table) {
 		struct pfkey_sock *pfk = pfkey_sk(sk);
 		int err2;
diff --git a/net/l2tp/l2tp_core.c b/net/l2tp/l2tp_core.c
index dcfd64e..d36875f 100644
--- a/net/l2tp/l2tp_core.c
+++ b/net/l2tp/l2tp_core.c
@@ -221,10 +221,9 @@ static struct l2tp_session *l2tp_session_find_2(struct net *net, u32 session_id)
 	struct hlist_head *session_list =
 		l2tp_session_id_hash_2(pn, session_id);
 	struct l2tp_session *session;
-	struct hlist_node *walk;
 	rcu_read_lock_bh();
-	hlist_for_each_entry_rcu(session, walk, session_list, global_hlist) {
+	hlist_for_each_entry_rcu(session, session_list, global_hlist) {
 		if (session->session_id == session_id) {
 			rcu_read_unlock_bh();
 			return session;
@@ -253,7 +252,6 @@ struct l2tp_session *l2tp_session_find(struct net *net, struct l2tp_tunnel *tunn
 	struct hlist_head *session_list;
 	/* In L2TPv3, session_ids are unique over all tunnels and we
 	 * sometimes need to look them up before we know the
@@ -264,7 +262,7 @@ struct l2tp_session *l2tp_session_find(struct net *net, struct l2tp_tunnel *tunn
 	session_list = l2tp_session_id_hash(tunnel, session_id);
 	read_lock_bh(&tunnel->hlist_lock);
-	hlist_for_each_entry(session, walk, session_list, hlist) {
+	hlist_for_each_entry(session, session_list, hlist) {
 			read_unlock_bh(&tunnel->hlist_lock);
 			return session;
@@ -279,13 +277,12 @@ EXPORT_SYMBOL_GPL(l2tp_session_find);
 struct l2tp_session *l2tp_session_find_nth(struct l2tp_tunnel *tunnel, int nth)
 	int hash;
 	int count = 0;
 	for (hash = 0; hash < L2TP_HASH_SIZE; hash++) {
-		hlist_for_each_entry(session, walk, &tunnel->session_hlist[hash], hlist) {
+		hlist_for_each_entry(session, &tunnel->session_hlist[hash], hlist) {
 			if (++count > nth) {
 				return session;
@@ -306,12 +303,11 @@ struct l2tp_session *l2tp_session_find_by_ifname(struct net *net, char *ifname)
 	struct l2tp_net *pn = l2tp_pernet(net);
 	int hash;
 	rcu_read_lock_bh();
 	for (hash = 0; hash < L2TP_HASH_SIZE_2; hash++) {
-		hlist_for_each_entry_rcu(session, walk, &pn->l2tp_session_hlist[hash], global_hlist) {
+		hlist_for_each_entry_rcu(session, &pn->l2tp_session_hlist[hash], global_hlist) {
 			if (!strcmp(session->ifname, ifname)) {
 				return session;
diff --git a/net/l2tp/l2tp_ip.c b/net/l2tp/l2tp_ip.c
index f7ac8f4..7f41b70 100644
--- a/net/l2tp/l2tp_ip.c
+++ b/net/l2tp/l2tp_ip.c
@@ -49,10 +49,9 @@ static inline struct l2tp_ip_sock *l2tp_ip_sk(const struct sock *sk)
 static struct sock *__l2tp_ip_bind_lookup(struct net *net, __be32 laddr, int dif, u32 tunnel_id)
 	struct sock *sk;
-	sk_for_each_bound(sk, node, &l2tp_ip_bind_table) {
+	sk_for_each_bound(sk, &l2tp_ip_bind_table) {
 		struct l2tp_ip_sock *l2tp = l2tp_ip_sk(sk);
diff --git a/net/l2tp/l2tp_ip6.c b/net/l2tp/l2tp_ip6.c
index 8ee4a86..41f2f81 100644
--- a/net/l2tp/l2tp_ip6.c
+++ b/net/l2tp/l2tp_ip6.c
@@ -60,10 +60,9 @@ static struct sock *__l2tp_ip6_bind_lookup(struct net *net,
 					   struct in6_addr *laddr,
 	struct sock *sk;
-	sk_for_each_bound(sk, node, &l2tp_ip6_bind_table) {
+	sk_for_each_bound(sk, &l2tp_ip6_bind_table) {
 		struct in6_addr *addr = inet6_rcv_saddr(sk);
 		struct l2tp_ip6_sock *l2tp = l2tp_ip6_sk(sk);
diff --git a/net/llc/llc_sap.c b/net/llc/llc_sap.c
index 7c5073b..78be45c 100644
--- a/net/llc/llc_sap.c
+++ b/net/llc/llc_sap.c
@@ -393,12 +393,11 @@ static void llc_sap_mcast(struct llc_sap *sap,
 	int i = 0, count = 256 / sizeof(struct sock *);
 	struct sock *sk, *stack[count];
 	struct llc_sock *llc;
 	struct hlist_head *dev_hb = llc_sk_dev_hash(sap, skb->dev->ifindex);
 	spin_lock_bh(&sap->sk_lock);
-	hlist_for_each_entry(llc, node, dev_hb, dev_hash_node) {
+	hlist_for_each_entry(llc, dev_hb, dev_hash_node) {
 		sk = &llc->sk;
diff --git a/net/mac80211/mesh_pathtbl.c b/net/mac80211/mesh_pathtbl.c
index 6b3c4e1..dc7c8df 100644
--- a/net/mac80211/mesh_pathtbl.c
+++ b/net/mac80211/mesh_pathtbl.c
@@ -72,9 +72,9 @@ static inline struct mesh_table *resize_dereference_mpp_paths(void)
  * it's used twice. So it is illegal to do
  *	for_each_mesh_entry(rcu_dereference(...), ...)
-#define for_each_mesh_entry(tbl, p, node, i) \
+#define for_each_mesh_entry(tbl, node, i) \
 	for (i = 0; i <= tbl->hash_mask; i++) \
-		hlist_for_each_entry_rcu(node, p, &tbl->hash_buckets[i], list)
+		hlist_for_each_entry_rcu(node, &tbl->hash_buckets[i], list)
 static struct mesh_table *mesh_table_alloc(int size_order)
@@ -139,7 +139,7 @@ static void mesh_table_free(struct mesh_table *tbl, bool free_leafs)
 	if (free_leafs) {
 		spin_lock_bh(&tbl->gates_lock);
-		hlist_for_each_entry_safe(gate, p, q,
+		hlist_for_each_entry_safe(gate, q,
 					 tbl->known_gates, list) {
 			hlist_del(&gate->list);
 			kfree(gate);
@@ -333,12 +333,11 @@ static struct mesh_path *mpath_lookup(struct mesh_table *tbl, const u8 *dst,
 				      struct ieee80211_sub_if_data *sdata)
 	struct mesh_path *mpath;
 	struct hlist_head *bucket;
 	struct mpath_node *node;
 	bucket = &tbl->hash_buckets[mesh_table_hash(dst, sdata, tbl)];
-	hlist_for_each_entry_rcu(node, n, bucket, list) {
+	hlist_for_each_entry_rcu(node, bucket, list) {
 		mpath = node->mpath;
 		if (mpath->sdata == sdata &&
 		    ether_addr_equal(dst, mpath->dst)) {
@@ -389,11 +388,10 @@ mesh_path_lookup_by_idx(struct ieee80211_sub_if_data *sdata, int idx)
 	struct mesh_table *tbl = rcu_dereference(mesh_paths);
 	int i;
 	int j = 0;
-	for_each_mesh_entry(tbl, p, node, i) {
+	for_each_mesh_entry(tbl, node, i) {
 		if (sdata && node->mpath->sdata != sdata)
 			continue;
 		if (j++ == idx) {
@@ -417,13 +415,12 @@ int mesh_path_add_gate(struct mesh_path *mpath)
 	struct mesh_table *tbl;
 	struct mpath_node *gate, *new_gate;
 	int err;
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(gate, n, tbl->known_gates, list)
+	hlist_for_each_entry_rcu(gate, tbl->known_gates, list)
 		if (gate->mpath == mpath) {
 			err = -EEXIST;
 			goto err_rcu;
@@ -460,9 +457,9 @@ err_rcu:
 static void mesh_gate_del(struct mesh_table *tbl, struct mesh_path *mpath)
 	struct mpath_node *gate;
-	struct hlist_node *p, *q;
+	struct hlist_node *q;
-	hlist_for_each_entry_safe(gate, p, q, tbl->known_gates, list) {
+	hlist_for_each_entry_safe(gate, q, tbl->known_gates, list) {
 		if (gate->mpath != mpath)
 			continue;
@@ -504,7 +501,6 @@ int mesh_path_add(struct ieee80211_sub_if_data *sdata, const u8 *dst)
 	struct mesh_path *mpath, *new_mpath;
 	struct mpath_node *node, *new_node;
 	int grow = 0;
 	int err = 0;
 	u32 hash_idx;
@@ -550,7 +546,7 @@ int mesh_path_add(struct ieee80211_sub_if_data *sdata, const u8 *dst)
 	spin_lock(&tbl->hashwlock[hash_idx]);
 	err = -EEXIST;
-	hlist_for_each_entry(node, n, bucket, list) {
+	hlist_for_each_entry(node, bucket, list) {
@@ -640,7 +636,6 @@ int mpp_path_add(struct ieee80211_sub_if_data *sdata,
 	int grow = 0;
 	int err = 0;
 	u32 hash_idx;
@@ -680,7 +675,7 @@ int mpp_path_add(struct ieee80211_sub_if_data *sdata,
 	err = -EEXIST;
@@ -725,14 +720,13 @@ void mesh_plink_broken(struct sta_info *sta)
 	static const u8 bcast[ETH_ALEN] = {0xff, 0xff, 0xff, 0xff, 0xff, 0xff};
 	struct ieee80211_sub_if_data *sdata = sta->sdata;
 	int i;
 	__le16 reason = cpu_to_le16(WLAN_REASON_MESH_PATH_DEST_UNREACHABLE);
 	rcu_read_lock();
 		if (rcu_dereference(mpath->next_hop) == sta &&
 		    mpath->flags & MESH_PATH_ACTIVE &&
@@ -792,13 +786,12 @@ void mesh_path_flush_by_nexthop(struct sta_info *sta)
 	int i;
 	rcu_read_lock();
 	read_lock_bh(&pathtbl_resize_lock);
 	tbl = resize_dereference_mesh_paths();
 		if (rcu_dereference(mpath->next_hop) == sta) {
 			spin_lock(&tbl->hashwlock[i]);
@@ -815,11 +808,10 @@ static void table_flush_by_iface(struct mesh_table *tbl,
 	int i;
 	WARN_ON(!rcu_read_lock_held());
 		if (mpath->sdata != sdata)
 			continue;
@@ -865,7 +857,6 @@ int mesh_path_del(struct ieee80211_sub_if_data *sdata, const u8 *addr)
 	int hash_idx;
 	int err = 0;
@@ -875,7 +866,7 @@ int mesh_path_del(struct ieee80211_sub_if_data *sdata, const u8 *addr)
 	bucket = &tbl->hash_buckets[hash_idx];
 		    ether_addr_equal(addr, mpath->dst)) {
@@ -920,7 +911,6 @@ void mesh_path_tx_pending(struct mesh_path *mpath)
 int mesh_path_send_to_gates(struct mesh_path *mpath)
 	struct ieee80211_sub_if_data *sdata = mpath->sdata;
 	struct mesh_path *from_mpath = mpath;
 	struct mpath_node *gate = NULL;
@@ -935,7 +925,7 @@ int mesh_path_send_to_gates(struct mesh_path *mpath)
 	if (!known_gates)
 		return -EHOSTUNREACH;
-	hlist_for_each_entry_rcu(gate, n, known_gates, list) {
+	hlist_for_each_entry_rcu(gate, known_gates, list) {
 		if (gate->mpath->sdata != sdata)
 			continue;
@@ -951,7 +941,7 @@ int mesh_path_send_to_gates(struct mesh_path *mpath)
 		if (gate->mpath->sdata == sdata) {
 			mpath_dbg(sdata, "Sending to %pM\n", gate->mpath->dst);
 			mesh_path_tx_pending(gate->mpath);
@@ -1096,12 +1086,11 @@ void mesh_path_expire(struct ieee80211_sub_if_data *sdata)
 	int i;
 	rcu_read_lock();
 		if (node->mpath->sdata != sdata)
 			continue;
diff --git a/net/netfilter/ipvs/ip_vs_conn.c b/net/netfilter/ipvs/ip_vs_conn.c
index 9f00db7..704e514 100644
--- a/net/netfilter/ipvs/ip_vs_conn.c
+++ b/net/netfilter/ipvs/ip_vs_conn.c
@@ -259,13 +259,12 @@ __ip_vs_conn_in_get(const struct ip_vs_conn_param *p)
 	unsigned int hash;
 	struct ip_vs_conn *cp;
 	hash = ip_vs_conn_hashkey_param(p, false);
 	ct_read_lock(hash);
-	hlist_for_each_entry(cp, n, &ip_vs_conn_tab[hash], c_list) {
+	hlist_for_each_entry(cp, &ip_vs_conn_tab[hash], c_list) {
 		if (cp->af == p->af &&
 		    p->cport == cp->cport && p->vport == cp->vport &&
 		    ip_vs_addr_equal(p->af, p->caddr, &cp->caddr) &&
@@ -344,13 +343,12 @@ struct ip_vs_conn *ip_vs_ct_in_get(const struct ip_vs_conn_param *p)
 	unsigned int hash;
 	ct_read_lock(hash);
 		if (!ip_vs_conn_net_eq(cp, p->net))
 			continue;
 		if (p->pe_data && p->pe->ct_match) {
@@ -394,7 +392,6 @@ struct ip_vs_conn *ip_vs_conn_out_get(const struct ip_vs_conn_param *p)
 	unsigned int hash;
 	struct ip_vs_conn *cp, *ret=NULL;
 	 *	Check for "full" addressed entries
@@ -403,7 +400,7 @@ struct ip_vs_conn *ip_vs_conn_out_get(const struct ip_vs_conn_param *p)
 	ct_read_lock(hash);
 		    p->vport == cp->cport && p->cport == cp->dport &&
 		    ip_vs_addr_equal(p->af, p->vaddr, &cp->caddr) &&
@@ -953,11 +950,10 @@ static void *ip_vs_conn_array(struct seq_file *seq, loff_t pos)
 	int idx;
 	struct ip_vs_iter_state *iter = seq->private;
 	for (idx = 0; idx < ip_vs_conn_tab_size; idx++) {
 		ct_read_lock_bh(idx);
-		hlist_for_each_entry(cp, n, &ip_vs_conn_tab[idx], c_list) {
+		hlist_for_each_entry(cp, &ip_vs_conn_tab[idx], c_list) {
 			if (pos-- == 0) {
 				iter->l = &ip_vs_conn_tab[idx];
 				return cp;
@@ -981,7 +977,6 @@ static void *ip_vs_conn_seq_next(struct seq_file *seq, void *v, loff_t *pos)
 	struct ip_vs_conn *cp = v;
-	struct hlist_node *e;
 	struct hlist_head *l = iter->l;
 	int idx;
@@ -990,15 +985,15 @@ static void *ip_vs_conn_seq_next(struct seq_file *seq, void *v, loff_t *pos)
 		return ip_vs_conn_array(seq, 0);
 	/* more on same hash chain? */
-	if ((e = cp->c_list.next))
-		return hlist_entry(e, struct ip_vs_conn, c_list);
+	if (cp->c_list.next)
+		return hlist_entry(cp->c_list.next, struct ip_vs_conn, c_list);
 	idx = l - ip_vs_conn_tab;
 	ct_read_unlock_bh(idx);
 	while (++idx < ip_vs_conn_tab_size) {
-		hlist_for_each_entry(cp, e, &ip_vs_conn_tab[idx], c_list) {
 			return cp;
@@ -1200,14 +1195,13 @@ void ip_vs_random_dropentry(struct net *net)
 	for (idx = 0; idx < (ip_vs_conn_tab_size>>5); idx++) {
 		unsigned int hash = net_random() & ip_vs_conn_tab_mask;
 		 *  Lock is actually needed in this loop.
 		ct_write_lock_bh(hash);
 			if (cp->flags & IP_VS_CONN_F_TEMPLATE)
 				/* connection template */
 				continue;
@@ -1255,14 +1249,12 @@ static void ip_vs_conn_flush(struct net *net)
 flush_again:
 		ct_write_lock_bh(idx);
 			if (!ip_vs_conn_net_eq(cp, net))
 				continue;
 			IP_VS_DBG(4, "del connection\n");
diff --git a/net/netfilter/nf_conntrack_expect.c b/net/netfilter/nf_conntrack_expect.c
index 3921e5b..8c10e3d 100644
--- a/net/netfilter/nf_conntrack_expect.c
+++ b/net/netfilter/nf_conntrack_expect.c
@@ -90,14 +90,13 @@ __nf_ct_expect_find(struct net *net, u16 zone,
 		    const struct nf_conntrack_tuple *tuple)
 	struct nf_conntrack_expect *i;
 	unsigned int h;
 	if (!net->ct.expect_count)
 		return NULL;
 	h = nf_ct_expect_dst_hash(tuple);
-	hlist_for_each_entry_rcu(i, n, &net->ct.expect_hash[h], hnode) {
+	hlist_for_each_entry_rcu(i, &net->ct.expect_hash[h], hnode) {
 		if (nf_ct_tuple_mask_cmp(tuple, &i->tuple, &i->mask) &&
 		    nf_ct_zone(i->master) == zone)
 			return i;
@@ -130,14 +129,13 @@ nf_ct_find_expectation(struct net *net, u16 zone,
 	struct nf_conntrack_expect *i, *exp = NULL;
 	unsigned int h;
 		return NULL;
-	hlist_for_each_entry(i, n, &net->ct.expect_hash[h], hnode) {
+	hlist_for_each_entry(i, &net->ct.expect_hash[h], hnode) {
 		if (!(i->flags & NF_CT_EXPECT_INACTIVE) &&
 		    nf_ct_zone(i->master) == zone) {
@@ -172,13 +170,13 @@ void nf_ct_remove_expectations(struct nf_conn *ct)
 	struct nf_conn_help *help = nfct_help(ct);
 	struct nf_conntrack_expect *exp;
-	struct hlist_node *n, *next;
 	/* Optimization: most connection never expect any others. */
 	if (!help)
 		return;
-	hlist_for_each_entry_safe(exp, n, next, &help->expectations, lnode) {
+	hlist_for_each_entry_safe(exp, next, &help->expectations, lnode) {
 		if (del_timer(&exp->timeout)) {
 			nf_ct_unlink_expect(exp);
 			nf_ct_expect_put(exp);
@@ -348,9 +346,8 @@ static void evict_oldest_expect(struct nf_conn *master,
 	struct nf_conn_help *master_help = nfct_help(master);
 	struct nf_conntrack_expect *exp, *last = NULL;
-	hlist_for_each_entry(exp, n, &master_help->expectations, lnode) {
+	hlist_for_each_entry(exp, &master_help->expectations, lnode) {
 		if (exp->class == new->class)
 			last = exp;
@@ -369,7 +366,7 @@ static inline int __nf_ct_expect_check(struct nf_conntrack_expect *expect)
 	struct nf_conntrack_helper *helper;
 	struct net *net = nf_ct_exp_net(expect);
 	unsigned int h;
 	int ret = 1;
@@ -378,7 +375,7 @@ static inline int __nf_ct_expect_check(struct nf_conntrack_expect *expect)
 		goto out;
 	h = nf_ct_expect_dst_hash(&expect->tuple);
-	hlist_for_each_entry_safe(i, n, next, &net->ct.expect_hash[h], hnode) {
+	hlist_for_each_entry_safe(i, next, &net->ct.expect_hash[h], hnode) {
 		if (expect_matches(i, expect)) {
 			if (del_timer(&i->timeout)) {
 				nf_ct_unlink_expect(i);
diff --git a/net/netfilter/nf_conntrack_helper.c b/net/netfilter/nf_conntrack_helper.c
index 013cdf6..a9740bd 100644
--- a/net/netfilter/nf_conntrack_helper.c
+++ b/net/netfilter/nf_conntrack_helper.c
@@ -116,14 +116,13 @@ __nf_ct_helper_find(const struct nf_conntrack_tuple *tuple)
 	struct nf_conntrack_tuple_mask mask = { .src.u.all = htons(0xFFFF) };
-	struct hlist_node *n;
 	unsigned int h;
 	if (!nf_ct_helper_count)
 		return NULL;
 	h = helper_hash(tuple);
-	hlist_for_each_entry_rcu(helper, n, &nf_ct_helper_hash[h], hnode) {
+	hlist_for_each_entry_rcu(helper, &nf_ct_helper_hash[h], hnode) {
 		if (nf_ct_tuple_src_mask_cmp(tuple, &helper->tuple, &mask))
 			return helper;
@@ -134,11 +133,10 @@ struct nf_conntrack_helper *
 __nf_conntrack_helper_find(const char *name, u16 l3num, u8 protonum)
 	struct nf_conntrack_helper *h;
 	unsigned int i;
 	for (i = 0; i < nf_ct_helper_hsize; i++) {
-		hlist_for_each_entry_rcu(h, n, &nf_ct_helper_hash[i], hnode) {
+		hlist_for_each_entry_rcu(h, &nf_ct_helper_hash[i], hnode) {
 			if (!strcmp(h->name, name) &&
 			    h->tuple.src.l3num == l3num &&
 			    h->tuple.dst.protonum == protonum)
@@ -357,7 +355,6 @@ int nf_conntrack_helper_register(struct nf_conntrack_helper *me)
 	int ret = 0;
 	struct nf_conntrack_helper *cur;
 	unsigned int h = helper_hash(&me->tuple);
 	BUG_ON(me->expect_policy == NULL);
@@ -365,7 +362,7 @@ int nf_conntrack_helper_register(struct nf_conntrack_helper *me)
 	BUG_ON(strlen(me->name) > NF_CT_HELPER_NAME_LEN - 1);
 	mutex_lock(&nf_ct_helper_mutex);
-	hlist_for_each_entry(cur, n, &nf_ct_helper_hash[h], hnode) {
+	hlist_for_each_entry(cur, &nf_ct_helper_hash[h], hnode) {
 		if (strncmp(cur->name, me->name, NF_CT_HELPER_NAME_LEN) == 0 &&
 		    cur->tuple.src.l3num == me->tuple.src.l3num &&
 		    cur->tuple.dst.protonum == me->tuple.dst.protonum) {
@@ -386,13 +383,13 @@ static void __nf_conntrack_helper_unregister(struct nf_conntrack_helper *me,
 	struct nf_conntrack_tuple_hash *h;
-	const struct hlist_node *n, *next;
+	const struct hlist_node *next;
 	const struct hlist_nulls_node *nn;
 	unsigned int i;
 	/* Get rid of expectations */
 	for (i = 0; i < nf_ct_expect_hsize; i++) {
 					  &net->ct.expect_hash[i], hnode) {
 			struct nf_conn_help *help = nfct_help(exp->master);
 			if ((rcu_dereference_protected(
diff --git a/net/netfilter/nf_conntrack_netlink.c b/net/netfilter/nf_conntrack_netlink.c
index 5d60e04..9904b15 100644
--- a/net/netfilter/nf_conntrack_netlink.c
+++ b/net/netfilter/nf_conntrack_netlink.c
@@ -2370,14 +2370,13 @@ ctnetlink_exp_dump_table(struct sk_buff *skb, struct netlink_callback *cb)
 	struct nf_conntrack_expect *exp, *last;
 	struct nfgenmsg *nfmsg = nlmsg_data(cb->nlh);
 	u_int8_t l3proto = nfmsg->nfgen_family;
 	rcu_read_lock();
 	last = (struct nf_conntrack_expect *)cb->args[1];
 	for (; cb->args[0] < nf_ct_expect_hsize; cb->args[0]++) {
 restart:
-		hlist_for_each_entry(exp, n, &net->ct.expect_hash[cb->args[0]],
+		hlist_for_each_entry(exp, &net->ct.expect_hash[cb->args[0]],
 				     hnode) {
 			if (l3proto && exp->tuple.src.l3num != l3proto)
 				continue;
@@ -2510,7 +2509,7 @@ ctnetlink_del_expect(struct sock *ctnl, struct sk_buff *skb,
 	struct nf_conntrack_tuple tuple;
 	struct nfgenmsg *nfmsg = nlmsg_data(nlh);
 	u_int8_t u3 = nfmsg->nfgen_family;
 	unsigned int i;
 	u16 zone;
@@ -2557,7 +2556,7 @@ ctnetlink_del_expect(struct sock *ctnl, struct sk_buff *skb,
 		/* delete all expectations for this helper */
 		spin_lock_bh(&nf_conntrack_lock);
 						  hnode) {
 				m_help = nfct_help(exp->master);
@@ -2575,7 +2574,7 @@ ctnetlink_del_expect(struct sock *ctnl, struct sk_buff *skb,
 		/* This basically means we have to flush everything*/
 						  hnode) {
diff --git a/net/netfilter/nf_conntrack_sip.c b/net/netfilter/nf_conntrack_sip.c
index 069229d..0e7d423 100644
--- a/net/netfilter/nf_conntrack_sip.c
+++ b/net/netfilter/nf_conntrack_sip.c
@@ -855,11 +855,11 @@ static int refresh_signalling_expectation(struct nf_conn *ct,
 	int found = 0;
 		if (exp->class != SIP_EXPECT_SIGNALLING ||
 		    !nf_inet_addr_cmp(&exp->tuple.dst.u3, addr) ||
 		    exp->tuple.dst.protonum != proto ||
@@ -881,10 +881,10 @@ static void flush_expectations(struct nf_conn *ct, bool media)
 		if ((exp->class != SIP_EXPECT_SIGNALLING) ^ media)
 			continue;
 		if (!del_timer(&exp->timeout))
diff --git a/net/netfilter/nf_nat_core.c b/net/netfilter/nf_nat_core.c
index 5f2f910..8d5769c 100644
--- a/net/netfilter/nf_nat_core.c
+++ b/net/netfilter/nf_nat_core.c
@@ -191,9 +191,8 @@ find_appropriate_src(struct net *net, u16 zone,
 	unsigned int h = hash_by_src(net, zone, tuple);
 	const struct nf_conn_nat *nat;
 	const struct nf_conn *ct;
-	const struct hlist_node *n;
-	hlist_for_each_entry_rcu(nat, n, &net->ct.nat_bysource[h], bysource) {
+	hlist_for_each_entry_rcu(nat, &net->ct.nat_bysource[h], bysource) {
 		ct = nat->ct;
 		if (same_src(ct, tuple) && nf_ct_zone(ct) == zone) {
 			/* Copy source part from reply tuple. */
diff --git a/net/netfilter/nfnetlink_cthelper.c b/net/netfilter/nfnetlink_cthelper.c
index 945950a..a191b6d 100644
--- a/net/netfilter/nfnetlink_cthelper.c
+++ b/net/netfilter/nfnetlink_cthelper.c
@@ -282,7 +282,6 @@ nfnl_cthelper_new(struct sock *nfnl, struct sk_buff *skb,
 	const char *helper_name;
 	struct nf_conntrack_helper *cur, *helper = NULL;
 	int ret = 0, i;
 	if (!tb[NFCTH_NAME] || !tb[NFCTH_TUPLE])
@@ -296,7 +295,7 @@ nfnl_cthelper_new(struct sock *nfnl, struct sk_buff *skb,
 	rcu_read_lock();
 	for (i = 0; i < nf_ct_helper_hsize && !helper; i++) {
-		hlist_for_each_entry_rcu(cur, n, &nf_ct_helper_hash[i], hnode) {
+		hlist_for_each_entry_rcu(cur, &nf_ct_helper_hash[i], hnode) {
 			/* skip non-userspace conntrack helpers. */
 			if (!(cur->flags & NF_CT_HELPER_F_USERSPACE))
@@ -452,13 +451,12 @@ static int
 nfnl_cthelper_dump_table(struct sk_buff *skb, struct netlink_callback *cb)
 	struct nf_conntrack_helper *cur, *last;
 	rcu_read_lock();
 	last = (struct nf_conntrack_helper *)cb->args[1];
 	for (; cb->args[0] < nf_ct_helper_hsize; cb->args[0]++) {
 restart:
 				&nf_ct_helper_hash[cb->args[0]], hnode) {
@@ -495,7 +493,6 @@ nfnl_cthelper_get(struct sock *nfnl, struct sk_buff *skb,
 	int ret = -ENOENT, i;
 	struct sk_buff *skb2;
 	char *helper_name = NULL;
@@ -520,7 +517,7 @@ nfnl_cthelper_get(struct sock *nfnl, struct sk_buff *skb,
@@ -568,7 +565,7 @@ nfnl_cthelper_del(struct sock *nfnl, struct sk_buff *skb,
-	struct hlist_node *n, *tmp;
 	bool tuple_set = false, found = false;
 	int i, j = 0, ret;
@@ -585,7 +582,7 @@ nfnl_cthelper_del(struct sock *nfnl, struct sk_buff *skb,
-		hlist_for_each_entry_safe(cur, n, tmp, &nf_ct_helper_hash[i],
+		hlist_for_each_entry_safe(cur, tmp, &nf_ct_helper_hash[i],
 								hnode) {
@@ -654,13 +651,13 @@ err_out:
 static void __exit nfnl_cthelper_exit(void)
 	int i;
 	nfnetlink_subsys_unregister(&nfnl_cthelper_subsys);
 	for (i=0; i<nf_ct_helper_hsize; i++) {
 									hnode) {
diff --git a/net/netfilter/nfnetlink_log.c b/net/netfilter/nfnetlink_log.c
index 92fd8ec..f248db5 100644
--- a/net/netfilter/nfnetlink_log.c
+++ b/net/netfilter/nfnetlink_log.c
@@ -87,11 +87,10 @@ static struct nfulnl_instance *
 __instance_lookup(u_int16_t group_num)
 	struct hlist_head *head;
 	struct nfulnl_instance *inst;
 	head = &instance_table[instance_hashfn(group_num)];
-	hlist_for_each_entry_rcu(inst, pos, head, hlist) {
+	hlist_for_each_entry_rcu(inst, head, hlist) {
 		if (inst->group_num == group_num)
 			return inst;
@@ -717,11 +716,11 @@ nfulnl_rcv_nl_event(struct notifier_block *this,
 		/* destroy all instances for this portid */
 		spin_lock_bh(&instances_lock);
 		for  (i = 0; i < INSTANCE_BUCKETS; i++) {
-			struct hlist_node *tmp, *t2;
+			struct hlist_node *t2;
 			struct hlist_head *head = &instance_table[i];
-			hlist_for_each_entry_safe(inst, tmp, t2, head, hlist) {
+			hlist_for_each_entry_safe(inst, t2, head, hlist) {
 				if ((net_eq(n->net, &init_net)) &&
 				    (n->portid == inst->peer_portid))
 					__instance_destroy(inst);
diff --git a/net/netfilter/nfnetlink_queue_core.c b/net/netfilter/nfnetlink_queue_core.c
index 3158d87..858fd52 100644
--- a/net/netfilter/nfnetlink_queue_core.c
+++ b/net/netfilter/nfnetlink_queue_core.c
@@ -80,11 +80,10 @@ static struct nfqnl_instance *
 instance_lookup(u_int16_t queue_num)
 	struct nfqnl_instance *inst;
 	head = &instance_table[instance_hashfn(queue_num)];
 		if (inst->queue_num == queue_num)
 			return inst;
@@ -583,11 +582,10 @@ nfqnl_dev_drop(int ifindex)
 	rcu_read_lock();
-		hlist_for_each_entry_rcu(inst, tmp, head, hlist)
 			nfqnl_flush(inst, dev_cmp, ifindex);
@@ -627,11 +625,11 @@ nfqnl_rcv_nl_event(struct notifier_block *this,
 		spin_lock(&instances_lock);
 				if ((n->net == &init_net) &&
diff --git a/net/netfilter/xt_RATEEST.c b/net/netfilter/xt_RATEEST.c
index f264032..370adf6 100644
--- a/net/netfilter/xt_RATEEST.c
+++ b/net/netfilter/xt_RATEEST.c
@@ -43,12 +43,11 @@ static void xt_rateest_hash_insert(struct xt_rateest *est)
 struct xt_rateest *xt_rateest_lookup(const char *name)
 	struct xt_rateest *est;
 	unsigned int h;
 	h = xt_rateest_hash(name);
 	mutex_lock(&xt_rateest_mutex);
-	hlist_for_each_entry(est, n, &rateest_hash[h], list) {
+	hlist_for_each_entry(est, &rateest_hash[h], list) {
 		if (strcmp(est->name, name) == 0) {
 			est->refcnt++;
 			mutex_unlock(&xt_rateest_mutex);
diff --git a/net/netfilter/xt_connlimit.c b/net/netfilter/xt_connlimit.c
index 70b5591..c40b269 100644
--- a/net/netfilter/xt_connlimit.c
+++ b/net/netfilter/xt_connlimit.c
@@ -101,7 +101,7 @@ static int count_them(struct net *net,
 	const struct nf_conntrack_tuple_hash *found;
 	struct xt_connlimit_conn *conn;
-	struct hlist_node *pos, *n;
+	struct hlist_node *n;
 	struct nf_conn *found_ct;
 	struct hlist_head *hash;
 	bool addit = true;
@@ -115,7 +115,7 @@ static int count_them(struct net *net,
 	rcu_read_lock();
 	/* check the saved connections */
-	hlist_for_each_entry_safe(conn, pos, n, hash, node) {
+	hlist_for_each_entry_safe(conn, n, hash, node) {
 		found    = nf_conntrack_find_get(net, NF_CT_DEFAULT_ZONE,
 						 &conn->tuple);
 		found_ct = NULL;
@@ -258,14 +258,14 @@ static void connlimit_mt_destroy(const struct xt_mtdtor_param *par)
 	const struct xt_connlimit_info *info = par->matchinfo;
 	struct hlist_head *hash = info->data->iphash;
 	unsigned int i;
 	nf_ct_l3proto_module_put(par->family);
 	for (i = 0; i < ARRAY_SIZE(info->data->iphash); ++i) {
-		hlist_for_each_entry_safe(conn, pos, n, &hash[i], node) {
+		hlist_for_each_entry_safe(conn, n, &hash[i], node) {
 			hlist_del(&conn->node);
 			kfree(conn);
diff --git a/net/netfilter/xt_hashlimit.c b/net/netfilter/xt_hashlimit.c
index 98218c8..f330e8b 100644
--- a/net/netfilter/xt_hashlimit.c
+++ b/net/netfilter/xt_hashlimit.c
@@ -141,11 +141,10 @@ dsthash_find(const struct xt_hashlimit_htable *ht,
 	     const struct dsthash_dst *dst)
 	struct dsthash_ent *ent;
 	u_int32_t hash = hash_dst(ht, dst);
 	if (!hlist_empty(&ht->hash[hash])) {
-		hlist_for_each_entry_rcu(ent, pos, &ht->hash[hash], node)
+		hlist_for_each_entry_rcu(ent, &ht->hash[hash], node)
 			if (dst_cmp(ent, dst)) {
 				spin_lock(&ent->lock);
 				return ent;
@@ -297,8 +296,8 @@ static void htable_selective_cleanup(struct xt_hashlimit_htable *ht,
 	spin_lock_bh(&ht->lock);
 	for (i = 0; i < ht->cfg.size; i++) {
 		struct dsthash_ent *dh;
-		hlist_for_each_entry_safe(dh, pos, n, &ht->hash[i], node) {
+		hlist_for_each_entry_safe(dh, n, &ht->hash[i], node) {
 			if ((*select)(ht, dh))
 				dsthash_free(ht, dh);
@@ -343,9 +342,8 @@ static struct xt_hashlimit_htable *htable_find_get(struct net *net,
 	struct hashlimit_net *hashlimit_net = hashlimit_pernet(net);
 	struct xt_hashlimit_htable *hinfo;
-	hlist_for_each_entry(hinfo, pos, &hashlimit_net->htables, node) {
+	hlist_for_each_entry(hinfo, &hashlimit_net->htables, node) {
 		if (!strcmp(name, hinfo->pde->name) &&
 		    hinfo->family == family) {
 			hinfo->use++;
@@ -821,10 +819,9 @@ static int dl_seq_show(struct seq_file *s, void *v)
 	struct xt_hashlimit_htable *htable = s->private;
 	unsigned int *bucket = (unsigned int *)v;
 	if (!hlist_empty(&htable->hash[*bucket])) {
-		hlist_for_each_entry(ent, pos, &htable->hash[*bucket], node)
+		hlist_for_each_entry(ent, &htable->hash[*bucket], node)
 			if (dl_seq_real_show(ent, htable->family, s))
 				return -1;
@@ -877,7 +874,6 @@ static int __net_init hashlimit_proc_net_init(struct net *net)
 static void __net_exit hashlimit_proc_net_exit(struct net *net)
 	struct proc_dir_entry *pde;
@@ -890,7 +886,7 @@ static void __net_exit hashlimit_proc_net_exit(struct net *net)
 	if (pde == NULL)
 		pde = hashlimit_net->ip6t_hashlimit;
 		remove_proc_entry(hinfo->pde->name, pde);
 	hashlimit_net->ipt_hashlimit = NULL;
diff --git a/net/netlink/af_netlink.c b/net/netlink/af_netlink.c
index 8097b4f..1e3fd5b 100644
--- a/net/netlink/af_netlink.c
+++ b/net/netlink/af_netlink.c
@@ -248,11 +248,10 @@ static struct sock *netlink_lookup(struct net *net, int protocol, u32 portid)
 	struct nl_portid_hash *hash = &nl_table[protocol].hash;
 	struct sock *sk;
 	read_lock(&nl_table_lock);
 	head = nl_portid_hashfn(hash, portid);
-	sk_for_each(sk, node, head) {
+	sk_for_each(sk, head) {
 		if (net_eq(sock_net(sk), net) && (nlk_sk(sk)->portid == portid)) {
 			sock_hold(sk);
 			goto found;
@@ -312,9 +311,9 @@ static int nl_portid_hash_rehash(struct nl_portid_hash *hash, int grow)
 	for (i = 0; i <= omask; i++) {
 		struct sock *sk;
+		struct hlist_node *tmp;
-		sk_for_each_safe(sk, node, tmp, &otable[i])
+		sk_for_each_safe(sk, tmp, &otable[i])
 			__sk_add_node(sk, nl_portid_hashfn(hash, nlk_sk(sk)->portid));
@@ -344,7 +343,6 @@ static void
 netlink_update_listeners(struct sock *sk)
 	struct netlink_table *tbl = &nl_table[sk->sk_protocol];
 	unsigned long mask;
 	unsigned int i;
 	struct listeners *listeners;
@@ -355,7 +353,7 @@ netlink_update_listeners(struct sock *sk)
 	for (i = 0; i < NLGRPLONGS(tbl->groups); i++) {
 		mask = 0;
-		sk_for_each_bound(sk, node, &tbl->mc_list) {
+		sk_for_each_bound(sk, &tbl->mc_list) {
 			if (i < NLGRPLONGS(nlk_sk(sk)->ngroups))
 				mask |= nlk_sk(sk)->groups[i];
@@ -371,18 +369,17 @@ static int netlink_insert(struct sock *sk, struct net *net, u32 portid)
 	int err = -EADDRINUSE;
 	struct sock *osk;
 	int len;
 	netlink_table_grab();
 	len = 0;
-	sk_for_each(osk, node, head) {
+	sk_for_each(osk, head) {
 		if (net_eq(sock_net(osk), net) && (nlk_sk(osk)->portid == portid))
 			break;
 		len++;
-	if (node)
+	if (osk)
 		goto err;
 	err = -EBUSY;
@@ -575,7 +572,6 @@ static int netlink_autobind(struct socket *sock)
 	struct nl_portid_hash *hash = &nl_table[sk->sk_protocol].hash;
 	struct sock *osk;
 	s32 portid = task_tgid_vnr(current);
 	int err;
 	static s32 rover = -4097;
@@ -584,7 +580,7 @@ retry:
 	cond_resched();
 		if (!net_eq(sock_net(osk), net))
 			continue;
 		if (nlk_sk(osk)->portid == portid) {
@@ -1101,7 +1097,6 @@ int netlink_broadcast_filtered(struct sock *ssk, struct sk_buff *skb, u32 portid
 	struct net *net = sock_net(ssk);
 	struct netlink_broadcast_data info;
 	struct sock *sk;
 	skb = netlink_trim(skb, allocation);
@@ -1124,7 +1119,7 @@ int netlink_broadcast_filtered(struct sock *ssk, struct sk_buff *skb, u32 portid
 	netlink_lock_table();
-	sk_for_each_bound(sk, node, &nl_table[ssk->sk_protocol].mc_list)
+	sk_for_each_bound(sk, &nl_table[ssk->sk_protocol].mc_list)
 		do_one_broadcast(sk, &info);
 	consume_skb(skb);
@@ -1200,7 +1195,6 @@ out:
 int netlink_set_err(struct sock *ssk, u32 portid, u32 group, int code)
 	struct netlink_set_err_data info;
 	struct sock *sk;
 	int ret = 0;
@@ -1212,7 +1206,7 @@ int netlink_set_err(struct sock *ssk, u32 portid, u32 group, int code)
 		ret += do_one_set_err(sk, &info);
 	read_unlock(&nl_table_lock);
@@ -1676,10 +1670,9 @@ int netlink_change_ngroups(struct sock *sk, unsigned int groups)
 void __netlink_clear_multicast_users(struct sock *ksk, unsigned int group)
 	struct sock *sk;
 	struct netlink_table *tbl = &nl_table[ksk->sk_protocol];
 		netlink_update_socket_mc(nlk_sk(sk), group, 0);
@@ -1974,14 +1967,13 @@ static struct sock *netlink_seq_socket_idx(struct seq_file *seq, loff_t pos)
 	struct nl_seq_iter *iter = seq->private;
 	int i, j;
 	struct sock *s;
 	loff_t off = 0;
 	for (i = 0; i < MAX_LINKS; i++) {
 		struct nl_portid_hash *hash = &nl_table[i].hash;
 		for (j = 0; j <= hash->mask; j++) {
-			sk_for_each(s, node, &hash->table[j]) {
+			sk_for_each(s, &hash->table[j]) {
 				if (sock_net(s) != seq_file_net(seq))
 					continue;
 				if (off == pos) {
diff --git a/net/netrom/af_netrom.c b/net/netrom/af_netrom.c
index 297b07a..d1fa1d9 100644
--- a/net/netrom/af_netrom.c
+++ b/net/netrom/af_netrom.c
@@ -104,10 +104,9 @@ static void nr_remove_socket(struct sock *sk)
 static void nr_kill_by_device(struct net_device *dev)
 	struct sock *s;
 	spin_lock_bh(&nr_list_lock);
-	sk_for_each(s, node, &nr_list)
+	sk_for_each(s, &nr_list)
 		if (nr_sk(s)->device == dev)
 			nr_disconnect(s, ENETUNREACH);
 	spin_unlock_bh(&nr_list_lock);
@@ -149,10 +148,9 @@ static void nr_insert_socket(struct sock *sk)
 static struct sock *nr_find_listener(ax25_address *addr)
 	struct sock *s;
-	struct hlist_node *node;
 		if (!ax25cmp(&nr_sk(s)->source_addr, addr) &&
 		    s->sk_state == TCP_LISTEN) {
 			bh_lock_sock(s);
@@ -170,10 +168,9 @@ found:
 static struct sock *nr_find_socket(unsigned char index, unsigned char id)
 	struct sock *s;
-	sk_for_each(s, node, &nr_list) {
+	sk_for_each(s, &nr_list) {
 		struct nr_sock *nr = nr_sk(s);
 		if (nr->my_index == index && nr->my_id == id) {
@@ -194,10 +191,9 @@ static struct sock *nr_find_peer(unsigned char index, unsigned char id,
 	ax25_address *dest)
 	struct sock *s;
 		if (nr->your_index == index && nr->your_id == id &&
diff --git a/net/netrom/nr_route.c b/net/netrom/nr_route.c
index 70ffff7..b976d5e 100644
--- a/net/netrom/nr_route.c
+++ b/net/netrom/nr_route.c
@@ -49,10 +49,9 @@ static struct nr_node *nr_node_get(ax25_address *callsign)
 	struct nr_node *found = NULL;
 	struct nr_node *nr_node;
 	spin_lock_bh(&nr_node_list_lock);
-	nr_node_for_each(nr_node, node, &nr_node_list)
+	nr_node_for_each(nr_node, &nr_node_list)
 		if (ax25cmp(callsign, &nr_node->callsign) == 0) {
 			nr_node_hold(nr_node);
 			found = nr_node;
@@ -67,10 +66,9 @@ static struct nr_neigh *nr_neigh_get_dev(ax25_address *callsign,
 	struct nr_neigh *found = NULL;
 	struct nr_neigh *nr_neigh;
 	spin_lock_bh(&nr_neigh_list_lock);
-	nr_neigh_for_each(nr_neigh, node, &nr_neigh_list)
+	nr_neigh_for_each(nr_neigh, &nr_neigh_list)
 		if (ax25cmp(callsign, &nr_neigh->callsign) == 0 &&
 		    nr_neigh->dev == dev) {
 			nr_neigh_hold(nr_neigh);
@@ -114,10 +112,9 @@ static int __must_check nr_add_node(ax25_address *nr, const char *mnemonic,
 	if (nr_neigh != NULL && nr_neigh->failed != 0 && quality == 0) {
 		struct nr_node *nr_nodet;
-		nr_node_for_each(nr_nodet, node, &nr_node_list) {
+		nr_node_for_each(nr_nodet, &nr_node_list) {
 			nr_node_lock(nr_nodet);
 			for (i = 0; i < nr_nodet->count; i++)
 				if (nr_nodet->routes[i].neighbour == nr_neigh)
@@ -485,11 +482,11 @@ static int nr_dec_obs(void)
 	struct nr_node  *s;
-	struct hlist_node *node, *nodet;
+	struct hlist_node *nodet;
 	int i;
-	nr_node_for_each_safe(s, node, nodet, &nr_node_list) {
+	nr_node_for_each_safe(s, nodet, &nr_node_list) {
 		nr_node_lock(s);
 		for (i = 0; i < s->count; i++) {
 			switch (s->routes[i].obs_count) {
@@ -540,15 +537,15 @@ static int nr_dec_obs(void)
 void nr_rt_device_down(struct net_device *dev)
 	struct nr_neigh *s;
-	struct hlist_node *node, *nodet, *node2, *node2t;
+	struct hlist_node *nodet, *node2t;
 	struct nr_node  *t;
 	int i;
-	nr_neigh_for_each_safe(s, node, nodet, &nr_neigh_list) {
+	nr_neigh_for_each_safe(s, nodet, &nr_neigh_list) {
 		if (s->dev == dev) {
-			nr_node_for_each_safe(t, node2, node2t, &nr_node_list) {
+			nr_node_for_each_safe(t, node2t, &nr_node_list) {
 				nr_node_lock(t);
 				for (i = 0; i < t->count; i++) {
 					if (t->routes[i].neighbour == s) {
@@ -737,11 +734,10 @@ int nr_rt_ioctl(unsigned int cmd, void __user *arg)
 void nr_link_failed(ax25_cb *ax25, int reason)
 	struct nr_neigh *s, *nr_neigh = NULL;
 	struct nr_node  *nr_node = NULL;
-	nr_neigh_for_each(s, node, &nr_neigh_list) {
+	nr_neigh_for_each(s, &nr_neigh_list) {
 		if (s->ax25 == ax25) {
 			nr_neigh_hold(s);
 			nr_neigh = s;
@@ -761,7 +757,7 @@ void nr_link_failed(ax25_cb *ax25, int reason)
 		return;
-	nr_node_for_each(nr_node, node, &nr_node_list) {
+	nr_node_for_each(nr_node, &nr_node_list) {
 		nr_node_lock(nr_node);
 		if (nr_node->which < nr_node->count &&
 		    nr_node->routes[nr_node->which].neighbour == nr_neigh)
@@ -1013,16 +1009,16 @@ void __exit nr_rt_free(void)
 	struct nr_neigh *s = NULL;
 	struct nr_node  *t = NULL;
-	nr_node_for_each_safe(t, node, nodet, &nr_node_list) {
+	nr_node_for_each_safe(t, nodet, &nr_node_list) {
 		nr_node_lock(t);
 		nr_remove_node_locked(t);
 		nr_node_unlock(t);
 		while(s->count) {
 			s->count--;
 			nr_neigh_put(s);
diff --git a/net/nfc/llcp/llcp.c b/net/nfc/llcp/llcp.c
index 746f5a2..7f8266d 100644
--- a/net/nfc/llcp/llcp.c
+++ b/net/nfc/llcp/llcp.c
@@ -71,14 +71,14 @@ static void nfc_llcp_socket_purge(struct nfc_llcp_sock *sock)
 static void nfc_llcp_socket_release(struct nfc_llcp_local *local, bool listen)
 	struct sock *sk;
-	struct hlist_node *node, *tmp;
 	struct nfc_llcp_sock *llcp_sock;
 	skb_queue_purge(&local->tx_queue);
 	write_lock(&local->sockets.lock);
-	sk_for_each_safe(sk, node, tmp, &local->sockets.head) {
+	sk_for_each_safe(sk, tmp, &local->sockets.head) {
 		llcp_sock = nfc_llcp_sock(sk);
 		bh_lock_sock(sk);
@@ -171,7 +171,6 @@ static struct nfc_llcp_sock *nfc_llcp_sock_get(struct nfc_llcp_local *local,
 					       u8 ssap, u8 dsap)
 	struct sock *sk;
 	struct nfc_llcp_sock *llcp_sock, *tmp_sock;
 	pr_debug("ssap dsap %d %d\n", ssap, dsap);
@@ -183,7 +182,7 @@ static struct nfc_llcp_sock *nfc_llcp_sock_get(struct nfc_llcp_local *local,
 	llcp_sock = NULL;
-	sk_for_each(sk, node, &local->sockets.head) {
+	sk_for_each(sk, &local->sockets.head) {
 		tmp_sock = nfc_llcp_sock(sk);
 		if (tmp_sock->ssap == ssap && tmp_sock->dsap == dsap) {
@@ -272,7 +271,6 @@ struct nfc_llcp_sock *nfc_llcp_sock_from_sn(struct nfc_llcp_local *local,
 					    u8 *sn, size_t sn_len)
 	struct sock *sk;
 	pr_debug("sn %zd %p\n", sn_len, sn);
@@ -284,7 +282,7 @@ struct nfc_llcp_sock *nfc_llcp_sock_from_sn(struct nfc_llcp_local *local,
 	llcp_sock = NULL;
 		pr_debug("llcp sock %p\n", tmp_sock);
@@ -601,14 +599,13 @@ static void nfc_llcp_set_nrns(struct nfc_llcp_sock *sock, struct sk_buff *pdu)
 void nfc_llcp_send_to_raw_sock(struct nfc_llcp_local *local,
 			       struct sk_buff *skb, u8 direction)
 	struct sk_buff *skb_copy = NULL, *nskb;
 	struct sock *sk;
 	u8 *data;
 	read_lock(&local->raw_sockets.lock);
-	sk_for_each(sk, node, &local->raw_sockets.head) {
+	sk_for_each(sk, &local->raw_sockets.head) {
 		if (sk->sk_state != LLCP_BOUND)
 			continue;
@@ -697,11 +694,10 @@ static struct nfc_llcp_sock *nfc_llcp_connecting_sock_get(struct nfc_llcp_local
 	struct sock *sk;
 	read_lock(&local->connecting_sockets.lock);
-	sk_for_each(sk, node, &local->connecting_sockets.head) {
+	sk_for_each(sk, &local->connecting_sockets.head) {
 		if (llcp_sock->ssap == ssap) {
diff --git a/net/openvswitch/datapath.c b/net/openvswitch/datapath.c
index 9dc537d..e87a265 100644
--- a/net/openvswitch/datapath.c
+++ b/net/openvswitch/datapath.c
@@ -158,11 +158,10 @@ static struct hlist_head *vport_hash_bucket(const struct datapath *dp,
 struct vport *ovs_lookup_vport(const struct datapath *dp, u16 port_no)
 	struct vport *vport;
 	head = vport_hash_bucket(dp, port_no);
-	hlist_for_each_entry_rcu(vport, n, head, dp_hash_node) {
+	hlist_for_each_entry_rcu(vport, head, dp_hash_node) {
 		if (vport->port_no == port_no)
 			return vport;
@@ -1386,9 +1385,9 @@ static void __dp_destroy(struct datapath *dp)
 	for (i = 0; i < DP_VPORT_HASH_BUCKETS; i++) {
-		struct hlist_node *node, *n;
-		hlist_for_each_entry_safe(vport, node, n, &dp->ports[i], dp_hash_node)
+		hlist_for_each_entry_safe(vport, n, &dp->ports[i], dp_hash_node)
 			if (vport->port_no != OVSP_LOCAL)
 				ovs_dp_detach_port(vport);
@@ -1825,10 +1824,9 @@ static int ovs_vport_cmd_dump(struct sk_buff *skb, struct netlink_callback *cb)
 	rcu_read_lock();
 	for (i = bucket; i < DP_VPORT_HASH_BUCKETS; i++) {
 		j = 0;
-		hlist_for_each_entry_rcu(vport, n, &dp->ports[i], dp_hash_node) {
+		hlist_for_each_entry_rcu(vport, &dp->ports[i], dp_hash_node) {
 			if (j >= skip &&
 			    ovs_vport_cmd_fill_info(vport, skb,
 						    NETLINK_CB(cb->skb).portid,
diff --git a/net/openvswitch/flow.c b/net/openvswitch/flow.c
index c3294ce..20605ec 100644
--- a/net/openvswitch/flow.c
+++ b/net/openvswitch/flow.c
@@ -299,10 +299,10 @@ void ovs_flow_tbl_destroy(struct flow_table *table)
 	for (i = 0; i < table->n_buckets; i++) {
 		struct sw_flow *flow;
 		struct hlist_head *head = flex_array_get(table->buckets, i);
 		int ver = table->node_ver;
-		hlist_for_each_entry_safe(flow, node, n, head, hash_node[ver]) {
+		hlist_for_each_entry_safe(flow, n, head, hash_node[ver]) {
 			hlist_del_rcu(&flow->hash_node[ver]);
 			ovs_flow_free(flow);
@@ -332,7 +332,6 @@ struct sw_flow *ovs_flow_tbl_next(struct flow_table *table, u32 *bucket, u32 *la
 	int ver;
 	int i;
@@ -340,7 +339,7 @@ struct sw_flow *ovs_flow_tbl_next(struct flow_table *table, u32 *bucket, u32 *la
 	while (*bucket < table->n_buckets) {
 		i = 0;
 		head = flex_array_get(table->buckets, *bucket);
-		hlist_for_each_entry_rcu(flow, n, head, hash_node[ver]) {
+		hlist_for_each_entry_rcu(flow, head, hash_node[ver]) {
 			if (i < *last) {
 				i++;
 				continue;
@@ -367,11 +366,10 @@ static void flow_table_copy_flows(struct flow_table *old, struct flow_table *new
 	for (i = 0; i < old->n_buckets; i++) {
 		head = flex_array_get(old->buckets, i);
-		hlist_for_each_entry(flow, n, head, hash_node[old_ver])
+		hlist_for_each_entry(flow, head, hash_node[old_ver])
 			ovs_flow_tbl_insert(new, flow);
 	old->keep_flows = true;
@@ -766,14 +764,13 @@ struct sw_flow *ovs_flow_tbl_lookup(struct flow_table *table,
 				struct sw_flow_key *key, int key_len)
 	u32 hash;
 	hash = ovs_flow_hash(key, key_len);
 	head = find_bucket(table, hash);
-	hlist_for_each_entry_rcu(flow, n, head, hash_node[table->node_ver]) {
+	hlist_for_each_entry_rcu(flow, head, hash_node[table->node_ver]) {
 		if (flow->hash == hash &&
 		    !memcmp(&flow->key, key, key_len)) {
diff --git a/net/openvswitch/vport.c b/net/openvswitch/vport.c
index 70af0be..ba717cc 100644
--- a/net/openvswitch/vport.c
+++ b/net/openvswitch/vport.c
@@ -86,9 +86,8 @@ struct vport *ovs_vport_locate(struct net *net, const char *name)
 	struct hlist_head *bucket = hash_bucket(net, name);
-	hlist_for_each_entry_rcu(vport, node, bucket, hash_node)
+	hlist_for_each_entry_rcu(vport, bucket, hash_node)
 		if (!strcmp(name, vport->ops->get_name(vport)) &&
 		    net_eq(ovs_dp_get_net(vport->dp), net))
 			return vport;
diff --git a/net/packet/af_packet.c b/net/packet/af_packet.c
index c7bfeff..1d6793d 100644
--- a/net/packet/af_packet.c
+++ b/net/packet/af_packet.c
@@ -3263,12 +3263,11 @@ static int packet_getsockopt(struct socket *sock, int level, int optname,
 static int packet_notifier(struct notifier_block *this, unsigned long msg, void *data)
 	struct sock *sk;
 	struct net_device *dev = data;
 	struct net *net = dev_net(dev);
 	rcu_read_lock();
-	sk_for_each_rcu(sk, node, &net->packet.sklist) {
+	sk_for_each_rcu(sk, &net->packet.sklist) {
 		struct packet_sock *po = pkt_sk(sk);
 		switch (msg) {
diff --git a/net/packet/diag.c b/net/packet/diag.c
index 8db6e21..d3fcd1e 100644
--- a/net/packet/diag.c
+++ b/net/packet/diag.c
@@ -172,13 +172,12 @@ static int packet_diag_dump(struct sk_buff *skb, struct netlink_callback *cb)
 	struct packet_diag_req *req;
 	struct net *net;
 	struct sock *sk;
 	req = nlmsg_data(cb->nlh);
 	mutex_lock(&net->packet.sklist_lock);
-	sk_for_each(sk, node, &net->packet.sklist) {
+	sk_for_each(sk, &net->packet.sklist) {
 		if (!net_eq(sock_net(sk), net))
 			continue;
 		if (num < s_num)
diff --git a/net/phonet/pep.c b/net/phonet/pep.c
index 576f22c..e774117 100644
--- a/net/phonet/pep.c
+++ b/net/phonet/pep.c
@@ -640,11 +640,10 @@ static struct sock *pep_find_pipe(const struct hlist_head *hlist,
 					const struct sockaddr_pn *dst,
 					u8 pipe_handle)
 	struct sock *sknode;
 	u16 dobj = pn_sockaddr_get_object(dst);
-	sk_for_each(sknode, node, hlist) {
+	sk_for_each(sknode, hlist) {
 		struct pep_sock *pnnode = pep_sk(sknode);
 		/* Ports match, but addresses might not: */
diff --git a/net/phonet/socket.c b/net/phonet/socket.c
index b7e9827..1afd138 100644
--- a/net/phonet/socket.c
+++ b/net/phonet/socket.c
@@ -76,7 +76,6 @@ static struct hlist_head *pn_hash_list(u16 obj)
 struct sock *pn_find_sock_by_sa(struct net *net, const struct sockaddr_pn *spn)
 	struct sock *rval = NULL;
 	u16 obj = pn_sockaddr_get_object(spn);
@@ -84,7 +83,7 @@ struct sock *pn_find_sock_by_sa(struct net *net, const struct sockaddr_pn *spn)
 	struct hlist_head *hlist = pn_hash_list(obj);
 	rcu_read_lock();
-	sk_for_each_rcu(sknode, node, hlist) {
+	sk_for_each_rcu(sknode, hlist) {
 		struct pn_sock *pn = pn_sk(sknode);
 		BUG_ON(!pn->sobject); /* unbound socket */
@@ -120,10 +119,9 @@ void pn_deliver_sock_broadcast(struct net *net, struct sk_buff *skb)
 	rcu_read_lock();
 	for (h = 0; h < PN_HASHSIZE; h++) {
 			struct sk_buff *clone;
 			if (!net_eq(sock_net(sknode), net))
@@ -543,12 +541,11 @@ static struct sock *pn_sock_get_idx(struct seq_file *seq, loff_t pos)
 	struct net *net = seq_file_net(seq);
 	struct hlist_head *hlist = pnsocks.hlist;
 	unsigned int h;
 			if (!net_eq(net, sock_net(sknode)))
 				continue;
 			if (!pos)
diff --git a/net/rds/bind.c b/net/rds/bind.c
index 637bde5..b5ad65a 100644
--- a/net/rds/bind.c
+++ b/net/rds/bind.c
@@ -52,13 +52,12 @@ static struct rds_sock *rds_bind_lookup(__be32 addr, __be16 port,
 					struct rds_sock *insert)
 	struct rds_sock *rs;
 	struct hlist_head *head = hash_to_bucket(addr, port);
 	u64 cmp;
 	u64 needle = ((u64)be32_to_cpu(addr) << 32) | be16_to_cpu(port);
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(rs, node, head, rs_bound_node) {
+	hlist_for_each_entry_rcu(rs, head, rs_bound_node) {
 		cmp = ((u64)be32_to_cpu(rs->rs_bound_addr) << 32) |
 		      be16_to_cpu(rs->rs_bound_port);
diff --git a/net/rds/connection.c b/net/rds/connection.c
index 9e07c75..642ad42 100644
--- a/net/rds/connection.c
+++ b/net/rds/connection.c
@@ -69,9 +69,8 @@ static struct rds_connection *rds_conn_lookup(struct hlist_head *head,
 					      struct rds_transport *trans)
 	struct rds_connection *conn, *ret = NULL;
-	hlist_for_each_entry_rcu(conn, pos, head, c_hash_node) {
+	hlist_for_each_entry_rcu(conn, head, c_hash_node) {
 		if (conn->c_faddr == faddr && conn->c_laddr == laddr &&
 				conn->c_trans == trans) {
 			ret = conn;
@@ -376,7 +375,6 @@ static void rds_conn_message_info(struct socket *sock, unsigned int len,
 				  int want_send)
 	struct list_head *list;
 	struct rds_connection *conn;
 	struct rds_message *rm;
@@ -390,7 +388,7 @@ static void rds_conn_message_info(struct socket *sock, unsigned int len,
 	for (i = 0, head = rds_conn_hash; i < ARRAY_SIZE(rds_conn_hash);
 	     i++, head++) {
 			if (want_send)
 				list = &conn->c_send_queue;
 			else
@@ -439,7 +437,6 @@ void rds_for_each_conn_info(struct socket *sock, unsigned int len,
 	uint64_t buffer[(item_len + 7) / 8];
 	size_t i;
@@ -450,7 +447,7 @@ void rds_for_each_conn_info(struct socket *sock, unsigned int len,
 	     i++, head++) {
 			/* XXX no c_lock usage.. */
 			if (!visitor(conn, buffer))
diff --git a/net/rose/af_rose.c b/net/rose/af_rose.c
index b768fe9..cf68e6e 100644
--- a/net/rose/af_rose.c
+++ b/net/rose/af_rose.c
@@ -165,10 +165,9 @@ static void rose_remove_socket(struct sock *sk)
 void rose_kill_by_neigh(struct rose_neigh *neigh)
 	struct sock *s;
 	spin_lock_bh(&rose_list_lock);
-	sk_for_each(s, node, &rose_list) {
+	sk_for_each(s, &rose_list) {
 		struct rose_sock *rose = rose_sk(s);
 		if (rose->neighbour == neigh) {
@@ -186,10 +185,9 @@ void rose_kill_by_neigh(struct rose_neigh *neigh)
 static void rose_kill_by_device(struct net_device *dev)
 	struct sock *s;
 		if (rose->device == dev) {
@@ -246,10 +244,9 @@ static void rose_insert_socket(struct sock *sk)
 static struct sock *rose_find_listener(rose_address *addr, ax25_address *call)
 	struct sock *s;
 		if (!rosecmp(&rose->source_addr, addr) &&
@@ -258,7 +255,7 @@ static struct sock *rose_find_listener(rose_address *addr, ax25_address *call)
 			goto found;
@@ -278,10 +275,9 @@ found:
 struct sock *rose_find_socket(unsigned int lci, struct rose_neigh *neigh)
 	struct sock *s;
 		if (rose->lci == lci && rose->neighbour == neigh)
diff --git a/net/sched/sch_api.c b/net/sched/sch_api.c
index a181b48..c297e2a 100644
--- a/net/sched/sch_api.c
+++ b/net/sched/sch_api.c
@@ -545,7 +545,7 @@ static void qdisc_class_hash_free(struct hlist_head *h, unsigned int n)
 void qdisc_class_hash_grow(struct Qdisc *sch, struct Qdisc_class_hash *clhash)
 	struct Qdisc_class_common *cl;
+	struct hlist_node *next;
 	struct hlist_head *nhash, *ohash;
 	unsigned int nsize, nmask, osize;
 	unsigned int i, h;
@@ -564,7 +564,7 @@ void qdisc_class_hash_grow(struct Qdisc *sch, struct Qdisc_class_hash *clhash)
 	sch_tree_lock(sch);
 	for (i = 0; i < osize; i++) {
-		hlist_for_each_entry_safe(cl, n, next, &ohash[i], hnode) {
+		hlist_for_each_entry_safe(cl, next, &ohash[i], hnode) {
 			h = qdisc_class_hash(cl->classid, nmask);
 			hlist_add_head(&cl->hnode, &nhash[h]);
diff --git a/net/sched/sch_cbq.c b/net/sched/sch_cbq.c
index 0e19948..13aa47a 100644
--- a/net/sched/sch_cbq.c
+++ b/net/sched/sch_cbq.c
@@ -1041,14 +1041,13 @@ static void cbq_adjust_levels(struct cbq_class *this)
 static void cbq_normalize_quanta(struct cbq_sched_data *q, int prio)
 	struct cbq_class *cl;
 	unsigned int h;
 	if (q->quanta[prio] == 0)
 		return;
 	for (h = 0; h < q->clhash.hashsize; h++) {
-		hlist_for_each_entry(cl, n, &q->clhash.hash[h], common.hnode) {
+		hlist_for_each_entry(cl, &q->clhash.hash[h], common.hnode) {
 			/* BUGGGG... Beware! This expression suffer of
 			 * arithmetic overflows!
@@ -1087,10 +1086,9 @@ static void cbq_sync_defmap(struct cbq_class *cl)
 			continue;
 			struct cbq_class *c;
-			hlist_for_each_entry(c, n, &q->clhash.hash[h],
+			hlist_for_each_entry(c, &q->clhash.hash[h],
 					     common.hnode) {
 				if (c->split == split && c->level < level &&
 				    c->defmap & (1<<i)) {
@@ -1210,7 +1208,6 @@ cbq_reset(struct Qdisc *sch)
 	struct cbq_sched_data *q = qdisc_priv(sch);
 	int prio;
 	unsigned int h;
@@ -1228,7 +1225,7 @@ cbq_reset(struct Qdisc *sch)
 		q->active[prio] = NULL;
 			qdisc_reset(cl->q);
 			cl->next_alive = NULL;
@@ -1697,7 +1694,7 @@ static void cbq_destroy_class(struct Qdisc *sch, struct cbq_class *cl)
 static void cbq_destroy(struct Qdisc *sch)
 	unsigned int h;
@@ -1710,11 +1707,11 @@ static void cbq_destroy(struct Qdisc *sch)
 	 * be bound to classes which have been destroyed already. --TGR '04
 			tcf_destroy_chain(&cl->filter_list);
-		hlist_for_each_entry_safe(cl, n, next, &q->clhash.hash[h],
+		hlist_for_each_entry_safe(cl, next, &q->clhash.hash[h],
 					  common.hnode)
 			cbq_destroy_class(sch, cl);
@@ -2013,14 +2010,13 @@ static void cbq_walk(struct Qdisc *sch, struct qdisc_walker *arg)
 	unsigned int h;
 	if (arg->stop)
 		return;
 			if (arg->count < arg->skip) {
 				arg->count++;
 				continue;
diff --git a/net/sched/sch_drr.c b/net/sched/sch_drr.c
index 71e50c8..759b308 100644
--- a/net/sched/sch_drr.c
+++ b/net/sched/sch_drr.c
@@ -293,14 +293,13 @@ static void drr_walk(struct Qdisc *sch, struct qdisc_walker *arg)
 	struct drr_sched *q = qdisc_priv(sch);
 	struct drr_class *cl;
 	unsigned int i;
 	if (arg->stop)
 		return;
 	for (i = 0; i < q->clhash.hashsize; i++) {
-		hlist_for_each_entry(cl, n, &q->clhash.hash[i], common.hnode) {
+		hlist_for_each_entry(cl, &q->clhash.hash[i], common.hnode) {
 				arg->count++;
 				continue;
@@ -451,11 +450,10 @@ static void drr_reset_qdisc(struct Qdisc *sch)
 	unsigned int i;
 			if (cl->qdisc->q.qlen)
 				list_del(&cl->alist);
 			qdisc_reset(cl->qdisc);
@@ -468,13 +466,13 @@ static void drr_destroy_qdisc(struct Qdisc *sch)
 	unsigned int i;
 	tcf_destroy_chain(&q->filter_list);
-		hlist_for_each_entry_safe(cl, n, next, &q->clhash.hash[i],
+		hlist_for_each_entry_safe(cl, next, &q->clhash.hash[i],
 					  common.hnode)
 			drr_destroy_class(sch, cl);
diff --git a/net/sched/sch_hfsc.c b/net/sched/sch_hfsc.c
index 6c2ec45..9facea0 100644
--- a/net/sched/sch_hfsc.c
+++ b/net/sched/sch_hfsc.c
@@ -1389,7 +1389,6 @@ static void
 hfsc_walk(struct Qdisc *sch, struct qdisc_walker *arg)
 	struct hfsc_sched *q = qdisc_priv(sch);
 	struct hfsc_class *cl;
 	unsigned int i;
@@ -1397,7 +1396,7 @@ hfsc_walk(struct Qdisc *sch, struct qdisc_walker *arg)
 		return;
 				     cl_common.hnode) {
 				arg->count++;
@@ -1523,11 +1522,10 @@ hfsc_reset_qdisc(struct Qdisc *sch)
 	unsigned int i;
-		hlist_for_each_entry(cl, n, &q->clhash.hash[i], cl_common.hnode)
+		hlist_for_each_entry(cl, &q->clhash.hash[i], cl_common.hnode)
 			hfsc_reset_class(cl);
 	q->eligible = RB_ROOT;
@@ -1540,16 +1538,16 @@ static void
 hfsc_destroy_qdisc(struct Qdisc *sch)
 	unsigned int i;
 					  cl_common.hnode)
 			hfsc_destroy_class(sch, cl);
@@ -1564,12 +1562,11 @@ hfsc_dump_qdisc(struct Qdisc *sch, struct sk_buff *skb)
 	unsigned char *b = skb_tail_pointer(skb);
 	struct tc_hfsc_qopt qopt;
 	unsigned int i;
 	sch->qstats.backlog = 0;
 			sch->qstats.backlog += cl->qdisc->qstats.backlog;
diff --git a/net/sched/sch_htb.c b/net/sched/sch_htb.c
index 03c2692..571f1d2 100644
--- a/net/sched/sch_htb.c
+++ b/net/sched/sch_htb.c
@@ -949,11 +949,10 @@ static void htb_reset(struct Qdisc *sch)
 	struct htb_sched *q = qdisc_priv(sch);
 	struct htb_class *cl;
 	unsigned int i;
 			if (cl->level)
 				memset(&cl->un.inner, 0, sizeof(cl->un.inner));
 			else {
@@ -1218,7 +1217,7 @@ static void htb_destroy_class(struct Qdisc *sch, struct htb_class *cl)
 static void htb_destroy(struct Qdisc *sch)
 	unsigned int i;
@@ -1232,11 +1231,11 @@ static void htb_destroy(struct Qdisc *sch)
 					  common.hnode)
 			htb_destroy_class(sch, cl);
@@ -1516,14 +1515,13 @@ static void htb_walk(struct Qdisc *sch, struct qdisc_walker *arg)
 	unsigned int i;
 	if (arg->stop)
 		return;
 				arg->count++;
 				continue;
diff --git a/net/sched/sch_qfq.c b/net/sched/sch_qfq.c
index 6ed3765..e9a77f6 100644
--- a/net/sched/sch_qfq.c
+++ b/net/sched/sch_qfq.c
@@ -276,9 +276,8 @@ static struct qfq_aggregate *qfq_find_agg(struct qfq_sched *q,
 					  u32 lmax, u32 weight)
 	struct qfq_aggregate *agg;
-	hlist_for_each_entry(agg, n, &q->nonfull_aggs, nonfull_next)
+	hlist_for_each_entry(agg, &q->nonfull_aggs, nonfull_next)
 		if (agg->lmax == lmax && agg->class_weight == weight)
 			return agg;
@@ -670,14 +669,13 @@ static void qfq_walk(struct Qdisc *sch, struct qdisc_walker *arg)
 	struct qfq_sched *q = qdisc_priv(sch);
 	struct qfq_class *cl;
 	unsigned int i;
 	if (arg->stop)
 		return;
 				arg->count++;
 				continue;
@@ -1376,11 +1374,10 @@ static unsigned int qfq_drop_from_slot(struct qfq_sched *q,
 				       struct hlist_head *slot)
 	unsigned int len;
-	hlist_for_each_entry(agg, n, slot, next) {
+	hlist_for_each_entry(agg, slot, next) {
 		list_for_each_entry(cl, &agg->active, alist) {
 			if (!cl->qdisc->ops->drop)
@@ -1459,11 +1456,10 @@ static void qfq_reset_qdisc(struct Qdisc *sch)
 	unsigned int i;
 			if (cl->qdisc->q.qlen > 0)
 				qfq_deactivate_class(q, cl);
@@ -1477,13 +1473,13 @@ static void qfq_destroy_qdisc(struct Qdisc *sch)
 	unsigned int i;
 					  common.hnode) {
 			qfq_destroy_class(sch, cl);
diff --git a/net/sctp/endpointola.c b/net/sctp/endpointola.c
index 73aad3d..2b3ef03 100644
--- a/net/sctp/endpointola.c
+++ b/net/sctp/endpointola.c
@@ -332,7 +332,6 @@ static struct sctp_association *__sctp_endpoint_lookup_assoc(
 	struct sctp_transport *t = NULL;
 	struct sctp_hashbucket *head;
 	struct sctp_ep_common *epb;
 	int hash;
 	int rport;
@@ -350,7 +349,7 @@ static struct sctp_association *__sctp_endpoint_lookup_assoc(
 				 rport);
 	head = &sctp_assoc_hashtable[hash];
 	read_lock(&head->lock);
-	sctp_for_each_hentry(epb, node, &head->chain) {
+	sctp_for_each_hentry(epb, &head->chain) {
 		tmp = sctp_assoc(epb);
 		if (tmp->ep != ep || rport != tmp->peer.port)
 			continue;
diff --git a/net/sctp/input.c b/net/sctp/input.c
index 965bbbb..4b2c831 100644
--- a/net/sctp/input.c
+++ b/net/sctp/input.c
@@ -784,13 +784,12 @@ static struct sctp_endpoint *__sctp_rcv_lookup_endpoint(struct net *net,
 	struct sctp_endpoint *ep;
 	int hash;
 	hash = sctp_ep_hashfn(net, ntohs(laddr->v4.sin_port));
 	head = &sctp_ep_hashtable[hash];
 		ep = sctp_ep(epb);
 		if (sctp_endpoint_is_match(ep, net, laddr))
 			goto hit;
@@ -876,7 +875,6 @@ static struct sctp_association *__sctp_lookup_association(
 	struct sctp_association *asoc;
 	struct sctp_transport *transport;
 	int hash;
 	/* Optimize here for direct hit, only listening connections can
@@ -886,7 +884,7 @@ static struct sctp_association *__sctp_lookup_association(
 				 ntohs(peer->v4.sin_port));
 		asoc = sctp_assoc(epb);
 		transport = sctp_assoc_is_match(asoc, net, local, peer);
 		if (transport)
diff --git a/net/sctp/proc.c b/net/sctp/proc.c
index 8c19e97..ab3bba8 100644
--- a/net/sctp/proc.c
+++ b/net/sctp/proc.c
@@ -213,7 +213,6 @@ static int sctp_eps_seq_show(struct seq_file *seq, void *v)
 	struct sock *sk;
 	int    hash = *(loff_t *)v;
 	if (hash >= sctp_ep_hashsize)
@@ -222,7 +221,7 @@ static int sctp_eps_seq_show(struct seq_file *seq, void *v)
 	sctp_local_bh_disable();
 		ep = sctp_ep(epb);
 		sk = epb->sk;
 		if (!net_eq(sock_net(sk), seq_file_net(seq)))
@@ -321,7 +320,6 @@ static int sctp_assocs_seq_show(struct seq_file *seq, void *v)
 	struct sctp_association *assoc;
 	struct sock *sk;
 	if (hash >= sctp_assoc_hashsize)
@@ -330,7 +328,7 @@ static int sctp_assocs_seq_show(struct seq_file *seq, void *v)
 		assoc = sctp_assoc(epb);
 		sk = epb->sk;
@@ -436,7 +434,6 @@ static int sctp_remaddr_seq_show(struct seq_file *seq, void *v)
 	struct sctp_transport *tsp;
@@ -447,7 +444,7 @@ static int sctp_remaddr_seq_show(struct seq_file *seq, void *v)
 	rcu_read_lock();
 		if (!net_eq(sock_net(epb->sk), seq_file_net(seq)))
 			continue;
diff --git a/net/sctp/socket.c b/net/sctp/socket.c
index cedd9bf..c99458d 100644
--- a/net/sctp/socket.c
+++ b/net/sctp/socket.c
@@ -5882,8 +5882,7 @@ static struct sctp_bind_bucket *sctp_bucket_create(
 static long sctp_get_port_local(struct sock *sk, union sctp_addr *addr)
 	struct sctp_bind_hashbucket *head; /* hash list */
-	struct sctp_bind_bucket *pp; /* hash list port iterator */
+	struct sctp_bind_bucket *pp;
 	unsigned short snum;
 	int ret;
@@ -5910,7 +5909,7 @@ static long sctp_get_port_local(struct sock *sk, union sctp_addr *addr)
 			index = sctp_phashfn(sock_net(sk), rover);
 			head = &sctp_port_hashtable[index];
 			sctp_spin_lock(&head->lock);
-			sctp_for_each_hentry(pp, node, &head->chain)
+			sctp_for_each_hentry(pp, &head->chain)
 				if ((pp->port == rover) &&
 				    net_eq(sock_net(sk), pp->net))
 					goto next;
@@ -5938,7 +5937,7 @@ static long sctp_get_port_local(struct sock *sk, union sctp_addr *addr)
 		head = &sctp_port_hashtable[sctp_phashfn(sock_net(sk), snum)];
-		sctp_for_each_hentry(pp, node, &head->chain) {
+		sctp_for_each_hentry(pp, &head->chain) {
 			if ((pp->port == snum) && net_eq(pp->net, sock_net(sk)))
 				goto pp_found;
@@ -5970,7 +5969,7 @@ pp_found:
 		 * that this port/socket (sk) combination are already
 		 * in an endpoint.
-		sk_for_each_bound(sk2, node, &pp->owner) {
+		sk_for_each_bound(sk2, &pp->owner) {
 			struct sctp_endpoint *ep2;
 			ep2 = sctp_sk(sk2)->ep;
diff --git a/net/sunrpc/auth.c b/net/sunrpc/auth.c
index 392adc4..f529404 100644
--- a/net/sunrpc/auth.c
+++ b/net/sunrpc/auth.c
@@ -407,7 +407,6 @@ rpcauth_lookup_credcache(struct rpc_auth *auth, struct auth_cred * acred,
 	LIST_HEAD(free);
 	struct rpc_cred_cache *cache = auth->au_credcache;
-	struct hlist_node *pos;
 	struct rpc_cred	*cred = NULL,
 			*entry, *new;
 	unsigned int nr;
@@ -415,7 +414,7 @@ rpcauth_lookup_credcache(struct rpc_auth *auth, struct auth_cred * acred,
 	nr = hash_long(from_kuid(&init_user_ns, acred->uid), cache->hashbits);
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(entry, pos, &cache->hashtable[nr], cr_hash) {
+	hlist_for_each_entry_rcu(entry, &cache->hashtable[nr], cr_hash) {
 		if (!entry->cr_ops->crmatch(acred, entry, flags))
 			continue;
 		spin_lock(&cache->lock);
@@ -439,7 +438,7 @@ rpcauth_lookup_credcache(struct rpc_auth *auth, struct auth_cred * acred,
-	hlist_for_each_entry(entry, pos, &cache->hashtable[nr], cr_hash) {
+	hlist_for_each_entry(entry, &cache->hashtable[nr], cr_hash) {
 			continue;
 		cred = get_rpccred(entry);
diff --git a/net/sunrpc/cache.c b/net/sunrpc/cache.c
index f3897d1..39a4112 100644
--- a/net/sunrpc/cache.c
+++ b/net/sunrpc/cache.c
@@ -670,13 +670,13 @@ static void cache_revisit_request(struct cache_head *item)
 	struct cache_deferred_req *dreq;
 	struct list_head pending;
-	struct hlist_node *lp, *tmp;
 	int hash = DFR_HASH(item);
 	INIT_LIST_HEAD(&pending);
 	spin_lock(&cache_defer_lock);
-	hlist_for_each_entry_safe(dreq, lp, tmp, &cache_defer_hash[hash], hash)
+	hlist_for_each_entry_safe(dreq, tmp, &cache_defer_hash[hash], hash)
 		if (dreq->item == item) {
 			__unhash_deferred_req(dreq);
 			list_add(&dreq->recent, &pending);
diff --git a/net/sunrpc/svcauth.c b/net/sunrpc/svcauth.c
index 7963569..2af7b0c 100644
--- a/net/sunrpc/svcauth.c
+++ b/net/sunrpc/svcauth.c
@@ -138,13 +138,12 @@ auth_domain_lookup(char *name, struct auth_domain *new)
 	struct auth_domain *hp;
-	struct hlist_node *np;
 	head = &auth_domain_table[hash_str(name, DN_HASHBITS)];
 	spin_lock(&auth_domain_lock);
-	hlist_for_each_entry(hp, np, head, hash) {
+	hlist_for_each_entry(hp, head, hash) {
 		if (strcmp(hp->name, name)==0) {
 			kref_get(&hp->ref);
 			spin_unlock(&auth_domain_lock);
diff --git a/net/tipc/name_table.c b/net/tipc/name_table.c
index 4675477..24b1679 100644
--- a/net/tipc/name_table.c
+++ b/net/tipc/name_table.c
@@ -473,11 +473,10 @@ static void tipc_nameseq_subscribe(struct name_seq *nseq,
 static struct name_seq *nametbl_find_seq(u32 type)
 	struct hlist_head *seq_head;
-	struct hlist_node *seq_node;
 	struct name_seq *ns;
 	seq_head = &table.types[hash(type)];
-	hlist_for_each_entry(ns, seq_node, seq_head, ns_list) {
+	hlist_for_each_entry(ns, seq_head, ns_list) {
 		if (ns->type == type)
 			return ns;
@@ -853,7 +852,6 @@ static int nametbl_list(char *buf, int len, u32 depth_info,
 			 u32 type, u32 lowbound, u32 upbound)
 	struct name_seq *seq;
 	int all_types;
 	int ret = 0;
@@ -873,7 +871,7 @@ static int nametbl_list(char *buf, int len, u32 depth_info,
 		upbound = ~0;
 		for (i = 0; i < TIPC_NAMETBL_SIZE; i++) {
 			seq_head = &table.types[i];
-			hlist_for_each_entry(seq, seq_node, seq_head, ns_list) {
+			hlist_for_each_entry(seq, seq_head, ns_list) {
 				ret += nameseq_list(seq, buf + ret, len - ret,
 						   depth, seq->type,
 						   lowbound, upbound, i);
@@ -889,7 +887,7 @@ static int nametbl_list(char *buf, int len, u32 depth_info,
 		ret += nametbl_header(buf + ret, len - ret, depth);
 		i = hash(type);
 			if (seq->type == type) {
 						   depth, type,
diff --git a/net/tipc/node.c b/net/tipc/node.c
index 48f39dd..6e6c434 100644
--- a/net/tipc/node.c
+++ b/net/tipc/node.c
@@ -69,12 +69,11 @@ static unsigned int tipc_hashfn(u32 addr)
 struct tipc_node *tipc_node_find(u32 addr)
 	struct tipc_node *node;
 	if (unlikely(!in_own_cluster_exact(addr)))
 		return NULL;
-	hlist_for_each_entry(node, pos, &node_htable[tipc_hashfn(addr)], hash) {
+	hlist_for_each_entry(node, &node_htable[tipc_hashfn(addr)], hash) {
 		if (node->addr == addr)
 			return node;
diff --git a/net/unix/af_unix.c b/net/unix/af_unix.c
index 87d2842..51be64f 100644
--- a/net/unix/af_unix.c
+++ b/net/unix/af_unix.c
@@ -263,9 +263,8 @@ static struct sock *__unix_find_socket_byname(struct net *net,
 					      int len, int type, unsigned int hash)
 	struct sock *s;
-	sk_for_each(s, node, &unix_socket_table[hash ^ type]) {
+	sk_for_each(s, &unix_socket_table[hash ^ type]) {
 		struct unix_sock *u = unix_sk(s);
 		if (!net_eq(sock_net(s), net))
@@ -298,10 +297,9 @@ static inline struct sock *unix_find_socket_byname(struct net *net,
 static struct sock *unix_find_socket_byinode(struct inode *i)
 	struct sock *s;
 	spin_lock(&unix_table_lock);
+	sk_for_each(s,
 		    &unix_socket_table[i->i_ino & (UNIX_HASH_SIZE - 1)]) {
 		struct dentry *dentry = unix_sk(s)->path.dentry;
diff --git a/net/unix/diag.c b/net/unix/diag.c
index 5ac19dc..d591091 100644
--- a/net/unix/diag.c
+++ b/net/unix/diag.c
@@ -192,10 +192,9 @@ static int unix_diag_dump(struct sk_buff *skb, struct netlink_callback *cb)
 	     slot < ARRAY_SIZE(unix_socket_table);
 	     s_num = 0, slot++) {
 		struct sock *sk;
 		num = 0;
-		sk_for_each(sk, node, &unix_socket_table[slot]) {
+		sk_for_each(sk, &unix_socket_table[slot]) {
 				continue;
 			if (num < s_num)
@@ -226,9 +225,7 @@ static struct sock *unix_lookup_by_ino(int ino)
 	for (i = 0; i < ARRAY_SIZE(unix_socket_table); i++) {
-		sk_for_each(sk, node, &unix_socket_table[i])
+		sk_for_each(sk, &unix_socket_table[i])
 			if (ino == sock_i_ino(sk)) {
 				sock_hold(sk);
 				spin_unlock(&unix_table_lock);
diff --git a/net/x25/af_x25.c b/net/x25/af_x25.c
index a306bc6..37ca969 100644
--- a/net/x25/af_x25.c
+++ b/net/x25/af_x25.c
@@ -208,11 +208,10 @@ static void x25_remove_socket(struct sock *sk)
 static void x25_kill_by_device(struct net_device *dev)
 	struct sock *s;
 	write_lock_bh(&x25_list_lock);
-	sk_for_each(s, node, &x25_list)
+	sk_for_each(s, &x25_list)
 		if (x25_sk(s)->neighbour && x25_sk(s)->neighbour->dev == dev)
 			x25_disconnect(s, ENETUNREACH, 0, 0);
@@ -280,12 +279,11 @@ static struct sock *x25_find_listener(struct x25_address *addr,
 	struct sock *s;
 	struct sock *next_best;
 	read_lock_bh(&x25_list_lock);
 	next_best = NULL;
 		if ((!strcmp(addr->x25_addr,
 			x25_sk(s)->source_addr.x25_addr) ||
@@ -323,9 +321,8 @@ found:
 static struct sock *__x25_find_socket(unsigned int lci, struct x25_neigh *nb)
 	struct sock *s;
 		if (x25_sk(s)->lci == lci && x25_sk(s)->neighbour == nb) {
 			sock_hold(s);
 			goto found;
@@ -1782,11 +1779,10 @@ static struct notifier_block x25_dev_notifier = {
 void x25_kill_by_neigh(struct x25_neigh *nb)
 	struct sock *s;
 		if (x25_sk(s)->neighbour == nb)
diff --git a/net/xfrm/xfrm_policy.c b/net/xfrm/xfrm_policy.c
index 5b47180..167c67d 100644
--- a/net/xfrm/xfrm_policy.c
+++ b/net/xfrm/xfrm_policy.c
@@ -379,27 +379,27 @@ static void xfrm_dst_hash_transfer(struct hlist_head *list,
 				   struct hlist_head *ndsttable,
 				   unsigned int nhashmask)
-	struct hlist_node *entry, *tmp, *entry0 = NULL;
+	struct hlist_node *tmp, *entry0 = NULL;
 	struct xfrm_policy *pol;
 	unsigned int h0 = 0;
 redo:
-	hlist_for_each_entry_safe(pol, entry, tmp, list, bydst) {
+	hlist_for_each_entry_safe(pol, tmp, list, bydst) {
 		unsigned int h;
 		h = __addr_hash(&pol->selector.daddr, &pol->selector.saddr,
 				pol->family, nhashmask);
 		if (!entry0) {
-			hlist_del(entry);
+			hlist_del(&pol->bydst);
 			hlist_add_head(&pol->bydst, ndsttable+h);
 			h0 = h;
 		} else {
 			if (h != h0)
 				continue;
-			hlist_del(entry);
 			hlist_add_after(entry0, &pol->bydst);
-		entry0 = entry;
+		entry0 = &pol->bydst;
 	if (!hlist_empty(list)) {
 		entry0 = NULL;
@@ -411,10 +411,10 @@ static void xfrm_idx_hash_transfer(struct hlist_head *list,
 				   struct hlist_head *nidxtable,
-	struct hlist_node *entry, *tmp;
-	hlist_for_each_entry_safe(pol, entry, tmp, list, byidx) {
+	hlist_for_each_entry_safe(pol, tmp, list, byidx) {
 		unsigned int h;
 		h = __idx_hash(pol->index, nhashmask);
@@ -544,7 +544,6 @@ static u32 xfrm_gen_index(struct net *net, int dir)
 	static u32 idx_generator;
 	for (;;) {
-		struct hlist_node *entry;
 		struct hlist_head *list;
 		struct xfrm_policy *p;
 		u32 idx;
@@ -556,7 +555,7 @@ static u32 xfrm_gen_index(struct net *net, int dir)
 			idx = 8;
 		list = net->xfrm.policy_byidx + idx_hash(net, idx);
 		found = 0;
-		hlist_for_each_entry(p, entry, list, byidx) {
+		hlist_for_each_entry(p, list, byidx) {
 			if (p->index == idx) {
 				found = 1;
 				break;
@@ -628,13 +627,13 @@ int xfrm_policy_insert(int dir, struct xfrm_policy *policy, int excl)
 	struct xfrm_policy *delpol;
 	struct hlist_head *chain;
-	struct hlist_node *entry, *newpos;
+	struct hlist_node *newpos;
 	write_lock_bh(&xfrm_policy_lock);
 	chain = policy_hash_bysel(net, &policy->selector, policy->family, dir);
 	delpol = NULL;
 	newpos = NULL;
-	hlist_for_each_entry(pol, entry, chain, bydst) {
+	hlist_for_each_entry(pol, chain, bydst) {
 		if (pol->type == policy->type &&
 		    !selector_cmp(&pol->selector, &policy->selector) &&
 		    xfrm_policy_mark_match(policy, pol) &&
@@ -691,13 +690,12 @@ struct xfrm_policy *xfrm_policy_bysel_ctx(struct net *net, u32 mark, u8 type,
 	struct xfrm_policy *pol, *ret;
 	*err = 0;
 	chain = policy_hash_bysel(net, sel, sel->family, dir);
 	ret = NULL;
 		if (pol->type == type &&
 		    (mark & pol->mark.m) == pol->mark.v &&
 		    !selector_cmp(sel, &pol->selector) &&
@@ -729,7 +727,6 @@ struct xfrm_policy *xfrm_policy_byid(struct net *net, u32 mark, u8 type,
 	*err = -ENOENT;
 	if (xfrm_policy_id2dir(id) != dir)
@@ -739,7 +736,7 @@ struct xfrm_policy *xfrm_policy_byid(struct net *net, u32 mark, u8 type,
 	chain = net->xfrm.policy_byidx + idx_hash(net, id);
 	ret = NULL;
-	hlist_for_each_entry(pol, entry, chain, byidx) {
+	hlist_for_each_entry(pol, chain, byidx) {
 		if (pol->type == type && pol->index == id &&
 		    (mark & pol->mark.m) == pol->mark.v) {
 			xfrm_pol_hold(pol);
@@ -772,10 +769,9 @@ xfrm_policy_flush_secctx_check(struct net *net, u8 type, struct xfrm_audit *audi
 	for (dir = 0; dir < XFRM_POLICY_MAX; dir++) {
 		int i;
 				     &net->xfrm.policy_inexact[dir], bydst) {
 			if (pol->type != type)
 				continue;
@@ -789,7 +785,7 @@ xfrm_policy_flush_secctx_check(struct net *net, u8 type, struct xfrm_audit *audi
 		for (i = net->xfrm.policy_bydst[dir].hmask; i >= 0; i--) {
 					     net->xfrm.policy_bydst[dir].table + i,
 					     bydst) {
@@ -828,11 +824,10 @@ int xfrm_policy_flush(struct net *net, u8 type, struct xfrm_audit *audit_info)
 		int i;
 	again1:
 				continue;
@@ -852,7 +847,7 @@ int xfrm_policy_flush(struct net *net, u8 type, struct xfrm_audit *audit_info)
 	again2:
 					     bydst) {
@@ -980,7 +975,6 @@ static struct xfrm_policy *xfrm_policy_lookup_bytype(struct net *net, u8 type,
 	int err;
 	const xfrm_address_t *daddr, *saddr;
 	u32 priority = ~0U;
@@ -992,7 +986,7 @@ static struct xfrm_policy *xfrm_policy_lookup_bytype(struct net *net, u8 type,
 	read_lock_bh(&xfrm_policy_lock);
 	chain = policy_hash_direct(net, daddr, saddr, family, dir);
 	ret = NULL;
 		err = xfrm_policy_match(pol, fl, type, family, dir);
 		if (err) {
 			if (err == -ESRCH)
@@ -1008,7 +1002,7 @@ static struct xfrm_policy *xfrm_policy_lookup_bytype(struct net *net, u8 type,
 	chain = &net->xfrm.policy_inexact[dir];
 		if (err) {
 			if (err == -ESRCH)
@@ -3041,13 +3035,12 @@ static struct xfrm_policy * xfrm_migrate_policy_find(const struct xfrm_selector
 						     u8 dir, u8 type)
 	struct xfrm_policy *pol, *ret = NULL;
 	u32 priority = ~0U;
 	chain = policy_hash_direct(&init_net, &sel->daddr, &sel->saddr, sel->family, dir);
 		if (xfrm_migrate_selector_match(sel, &pol->selector) &&
 		    pol->type == type) {
 			ret = pol;
@@ -3056,7 +3049,7 @@ static struct xfrm_policy * xfrm_migrate_policy_find(const struct xfrm_selector
 	chain = &init_net.xfrm.policy_inexact[dir];
 		    pol->priority < priority) {
diff --git a/net/xfrm/xfrm_state.c b/net/xfrm/xfrm_state.c
index ae01bdb..2c341bd 100644
--- a/net/xfrm/xfrm_state.c
+++ b/net/xfrm/xfrm_state.c
@@ -72,10 +72,10 @@ static void xfrm_hash_transfer(struct hlist_head *list,
 			       struct hlist_head *nspitable,
 	struct xfrm_state *x;
-	hlist_for_each_entry_safe(x, entry, tmp, list, bydst) {
+	hlist_for_each_entry_safe(x, tmp, list, bydst) {
 		unsigned int h;
 		h = __xfrm_dst_hash(&x->id.daddr, &x->props.saddr,
@@ -368,14 +368,14 @@ static void xfrm_state_gc_task(struct work_struct *work)
 	struct net *net = container_of(work, struct net, xfrm.state_gc_work);
 	struct hlist_head gc_list;
 	spin_lock_bh(&xfrm_state_gc_lock);
 	hlist_move_list(&net->xfrm.state_gc_list, &gc_list);
 	spin_unlock_bh(&xfrm_state_gc_lock);
-	hlist_for_each_entry_safe(x, entry, tmp, &gc_list, gclist)
+	hlist_for_each_entry_safe(x, tmp, &gc_list, gclist)
 		xfrm_state_gc_destroy(x);
 	wake_up(&net->xfrm.km_waitq);
@@ -577,10 +577,9 @@ xfrm_state_flush_secctx_check(struct net *net, u8 proto, struct xfrm_audit *audi
 	int i, err = 0;
 	for (i = 0; i <= net->xfrm.state_hmask; i++) {
-		hlist_for_each_entry(x, entry, net->xfrm.state_bydst+i, bydst) {
+		hlist_for_each_entry(x, net->xfrm.state_bydst+i, bydst) {
 			if (xfrm_id_proto_match(x->id.proto, proto) &&
 			   (err = security_xfrm_state_delete(x)) != 0) {
 				xfrm_audit_state_delete(x, 0,
@@ -613,10 +612,9 @@ int xfrm_state_flush(struct net *net, u8 proto, struct xfrm_audit *audit_info)
 	err = -ESRCH;
 restart:
 			if (!xfrm_state_kern(x) &&
 			    xfrm_id_proto_match(x->id.proto, proto)) {
 				xfrm_state_hold(x);
@@ -685,9 +683,8 @@ static struct xfrm_state *__xfrm_state_lookup(struct net *net, u32 mark,
 	unsigned int h = xfrm_spi_hash(net, daddr, spi, proto, family);
-	hlist_for_each_entry(x, entry, net->xfrm.state_byspi+h, byspi) {
+	hlist_for_each_entry(x, net->xfrm.state_byspi+h, byspi) {
 		if (x->props.family != family ||
 		    x->id.spi       != spi ||
 		    x->id.proto     != proto ||
@@ -710,9 +707,8 @@ static struct xfrm_state *__xfrm_state_lookup_byaddr(struct net *net, u32 mark,
 	unsigned int h = xfrm_src_hash(net, daddr, saddr, family);
-	hlist_for_each_entry(x, entry, net->xfrm.state_bysrc+h, bysrc) {
+	hlist_for_each_entry(x, net->xfrm.state_bysrc+h, bysrc) {
 		    !xfrm_addr_equal(&x->id.daddr, daddr, family) ||
@@ -798,7 +794,6 @@ xfrm_state_find(const xfrm_address_t *daddr, const xfrm_address_t *saddr,
 	static xfrm_address_t saddr_wildcard = { };
 	struct net *net = xp_net(pol);
 	unsigned int h, h_wildcard;
 	struct xfrm_state *x, *x0, *to_put;
 	int acquire_in_progress = 0;
 	int error = 0;
@@ -810,7 +805,7 @@ xfrm_state_find(const xfrm_address_t *daddr, const xfrm_address_t *saddr,
 	spin_lock_bh(&xfrm_state_lock);
 	h = xfrm_dst_hash(net, daddr, saddr, tmpl->reqid, encap_family);
-	hlist_for_each_entry(x, entry, net->xfrm.state_bydst+h, bydst) {
+	hlist_for_each_entry(x, net->xfrm.state_bydst+h, bydst) {
 		if (x->props.family == encap_family &&
 		    x->props.reqid == tmpl->reqid &&
 		    (mark & x->mark.m) == x->mark.v &&
@@ -826,7 +821,7 @@ xfrm_state_find(const xfrm_address_t *daddr, const xfrm_address_t *saddr,
 		goto found;
 	h_wildcard = xfrm_dst_hash(net, daddr, &saddr_wildcard, tmpl->reqid, encap_family);
-	hlist_for_each_entry(x, entry, net->xfrm.state_bydst+h_wildcard, bydst) {
+	hlist_for_each_entry(x, net->xfrm.state_bydst+h_wildcard, bydst) {
@@ -906,11 +901,10 @@ xfrm_stateonly_find(struct net *net, u32 mark,
 	unsigned int h;
 	struct xfrm_state *rx = NULL, *x = NULL;
 	spin_lock(&xfrm_state_lock);
 	h = xfrm_dst_hash(net, daddr, saddr, reqid, family);
 		if (x->props.family == family &&
 		    x->props.reqid == reqid &&
@@ -972,12 +966,11 @@ static void __xfrm_state_bump_genids(struct xfrm_state *xnew)
 	unsigned short family = xnew->props.family;
 	u32 reqid = xnew->props.reqid;
 	unsigned int h;
 	u32 mark = xnew->mark.v & xnew->mark.m;
 	h = xfrm_dst_hash(net, &xnew->id.daddr, &xnew->props.saddr, reqid, family);
@@ -1004,11 +997,10 @@ static struct xfrm_state *__find_acq_core(struct net *net, struct xfrm_mark *m,
 					  const xfrm_address_t *saddr, int create)
 	unsigned int h = xfrm_dst_hash(net, daddr, saddr, reqid, family);
 	u32 mark = m->v & m->m;
 		if (x->props.reqid  != reqid ||
 		    x->props.mode   != mode ||
@@ -1215,12 +1207,11 @@ struct xfrm_state * xfrm_migrate_state_find(struct xfrm_migrate *m)
 	unsigned int h;
 	if (m->reqid) {
 		h = xfrm_dst_hash(&init_net, &m->old_daddr, &m->old_saddr,
 				  m->reqid, m->old_family);
-		hlist_for_each_entry(x, entry, init_net.xfrm.state_bydst+h, bydst) {
+		hlist_for_each_entry(x, init_net.xfrm.state_bydst+h, bydst) {
 			if (x->props.mode != m->mode ||
 			    x->id.proto != m->proto)
 				continue;
@@ -1237,7 +1228,7 @@ struct xfrm_state * xfrm_migrate_state_find(struct xfrm_migrate *m)
 	} else {
 		h = xfrm_src_hash(&init_net, &m->old_daddr, &m->old_saddr,
 				  m->old_family);
-		hlist_for_each_entry(x, entry, init_net.xfrm.state_bysrc+h, bysrc) {
+		hlist_for_each_entry(x, init_net.xfrm.state_bysrc+h, bysrc) {
 				continue;
@@ -1466,10 +1457,9 @@ static struct xfrm_state *__xfrm_find_acq_byseq(struct net *net, u32 mark, u32 s
 	int i;
 			if (x->km.seq == seq &&
 			    x->km.state == XFRM_STATE_ACQ) {
diff --git a/security/integrity/ima/ima_queue.c b/security/integrity/ima/ima_queue.c
index 55a6271..ff63fe0 100644
--- a/security/integrity/ima/ima_queue.c
+++ b/security/integrity/ima/ima_queue.c
@@ -45,12 +45,11 @@ static struct ima_queue_entry *ima_lookup_digest_entry(u8 *digest_value)
 	struct ima_queue_entry *qe, *ret = NULL;
 	unsigned int key;
 	int rc;
 	key = ima_hash_key(digest_value);
 	rcu_read_lock();
-	hlist_for_each_entry_rcu(qe, pos, &ima_htable.queue[key], hnext) {
+	hlist_for_each_entry_rcu(qe, &ima_htable.queue[key], hnext) {
 		rc = memcmp(qe->entry->digest, digest_value, IMA_DIGEST_SIZE);
 		if (rc == 0) {
 			ret = qe;
diff --git a/security/selinux/avc.c b/security/selinux/avc.c
index 4d3fab4..dad36a6 100644
--- a/security/selinux/avc.c
+++ b/security/selinux/avc.c
@@ -188,11 +188,9 @@ int avc_get_hash_stats(char *page)
 	for (i = 0; i < AVC_CACHE_SLOTS; i++) {
 		head = &avc_cache.slots[i];
 		if (!hlist_empty(head)) {
-			struct hlist_node *next;
 			slots_used++;
 			chain_len = 0;
-			hlist_for_each_entry_rcu(node, next, head, list)
+			hlist_for_each_entry_rcu(node, head, list)
 				chain_len++;
 			if (chain_len > max_chain_len)
 				max_chain_len = chain_len;
@@ -241,7 +239,6 @@ static inline int avc_reclaim_node(void)
 	int hvalue, try, ecx;
 	unsigned long flags;
 	spinlock_t *lock;
 	for (try = 0, ecx = 0; try < AVC_CACHE_SLOTS; try++) {
@@ -253,7 +250,7 @@ static inline int avc_reclaim_node(void)
 			continue;
 		rcu_read_lock();
-		hlist_for_each_entry(node, next, head, list) {
+		hlist_for_each_entry(node, head, list) {
 			avc_node_delete(node);
 			avc_cache_stats_incr(reclaims);
 			ecx++;
@@ -301,11 +298,10 @@ static inline struct avc_node *avc_search_node(u32 ssid, u32 tsid, u16 tclass)
 	struct avc_node *node, *ret = NULL;
 	int hvalue;
 	hvalue = avc_hash(ssid, tsid, tclass);
 	head = &avc_cache.slots[hvalue];
-	hlist_for_each_entry_rcu(node, next, head, list) {
+	hlist_for_each_entry_rcu(node, head, list) {
 		if (ssid == node->ae.ssid &&
 		    tclass == node->ae.tclass &&
 		    tsid == node->ae.tsid) {
@@ -394,7 +390,6 @@ static struct avc_node *avc_insert(u32 ssid, u32 tsid, u16 tclass, struct av_dec
 	node = avc_alloc_node();
 	if (node) {
 		spinlock_t *lock;
@@ -404,7 +399,7 @@ static struct avc_node *avc_insert(u32 ssid, u32 tsid, u16 tclass, struct av_dec
 		lock = &avc_cache.slots_lock[hvalue];
 		spin_lock_irqsave(lock, flag);
-		hlist_for_each_entry(pos, next, head, list) {
+		hlist_for_each_entry(pos, head, list) {
 			if (pos->ae.ssid == ssid &&
 			    pos->ae.tsid == tsid &&
 			    pos->ae.tclass == tclass) {
@@ -541,7 +536,6 @@ static int avc_update_node(u32 event, u32 perms, u32 ssid, u32 tsid, u16 tclass,
 	unsigned long flag;
 	struct avc_node *pos, *node, *orig = NULL;
 	spinlock_t *lock;
@@ -558,7 +552,7 @@ static int avc_update_node(u32 event, u32 perms, u32 ssid, u32 tsid, u16 tclass,
 		if (ssid == pos->ae.ssid &&
 		    tsid == pos->ae.tsid &&
 		    tclass == pos->ae.tclass &&
@@ -614,7 +608,6 @@ out:
 static void avc_flush(void)
 	struct avc_node *node;
 	spinlock_t *lock;
 	unsigned long flag;
@@ -630,7 +623,7 @@ static void avc_flush(void)
 		 * prevent RCU grace periods from ending.
 		rcu_read_lock();
 		rcu_read_unlock();
 		spin_unlock_irqrestore(lock, flag);
diff --git a/tools/perf/util/evlist.c b/tools/perf/util/evlist.c
index bc4ad79..c8be0fb 100644
--- a/tools/perf/util/evlist.c
+++ b/tools/perf/util/evlist.c
@@ -314,7 +314,6 @@ static int perf_evlist__id_add_fd(struct perf_evlist *evlist,
 struct perf_evsel *perf_evlist__id2evsel(struct perf_evlist *evlist, u64 id)
 	struct perf_sample_id *sid;
 	int hash;
@@ -324,7 +323,7 @@ struct perf_evsel *perf_evlist__id2evsel(struct perf_evlist *evlist, u64 id)
 	hash = hash_64(id, PERF_EVLIST__HLIST_BITS);
 	head = &evlist->heads[hash];
-	hlist_for_each_entry(sid, pos, head, node)
+	hlist_for_each_entry(sid, head, node)
 		if (sid->id == id)
 			return sid->evsel;
diff --git a/virt/kvm/eventfd.c b/virt/kvm/eventfd.c
index b6eea5c..adb17f2 100644
--- a/virt/kvm/eventfd.c
+++ b/virt/kvm/eventfd.c
@@ -268,14 +268,13 @@ static void irqfd_update(struct kvm *kvm, struct _irqfd *irqfd,
 			 struct kvm_irq_routing_table *irq_rt)
 	struct kvm_kernel_irq_routing_entry *e;
-	struct hlist_node *n;
 	if (irqfd->gsi >= irq_rt->nr_rt_entries) {
 		rcu_assign_pointer(irqfd->irq_entry, NULL);
 		return;
-	hlist_for_each_entry(e, n, &irq_rt->map[irqfd->gsi], link) {
+	hlist_for_each_entry(e, &irq_rt->map[irqfd->gsi], link) {
 		/* Only fast-path MSI. */
 		if (e->type == KVM_IRQ_ROUTING_MSI)
 			rcu_assign_pointer(irqfd->irq_entry, e);
diff --git a/virt/kvm/irq_comm.c b/virt/kvm/irq_comm.c
index ff6d40e..e9073cf 100644
--- a/virt/kvm/irq_comm.c
+++ b/virt/kvm/irq_comm.c
@@ -173,7 +173,6 @@ int kvm_set_irq(struct kvm *kvm, int irq_source_id, u32 irq, int level)
 	struct kvm_kernel_irq_routing_entry *e, irq_set[KVM_NR_IRQCHIPS];
 	int ret = -1, i = 0;
 	struct kvm_irq_routing_table *irq_rt;
 	trace_kvm_set_irq(irq, level, irq_source_id);
@@ -184,7 +183,7 @@ int kvm_set_irq(struct kvm *kvm, int irq_source_id, u32 irq, int level)
 	rcu_read_lock();
 	irq_rt = rcu_dereference(kvm->irq_routing);
 	if (irq < irq_rt->nr_rt_entries)
-		hlist_for_each_entry(e, n, &irq_rt->map[irq], link)
+		hlist_for_each_entry(e, &irq_rt->map[irq], link)
 			irq_set[i++] = *e;
 	rcu_read_unlock();
@@ -212,7 +211,6 @@ int kvm_set_irq_inatomic(struct kvm *kvm, int irq_source_id, u32 irq, int level)
 	int ret = -EINVAL;
@@ -227,7 +225,7 @@ int kvm_set_irq_inatomic(struct kvm *kvm, int irq_source_id, u32 irq, int level)
 	rcu_read_lock();
-		hlist_for_each_entry(e, n, &irq_rt->map[irq], link) {
+		hlist_for_each_entry(e, &irq_rt->map[irq], link) {
 			if (likely(e->type == KVM_IRQ_ROUTING_MSI))
 				ret = kvm_set_msi_inatomic(e, kvm);
 			else
@@ -241,13 +239,12 @@ int kvm_set_irq_inatomic(struct kvm *kvm, int irq_source_id, u32 irq, int level)
 bool kvm_irq_has_notifier(struct kvm *kvm, unsigned irqchip, unsigned pin)
 	struct kvm_irq_ack_notifier *kian;
 	int gsi;
 	rcu_read_lock();
 	gsi = rcu_dereference(kvm->irq_routing)->chip[irqchip][pin];
 	if (gsi != -1)
-		hlist_for_each_entry_rcu(kian, n, &kvm->irq_ack_notifier_list,
+		hlist_for_each_entry_rcu(kian, &kvm->irq_ack_notifier_list,
 					 link)
 			if (kian->gsi == gsi) {
 				rcu_read_unlock();
@@ -263,7 +260,6 @@ EXPORT_SYMBOL_GPL(kvm_irq_has_notifier);
 void kvm_notify_acked_irq(struct kvm *kvm, unsigned irqchip, unsigned pin)
 	int gsi;
 	trace_kvm_ack_irq(irqchip, pin);
@@ -271,7 +267,7 @@ void kvm_notify_acked_irq(struct kvm *kvm, unsigned irqchip, unsigned pin)
 	rcu_read_lock();
 	if (gsi != -1)
 					 link)
 				kian->irq_acked(kian);
@@ -369,13 +365,12 @@ void kvm_fire_mask_notifiers(struct kvm *kvm, unsigned irqchip, unsigned pin,
 			     bool mask)
 	struct kvm_irq_mask_notifier *kimn;
 	int gsi;
 	rcu_read_lock();
 	if (gsi != -1)
-		hlist_for_each_entry_rcu(kimn, n, &kvm->mask_notifier_list, link)
+		hlist_for_each_entry_rcu(kimn, &kvm->mask_notifier_list, link)
 			if (kimn->irq == gsi)
 				kimn->func(kimn, mask);
 	rcu_read_unlock();
@@ -396,13 +391,12 @@ static int setup_routing_entry(struct kvm_irq_routing_table *rt,
 	int delta;
 	unsigned max_pin;
 	struct kvm_kernel_irq_routing_entry *ei;
 	 * Do not allow GSI to be mapped to the same irqchip more than once.
 	 * Allow only one to one mapping between GSI and MSI.
-	hlist_for_each_entry(ei, n, &rt->map[ue->gsi], link)
+	hlist_for_each_entry(ei, &rt->map[ue->gsi], link)
 		if (ei->type == KVM_IRQ_ROUTING_MSI ||
 		    ue->type == KVM_IRQ_ROUTING_MSI ||
 		    ue->u.irqchip.irqchip == ei->irqchip.irqchip)
BtrLinux
