mtd: bf5xx_nand: use the managed version of kzalloc
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions. Also, the now unnecessary label out_err_hw_init is done away
with and the label out_err_kzalloc is renamed to out_err.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Signed-off-by: Brian Norris
 drivers/mtd/nand/bf5xx_nand.c | 13 ++++---------
 1 file changed, 4 insertions(+), 9 deletions(-)
diff --git a/drivers/mtd/nand/bf5xx_nand.c b/drivers/mtd/nand/bf5xx_nand.c
index b7a2494..722898a 100644
--- a/drivers/mtd/nand/bf5xx_nand.c
+++ b/drivers/mtd/nand/bf5xx_nand.c
@@ -679,9 +679,6 @@ static int bf5xx_nand_remove(struct platform_device *pdev)
 	peripheral_free_list(bfin_nfc_pin_req);
 	bf5xx_nand_dma_remove(info);
-	/* free the common resources */
-	kfree(info);
 	return 0;
@@ -742,10 +739,10 @@ static int bf5xx_nand_probe(struct platform_device *pdev)
 		return -EFAULT;
-	info = kzalloc(sizeof(*info), GFP_KERNEL);
+	info = devm_kzalloc(&pdev->dev, sizeof(*info), GFP_KERNEL);
 	if (info == NULL) {
 		err = -ENOMEM;
-		goto out_err_kzalloc;
+		goto out_err;
 	platform_set_drvdata(pdev, info);
@@ -790,7 +787,7 @@ static int bf5xx_nand_probe(struct platform_device *pdev)
 	/* initialise the hardware */
 	err = bf5xx_nand_hw_init(info);
 	if (err)
-		goto out_err_hw_init;
+		goto out_err;
 	/* setup hardware ECC data struct */
 	if (hardware_ecc) {
@@ -827,9 +824,7 @@ static int bf5xx_nand_probe(struct platform_device *pdev)
 out_err_nand_scan:
-out_err_hw_init:
-	kfree(info);
-out_err_kzalloc:
+out_err:
 	return err;
BtrLinux
