ceph: replace comma with a semicolon
Author: Himangi Saraogi <himangi774@gmail.com>
Replace a comma between expression statements by a semicolon. This changes
the semantics of the code, but given the current indentation appears to be
what is intended.
A simplified version of the Coccinelle semantic patch that performs this
transformation is as follows:
@r@
expression e1,e2;
 e1
 e2;
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Ilya Dryomov
 fs/ceph/caps.c | 2 +-
diff --git a/fs/ceph/caps.c b/fs/ceph/caps.c
index 1fde164..6d1cd45 100644
--- a/fs/ceph/caps.c
+++ b/fs/ceph/caps.c
@@ -3277,7 +3277,7 @@ int ceph_encode_inode_release(void **p, struct inode *inode,
 			rel->ino = cpu_to_le64(ceph_ino(inode));
 			rel->cap_id = cpu_to_le64(cap->cap_id);
 			rel->seq = cpu_to_le32(cap->seq);
-			rel->issue_seq = cpu_to_le32(cap->issue_seq),
+			rel->issue_seq = cpu_to_le32(cap->issue_seq);
 			rel->mseq = cpu_to_le32(cap->mseq);
 			rel->caps = cpu_to_le32(cap->implemented);
 			rel->wanted = cpu_to_le32(cap->mds_wanted);
BtrLinux
