usb: phy: drop kfree of devm_kzalloc’s data
Author: Himangi Saraogi <himangi774@gmail.com>
Using kfree to free data allocated with devm_kzalloc causes double frees.
The Coccinelle semantic patch that fixes this problem is as follows:
expression x;
x = devm_kzalloc(...)
?-kfree(x);
Reviewed-by: Jingoo Han
Acked-by: Julia Lawall
Signed-off-by: Himangi Saraogi
Signed-off-by: Felipe Balbi
 drivers/usb/phy/phy-gpio-vbus-usb.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/usb/phy/phy-gpio-vbus-usb.c b/drivers/usb/phy/phy-gpio-vbus-usb.c
index ea9e705..f4b14bd 100644
--- a/drivers/usb/phy/phy-gpio-vbus-usb.c
+++ b/drivers/usb/phy/phy-gpio-vbus-usb.c
@@ -260,10 +260,8 @@ static int gpio_vbus_probe(struct platform_device *pdev)
 	gpio_vbus->phy.otg = devm_kzalloc(&pdev->dev, sizeof(struct usb_otg),
 					  GFP_KERNEL);
-	if (!gpio_vbus->phy.otg) {
-		kfree(gpio_vbus);
+	if (!gpio_vbus->phy.otg)
 		return -ENOMEM;
 	platform_set_drvdata(pdev, gpio_vbus);
 	gpio_vbus->dev = &pdev->dev;
BtrLinux
