staging: lustre: lnet: klnds: o2iblnd: fix null dereference on failed path in o2iblnd.c
Author: Jiayi Ye <yejiayily@gmail.com>
If net is null and failed path is executed, dereference null may happen.
This patch fixes it. The following Coccinelle semantic patch was used.
expression E, E1;
identifier f;
statement S1,S2,S3;
* if (E == NULL)
  ... when != if (E == NULL) S1 else S2
      when != E = E1
* E->f
  ... when any
  return ...;
else S3
Signed-off-by: Jiayi Ye
 drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd.c b/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd.c
index 045f2be..bc479a7 100644
--- a/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd.c
+++ b/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd.c
@@ -3081,7 +3081,7 @@ kiblnd_startup (lnet_ni_t *ni)
 	LIBCFS_ALLOC(net, sizeof(*net));
 	ni->ni_data = net;
 	if (net == NULL)
-		goto failed;
+		goto net_failed;
 	do_gettimeofday(&tv);
 	net->ibn_incarnation = (((__u64)tv.tv_sec) * 1000000) + tv.tv_usec;
@@ -3147,6 +3147,7 @@ failed:
 	if (net->ibn_dev == NULL && ibdev != NULL)
 		kiblnd_destroy_dev(ibdev);
+net_failed:
 	kiblnd_shutdown(ni);
 	CDEBUG(D_NET, "kiblnd_startup failed\n");
BtrLinux
