firmware class: Deletion of an unnecessary check before the function call « vunmap »
Author: Markus Elfring <elfring@users.sourceforge.net>
The vunmap() function performes also input parameter validation. Thus the test
around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
 drivers/base/firmware_class.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/base/firmware_class.c b/drivers/base/firmware_class.c
index 9962744..58470c3 100644
--- a/drivers/base/firmware_class.c
+++ b/drivers/base/firmware_class.c
@@ -591,8 +591,7 @@ static int fw_map_pages_buf(struct firmware_buf *buf)
 	if (!buf->is_paged_buf)
 		return 0;
-	if (buf->data)
-		vunmap(buf->data);
+	vunmap(buf->data);
 	buf->data = vmap(buf->pages, buf->nr_pages, 0, PAGE_KERNEL_RO);
 	if (!buf->data)
 		return -ENOMEM;
BtrLinux
