NetCP: Deletion of unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The functions cpsw_ale_destroy() and of_dev_put() test whether their argument
is NULL and then return immediately. Thus the test around the call
is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
 drivers/net/ethernet/ti/netcp_ethss.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/net/ethernet/ti/netcp_ethss.c b/drivers/net/ethernet/ti/netcp_ethss.c
index 345cd25..84f5ce5 100644
--- a/drivers/net/ethernet/ti/netcp_ethss.c
+++ b/drivers/net/ethernet/ti/netcp_ethss.c
@@ -2011,12 +2011,10 @@ static int gbe_probe(struct netcp_device *netcp_device, struct device *dev,
 quit:
 	if (gbe_dev->hw_stats)
 		devm_kfree(dev, gbe_dev->hw_stats);
-	if (gbe_dev->ale)
-		cpsw_ale_destroy(gbe_dev->ale);
+	cpsw_ale_destroy(gbe_dev->ale);
 	if (gbe_dev->ss_regs)
 		devm_iounmap(dev, gbe_dev->ss_regs);
-	if (interfaces)
-		of_node_put(interfaces);
+	of_node_put(interfaces);
 	devm_kfree(dev, gbe_dev);
 	return ret;
BtrLinux
