Staging: media: lirc: Use setup_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of function setup_timer
instead of structure assignments as it is the preferred
way to setup and set the timer.
This is done using Coccinelle and semantic patch used is
as follows:
expression x,y,z;
- init_timer (&x);
+ setup_timer (&x, y, z);
- x.function = y;
- x.data = z;
Signed-off-by: Vaishali Thakkar
 drivers/staging/media/lirc/lirc_sir.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/media/lirc/lirc_sir.c b/drivers/staging/media/lirc/lirc_sir.c
index 39f4733..d1ada8c 100644
--- a/drivers/staging/media/lirc/lirc_sir.c
+++ b/drivers/staging/media/lirc/lirc_sir.c
@@ -683,9 +683,7 @@ static int init_port(void)
 	pr_info("I/O port 0x%.4x, IRQ %d.\n", io, irq);
-	init_timer(&timerlist);
-	timerlist.function = sir_timeout;
-	timerlist.data = 0xabadcafe;
+	setup_timer(&timerlist, sir_timeout, 0xabadcafe);
 	return 0;
BtrLinux
