HSI: nokia-modem: fix error return code
Return a negative error code on failure.
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Sebastian Reichel
 drivers/hsi/clients/nokia-modem.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/hsi/clients/nokia-modem.c b/drivers/hsi/clients/nokia-modem.c
index eb4dc63..9be4867 100644
--- a/drivers/hsi/clients/nokia-modem.c
+++ b/drivers/hsi/clients/nokia-modem.c
@@ -200,6 +200,7 @@ static int nokia_modem_probe(struct device *dev)
 	modem->ssi_protocol = hsi_new_client(port, &ssip);
 	if (!modem->ssi_protocol) {
 		dev_err(dev, "Could not register ssi-protocol device\n");
+		err = -ENOMEM;
 		goto error2;
BtrLinux
