staging: rtl8188eu: Compress two statements into one.
Author: Navya Sri Nizamkari <navyasri.tech@gmail.com>
This patch removes the use of a variable used only for
returning a value. The following coccinelle script was
used to discover it:
expression ret;
identifier f;
-ret =
+return
     f(...);
     -return ret;
It also fixes the checkpatch.pl warning about line being over
80 characters, in the lines where changes were made.
Signed-off-by: Navya Sri Nizamkari
 drivers/staging/rtl8188eu/os_dep/usb_ops_linux.c | 15 ++++++---------
 1 file changed, 6 insertions(+), 9 deletions(-)
diff --git a/drivers/staging/rtl8188eu/os_dep/usb_ops_linux.c b/drivers/staging/rtl8188eu/os_dep/usb_ops_linux.c
index 80e7ef9..b9e1a61 100644
--- a/drivers/staging/rtl8188eu/os_dep/usb_ops_linux.c
+++ b/drivers/staging/rtl8188eu/os_dep/usb_ops_linux.c
@@ -552,7 +552,6 @@ int usb_write8(struct adapter *adapter, u32 addr, u8 val)
 	u16 index;
 	u16 len;
 	u8 data;
-	int ret;
 	request = 0x05;
 	requesttype = 0x00;/* write_out */
@@ -560,8 +559,8 @@ int usb_write8(struct adapter *adapter, u32 addr, u8 val)
 	wvalue = (u16)(addr&0x0000ffff);
 	len = 1;
 	data = val;
-	ret = usbctrl_vendorreq(adapter, request, wvalue, index, &data, len, requesttype);
-	return ret;
+	return usbctrl_vendorreq(adapter, request, wvalue,
+				 index, &data, len, requesttype);
 int usb_write16(struct adapter *adapter, u32 addr, u16 val)
@@ -572,7 +571,6 @@ int usb_write16(struct adapter *adapter, u32 addr, u16 val)
 	u16 index;
 	u16 len;
 	__le32 data;
-	int ret;
 	request = 0x05;
@@ -584,10 +582,10 @@ int usb_write16(struct adapter *adapter, u32 addr, u16 val)
 	data = cpu_to_le32(val & 0x0000ffff);
-	return ret;
 int usb_write32(struct adapter *adapter, u32 addr, u32 val)
@@ -598,7 +596,6 @@ int usb_write32(struct adapter *adapter, u32 addr, u32 val)
 	u16 index;
 	u16 len;
 	__le32 data;
-	int ret;
 	request = 0x05;
@@ -609,10 +606,10 @@ int usb_write32(struct adapter *adapter, u32 addr, u32 val)
 	len = 4;
 	data = cpu_to_le32(val);
-	return ret;
 static void usb_write_port_complete(struct urb *purb, struct pt_regs *regs)
BtrLinux
