staging: slicoss: remove extra parentheses around left bit shift operations
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise left shift operations.
The case handled is when resultant value is assigned to a variable.
The issue was detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Signed-off-by: Aya Mahfouz
 drivers/staging/slicoss/slicoss.c | 2 +-
diff --git a/drivers/staging/slicoss/slicoss.c b/drivers/staging/slicoss/slicoss.c
index c84dd60..a3afb3e 100644
--- a/drivers/staging/slicoss/slicoss.c
+++ b/drivers/staging/slicoss/slicoss.c
@@ -1850,7 +1850,7 @@ static void slic_xmit_build_request(struct adapter *adapter,
 	ihcmd = &hcmd->cmd64;
-	ihcmd->flags = (adapter->port << IHFLG_IFSHFT);
+	ihcmd->flags = adapter->port << IHFLG_IFSHFT;
 	ihcmd->command = IHCMD_XMT_REQ;
 	ihcmd->u.slic_buffers.totlen = skb->len;
 	phys_addr = pci_map_single(adapter->pcidev, skb->data, skb->len,
BtrLinux
