Staging: slicoss: clean dev_err logging
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
This patch removes  __func__ from dev_err. dev_err includes information about:
(devcice, driver, specific instance of device, etc) in the log printout.
This was done using Coccinelle, with the following semantic patch:
@a@
expression E, R;
expression  msg;
dev_err(E, msg, __func__, R);
@script:python b@
e << a.msg;
y;
if(e.find("%s: ") == True):
	m = e.replace("%s: ", "", 1);
	coccinelle.y = m;
elif(e.find("%s ") == True):
	m = e.replace("%s ", "", 1);
	coccinelle.y = m;
elif(e.find("%s:") == True):
	m = e.replace("%s:", "", 1);
	coccinelle.y = m;
else:
	m = e.replace("%s", "",1);
	coccinelle.y = m;
@c@
expression a.E, a.msg, a.R;
identifier  b.y;
- dev_err(E, msg, __func__, R);
+ dev_err(E, y, R);
Signed-off-by: Haneen Mohammed
 drivers/staging/slicoss/slicoss.c | 9 ++++-----
 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/slicoss/slicoss.c b/drivers/staging/slicoss/slicoss.c
index a3afb3e..3104cb0 100644
--- a/drivers/staging/slicoss/slicoss.c
+++ b/drivers/staging/slicoss/slicoss.c
@@ -2313,9 +2313,8 @@ static int slic_if_init(struct adapter *adapter)
 	rc = slic_adapter_allocresources(adapter);
 	if (rc) {
-		dev_err(&dev->dev,
-			"%s: slic_adapter_allocresources FAILED %x\n",
-			__func__, rc);
+		dev_err(&dev->dev, "slic_adapter_allocresources FAILED %x\n",
+			rc);
 		slic_adapter_freeresources(adapter);
 		goto err;
@@ -2549,8 +2548,8 @@ static int slic_ioctl(struct net_device *dev, struct ifreq *rq, int cmd)
 		if (copy_from_user(data, rq->ifr_data, 28))
 			return -EFAULT;
 		intagg = data[0];
-		dev_err(&dev->dev, "%s: set interrupt aggregation to %d\n",
-			__func__, intagg);
+		dev_err(&dev->dev, "set interrupt aggregation to %d\n",
+			intagg);
 		slic_intagg_set(adapter, intagg);
 		return 0;
BtrLinux
