Staging: gdm724x: replace pr_* with dev_*
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
This patch replace pr_err/pr_info with dev_err/dev_info, when
appropriate device structure is found.
Issue found  and resolved using the following Coccinelle script.
pr_err/dev_err was substituted with pr_info/dev_info in the later case.
@r exists@
identifier f, s, i;
position p;
f(...,struct s *i,...) {
when != i == NULL
pr_err@p(...);
@rr@
identifier r.s, s2, fld;
struct s {
	struct s2 *fld;
@rrr@
identifier rr.s2, fld2;
struct s2 {
	struct device fld2;
identifier r.i, r.s, rr.fld, rrr.fld2;
position r.p;
-pr_err@p
+dev_err
+ &i->fld->fld2,
Signed-off-by: Haneen Mohammed
 drivers/staging/gdm724x/gdm_mux.c | 4 ++--
 drivers/staging/gdm724x/gdm_usb.c | 7 ++++---
 2 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/gdm724x/gdm_mux.c b/drivers/staging/gdm724x/gdm_mux.c
index b987ba0..8199b0a 100644
--- a/drivers/staging/gdm724x/gdm_mux.c
+++ b/drivers/staging/gdm724x/gdm_mux.c
@@ -270,7 +270,7 @@ static void gdm_mux_rcv_complete(struct urb *urb)
 	if (urb->status) {
 		if (mux_dev->usb_state == PM_NORMAL)
-			pr_err("%s: urb status error %d\n",
+			dev_err(&urb->dev->dev, "%s: urb status error %d\n",
 			       __func__, urb->status);
 		put_rx_struct(rx, r);
 	} else {
@@ -342,7 +342,7 @@ static void gdm_mux_send_complete(struct urb *urb)
 	struct mux_tx *t = urb->context;
 	if (urb->status == -ECONNRESET) {
-		pr_info("CONNRESET\n");
+		dev_info(&urb->dev->dev, "CONNRESET\n");
 		free_mux_tx(t);
 		return;
diff --git a/drivers/staging/gdm724x/gdm_usb.c b/drivers/staging/gdm724x/gdm_usb.c
index d59810f..ed1a12f 100644
--- a/drivers/staging/gdm724x/gdm_usb.c
+++ b/drivers/staging/gdm724x/gdm_usb.c
@@ -480,7 +480,7 @@ static void gdm_usb_rcv_complete(struct urb *urb)
 		spin_unlock_irqrestore(&rx->to_host_lock, flags);
 	} else {
 		if (urb->status && udev->usb_state == PM_NORMAL)
@@ -557,7 +557,7 @@ static void gdm_usb_send_complete(struct urb *urb)
 	unsigned long flags;
 		return;
@@ -590,7 +590,8 @@ static int send_tx_packet(struct usb_device *usbdev, struct usb_tx *t, u32 len)
 	ret = usb_submit_urb(t->urb, GFP_ATOMIC);
 	if (ret)
-		pr_err("usb_submit_urb failed: %d\n", ret);
+		dev_err(&usbdev->dev, "usb_submit_urb failed: %d\n",
+			ret);
 	usb_mark_last_busy(usbdev);
BtrLinux
