Staging: sm750fb: Remove zero testing pointer typed value
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Removes variable comparison with 0.
Done using following coccinelle script.
@ disable is_zero,isnt_zero @
expression *E;
expression E1,f;
E = f(...)
- E == 0
+ !E
- E != 0
+ E
- 0 == E
+ !E
- 0 != E
+ E
?E = E1
expression *E;
  E ==
- 0
+ NULL
  E !=
- 0
+ NULL
- 0
+ NULL
  == E
- 0
+ NULL
  != E
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/sm750fb/ddk750_chip.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/sm750fb/ddk750_chip.c b/drivers/staging/sm750fb/ddk750_chip.c
index cd1508a..9b5bb7e 100644
--- a/drivers/staging/sm750fb/ddk750_chip.c
+++ b/drivers/staging/sm750fb/ddk750_chip.c
@@ -110,7 +110,7 @@ void setChipClock(unsigned int frequency)
 		return;
 #endif
-	if (frequency != 0) {
+	if (frequency) {
 		* Set up PLL, a structure to hold the value to be set in clocks.
@@ -139,7 +139,7 @@ void setMemoryClock(unsigned int frequency)
 	if (getChipType() == SM750LE)
 		return;
 #endif
+	if (frequency) {
 		/* Set the frequency to the maximum frequency that the DDR Memory can take
 		which is 336MHz. */
 		if (frequency > MHz(336))
@@ -187,7 +187,7 @@ void setMasterClock(unsigned int frequency)
 		return;
 #endif
+	if (frequency) {
 		/* Set the frequency to the maximum frequency that the SM750 engine can
 		run, which is about 190 MHz. */
 		if (frequency > MHz(190))
BtrLinux
