9p: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,l;
position p1,p2;
expression *ptr != NULL;
if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f = E
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: Eric Van Hensbergen
Signed-off-by: Andrew Morton
 net/9p/trans_fd.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/net/9p/trans_fd.c b/net/9p/trans_fd.c
index 0b4eb5f..d652baf 100644
--- a/net/9p/trans_fd.c
+++ b/net/9p/trans_fd.c
@@ -870,8 +870,10 @@ static struct p9_req *p9_send_request(struct p9_conn *m,
 	else
 		n = p9_mux_get_tag(m);
-	if (n < 0)
+	if (n < 0) {
+		kfree(req);
 		return ERR_PTR(-ENOMEM);
 	p9_set_tag(tc, n);
BtrLinux
