[S390] cio: Correct use of ! and &
In commit e6bafba5b4765a5a252f1b8d31cbf6d2459da337, a bug was fixed that
involved converting !x & y to !(x & y).  The code below shows the same
pattern, and thus should perhaps be fixed in the same way.  In particular,
the result of !scsw_stctl(&request->irb.scsw) & SCSW_STCTL_STATUS_PEND is
always just !scsw_stctl(&request->irb.scsw).
(http://www.emn.fr/x-info/coccinelle/)
@@ expression E; constant C; @@
  !E & !C
- !E & C
+ !(E & C)
Signed-off-by: Julia Lawall
Signed-off-by: Heiko Carstens
Signed-off-by: Martin Schwidefsky
 drivers/s390/cio/chsc_sch.c | 2 +-
diff --git a/drivers/s390/cio/chsc_sch.c b/drivers/s390/cio/chsc_sch.c
index 91ca87a..f49f0e5 100644
--- a/drivers/s390/cio/chsc_sch.c
+++ b/drivers/s390/cio/chsc_sch.c
@@ -261,7 +261,7 @@ static int chsc_examine_irb(struct chsc_request *request)
 	int backed_up;
-	if (!scsw_stctl(&request->irb.scsw) & SCSW_STCTL_STATUS_PEND)
+	if (!(scsw_stctl(&request->irb.scsw) & SCSW_STCTL_STATUS_PEND))
 		return -EIO;
 	backed_up = scsw_cstat(&request->irb.scsw) & SCHN_STAT_CHAIN_CHECK;
 	request->irb.scsw.cmd.cstat &= ~SCHN_STAT_CHAIN_CHECK;
BtrLinux
