arch/m32r: Use DIV_ROUND_CLOSEST
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d
but is perhaps more readable.
(http://www.emn.fr/x-info/coccinelle/)
@haskernel@
@depends on haskernel@
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
Signed-off-by: Julia Lawall
Signed-off-by: Hirokazu Takata
arch/m32r/kernel/time.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/m32r/kernel/time.c b/arch/m32r/kernel/time.c
index e7fee0f1..9cedcef 100644
--- a/arch/m32r/kernel/time.c
+++ b/arch/m32r/kernel/time.c
@@ -75,7 +75,7 @@ u32 arch_gettimeoffset(void)
count = 0;
count = (latch - count) * TICK_SIZE;
- elapsed_time = (count + latch / 2) / latch;
+ elapsed_time = DIV_ROUND_CLOSEST(count, latch);
/* NOTE: LATCH is equal to the "interval" value (= reload count). */
#else /* CONFIG_SMP */
@@ -93,7 +93,7 @@ u32 arch_gettimeoffset(void)
p_count = count;
#endif /* CONFIG_SMP */
#elif defined(CONFIG_CHIP_M32310)
@@ -211,7 +211,7 @@ void __init time_init(void)
bus_clock = boot_cpu_data.bus_clock;
divide = boot_cpu_data.timer_divide;
- latch = (bus_clock/divide + HZ / 2) / HZ;
+ latch = DIV_ROUND_CLOSEST(bus_clock/divide, HZ);
printk("Timer start : latch = %ld\n", latch); |
count = 0;
p_count = count;
