V4L/DVB (13413): introduce missing kfree
Error handling code following a kzalloc should free the allocated data.
Similarly for usb-alloc urb.
The semantic match that finds the first problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/video/hdpvr/hdpvr-video.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/media/video/hdpvr/hdpvr-video.c b/drivers/media/video/hdpvr/hdpvr-video.c
index 2eb9dc2..b5439ca 100644
--- a/drivers/media/video/hdpvr/hdpvr-video.c
+++ b/drivers/media/video/hdpvr/hdpvr-video.c
@@ -139,7 +139,7 @@ int hdpvr_alloc_buffers(struct hdpvr_device *dev, uint count)
 		urb = usb_alloc_urb(0, GFP_KERNEL);
 		if (!urb) {
 			v4l2_err(&dev->v4l2_dev, "cannot allocate urb\n");
-			goto exit;
+			goto exit_urb;
 		buf->urb = urb;
@@ -148,7 +148,7 @@ int hdpvr_alloc_buffers(struct hdpvr_device *dev, uint count)
 		if (!mem) {
 				 "cannot allocate usb transfer buffer\n");
-			goto exit;
+			goto exit_urb_buffer;
 		usb_fill_bulk_urb(buf->urb, dev->udev,
@@ -161,6 +161,10 @@ int hdpvr_alloc_buffers(struct hdpvr_device *dev, uint count)
 		list_add_tail(&buf->buff_list, &dev->free_buff_list);
 	return 0;
+exit_urb_buffer:
+	usb_free_urb(urb);
+exit_urb:
+	kfree(buf);
 exit:
 	hdpvr_free_buffers(dev);
 	return retval;
BtrLinux
