drivers/net/sfc: Correct code taking the size of a pointer
The function efx_iterate_state contains the code
memcpy(&payload->msg, payload_msg, sizeof(payload_msg));
This is the only use of payload_msg.  The type of payload_msg is
changed from a pointer to an array, so that the result of sizeof really is
the length of the string.
A simplified version of the semantic patch that finds this problem is as
expression *x;
expression f;
type T;
*f(...,(T)x,...)
Signed-off-by: Julia Lawall
 drivers/net/sfc/selftest.c | 2 +-
diff --git a/drivers/net/sfc/selftest.c b/drivers/net/sfc/selftest.c
index 14949bb..af39335 100644
--- a/drivers/net/sfc/selftest.c
+++ b/drivers/net/sfc/selftest.c
@@ -47,7 +47,7 @@ static const unsigned char payload_source[ETH_ALEN] = {
 	0x00, 0x0f, 0x53, 0x1b, 0x1b, 0x1b,
-static const char *payload_msg =
+static const char payload_msg[] =
 	"Hello world! This is an Efx loopback test in progress!";
BtrLinux
