drivers/net/cpmac.c: Correct code taking the size of a pointer
sizeof(dev->dev_addr) is the size of a pointer.  On the other hand,
sizeof(pdata->dev_addr) is the size of an array, so use that instead.
A simplified version of the semantic patch that finds this problem is as
expression *x;
expression f;
type T;
*f(...,(T)x,...)
Signed-off-by: Julia Lawall
 drivers/net/cpmac.c | 2 +-
diff --git a/drivers/net/cpmac.c b/drivers/net/cpmac.c
index 6782223..8d0be26 100644
--- a/drivers/net/cpmac.c
+++ b/drivers/net/cpmac.c
@@ -1163,7 +1163,7 @@ static int __devinit cpmac_probe(struct platform_device *pdev)
 	priv->dev = dev;
 	priv->ring_size = 64;
 	priv->msg_enable = netif_msg_init(debug_level, 0xff);
-	memcpy(dev->dev_addr, pdata->dev_addr, sizeof(dev->dev_addr));
+	memcpy(dev->dev_addr, pdata->dev_addr, sizeof(pdata->dev_addr));
 	snprintf(priv->phy_name, MII_BUS_ID_SIZE, PHY_ID_FMT, mdio_bus_id, phy_id);
BtrLinux
