mtd: physmap_of: Correct the size argument to kzalloc
mtd_list has type struct mtd_info **, not struct mtd_info *, so the
elements of the array should have pointer type, not structure type.
(http://coccinelle.lip6.fr/)
@disable sizeof_type_expr@
type T;
T **x;
  x =
  <+...sizeof(
- T
+ *x
Signed-off-by: Julia Lawall
Signed-off-by: David Woodhouse
 drivers/mtd/maps/physmap_of.c | 2 +-
diff --git a/drivers/mtd/maps/physmap_of.c b/drivers/mtd/maps/physmap_of.c
index 61e4eb4..1d91333 100644
--- a/drivers/mtd/maps/physmap_of.c
+++ b/drivers/mtd/maps/physmap_of.c
@@ -217,7 +217,7 @@ static int __devinit of_flash_probe(struct of_device *dev,
 	dev_set_drvdata(&dev->dev, info);
-	mtd_list = kzalloc(sizeof(struct mtd_info) * count, GFP_KERNEL);
+	mtd_list = kzalloc(sizeof(*mtd_list) * count, GFP_KERNEL);
 	if (!mtd_list)
 		goto err_flash_remove;
BtrLinux
