dma: make Open Firmware device id constant
Author: Márton Németh <nm127@freemail.hu>
The match_table field of the struct of_device_id is constant in
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Cc: cocci@diku.dk
[dan.j.williams@intel.com: resolved conflict with recent fsldma updates]
Signed-off-by: Dan Williams
 drivers/dma/fsldma.c      | 2 +-
 drivers/dma/ppc4xx/adma.c | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/dma/fsldma.c b/drivers/dma/fsldma.c
index 19011c2..92efa87 100644
--- a/drivers/dma/fsldma.c
+++ b/drivers/dma/fsldma.c
@@ -1398,7 +1398,7 @@ static int fsldma_of_remove(struct of_device *op)
 	return 0;
-static struct of_device_id fsldma_of_ids[] = {
+static const struct of_device_id fsldma_of_ids[] = {
 	{ .compatible = "fsl,eloplus-dma", },
 	{ .compatible = "fsl,elo-dma", },
diff --git a/drivers/dma/ppc4xx/adma.c b/drivers/dma/ppc4xx/adma.c
index 0a3478e..e69d87f 100644
--- a/drivers/dma/ppc4xx/adma.c
+++ b/drivers/dma/ppc4xx/adma.c
@@ -4940,7 +4940,7 @@ out_free:
 	return ret;
-static struct of_device_id __devinitdata ppc440spe_adma_of_match[] = {
+static const struct of_device_id ppc440spe_adma_of_match[] __devinitconst = {
 	{ .compatible	= "ibm,dma-440spe", },
 	{ .compatible	= "amcc,xor-accelerator", },
BtrLinux
