drivers/net: drop redundant memset
The region set by the call to memset is immediately overwritten by the
subsequent call to memcpy.
(http://coccinelle.lip6.fr/)
expression e1,e2,e3,e4;
- memset(e1,e2,e3);
  memcpy(e1,e4,e3);
Signed-off-by: Julia Lawall
 drivers/net/s2io.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/net/s2io.c b/drivers/net/s2io.c
index df70657..2eb7f8a 100644
--- a/drivers/net/s2io.c
+++ b/drivers/net/s2io.c
@@ -5819,10 +5819,8 @@ static void s2io_vpd_read(struct s2io_nic *nic)
-	if ((!fail) && (vpd_data[1] < VPD_STRING_LEN)) {
-		memset(nic->product_name, 0, vpd_data[1]);
+	if ((!fail) && (vpd_data[1] < VPD_STRING_LEN))
 		memcpy(nic->product_name, &vpd_data[3], vpd_data[1]);
 	kfree(vpd_data);
 	swstats->mem_freed += 256;
BtrLinux
