ring-buffer: Add missing unlock
In some error handling cases the lock is not unlocked. The return is
converted to a goto, to share the unlock at the end of the function.
A simplified version of the semantic patch that finds this problem is as
@r exists@
expression E1;
identifier f;
f (...) { <+...
* spin_lock_irq (E1,...);
... when != E1
* return ...;
Signed-off-by: Julia Lawall
LKML-Reference:
Signed-off-by: Steven Rostedt
kernel/trace/ring_buffer.c | 8 +++++---
1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/kernel/trace/ring_buffer.c b/kernel/trace/ring_buffer.c
index d1187ef..9a0f9bf 100644
--- a/kernel/trace/ring_buffer.c
+++ b/kernel/trace/ring_buffer.c
@@ -1209,18 +1209,19 @@ rb_remove_pages(struct ring_buffer_per_cpu *cpu_buffer, unsigned nr_pages)
for (i = 0; i < nr_pages; i++) {
if (RB_WARN_ON(cpu_buffer, list_empty(cpu_buffer->pages)))
- return;
+ goto out;
p = cpu_buffer->pages->next;
bpage = list_entry(p, struct buffer_page, list);
list_del_init(&bpage->list);
free_buffer_page(bpage);
- return;
+ goto out;
rb_reset_cpu(cpu_buffer);
rb_check_pages(cpu_buffer);
+out:
spin_unlock_irq(&cpu_buffer->reader_lock);
@@ -1237,7 +1238,7 @@ rb_insert_pages(struct ring_buffer_per_cpu *cpu_buffer,
if (RB_WARN_ON(cpu_buffer, list_empty(pages)))
- return;
+ goto out;
p = pages->next;
@@ -1246,6 +1247,7 @@ rb_insert_pages(struct ring_buffer_per_cpu *cpu_buffer,
+out:
- return;
+ goto out;
- return;
+ goto out;
+out:
- return;
+ goto out;
p = pages->next;
+out:
