fs/affs: use ERR_CAST
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)).  The former makes more
clear what is the purpose of the operation, which otherwise looks like a
no-op.
(http://coccinelle.lip6.fr/)
type T;
T x;
identifier f;
T f (...) { <+...
- ERR_PTR(PTR_ERR(x))
+ x
expression x;
+ ERR_CAST(x)
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 fs/affs/namei.c | 2 +-
diff --git a/fs/affs/namei.c b/fs/affs/namei.c
index d70bbba..914d1c0 100644
--- a/fs/affs/namei.c
+++ b/fs/affs/namei.c
@@ -224,7 +224,7 @@ affs_lookup(struct inode *dir, struct dentry *dentry, struct nameidata *nd)
 		affs_brelse(bh);
 		inode = affs_iget(sb, ino);
 		if (IS_ERR(inode))
-			return ERR_PTR(PTR_ERR(inode));
+			return ERR_CAST(inode);
 	dentry->d_op = AFFS_SB(sb)->s_flags & SF_INTL ? &affs_intl_dentry_operations : &affs_dentry_operations;
 	d_add(dentry, inode);
BtrLinux
