drivers/net/wireless/libertas_tf: Use kmemdup
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
expression from,to,size,flag;
statement S;
-  to = \(kmalloc\|kzalloc\)(size,flag);
+  to = kmemdup(from,size,flag);
   if (to==NULL || ...) S
-  memcpy(to, from, size);
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
 drivers/net/wireless/libertas_tf/if_usb.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/net/wireless/libertas_tf/if_usb.c b/drivers/net/wireless/libertas_tf/if_usb.c
index c445500..b172f5d 100644
--- a/drivers/net/wireless/libertas_tf/if_usb.c
+++ b/drivers/net/wireless/libertas_tf/if_usb.c
@@ -538,7 +538,8 @@ static void if_usb_receive_fwload(struct urb *urb)
 		return;
-	syncfwheader = kmalloc(sizeof(struct fwsyncheader), GFP_ATOMIC);
+	syncfwheader = kmemdup(skb->data, sizeof(struct fwsyncheader),
+			       GFP_ATOMIC);
 	if (!syncfwheader) {
 		lbtf_deb_usbd(&cardp->udev->dev, "Failure to allocate syncfwheader\n");
 		kfree_skb(skb);
@@ -546,8 +547,6 @@ static void if_usb_receive_fwload(struct urb *urb)
 		return;
-	memcpy(syncfwheader, skb->data, sizeof(struct fwsyncheader));
 	if (!syncfwheader->cmd) {
 		lbtf_deb_usb2(&cardp->udev->dev, "FW received Blk with correct CRC\n");
 		lbtf_deb_usb2(&cardp->udev->dev, "FW received Blk seqnum = %d\n",
BtrLinux
