perf timechart: Adjust confusing if indentation
Outdent the code following the if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
  cocci.print_main("branch",p1)
  cocci.print_secs("after",p2)
Cc: Peter Zijlstra
Cc: Paul Mackerras
Cc: Ingo Molnar
LKML-Reference:
Signed-off-by: Julia Lawall
Signed-off-by: Arnaldo Carvalho de Melo
 tools/perf/builtin-timechart.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/perf/builtin-timechart.c b/tools/perf/builtin-timechart.c
index 5161619..9bcc38f 100644
--- a/tools/perf/builtin-timechart.c
+++ b/tools/perf/builtin-timechart.c
@@ -455,8 +455,8 @@ static void sched_switch(int cpu, u64 timestamp, struct trace_entry *te)
 		if (p->current->state != TYPE_NONE)
 			pid_put_sample(sw->next_pid, p->current->state, cpu, p->current->state_since, timestamp);
-			p->current->state_since = timestamp;
-			p->current->state = TYPE_RUNNING;
+		p->current->state_since = timestamp;
+		p->current->state = TYPE_RUNNING;
 	if (prev_p->current) {
BtrLinux
