powerpc/maple: Add of_node_put to avoid memory leak
Add a call to of_node_put in the error handling code following a call to
of_find_node_by_path.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r exists@
local idexpression x;
expression E,E1;
statement S;
*x =
(of_find_node_by_path
|of_find_node_by_name
|of_find_node_by_phandle
|of_get_parent
|of_get_next_parent
|of_get_next_child
|of_find_compatible_node
|of_match_node
if (x == NULL) S
<... when != x = E
*if (...) {
  ... when != of_node_put(x)
      when != if (...) { ... of_node_put(x); ... }
  return <+...x...+>;
*  return ...;
of_node_put(x);
Signed-off-by: Julia Lawall
Signed-off-by: Benjamin Herrenschmidt
 arch/powerpc/platforms/maple/setup.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/arch/powerpc/platforms/maple/setup.c b/arch/powerpc/platforms/maple/setup.c
index 3fff8d9..fe34c3d 100644
--- a/arch/powerpc/platforms/maple/setup.c
+++ b/arch/powerpc/platforms/maple/setup.c
@@ -358,6 +358,7 @@ static int __init maple_cpc925_edac_setup(void)
 	model = (const unsigned char *)of_get_property(np, "model", NULL);
 	if (!model) {
 		printk(KERN_ERR "%s: Unabel to get model info\n", __func__);
+		of_node_put(np);
 		return -ENODEV;
BtrLinux
