drivers/video/bfin-lq035q1-fb.c: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Acked-by: Mike Frysinger
Signed-off-by: Paul Mundt
 drivers/video/bfin-lq035q1-fb.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/video/bfin-lq035q1-fb.c b/drivers/video/bfin-lq035q1-fb.c
index c8e1f04..23b6c4b 100644
--- a/drivers/video/bfin-lq035q1-fb.c
+++ b/drivers/video/bfin-lq035q1-fb.c
@@ -154,8 +154,10 @@ static int __devinit lq035q1_spidev_probe(struct spi_device *spi)
 	ret = lq035q1_control(spi, LQ035_SHUT_CTL, LQ035_ON);
 	ret |= lq035q1_control(spi, LQ035_DRIVER_OUTPUT_CTL, ctl->mode);
-	if (ret)
+	if (ret) {
+		kfree(ctl);
 		return ret;
 	spi_set_drvdata(spi, ctl);
BtrLinux
