fs/ext2/balloc.c: delete useless initialization
Delete nontrivial initialization that is immediately overwritten by the
result of an allocation function.
The semantic match that makes this change is as follows:
(http://coccinelle.lip6.fr/)
type T;
identifier i;
expression e;
T i = \(0\|NULL\|ERR_PTR(...)\);
-T i = e;
+T i;
... when != i
i = \(kzalloc\|kcalloc\|kmalloc\)(...);
Signed-off-by: Julia Lawall
Signed-off-by: Jan Kara
 fs/ext2/balloc.c | 2 +-
diff --git a/fs/ext2/balloc.c b/fs/ext2/balloc.c
index 8f44cef..a8cbe1b 100644
--- a/fs/ext2/balloc.c
+++ b/fs/ext2/balloc.c
@@ -421,7 +421,7 @@ static inline int rsv_is_empty(struct ext2_reserve_window *rsv)
 void ext2_init_block_alloc_info(struct inode *inode)
 	struct ext2_inode_info *ei = EXT2_I(inode);
-	struct ext2_block_alloc_info *block_i = ei->i_block_alloc_info;
+	struct ext2_block_alloc_info *block_i;
 	struct super_block *sb = inode->i_sb;
 	block_i = kmalloc(sizeof(*block_i), GFP_NOFS);
BtrLinux
