ARM: davinci: edma: use kzalloc()
Author: Thomas Meyer <thomas@m3y3r.de>
 Use kzalloc rather than kmalloc followed by memset with 0
 This considers some simple cases that are common and easy to validate
 Note in particular that there are no ...s in the rule, so all of the
 matched code has to be contiguous
 The semantic patch that makes this output is available
 in scripts/coccinelle/api/alloc/kzalloc-simple.cocci.
 More information about semantic patching is available at
 http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer
Signed-off-by: Sekhar Nori
 arch/arm/mach-davinci/dma.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-davinci/dma.c b/arch/arm/mach-davinci/dma.c
index 6ba4191..da90103 100644
--- a/arch/arm/mach-davinci/dma.c
+++ b/arch/arm/mach-davinci/dma.c
@@ -1435,12 +1435,11 @@ static int __init edma_probe(struct platform_device *pdev)
 			goto fail1;
-		edma_cc[j] = kmalloc(sizeof(struct edma), GFP_KERNEL);
+		edma_cc[j] = kzalloc(sizeof(struct edma), GFP_KERNEL);
 		if (!edma_cc[j]) {
 			status = -ENOMEM;
 			goto fail1;
-		memset(edma_cc[j], 0, sizeof(struct edma));
 		edma_cc[j]->num_channels = min_t(unsigned, info[j]->n_channel,
 							EDMA_MAX_DMACH);
BtrLinux
