HID: drivers/hid/hid-roccat.c: eliminate a null pointer dereference
It is not possible to take the lock in device if device is NULL.
The mutex_lock is thus moved after the NULL test. New error handling
labels are added at the end to differentiate between the cases where
different sets of locks should be unlocks, and between whether or not
reader should be freed (only on error).
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
expression E, E1;
identifier f;
statement S1,S2,S3;
if (E == NULL)
... when != if (E == NULL || ...) S1 else S2
when != E = E1
*E->f
... when any
return ...;
else S3
Signed-off-by: Julia Lawall
Signed-off-by: Jiri Kosina
drivers/hid/hid-roccat.c | 18 +++++++++---------
1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/hid/hid-roccat.c b/drivers/hid/hid-roccat.c
index 5666e75..56ce12c 100644
--- a/drivers/hid/hid-roccat.c
+++ b/drivers/hid/hid-roccat.c
@@ -162,27 +162,27 @@ static int roccat_open(struct inode *inode, struct file *file)
device = devices[minor];
- mutex_lock(&device->readers_lock);
if (!device) {
pr_emerg("roccat device with minor %d doesn't exist\n", minor);
error = -ENODEV;
- goto exit_err;
+ goto exit_err_devices;
+ mutex_lock(&device->readers_lock);
if (!device->open++) {
/* power on device on adding first reader */
error = hid_hw_power(device->hid, PM_HINT_FULLON);
if (error < 0) {
--device->open;
- goto exit_err;
+ goto exit_err_readers;
error = hid_hw_open(device->hid);
if (error < 0) {
hid_hw_power(device->hid, PM_HINT_NORMAL);
--device->open;
- goto exit_err;
@@ -193,13 +193,13 @@ static int roccat_open(struct inode *inode, struct file *file)
list_add_tail(&reader->node, &device->readers);
file->private_data = reader;
-exit_unlock:
+exit_err_readers:
mutex_unlock(&device->readers_lock);
+exit_err_devices:
mutex_unlock(&devices_lock);
+ if (error)
+ kfree(reader);
return error;
-exit_err:
- kfree(reader);
- goto exit_unlock;
static int roccat_release(struct inode *inode, struct file *file) |
if (!device) {
error = -ENODEV;
- goto exit_err;
if (error < 0) {
--device->open;
- goto exit_err;
if (error < 0) {
--device->open;
- goto exit_err;
-exit_unlock:
+exit_err_readers:
+exit_err_devices:
+ if (error)
+ kfree(reader);
return error;
-exit_err:
- kfree(reader);
- goto exit_unlock;
