ARM: OMAP2+: arch/arm/mach-omap2/devices.c: introduce missing kfree
pdata needs to be freed before leaving the function in an error case.
A simplified version of the semantic match that finds the problem is as
follows: (http://coccinelle.lip6.fr)
@r exists@
local idexpression x;
statement S;
identifier f1;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: Tony Lindgren
 arch/arm/mach-omap2/devices.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-omap2/devices.c b/arch/arm/mach-omap2/devices.c
index 0b510ad..283d11e 100644
--- a/arch/arm/mach-omap2/devices.c
+++ b/arch/arm/mach-omap2/devices.c
@@ -405,6 +405,7 @@ static int omap_mcspi_init(struct omap_hwmod *oh, void *unused)
 			break;
 	default:
 			pr_err("Invalid McSPI Revision value\n");
+			kfree(pdata);
 			return -EINVAL;
BtrLinux
