net:phy:bcm63xx: remove unnecessary code
Author: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Compile tested.
remove unnecessary code that matches this coccinelle pattern
	ret = phy_write(x, y , z)
	if (ret < 0)
		return ret;
	return 0;
As phy_write returns error code, we dont need to do not need extra check
before returning.
Signed-off-by: Srinivas Kandagatla
 drivers/net/phy/bcm63xx.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/net/phy/bcm63xx.c b/drivers/net/phy/bcm63xx.c
index e16f98c..cd802eb 100644
--- a/drivers/net/phy/bcm63xx.c
+++ b/drivers/net/phy/bcm63xx.c
@@ -39,10 +39,7 @@ static int bcm63xx_config_init(struct phy_device *phydev)
 		MII_BCM63XX_IR_SPEED |
 		MII_BCM63XX_IR_LINK) |
 		MII_BCM63XX_IR_EN;
-	err = phy_write(phydev, MII_BCM63XX_IR, reg);
-	if (err < 0)
-		return err;
-	return 0;
+	return phy_write(phydev, MII_BCM63XX_IR, reg);
 static int bcm63xx_ack_interrupt(struct phy_device *phydev)
BtrLinux
