mac80211: Convert compare_ether_addr to ether_addr_equal by hand
Author: Joe Perches <joe@perches.com>
spatch/coccinelle isn't perfect.  It doesn't understand
__aligned(x) and doesn't convert functions it can't parse.
Convert the remaining compare_ether_addr uses.
Signed-off-by: Joe Perches
 net/mac80211/rx.c       | 4 ++--
 net/mac80211/sta_info.h | 2 +-
 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/net/mac80211/rx.c b/net/mac80211/rx.c
index 26bfd6f..d722c40 100644
--- a/net/mac80211/rx.c
+++ b/net/mac80211/rx.c
@@ -1714,8 +1714,8 @@ static bool ieee80211_frame_allowed(struct ieee80211_rx_data *rx, __le16 fc)
 	 * of whether the frame was encrypted or not.
 	if (ehdr->h_proto == rx->sdata->control_port_protocol &&
-	    (compare_ether_addr(ehdr->h_dest, rx->sdata->vif.addr) == 0 ||
-	     compare_ether_addr(ehdr->h_dest, pae_group_addr) == 0))
+	    (ether_addr_equal(ehdr->h_dest, rx->sdata->vif.addr) ||
+	     ether_addr_equal(ehdr->h_dest, pae_group_addr)))
 		return true;
 	if (ieee80211_802_1x_port_control(rx) ||
diff --git a/net/mac80211/sta_info.h b/net/mac80211/sta_info.h
index f75f5d9..e920b22 100644
--- a/net/mac80211/sta_info.h
+++ b/net/mac80211/sta_info.h
@@ -501,7 +501,7 @@ void for_each_sta_info_type_check(struct ieee80211_local *local,
 		nxt = _sta ? rcu_dereference(_sta->hnext) : NULL	\
 	/* compare address and run code only if it matches */		\
-	if (compare_ether_addr(_sta->sta.addr, (_addr)) == 0)
+	if (ether_addr_equal(_sta->sta.addr, (_addr)))
  * Get STA info by index, BROKEN!
BtrLinux
