bcma: add missing iounmap on error path
Author: Hauke Mehrtens <hauke@hauke-m.de>
This should fix the problem reported by Fengguang:
The coccinelle static checker emits these warnings:
drivers/bcma/scan.c:466:3-9: ERROR: missing iounmap; ioremap on line 451 and execution via conditional on line 465
drivers/bcma/scan.c:540:3-9: ERROR: missing iounmap; ioremap on line 515 and execution via conditional on line 539
Reported-by: Fengguang Wu
Signed-off-by: Hauke Mehrtens
Signed-off-by: John W. Linville
 drivers/bcma/scan.c | 15 ++++++++++-----
 1 file changed, 10 insertions(+), 5 deletions(-)
diff --git a/drivers/bcma/scan.c b/drivers/bcma/scan.c
index 5672b13..8d0b571 100644
--- a/drivers/bcma/scan.c
+++ b/drivers/bcma/scan.c
@@ -462,8 +462,10 @@ int bcma_bus_scan(struct bcma_bus *bus)
 	while (eromptr < eromend) {
 		struct bcma_device *other_core;
 		struct bcma_device *core = kzalloc(sizeof(*core), GFP_KERNEL);
-		if (!core)
-			return -ENOMEM;
+		if (!core) {
+			err = -ENOMEM;
+			goto out;
 		INIT_LIST_HEAD(&core->list);
 		core->bus = bus;
@@ -478,7 +480,7 @@ int bcma_bus_scan(struct bcma_bus *bus)
 			} else if (err == -ESPIPE) {
 				break;
-			return err;
+			goto out;
 		core->core_index = core_num++;
@@ -494,10 +496,12 @@ int bcma_bus_scan(struct bcma_bus *bus)
 		list_add_tail(&core->list, &bus->cores);
+	err = 0;
+out:
 	if (bus->hosttype == BCMA_HOSTTYPE_SOC)
 		iounmap(eromptr);
-	return 0;
+	return err;
 int __init bcma_bus_scan_early(struct bcma_bus *bus,
@@ -537,7 +541,7 @@ int __init bcma_bus_scan_early(struct bcma_bus *bus,
 			break;
 		else if (err < 0)
-			return err;
+			goto out;
 		bus->nr_cores++;
@@ -551,6 +555,7 @@ int __init bcma_bus_scan_early(struct bcma_bus *bus,
 		break;
+out:
 		iounmap(eromptr);
BtrLinux
