ALSA: sound/pci/rme9652/hdspm.c: fix error return code
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/pci/rme9652/hdspm.c | 2 +-
diff --git a/sound/pci/rme9652/hdspm.c b/sound/pci/rme9652/hdspm.c
index b8ac871..b12308b 100644
--- a/sound/pci/rme9652/hdspm.c
+++ b/sound/pci/rme9652/hdspm.c
@@ -6585,7 +6585,7 @@ static int __devinit snd_hdspm_create(struct snd_card *card,
 		snd_printk(KERN_ERR "HDSPM: "
 				"unable to kmalloc Mixer memory of %d Bytes\n",
 				(int)sizeof(struct hdspm_mixer));
-		return err;
+		return -ENOMEM;
 	hdspm->port_names_in = NULL;
BtrLinux
