drivers/iio/adc/at91_adc.c: adjust inconsistent IS_ERR and PTR_ERR
Change the call to PTR_ERR to access the value just tested by IS_ERR.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e,e1;
if (IS_ERR(e)) { ... PTR_ERR(e) ... }
if (IS_ERR(e=e1)) { ... PTR_ERR(e) ... }
*if (IS_ERR(e))
*  PTR_ERR(e1)
Signed-off-by: Julia Lawall
Signed-off-by: Jonathan Cameron
 drivers/iio/adc/at91_adc.c | 2 +-
diff --git a/drivers/iio/adc/at91_adc.c b/drivers/iio/adc/at91_adc.c
index f61780a..3bd5540 100644
--- a/drivers/iio/adc/at91_adc.c
+++ b/drivers/iio/adc/at91_adc.c
@@ -617,7 +617,7 @@ static int __devinit at91_adc_probe(struct platform_device *pdev)
 	st->adc_clk = clk_get(&pdev->dev, "adc_op_clk");
 	if (IS_ERR(st->adc_clk)) {
 		dev_err(&pdev->dev, "Failed to get the ADC clock.\n");
-		ret = PTR_ERR(st->clk);
+		ret = PTR_ERR(st->adc_clk);
 		goto error_disable_clk;
BtrLinux
