Staging: rtl8192u: use is_zero_ether_addr() instead of memcmp()
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Using is_zero_ether_addr() instead of directly use
memcmp() to determine if the ethernet address is all
zeros.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
 drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
index cb5a3c3..421da8a 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
@@ -14,6 +14,8 @@
+#include <linux/etherdevice.h>
 #include "ieee80211.h"
 #include "dot11d.h"
 /* FIXME: add A freqs */
@@ -136,7 +138,6 @@ int ieee80211_wx_set_wap(struct ieee80211_device *ieee,
 	int ret = 0;
-	u8 zero[] = {0,0,0,0,0,0};
 	unsigned long flags;
 	short ifup = ieee->proto_started;//dev->flags & IFF_UP;
@@ -165,7 +166,7 @@ int ieee80211_wx_set_wap(struct ieee80211_device *ieee,
 	spin_lock_irqsave(&ieee->lock, flags);
 	memcpy(ieee->current_network.bssid, temp->sa_data, ETH_ALEN);
-	ieee->wap_set = memcmp(temp->sa_data, zero,ETH_ALEN)!=0;
+	ieee->wap_set = !is_zero_ether_addr(temp->sa_data);
 	spin_unlock_irqrestore(&ieee->lock, flags);
BtrLinux
