fbdev: ssd1307fb: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Propagate error code on failure.  Also changed %ld to %d in dev_err to use
ret variable rather than putting two calls to PTR_ERR.
A simplified version of the semantic match that finds the first problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Tomi Valkeinen
 drivers/video/fbdev/ssd1307fb.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/video/fbdev/ssd1307fb.c b/drivers/video/fbdev/ssd1307fb.c
index b6edd28..93f4c90 100644
--- a/drivers/video/fbdev/ssd1307fb.c
+++ b/drivers/video/fbdev/ssd1307fb.c
@@ -656,8 +656,9 @@ static int ssd1307fb_probe(struct i2c_client *client,
 	bl = backlight_device_register(bl_name, &client->dev, par,
 				       &ssd1307fb_bl_ops, NULL);
 	if (IS_ERR(bl)) {
-		dev_err(&client->dev, "unable to register backlight device: %ld\n",
-			PTR_ERR(bl));
+		ret = PTR_ERR(bl);
+		dev_err(&client->dev, "unable to register backlight device: %d\n",
+			ret);
 		goto bl_init_error;
BtrLinux
Privacy Overview
