ehea: Introduce the use of the managed version of kzalloc
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions. Also, linux/device.h is added to make sure the devm_*()
routine declarations are unambiguously available.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Compile-Tested-by: Thadeu Lima de Souza Cascardo
Signed-off-by: David S. Miller
 drivers/net/ethernet/ibm/ehea/ehea_main.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/ibm/ehea/ehea_main.c b/drivers/net/ethernet/ibm/ehea/ehea_main.c
index 538903b..a0b418e 100644
--- a/drivers/net/ethernet/ibm/ehea/ehea_main.c
+++ b/drivers/net/ethernet/ibm/ehea/ehea_main.c
@@ -28,6 +28,7 @@
 #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
+#include <linux/device.h>
 #include <linux/in.h>
 #include <linux/ip.h>
 #include <linux/tcp.h>
@@ -3273,7 +3274,7 @@ static int ehea_probe_adapter(struct platform_device *dev)
 		return -EINVAL;
-	adapter = kzalloc(sizeof(*adapter), GFP_KERNEL);
+	adapter = devm_kzalloc(&dev->dev, sizeof(*adapter), GFP_KERNEL);
 	if (!adapter) {
 		ret = -ENOMEM;
 		dev_err(&dev->dev, "no mem for ehea_adapter\n");
@@ -3359,7 +3360,6 @@ out_kill_eq:
 out_free_ad:
 	list_del(&adapter->list);
-	kfree(adapter);
 out:
 	ehea_update_firmware_handles();
@@ -3386,7 +3386,6 @@ static int ehea_remove(struct platform_device *dev)
 	ehea_destroy_eq(adapter->neq);
 	ehea_remove_adapter_mr(adapter);
-	kfree(adapter);
BtrLinux
Privacy Overview
