EDAC: Delete unnecessary checks before pci_dev_put()
Author: Markus Elfring <elfring@users.sourceforge.net>
The pci_dev_put() function tests whether its argument is NULL and thus
the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Link: http://lkml.kernel.org/r/54CFC12C.9010002@users.sourceforge.net
Signed-off-by: Borislav Petkov
 drivers/edac/i82443bxgx_edac.c | 4 +---
 drivers/edac/i82860_edac.c     | 9 ++-------
 drivers/edac/i82875p_edac.c    | 4 +---
 drivers/edac/i82975x_edac.c    | 4 +---
 4 files changed, 5 insertions(+), 16 deletions(-)
diff --git a/drivers/edac/i82443bxgx_edac.c b/drivers/edac/i82443bxgx_edac.c
index b4705d9..38d6406 100644
--- a/drivers/edac/i82443bxgx_edac.c
+++ b/drivers/edac/i82443bxgx_edac.c
@@ -445,9 +445,7 @@ fail1:
 	pci_unregister_driver(&i82443bxgx_edacmc_driver);
 fail0:
-	if (mci_pdev != NULL)
-		pci_dev_put(mci_pdev);
+	pci_dev_put(mci_pdev);
 	return pci_rc;
diff --git a/drivers/edac/i82860_edac.c b/drivers/edac/i82860_edac.c
index 4382343..ee1078c 100644
--- a/drivers/edac/i82860_edac.c
+++ b/drivers/edac/i82860_edac.c
@@ -343,20 +343,15 @@ fail1:
 	pci_unregister_driver(&i82860_driver);
 fail0:
 	return pci_rc;
 static void __exit i82860_exit(void)
 	edac_dbg(3, "\n");
 module_init(i82860_init);
diff --git a/drivers/edac/i82875p_edac.c b/drivers/edac/i82875p_edac.c
index 64b6832..c26a513 100644
--- a/drivers/edac/i82875p_edac.c
+++ b/drivers/edac/i82875p_edac.c
@@ -576,9 +576,7 @@ fail1:
 	pci_unregister_driver(&i82875p_driver);
 fail0:
 	return pci_rc;
diff --git a/drivers/edac/i82975x_edac.c b/drivers/edac/i82975x_edac.c
index 10b1052..35ab66c 100644
--- a/drivers/edac/i82975x_edac.c
+++ b/drivers/edac/i82975x_edac.c
@@ -685,9 +685,7 @@ fail1:
 	pci_unregister_driver(&i82975x_driver);
 fail0:
 	return pci_rc;
