EDAC: Delete unnecessary check before calling pci_dev_put()
Author: Markus Elfring <elfring@users.sourceforge.net>
The pci_dev_put() function tests whether its argument is NULL and then
returns immediately. Thus the test before the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Link: http://lkml.kernel.org/r/546CB20D.4070808@users.sourceforge.net
[ Boris: commit message. ]
Signed-off-by: Borislav Petkov
 drivers/edac/i3000_edac.c      | 3 +--
 drivers/edac/i3200_edac.c      | 3 +--
 drivers/edac/i82443bxgx_edac.c | 3 +--
 drivers/edac/x38_edac.c        | 3 +--
 4 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/edac/i3000_edac.c b/drivers/edac/i3000_edac.c
index cd28b96..5cb36a6 100644
--- a/drivers/edac/i3000_edac.c
+++ b/drivers/edac/i3000_edac.c
@@ -542,8 +542,7 @@ fail1:
 	pci_unregister_driver(&i3000_driver);
 fail0:
-	if (mci_pdev)
-		pci_dev_put(mci_pdev);
+	pci_dev_put(mci_pdev);
 	return pci_rc;
diff --git a/drivers/edac/i3200_edac.c b/drivers/edac/i3200_edac.c
index 022a702..d1ff0ea 100644
--- a/drivers/edac/i3200_edac.c
+++ b/drivers/edac/i3200_edac.c
@@ -523,8 +523,7 @@ fail1:
 	pci_unregister_driver(&i3200_driver);
 fail0:
-	if (mci_pdev)
 	return pci_rc;
diff --git a/drivers/edac/i82443bxgx_edac.c b/drivers/edac/i82443bxgx_edac.c
index d730e276..b4705d9 100644
--- a/drivers/edac/i82443bxgx_edac.c
+++ b/drivers/edac/i82443bxgx_edac.c
@@ -458,8 +458,7 @@ static void __exit i82443bxgx_edacmc_exit(void)
 	if (!i82443bxgx_registered)
 		i82443bxgx_edacmc_remove_one(mci_pdev);
-	if (mci_pdev)
 module_init(i82443bxgx_edacmc_init);
diff --git a/drivers/edac/x38_edac.c b/drivers/edac/x38_edac.c
index e644b52..7c5cdc6 100644
--- a/drivers/edac/x38_edac.c
+++ b/drivers/edac/x38_edac.c
@@ -500,8 +500,7 @@ fail1:
 	pci_unregister_driver(&x38_driver);
 fail0:
-	if (mci_pdev)
 	return pci_rc;
BtrLinux
Privacy Overview
