ecryptfs: Eliminate useless code
The variable lower_dentry is initialized twice to the same (side effect-free)
expression.  Drop one initialization.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
@forall@
idexpression *x;
identifier f!=ERR_PTR;
x = f(...)
... when != x
x = f(...,<+...x...+>,...)
* x = f(...)
Signed-off-by: Julia Lawall
Signed-off-by: Tyler Hicks
 fs/ecryptfs/file.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/fs/ecryptfs/file.c b/fs/ecryptfs/file.c
index dde7bb4..678172b 100644
--- a/fs/ecryptfs/file.c
+++ b/fs/ecryptfs/file.c
@@ -158,7 +158,7 @@ static int ecryptfs_open(struct inode *inode, struct file *file)
 	struct dentry *ecryptfs_dentry = file->f_path.dentry;
 	/* Private value of ecryptfs_dentry allocated in
 	 * ecryptfs_lookup() */
-	struct dentry *lower_dentry = ecryptfs_dentry_to_lower(ecryptfs_dentry);
+	struct dentry *lower_dentry;
 	struct ecryptfs_file_info *file_info;
 	mount_crypt_stat = &ecryptfs_superblock_to_private(
BtrLinux
Privacy Overview
