eCryptfs: Delete a check before the function call “key_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The key_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around this call might not be needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Tyler Hicks
 fs/ecryptfs/crypto.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/fs/ecryptfs/crypto.c b/fs/ecryptfs/crypto.c
index 97315f2..80d6901 100644
--- a/fs/ecryptfs/crypto.c
+++ b/fs/ecryptfs/crypto.c
@@ -258,8 +258,7 @@ void ecryptfs_destroy_mount_crypt_stat(
 				 &mount_crypt_stat->global_auth_tok_list,
 				 mount_crypt_stat_list) {
 		list_del(&auth_tok->mount_crypt_stat_list);
-		if (auth_tok->global_auth_tok_key
-		    && !(auth_tok->flags & ECRYPTFS_AUTH_TOK_INVALID))
+		if (!(auth_tok->flags & ECRYPTFS_AUTH_TOK_INVALID))
 			key_put(auth_tok->global_auth_tok_key);
 		kmem_cache_free(ecryptfs_global_auth_tok_cache, auth_tok);
BtrLinux
Privacy Overview
