e1000: remove unnecessary code
Author: Greg Dietsche <Gregory.Dietsche@cuw.edu>
Compile tested.
remove unnecessary code that matches this coccinelle pattern
	if (...)
		return ret;
	return ret;
Signed-off-by: Greg Dietsche
Signed-off-by: David S. Miller
 drivers/net/e1000/e1000_hw.c | 7 +------
 1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/drivers/net/e1000/e1000_hw.c b/drivers/net/e1000/e1000_hw.c
index 7501d97..1698622 100644
--- a/drivers/net/e1000/e1000_hw.c
+++ b/drivers/net/e1000/e1000_hw.c
@@ -3080,7 +3080,6 @@ s32 e1000_phy_hw_reset(struct e1000_hw *hw)
 	u32 ctrl, ctrl_ext;
 	u32 led_ctrl;
-	s32 ret_val;
 	e_dbg("e1000_phy_hw_reset");
@@ -3126,11 +3125,7 @@ s32 e1000_phy_hw_reset(struct e1000_hw *hw)
 	/* Wait for FW to finish PHY configuration. */
-	ret_val = e1000_get_phy_cfg_done(hw);
-	if (ret_val != E1000_SUCCESS)
-		return ret_val;
-	return ret_val;
+	return e1000_get_phy_cfg_done(hw);
BtrLinux
Privacy Overview
