drm/vmwgfx: Deletion of an unnecessary check before the function call “vfree”
Author: Markus Elfring <elfring@users.sourceforge.net>
The vfree() function performes also input parameter validation. Thus the test
around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Reviewed-by: Thierry Reding
Signed-off-by: Dave Airlie
 drivers/gpu/drm/vmwgfx/vmwgfx_drv.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/gpu/drm/vmwgfx/vmwgfx_drv.c b/drivers/gpu/drm/vmwgfx/vmwgfx_drv.c
index 25f3c25..db76218 100644
--- a/drivers/gpu/drm/vmwgfx/vmwgfx_drv.c
+++ b/drivers/gpu/drm/vmwgfx/vmwgfx_drv.c
@@ -889,8 +889,7 @@ static int vmw_driver_unload(struct drm_device *dev)
 	if (dev_priv->ctx.res_ht_initialized)
 		drm_ht_remove(&dev_priv->ctx.res_ht);
-	if (dev_priv->ctx.cmd_bounce)
-		vfree(dev_priv->ctx.cmd_bounce);
+	vfree(dev_priv->ctx.cmd_bounce);
 	if (dev_priv->enable_fb) {
 		vmw_fb_close(dev_priv);
 		vmw_kms_restore_vga(dev_priv);
BtrLinux
Privacy Overview
