drm/vc4: fix platform_no_drv_owner.cocci warnings
Author: Julia Lawall <julia.lawall@lip6.fr>
drivers/gpu/drm/vc4/vc4_drv.c:248:3-8: No need to set .owner here. The core will do it.
 Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
Signed-off-by: Fengguang Wu
Signed-off-by: Julia Lawall
Signed-off-by: Eric Anholt
 drivers/gpu/drm/vc4/vc4_drv.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/gpu/drm/vc4/vc4_drv.c b/drivers/gpu/drm/vc4/vc4_drv.c
index 6e73060..d5db9e0 100644
--- a/drivers/gpu/drm/vc4/vc4_drv.c
+++ b/drivers/gpu/drm/vc4/vc4_drv.c
@@ -259,7 +259,6 @@ static struct platform_driver vc4_platform_driver = {
 	.remove		= vc4_platform_drm_remove,
 	.driver		= {
 		.name	= "vc4-drm",
-		.owner	= THIS_MODULE,
 		.of_match_table = vc4_of_match,
BtrLinux
Privacy Overview
