drm/vc4: Delete unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The following functions test whether their argument is NULL
and then return immediately.
* drm_fbdev_cma_hotplug_event
* drm_fbdev_cma_restore_mode
Thus the tests around their calls are not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Daniel Vetter
Link: http://patchwork.freedesktop.org/patch/msgid/fb33d930-6a5c-c501-6676-26bd486f1cb5@users.sourceforge.net
 drivers/gpu/drm/vc4/vc4_drv.c | 3 +--
 drivers/gpu/drm/vc4/vc4_kms.c | 3 +--
 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/gpu/drm/vc4/vc4_drv.c b/drivers/gpu/drm/vc4/vc4_drv.c
index 9e88231..493bb58 100644
--- a/drivers/gpu/drm/vc4/vc4_drv.c
+++ b/drivers/gpu/drm/vc4/vc4_drv.c
@@ -47,8 +47,7 @@ static void vc4_lastclose(struct drm_device *dev)
 	struct vc4_dev *vc4 = to_vc4_dev(dev);
-	if (vc4->fbdev)
-		drm_fbdev_cma_restore_mode(vc4->fbdev);
+	drm_fbdev_cma_restore_mode(vc4->fbdev);
 static const struct file_operations vc4_drm_fops = {
diff --git a/drivers/gpu/drm/vc4/vc4_kms.c b/drivers/gpu/drm/vc4/vc4_kms.c
index 8f4d5ff..0fa3c81 100644
--- a/drivers/gpu/drm/vc4/vc4_kms.c
+++ b/drivers/gpu/drm/vc4/vc4_kms.c
@@ -26,8 +26,7 @@ static void vc4_output_poll_changed(struct drm_device *dev)
-	if (vc4->fbdev)
-		drm_fbdev_cma_hotplug_event(vc4->fbdev);
+	drm_fbdev_cma_hotplug_event(vc4->fbdev);
 struct vc4_commit {
BtrLinux
Privacy Overview
