drm/udl: Use module_usb_driver
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Macro module_usb_driver is used for drivers whose init and exit paths
only register and unregister to usb API. So remove boilerplate code to
make code simpler by using module_usb_driver.
This change was made with the help of the following Coccinelle
semantic patch:
@a@
identifier f, x;
-static f(...) { return usb_register(&x); }
@b depends on a@
identifier e, a.x;
-static e(...) { usb_deregister(&x); }
@c depends on a && b@
identifier a.f;
declarer name module_init;
-module_init(f);
@d depends on a && b && c@
identifier b.e, a.x;
declarer name module_exit;
declarer name module_usb_driver;
-module_exit(e);
+module_usb_driver(x);
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Daniel Vetter
Link: http://patchwork.freedesktop.org/patch/msgid/20160217121327.GA29682@amitoj-Inspiron-3542
 drivers/gpu/drm/udl/udl_drv.c | 14 +-------------
 1 file changed, 1 insertion(+), 13 deletions(-)
diff --git a/drivers/gpu/drm/udl/udl_drv.c b/drivers/gpu/drm/udl/udl_drv.c
index d5728ec..772ec9e 100644
--- a/drivers/gpu/drm/udl/udl_drv.c
+++ b/drivers/gpu/drm/udl/udl_drv.c
@@ -125,17 +125,5 @@ static struct usb_driver udl_driver = {
 	.disconnect = udl_usb_disconnect,
 	.id_table = id_table,
-static int __init udl_init(void)
-	return usb_register(&udl_driver);
-static void __exit udl_exit(void)
-	usb_deregister(&udl_driver);
-module_init(udl_init);
-module_exit(udl_exit);
+module_usb_driver(udl_driver);
 MODULE_LICENSE("GPL");
BtrLinux
Privacy Overview
